Tim.
Loc: Not here
PSP Mixpack
#256469 - 19/02/06 07:36 PM
PSP Audioware MixPack - Version 1.7
Based in Poland, PSP Audioware produces a range
of fine sounding plug-ins that has been well received in both the audio press and by
studio owners all over the world. As the name would suggest, MixPack is a collection of
plug-ins designed for use on individual tracks; their excellent audio quality makes them
highly suitable for mastering too. The four plug-ins in the pack are:
MixBass
MixSaturator MixPressor MixTreble
VST, DX and RTAS plug-ins
are included in the PC version.
Copy protection is sensibly based on the
registered user’s name and allotted serial number; a system I much prefer over the
restrictive practices of certain other companies. Mac OS X version in HTDM and RTAS
format require an iLok for copy protection.
MixBass As
its name implies, MixBass is a dedicated bass processor/compressor working on the lower
end of the spectrum to produce rich deep analogue sounds with both character and
definition.
Controls The Tune knob in the left
hand Input section may be used to tune the target frequency in the range of 20 to 600Hz.
The circular meter in the Compress section indicates how much gain has been applied to the
processed signal; dependant on the green threshold setting below. There is no compression
ratio control. Ratio is fixed at 2:1, however this doesn’t at all limit the ‘earth
shaking’ possibilities of this plug-in.
The Tone section Colour and Bass
controls affect saturation of the processed bass frequencies, adding both odd and even
harmonics.
The Output section Saturation button switches a soft-clipping
limiter in and out. The red LED below indicates signals when three or more continuous
samples have reached or exceeded 0dBFS. A rotary Gain knob is provided to regulate output
level. Below the Gain control, a Mix slider may be used to blend the wet and dry signals.
Presets The 21 presets provided range from subtle
psychoacoustic bass enhancement to extreme distortion. MixBass is a very capable plug-in
and great for all bass and drum sounds. It can provide that much sought after analogue
warmth and deep big bottom end.
Of course, as with all bass processors, full
range monitoring with extended bass response is really an essential requirement. Not only
can over enhanced bass eat into valuable headroom, but there is also the danger of
creating mixes with excessive bass that will not translate well on other systems. A
spectrum analyser may also be employed for visual checking the bass end, but nothing
really beats hearing and feeling the bass through full range monitors.
MixSaturator Designed to emulate the saturation effects of tape and
valves, MixSaturator is capable of compressing and adding both warmth and sparkle to
individual tracks or a whole mix.
Controls The left hand Drive control…
I mean the Drive control on the left varies the amount of signal fed into the process. An Input rotary knob is
also provided to balance the input level. The next three knobs: Freq, Warmth and Adjust
affect the bass end of the spectrum and can be switched in or out of circuit with the
illuminated Bass button above. The Treble button directly below the right hand meter does
the same for the three rotary treble controls below; not surprisingly, these affect the
treble end of the spectrum. The central Process button may be used to bypass the plug-in
and, unlike the integral Logic Bypass button, leaves the meters still functioning.
The central meter’s dual needles indicate peak (red) and average (black) signal
levels and +14 is equal to 0dBFS. The Pre and Post buttons have three functions:
monitoring the input signal, output signal and if neither button is lit, the metres then
indicate drive level.
On the far right, the Shape control offers seven
different saturation levels that include three different settings for both valve and tape
and also a digital setting. With the Shape slider at its minimum, shape is turned off.
As with all plug-ins in the pack, a mix slider is also provided for adjusting the wet/dry
relationship.
MixSaturator’s 31 presets provide some excellent settings for
everything from vocals to whole mixes and give insight into what this plug-in is capable
of.
MixPressor MixPressor emulates the
characteristics of optical and valve based compressors and includes facilities for both
de-essing and limiting.
Controls On the left, the input knob may
be used to cut or boost the input level. Although there is no ratio control, the Compress
slider above adjusts the amount of compression. Below the left hand meter, the DEL
button activates a delay that reduces attack peaks. The SCL button (see below) is used in
conjunction with the Freq and Q knobs located underneath. Next are the compressor’s
control knobs: Attack, Hold, Release and Make-up gain. Both the Attack and Release knobs
each have three modes: fast and slow automatic, and manual. Turning the Make-up rotary
knob fully counter clockwise switches to automatic make up gain; all other positions
facilitate variable manual level adjustment.
Above the compressor controls
are three buttons: Process (bypass), RMS, Limiter. The RMS button switches the compressor
between peak and RMS sensing. RMS is more appropriate for vocals, whilst Peak is better
suited to signals with high transients such as cymbals. The Limiter has three settings:
OFF, SAT, LIM. Lim is a standard 0dBFS limiter whilst PSP describe SAT as a
‘limiter-saturator’ function; this can add ‘grunge’ or distortion to the signal.
Above the right hand side Mix and Output controls, the Slope slider changes
between soft and hard knee operation and various levels in between.
Again, a
mix slider is also provided for adjusting the wet/dry relationship to achieve ‘parallel
compression’.
Meters The three needles indicate peak level
(red) average (black) and the shorter blue needle shows compressor gain reduction. Pre
and Post buttons are provided to set and monitor both input and output levels. The red
lights below the needles indicate signals exceeding 0dBFS and also if the limiter is being
overdriven. SCL - de-essing and pumping The SCL button switches
the plug-in to Side Chain Listen mode. The Freq and Q rotary knobs may then be used to
home in on the frequency to be de-essed. Alternatively, with Freq settings of around
500Hz and Q values of between 0 and 0.3, the SCL mode can also reduce the effects of bass
drum pumping the compressor. If desired it is also very easy to achieve a pumping sound.
A rough guide to the appropriate settings to achieve pumping is: set an Attack of around
30ms, Release of about 350ms and a Q of below 0.20. Then switch both the DEL and RMS
buttons off, set the Compress slider somewhere above 50% and adjust the Hold control to
taste. Before setting the Compress slider at or near maximum, it’s advisable to have the
limiter switched on and/or turn the Make-up gain control so that it’s no longer on auto
make-up.
MixPressor is supplied with 37 presets and, as ever, they are a
great basis for understanding just what this plug-in is capable of. It also includes
settings that simulate some well know classic compressors.
MixTreble The final plug-in, MixTreble, consists of four independently
switched sections for processing and enhancing the treble content of individual tracks or
complete mixes, and also hiss removal.
Hiss Remover Although primarily designed
to remove unwanted hiss, this section may also be used to reduce the high frequency
content of a reverberant signal – this can be very useful for rescuing tracks with
overdone reverb. The Threshold slider sets the level at which the reduction takes place.
The Attenuation knob adjusts the level of attenuation. The Speed knob adjusts the
filter’s speed of operation; settings are dependant on the material being treated.
Settings over 50% are recommended for sounds with a slow attack, and under 50% for sounds
with high transients such as cymbals. Of course these are only recommendations; other
settings may be used to produce special effects.
Transients This
section may be used to revitalise squashed and softened transients, or to generally
increase the overall brightness of a track. Increasing the Adjust slider boosts the
signal and the three rotary knobs tune the effect. An extremely wide range of treatments
can be produced ranging from subtle enhancement to ear piercing high frequencies that are
quite possibly dangerous to dogs and bats!
Enhancer The enhancer
may be used to increase the width of stereo material and works by adjusting phase. The
Filt Slope knob adjusts the filter’s slope between 0 and 6dB. It is quite possible with
the enhance knob to severely adversely affect mono compatibility. The centrally located
Over Enhanced red light gives some warning of this but regularly checking with the mixer’s
mono button will show if you are getting unacceptable levels of cancellation. If you
aren’t using a mixer with mono button, then a goniometer or phase correlation meter is
useful for a visual check. PSP also offer their recently updated ‘StereoPack’ plug-in
that provides a phase correlation meter (and stereo enhancement tools) for the very
reasonable sum of $49 / £28 / €41
Harmonics This is an exciter
type circuit that generates odd and even harmonics for body and improved clarity and
definition. The Frequency slider may be adjusted to tune between 500 and 16kHz and the
three central knobs adjust: Q, Drive and First Out. Depending on program material, the
First Out knob may be used to remove the fundamental frequency leaving the harmonics for
processing.
Output The final output section houses a SAT switch
used to switch in the 0dB soft limiter and, lower down, the familiar peak level red light
and below that the rotary level control knob.
Presets A
collection of 38 well tailored presets is included, again a useful starting point for fine
tuning and exploring the plug-in’s capabilities.
Conclusion With double precision 64 bit floating point internal signal processing, all the MixPack
plug-ins sound excellent whether used on individual tracks or inserted on the final mix.
All MixPack controls may be reset to their defaults by holding Ctrl and left clicking;
each plug-in also sports a mix control to blend the processed and dry signals.
One very small area of concern is that adjusting some (but not all) MixPack controls
introduces slight audible distortion or ‘zipper’ noise. The noise can be a little
disconcerting when adjusting the MixBass Tune control knob but it is not recorded;
provided of course you don’t attempt to automate the controls via the host. PSP are aware
of the issue and hopefully will be addressing it in a future update. As a point of
reference, some of Logic’s own plug-ins also respond in the same way so it is by no means
unusual.
I’ve been using MixPack for several years (since version 1.5) and
the new colour scheme and other improvements in version 1.7 definitely enhance what was an
already great collection of plug-ins. Also new in version 1.7 is support for sample rates
up to 192kHz. MixPack certainly sounds impressive. Try out the demos and prepare to be
impressed!
Version 1.8.4 is available but the release notes say:
“Due to the fact that this new 1.8.4 version of the PSP MixPack doesn't include
serious processing changes prior to v.1.7.0 we strongly recommend not to install this new
version on machines where v.1.7.0 performs correctly.
However we recommend to
install those plug-ins when multi format support is required and compatibility to the
latest versions of audio applications is a priority.
Please note that this new
version will not run correctly in projects where old plug-ins where used.”
Mixpack v1.7
Pros Superb audio
quality Four Separate plug-ins Well designed presets Simple implementation
of parallel compression Great value for money
Cons Some
controls introduce ‘zipper’ noise Limited automation possibilities
Summary MixPack is a very useful collection of plug-ins that not only sound
great but can also add the warmth and clarity often associated with esoteric and expensive
analogue outboard. Considering the sound quality and the fact that there are four
separate plug-ins included in the price, MixPack is a bargain not to be missed.
Mixpack Price $149 / £85 / €124
http://www.pspaudioware.com/
Minimum Hardware Requirements
Windows 98 or later VST, DirectX or RTAS compatible host application 256 MB RAM Pentium III 600
MHz High Color S-VGA, 1024x768 MacOS X v 10.1 or later VST, AudioUnit
and RTAS compatible host application MacOS 8.5 VST or MAS compatible host
application 256 MB RAM memory settings on MacOS G3 300 Mhz High Color
S-VGA, 1024x768
This review ©Tim Rainey 2006
-------------------- Studio: www.kymatasound.com
active member
Re: PSP Mixpack
[Re: Tim.]
#256491 - 19/02/06 08:15 PM
Very nice review Tim!
Tim.
Loc: Not here
Re: PSP Mixpack
[Re: -----]
#257327 - 21/02/06 02:49 PM
Thanks for the feedback Wonks.
Sounds-and-images
active member
Loc: Under a table
Re: PSP Mixpack
[Re: Tim.]
#257801 - 22/02/06 12:23 PM
Nice informative review Tim, very useful indeed.
-------------------- www.sounds-and-images.co.uk
http://twitter.com/soundsandimages
Tim.
Loc: Not here
From one old hippy to
another, thanks, and glad you found it useful… and if I ever need a didgeridoo player,
I’ll know who to call… I like your photos too.
Squarepeg
Loc: Somerset, UK
Re: PSP Mixpack
[Re: Tim.]
#307915 - 06/06/06 01:18 PM
After reading Tim's review and extensive playing with the demo versions I have just bought
the MixPack. So far I am very pleased with it.
My personal take was that,
compared to the Vintage Warmer, the package offered a little more subtlty (though I am not
an expirienced engineer by any means)and the four seperate elements allowed you to focus
more effectively on individual sounds.
The MixBass is very useful and I have
been using it on drum loops as well as bass sounds. The Mixpre is also excellent and, IMO,
is giving me far better impact with dance sounds than the native Logic compressors.
I have not used the other two a great deal but have had some incouraging results
with them.
Download the demo and give them a go!
Thanks for the
review Tim.
0 registered and 3 anonymous users are browsing this forum.
Moderator: Forum Admin, Frank Eleveld, ForumModTeam
Forum Permissions
You cannot start new topics
You cannot reply to topics
HTML is disabled
UBBCode is enabled
Rating:
UBB.threads™ 6.4.2
| Thursday 9th September 2010
WIN Great Prizes in SOS Competitions!
September 2010
On sale now at main newsagents and bookstores (or buy direct from the SOS Web Shop)
Click image for September 2010
Buy + Download PDF Articles
Now direct from SOS — we sell downloadable Acrobat PDF versions of SOS articles (from 99p each).
