Main Forums >> Recording Techniques
        Print Thread
Pages: 1 | 2 | (show all)
wave1
Valve compressor and mains voltages
      #969768 - 12/02/12 05:22 PM
Hi all - a friend of mine is using a Thermionic Culture Phoenix valve compressor on the stereo bus at his studio, and complains that when he recalls a mix, the compressor often sounds different despite the settings on the Phoenix being the same. Could this be caused by fluctuations in mains voltage at different times of day affecting the valves? Is there a simple and cheap tool to measure mains voltage (other than sticking the probes of a multimeter into the socket which he doesn't feel comfortable doing) and if this does measure a fluctuation is there anything we can do about it? The Phoenix has recently been back to TC for a checkup, so I don't think the hardware is the issue....
Thanks in advance!
Jack Ruston
Re: Valve compressor and mains voltages new [Re: wave1]
      #969793 - 12/02/12 09:16 PM
That's Thermionic Culture gear I'm afraid. It sounds WONDERFUL. But it's 'organic' to the point of being a bit different as the week goes on in my experience. All I can suggest is that he lets it warm up for a good while before trying to recall it. And rather than rely on knob positions, use tone where possible to get an exact line up. But this is the reason I stopped using a Culture Vulture I had for mixing. It was just too inconsistent. One day it would sound one way, and then next one side would be noisy, or half a dB down, or just...different. I sent mine back a couple of times to get it checked but that's just the way it always was. It's a shame because the way I work does rely on reliable recalls these days, and I'd have Thermionic gear in my racks if it wasn't for these sorts of problems. I don't know if some of the later designs are better in this respect. Whatever they're doing it sounds really nice. I just don't know if they'd be able to make it more consistent without affecting the cost in a major way. For example using switches instead of those (frankly totally useless) detented pots would be good, but it would add hundreds to the cost of each unit. I think a lot of the weird inconsistencies could be down to some sort of valve related stuff...current, bias whatever.
J
www.jackruston.com
Loc: northampton uk
Re: Valve compressor and mains voltages new [Re: Jack Ruston]
      #969794 - 12/02/12 09:37 PM
Well, I know nothing of the equipment save what I have read in SoS but perhaps someone should send the makers a copy of Nelson Jones' Valve Amplifiers!
Making stabilized heater, bias and HT supplies using modern ICs is pretty simple and would add little to the cost of the units.
Bugger! Were I 30 years younger! I can see an nice little earner there! Will, want a lucrative sideline modding vulture giblets?
I know people want the "sound" of valves but surely the challenge is to keep the sound but use modern techniques to overcome their many shortcomimgs and extend their life?
Hugh RobjohnsAdministrator
SOS Technical Editor
Loc: Worcestershire
      #969851 - 13/02/12 10:48 AM
Quote wave1:
...when he recalls a mix, the compressor often sounds different despite the settings on the Phoenix being the same.
They all do that, Sir! I concur with Jack; the Thermionic stuff sounds great, but it can be quite variable over time as it warms up and the biasing drifts.
Possible, but not that likely. I'm not sure how the power supply is configured, but I'd be surprised if the rail voltages vary much.
Au contraire -- if you dig around you'll find similar observations from a lot of users. The Thermionic stuff is wonderfully musical, but you have to use it 'in the moment' and print what you get because getting back to exactly the same place might prove tricky, frustrating and time consuming!
hugh
Loc: northampton uk
Re: Valve compressor and mains voltages new [Re: Hugh Robjohns]
      #969857 - 13/02/12 11:01 AM
"Possible, but not that likely. I'm not sure how the power supply is configured, but I'd be surprised if the rail voltages vary much."
Oh I don't know Hugh? Say 300V as a good guess for the HT supply for a nominal 230V in that gives 330 and 290 max/min for a 10% mains shift.
Then the heaters will be affected as well tho' I would be MOST suprised if kit of that quality had raw AC heaters!
Continuous converting UPS as an answer perhaps?
Loc: Worcestershire
Re: Valve compressor and mains voltages new [Re: ef37a]
      #969868 - 13/02/12 11:19 AM
The continuous UPS idea is a good one, Dave, if the mains supply volts really do vary a lot in the studio and if the anode HT really does vary with it. But there are several 'ifs' there and I'd want to hard figures on the incoming mains variation and the anode HT variation before making that kind of investment in a continuous UPS.
The Thermionic stuff is quite old-school in mnay ways -- inherently so -- but I think I've seen some solid-state power supply regulation in them for at least some rails -- although I wouldn't swear to it!
I think the sonic variation is more likely to be an issue of thermal drift... but it's only a guess and I'm not a valve man, really. I gladly defer to your far greater experience.
hugh
Loc: northampton uk
      #969874 - 13/02/12 11:29 AM
Greater experience Hugh?
Only with guitar amps and NOBODY ever complains about mains variations!
I bit of thought brings me to conclude that a SMPSU as fitted to much high end solid state studio gear now (thus banishing the wall rats I know you love!) is the best solution but 230in 300V ish out supplies are remarkably hard to find.
zenguitarModerator
active member
Loc: Devon
      #969891 - 13/02/12 12:47 PM
Quote ef37a:
Apart from Neil Young apparently. His tech's report that that he can hear his Fender Deluxe in a new venue and accurately identify the voltage at the drop down transformer. However, it is the exception that proves the rule
Andy
When the going gets weird, the Weird turn Pro.
. . . Delete This
Here be Dragons
Re: Valve compressor and mains voltages new [Re: zenguitar]
      #969915 - 13/02/12 02:47 PM
yeah, and eric johnson can hear the difference between nickel jack plugs and brass jack plugs.
Loc: northampton uk
Re: Valve compressor and mains voltages new [Re: . . . Delete This User . . .]
      #969917 - 13/02/12 02:58 PM
Quote Idris Y Draig:
Who was the guy said he could tell the difference between brands of PP3 pedal batts?
zenguitarModerator
active member
Loc: Devon
      #969929 - 13/02/12 03:54 PM
Quote ef37a:
That's Eric Johnson too. And again apparently confirmed in blind tests. However, both Neil Young and Eric Johnson are VERY familiar with their set-ups and have put them together over many years of experimenting. It's more that they know exactly how their full signal chain sounds and responds to their playing and can hear very subtle differences if anything is changed from what they know. Not sure if that's a blessing or a curse to be honest
Andy
wave1
      #969941 - 13/02/12 05:11 PM
Thanks for the contributions, chaps - any suggestions for a handy (and idiot proof)gizmo for measuring mains voltage?
chris...
active member
Loc: Glasgow
      #969952 - 13/02/12 06:05 PM
Something like this:
http://www.maplin.co.uk/plug-in-mains-power-and-energy-monitor-38343 < br />
should do - tho' not sure how accurate.
Whether this is your problem is another matter!
Loc: Worcestershire
Re: Valve compressor and mains voltages new [Re: chris...]
      #969958 - 13/02/12 06:12 PM
I use the very same thing to keep an eye on both incoming mains volts and to measure power consumption and that kind of thing. Seems very accurate and reliable. Mains volts here only seems to vary a few volts either side of 230. Don't think I've seen it lower than about 228 or higher than 233... But the legal supply tolerances allow much greater range.
hugh
Loc: Rochester, UK
      #969976 - 13/02/12 07:15 PM
Got one of those mains voltage/current jobbies myself. Quite useful.
Don't underestimate the effect of supply changes on valve kit. As far as I've seen only fairly recent top quality kit has done serious control, and if the mains voltage rises you get a multiplying effect as higher anode/screen voltage gives more gain, but changes the working point of the valves, and at the same time higher heater voltage increases the emission, so again changes the working point.
UK supply voltage used to be quoted as 240V +6% - 10%, but now is European 'harmonised' 230V +- 10% which effectively means the supply companies can get away with lower voltages
It wasn't me!
(Well, actually, it probably was)
Loc: northampton uk
      #970002 - 13/02/12 09:18 PM
Quote chris...:
That should be as accurate as you can be with mains volts Chris. I don't know whether you have ever monitored the mains but it is never still! I had to set it to 230V for spec' tests with a Variac and everytime I glanced at the meter it was 231 or 229!
chris...
active member
Loc: Glasgow
      #970021 - 13/02/12 11:59 PM
Quote ef37a:
I'm glad to hear it.
Right, but of course that in itself doesn't tell us much about the meter's accuracy...
Loc: Worcestershire
      #970067 - 14/02/12 10:03 AM
Quote chris...:
No, it doesn't... but if you go to that Maplin Link and then click on SPECIFICATIONS you'll see the rms AC voltage accuracy is quoted as typically 0.002V and maximum 0.01V.
Hugh
Loc: Rochester, UK
      #970159 - 14/02/12 06:23 PM
Good Lord! Whatever for? Switch on your washing machine and the figures will be flapping about all over the place.
It wasn't me!
Loc: northampton uk
Re: Valve compressor and mains voltages new [Re: Folderol]
      #970162 - 14/02/12 06:33 PM
Quote Folderol:
Verily! And that is why if I paid £2k+ for a compressor I would expect it to have fully regulated supplies, all of 'em!
I don't know about the RNC but the RNP has quite sophisticated power management I understand? And that at 1/4 the price.
Loc: Worcestershire
      #970165 - 14/02/12 07:57 PM
You seem to be assuming that the thermionic culture products don't have regulated supplies... Is there anything to substantiate that?
Hugh
Loc: northampton uk
      #970177 - 14/02/12 10:12 PM
Quote Hugh Robjohns:
Hugh
Well that's where we came in wasn't it Hugh? The compliant that the devices have an inconsistant performance day to day. Valves, especially small signal valves are pretty stable devices (assuming TC don't use bottom draw Russkies!)so the most likely explaination for the wandering parameters IS supply variation, just keeping the heater supply stable is probably 75% of the battle. In fact my experience is that put ECC83s on a 7812 regulator and the damn things last for ever!
Didn't anyone notice when they popped the cans for the photos?
Loc: northampton uk
      #970180 - 14/02/12 10:31 PM
I am so slow these days!
There is no longer any need for makers of valved devices such as preamps, EQ etc to get into conventional HT supplies!
I have in front of me a pcb, 150x110mm containing a pos and neg 15volt supply, part of which feeds a heater and a UC3843AN chip driving a FET that produces 304volts at about 2mA but that can be made to supply 400V* and beefed up for more current. The whole circuit is powered from a 24V DC supply which could be a conventional 50Hz job or, as in this case, an external 24V SMPSU.
The pcb is part of two others in a pedal that sells for less than £200 for the top product (psu pcb is common to the range). So there really is no excuse for unregulated heater and HT supplies in anything but the cheapest Bellringer crap!
*I have one modded for 48V spook juice.
Korff
Loose Cannon (Reviews Editor)
Loc: The Wrong Precinct
      #970238 - 15/02/12 12:18 PM
Here's a little Bustard... There might be more gut shots of TC gear knocking around.
Loc: northampton uk
Re: Valve compressor and mains voltages new [Re: Korff]
      #970249 - 15/02/12 12:56 PM
Quote Korff:
I can't get a big enough image with good enough resolution to tell much. There does seem to be two bridge rectifiers so the heaters could well be DC but regulated?
Oh FCS! the image has now got better as I review the post! No, not a bridge and there are some (limply!)twisted wires that could be heaters and that suggests bog standard AC.
Richie Royale
Loc: Bristol, England.
      #970254 - 15/02/12 01:21 PM
http://media.soundonsound.com/sos/nov10/images/thermionic_littlebustard_02 .jpg
Same picture, but bigger resolution. Click on it to zoom in if you are on a smaller monitor.
http://media.soundonsound.com/sos/jan10/images/thermionic_fatbustard_02.jp g
Another one.
http://soundcloud.com/richie-royale
http://www.mixcrate.com/richieroyale
SafeandSound Masteri...
Loc: London UK
      #970256 - 15/02/12 01:30 PM
The choice of knobs on these devices is awful for what is a very expensive compressor. (Sure I know, listen don't look but...£3K +) I have been seriously considering another high end valve compressor (something more coloured than my Summit DCL-200)and I am not impressed by the visual aspect of these devices from the outside. I was thinking "They must have spent the money on the inside". This has been an interesting read.
SafeandSound Mastering
Mastering online mastering
Loc: northampton uk
      #970269 - 15/02/12 02:07 PM
Thanks,
Still hard to tell if it has DC heaters but I can see no evidence of any regulation,HT or heaters.
I suppose the construction is well...Ok. "Fender circa 1970"? I would expect these day to see all the power supply components sans transformer on a decent pcb.
Loc: Rochester, UK
      #970308 - 15/02/12 05:33 PM
Thanks for the detailed pix. That power supply is a house of horrors!
The heaters are in fact DC. There are 4 diodes in a bridge configuration (you can see them quite clearly if you zoom in). However, they are actually 8 diodes wired in parallel pairs - something you should never do under any circumstances!
Above the ceramic resistor is one of those little circular 1 amp bridges bodged onto the tagstrip. This is obviously for the HT
As Dave said, there is absolutely no attempt a voltage regulation - not even crude mains tappings. And why have the put screening round the mains Tx, which is well away from everything else, but none round the power switch right beside signal switches.
I notice the transformer hasn't been very well fitted - it's sitting to one side of the dished washer.
Apart from what looks like a fuse carrier between the power switch and the transformer there appears to be no protection, and no spike/EMI suppression.
Main PCB looks like cheap paxolin rather than a GRP one - a decision that can only be described as 'quaint'.
All in all, nothing like what I'd expect for 2k - especially including those bargain basement pot knobs.
It wasn't me!
wave1
      #970322 - 15/02/12 07:00 PM
Thanks again chaps - all useful stuff. My friend will get to Maplins for one of these gizmos asap, I'll update the post once we get some results. Had a look for some gut shots of the Phoenix online, but nothing doing, so I'll try to get some if anyone is interested - won't be able to do it till next week though.
Cheers
James PerrettModerator
Loc: The wilds of Hampshire
      #970391 - 16/02/12 09:46 AM
Quote ef37a:
Hand made point to point wiring is a big selling point for these things. It may have kept the radio/TV repair trade in business during the 50's and 60's but I'm not sure I want that type of construction in a working studio - unless it is done really well.
James.
JRP Music - Audio Mastering and Restoration.
http://www.jrpmusic.net
Loc: Worcestershire
Re: Valve compressor and mains voltages new [Re: James Perrett]
      #970394 - 16/02/12 09:54 AM
For info, I have invited Thermionic Culture and/or their agents to comment and am awaiting a response.
hugh
Loc: northampton uk
      #970405 - 16/02/12 11:03 AM
Quote James Perrett:
Quote ef37a:
James.
Yes James, peeps love to see "hand wired" in guitar amps too and some think it adds to the sound quality.
In truth the things are FAR more consistant when build on pcb's. I personally think you get a better product at a cheaper price and/or you can put in more features apt to the modern player such as FX loops and MIDI.
Mixedup
active member
Loc: Cambridge, UK
      #970435 - 16/02/12 12:45 PM
Quote ef37a:
peeps love to see "hand wired" in guitar amps... In truth the things are FAR more consistant when build on pcb's.
I'd like it if my Twin had been hand-wired, as the PCB traces which raised off the PCB wouldn't have required tracking down and repairing There are pros and cons to both approaches.
Tomás Mulcahy
active member
Loc: Cork, Ireland.
      #970462 - 16/02/12 03:00 PM
Badly chosen PCB materials- they forgot about the heat inside the amp. It doesn't follow that all PCBs are "bad".
madtheory creations
Synths and pianos for Kontakt
Loc: northampton uk
      #970579 - 17/02/12 10:05 AM
Just clocked the gutshot of the Ingram pre' page 176 March issue.
Now THAT'S the way to make a power supply in the 21st century TC!
BTW, early days but the March issue looks virtually as well stuffed as Febs!
Loc: Worcestershire
      #970584 - 17/02/12 10:15 AM
Yep, there's no doubting that you get what you pay for in the Ingram. Beautifully designed. Shame about the silly production wiring cockup and incomplete QC, but easily resolved and I'm confident that the company has addressed that particular weakness.
Also glad that you're finding so much to enjoy in each issue, Dave
hugh
Red Mastering
Loc: London
Re: Valve compressor and mains voltages new [Re: SafeandSound Mastering]
      #970656 - 17/02/12 04:04 PM
Quote SafeandSound Mastering:
I am also looking for a vari -mu type compressor, and considered thermionic, but it's a bit out of my range (money) and this thread is a bit eye opening too....
here :
http://www.igsaudio.pl/index.php?option=com_content&task=view&id=5
is a guy in Poland who builds many professional audio tools, and also prices are on the 'indie' side:)
many studios in Poland (and not only - check GS -there are happy folks in US too) use his gears and they love it,
I myself got ssl4k 'wannabe':) and it's wicked buss comp
I am considering to get one (vari mu), (I am not reseller or sth.) just dropped that link so you can check it yourself,
good luck!
online mastering studio | mastering audio
wave1
      #971193 - 20/02/12 03:59 PM
Hi all - just got the first voltage readings from my friend - seems to vary between 241 and 245 so far, well within spec I would have thought!
Cheers
Loc: Worcestershire
      #971202 - 20/02/12 04:45 PM
For a mains supply, yes, that's well within the spec, although obviously a little on the high side of the nominal 230V. Probably because he's either close to the local substation transformer or the thing has been left on a higher tap for some reason.
The variation is only 1.6% though, which isn't a lot. Has he been able to correlate 'good' and 'bad' sound with those 'high' and 'low' mains input voltages?
Hugh
Rate this thread
Jump to
Extra Information
0 registered and 45 anonymous users are browsing this forum.
Forum Permissions
      You cannot start new topics
      You cannot reply to topics
      HTML is disabled
      UBBCode is enabled
Rating: *****
June 2013
SOS Web Shop)
Click image for June 2013
DAW Tips from SOS
Email: Contact SOS
Telephone: +44 (0)1954 789888
Fax: +44 (0)1954 789895
