Tim.
Loc: Not here
Elemental Audio Systems Firium and Eqium
#261136 - 01/03/06 05:36 AM
Elemental Audio Systems Firium and Eqium plug-in bundle Version 2.0.2
Based in Baltimore, Maryland USA, Elemental Audio
Systems produce a small but perfectly formed range of high quality plug-ins addressing:
compression, limiting, EQ and metering. This review is primarily based on their EQ
plug-ins: Firium and Eqium
Firium Firium is a sophisticated
linear phase equaliser plug-in with fully customisable and completely transparent
equalisation. Offering a large number of editing functions, dual workspaces and spectrum
analyser, Firium may also be automated via the host application to morph EQ curves through
up to fifty different states. The EQ characteristics of any piece of music may be
‘sampled’ with the resulting automatically generated correction EQ applied to another
piece of music for CD track continuity or other creative purposes.
As a
mastering EQ, Firium will usually be inserted on the master stereo outputs so the
inevitable processing delay (all analytical plug-ins introduce a delay) will not pose a
problem. Firium may of course also be used on individual tracks within a mix and as most
modern hosts include automatic plug-in delay compensation, the inevitable processing delay
will be transparently dealt with. Should manual compensation be necessary, Firium
helpfully displays the delay (in samples) in the top right of the main window.
Copy protection is serial number based. You do not have to have your DAW connected to
the net to authorise any Elemental Audio plug-ins. I much prefer serial number based copy
protection over other more restrictive practices employed by some other companies. All
native plug-in formats (Mac RTAS/VST/AU and Win RTAS/VST) are included in the price.
Main window EQ curves may be freely drawn with the mouse in the main
spectral display window and edited by clicking and dragging one of fifty control point
nodes. Below the main spectral display, a Curve Scale slider reduces or increases the
curve’s amplitude whilst the Smooth slider automatically evens out hand drawn curves. The
top left A and B buttons access the two independent workspaces where separate EQ curves
may be created, stored, edited and compared.
Below the A and B buttons, the
Coupling section influences curve construction/editing and determine how adjacent nodes
are affected when dragged by the mouse. One of two different geometric curve shapes
(Gauss and Geom) is selected by clicking the curve’s graphic representation. The arrow
buttons below select between one of four levels for each curve type; coupling may also be
switched off.
The extremely useful History slider and associated arrow
buttons enable the last 100 edits to curves in either workspace to be viewed step by step.
In effect, the history slider combined with the two workspaces could be viewed as a total
of 200 memory locations or undo stages.
At bottom left, the Channel Editing
And Linking section buttons enable editing of curves either jointly or independently to
both left and right channels. When drawing or editing independent left or right channels,
the Rev button produces equal but opposite actions in the other channel.
 Independent EQ curves applied to left (blue) and right (red)
channels
Buttons in the central lower Show section toggle the main
spectral window’s graph views. The Input and Output buttons toggle superimposition of the
spectrum analyser waveform graphs; see image at top of the page
On the
far right, the stereo peak reading meters (with red 0dB clip indicators) register post
processing signal levels. Gain may be adjusted by up to ±24dB with the adjacent fader.
The window below numerically shows the amount of gain/reduction applied.
Clicking either the Firium name or the Elemental Logo helpfully displays a list of
modifier keys; a great aid to making full use of the plug-in without having to refer back
to the 66 page PDF manual.
States Next we come to what Elemental
call ‘States’. States is a very powerful feature where up to fifty different EQ curves
may be stored, accessed and automated through the host. Thumbnails of all fifty states
may be viewed in the states overview window; toggled by clicking the top left orange
triangle. Individual states numbered from one to fifty may be accessed from both the main
and states overview windows by clicking either the arrow buttons or slider located at the
top. Double clicking a thumbnail in the states overview window returns the numbered state
to the main window for editing.
The Insert (INS) button may be used to insert
a new curve in between other states; all states to the right then advance by one. States
may also be copied and freely swapped from one position to another. Multiple states are
selected by holding the shift key. The Reset (R) button resets individual states: if the
shift key is also held then all states are reset. There is no undo for a full 50 states
reset.
With two EQ curves inserted in the states window, Fill automatically
generates the intermediate curves; a powerful time saving feature and excellent for
generating smoothly changing curves over a range of states.
Without a doubt
the best part of states is when combined with host automation; states may be seamlessly
switched from one to another and subtle or startling effects can be created by sweeping
backwards and forwards morphing from one curve to another.
Logic
Automation Example In the screen shot below, a severely reduced bandwidth EQ was
inserted in state number one, a flat EQ in state number 10 and the fill function used to
generate the intermediate curves. The fill function was used four more times across
blocks of ten states to automatically generate all the other curves up to state number
fifty.
 States overview window with Logic automation vector
displayed above
Unfortunately, automation nodes in Logic (my chosen host)
are displayed in percentages from 0 to 100 so the numbers do not agree with the Firium
state numbers. Thankfully it is a simple matter to halve the numbers displayed by Logic
to know exactly which Firium state relates to Logic’s nodes.
Match
Match is used to sample the spectral characteristics of a source sound and apply it
to another (target). Match may be used for: matching the sound of instruments recorded in
different locations, matching the spectral characteristics from one track to the next on a
CD, imprinting the sonic characteristics of one track (source) to another (target). Match
may be used on files with different sample rates up to and including 192kHz.
 Yellow trace = source audio. White = target. Blue =
correction curve generated by Firium.
Clicking the top left Match button
displays the match controls above the main window. Whilst playing back the chosen section
of source material, click the Source Learn button to sample the source audio and Firium
generates the yellow trace. Then, with the target track playing, click the Target Learn
button and Firium will calculate and display the white trace. The blue trace is the
automatically generated correction curve that is applied to the target audio and can of
course be freely edited further if required.
Conclusion Firium is
a totally transparent EQ well suited to mastering and can also obviously be used on
individual tracks within a mix too. The facilities to independently EQ left and right
channels, and automate changes via the host, are welcome additions to a well conceived
plug-in. Match is also extremely useful tool and works superbly well. The Firium/Eqium
bundle is a very attractively priced and capable duo.
Elemental Audio
Systems Firium Version 2.0.2
Pros Transparent sound No phase distortion or smearing Independent left/right channel EQ EQ morphing
via host automation Match EQ mode Non restrictive copy protection
Cons None at this price… well, none I can find after more than two years
use.
Summary A transparent mastering EQ with superb editing and
automation.
Price $169 / £92 / €136 for BOTH Firium and Eqium
(either can be purchased separately at a cost of $129 EACH so the bundle at $169
represents extremely good value for money)
There are other exceptionally good
value bundle options too, i.e. Firium, Eqium, Neodynium and Finis for a total price of
$349 / £198 / €292. That is a real bargain; individually they would cost a total of $576 /
£329 / €482.
Neodynium is innovative, highly intuitive and unlike any
compressor you’ve ever used. You will love Finis too; it knocks spots off Logic’s Adaptive
Limiter. Don’t take my word for it though, download the demos and try them out for
yourself.
http://www.elementalaudio.com
Eqium Eqium is an
extremely versatile equaliser with virtually unlimited bands, supports sample rates up to
192kHz, and is supplied in both mono and stereo versions. In common with Firium, Eqium
also has two separate workspaces designated A and B; filters may also be split into
independently adjustable left and right channels.
Filters Clicking on one of the named filter icons
in the top left Filters section inserts it into both the main filter graph window and the
lower left Filters Created list. Filters may be edited with the sliders and arrows in the
central section below, or by mouse in the main graph window. Whilst manipulating with the
mouse: the Shift key constrains changes to gain only, Ctrl+Shift [CMD] adjusts frequency
only and Ctrl [Option] key restricts changes to bandwidth, Q or slope; dependant on the
selected filter type.
It is perhaps worth noting that Eqium uses bandwidth*
and not Q to describe a parametric filter’s width. Eqium’s parametric minimum bandwidth
of 0.02 equals a Q of 72.13. This is an order of magnitude greater than the parametric
plug-in included in Logic version 5.5 (minimum bandwidth of 0.14, expressed in Logic as a
Q-Factor value of 10). Eqium’s special harmonic 4 and 8 parametric filters have a minimum
bandwidth of 0.005; an incredibly narrow Q of 288.54!
The harmonic 4 and 8
filters are especially useful for removing mains hum or other narrow band constant
frequency noises. They may also be used creatively to accentuate specific notes. In the
central lower section, (see image below) Eqium provides orange ‘illuminated’ switches to
individually enable combinations of fundamental frequency, odd and even harmonics.
In the screen shot below, the five different filters are, from left to
right: Hi Pass set to remove frequencies below 29Hz, a Harmonic 4 with a steep -18dB cut
centred on 50Hz to remove European mains hum (and decreasing odd and even harmonics at
100, 150 and 200Hz), a Parametric cut of -4dB at 808Hz, a Hi Shelf giving +5dB shelf
starting at 3,625Hz and finally a Low Pass rolling of the high frequencies from 17,195Hz.
With the Fill button switched on, the filter’s overall response is graphically displayed
by the dark blue filled section. The white line is showing the deep narrow cuts of the
50Hz Harmonic 4.
Created Filters Section Individual filters
may be activated/deactivated by clicking the white circle in the lower left hand Created
Filters list, and deleted from the list by clicking the orange ‘X’. Clicking the small
blue and red icons in the ‘C’ column separates a filter into independently adjustable left
and right channels. The selected filter is also shown outlined in white in the graphic
window. The ‘Fc’ column shows (where appropriate) each filter’s centre frequency and the
‘G’ column gain. The ‘H’ column shows the designated automation handler letter; more on
handlers in a moment. The white numbers (5/5) in the lower left indicate both the total
number of filters inserted plus the number of the selected filter. Further filters may be
added to the list. With more than eight inserted, the two orange triangles at the bottom
scroll the list. The list may be sorted in various ways by clicking the headings.
Handler The central lower section labelled Handler, with its adjacent
buttons from A to J, is to facilitate simultaneous automation via the host of up to ten
individual filters. In the example screen shot above, Eqium has intelligently not
associated a handler with the Harmonic 4 filter as it would rarely make sense to automate
a mains hum filter. If required, an automation handler can be manually associated by
simply clicking on an unused (white) handler letter.
Presets Although supplied with a seemingly small selection of presets, some of them contain
several filters ready to be adjusted to suit. For instance, the Channel EQ preset
contains: low shelf, high shelf, 3 band parametric and also hi and low pass filters. New
presets may of course be saved and loaded via the integral buttons. Loading a preset will
erase the one currently held in the active workspace but if the Ctrl [Option] key is held
while clicking Load, then the filters in the preset will be added to the filters already
in the current workspace.
Output meters On the far right, the
stereo peak reading meters (with red 0dB clip indicators) register post processing signal
levels. Gain may be adjusted by up to ±24dB with the adjacent linked vertical faders. An
orange link button is also provided for independent left and right channel adjustments.
As with Firium, clicking on the plug-in name or the Elemental logo displays
the modifier keys list.
Conclusion Eqium is a powerful well
designed plug-in with clear interface and excellent host automation implementation. A
single instance of Eqium includes every filter combination you could possibly need, and is
certainly a lot quicker to use than selecting any one or more of the ten different EQ
plug-ins included with Logic version 5.5. Eqium is not only quicker, but if you need to
add a low cut, high cut or any other filter you can do so without having to insert yet
more plug-ins in the channel strip and lengthening it as a result. Eqium could be the
only EQ plug-in you will ever need.
Eqium Version 2.0.2
Pros Linked and independent left/right
channel adjustments Excellent host automation implementation Stereo and mono
versions supplied Virtually unlimited bands of EQ Non restrictive copy
protection
more than two years use.
superb editing and automation.
Price So good I thought it worth
repeating $169 / £92 / €136 for BOTH Firium and Eqium (either can be purchased separately at a
cost of $129 EACH so the bundle at $169 represents extremely good value for money)
There are other exceptionally good value bundle options too, i.e. Firium, Eqium,
Neodynium and Finis for a total price of $349 / £198 / €292. That is a real bargain;
individually they would cost a total of $576 / £329 / €482.
Neodynium is
innovative, highly intuitive and unlike any compressor you’ve ever used. You will love
Finis too; it knocks spots off Logic’s Adaptive Limiter. Don’t take my word for it
though, download the demos and try them out for yourself.
Minimum Hardware Requirements
PC: VST Pentium 3 or higher processor Windows 98/ME/2000/XP VST compatible host
application
RTAS Windows XP Pro Tools 6.1 and Digidesign approved
system
Mac: Audio Units Power PC G4 or higher
processor Mac OS X v10.2 or higher Audio Unit compatible host application
VST Mac OS X Power PC G4 or higher processor Mac OS X v10.2 or
higher VST or AudioUnit compatible host application
RTAS Power PC
G4 Pro Tools 6 and Digidesign approved system
I must just tell you about one more
Elemental plug-in suite: InspectorXL… a collection of five sophisticated metering and
analysis plug-ins with a wealth of options and innovative displays. Definitely worth the
asking price (currently on special offer).
One further thing… all Elemental
Audio System plug-in PDF manuals are extremely well written, easy to follow and very
informative; I wish that were true of all manuals!
It probably goes without
saying but I will anyway; I do not work for Elemental Audio Systems.
*Converter Screenshot
of my Excel spreadsheet for converting Bandwidth to Q/Q to bandwidth.
Available for free download from:
http://www.kymatasound.com/kymatafiles.htm (size: 23kb)
This review and spreadsheet ©Tim Rainey 2006
-------------------- Studio: www.kymatasound.com
James Lehmann
Loc: Europe
Re: Elemental Audio Systems Firium and Eqium
[Re: Tim.]
#261145 - 01/03/06 07:32 AM
Very nice review Tim.
I've been a committed Elemental Audio user for some
time and I whole-heartedly agree with your overall assessment - these plug-ins are
incredibly professional tools and outstanding value for money.
One minor
niggle with Firium and that is I find the nodes quite small and fiddly to pick up with the
mouse - I wish you could resize the whole plug-in window to whatever resolution fits your
monitor (I wish this of nearly all plug-ins actually!). No such issues with Eqium - it's a
beautifully designed interface.
Watcher Of The Skies
Loc: Cornwall, UK
[Re: Tim.]
#261334 - 01/03/06 01:28 PM
Agreed - very nice review Tim, and well done. I'm sure I'll be investigating Elemental
Audio fairly soon as a result.
It would be great if we could devote seven
screenshots and several pages of SOS to a pair of plugins, but there simply isn't enough
space in the magazine
However, when Vincent Chenais reviewed Eqium/Firium for
SOS November 2004 he was also very impressed. Here's a link to his review for anyone who
fancies a second opinion:
www.soundonsound.com/sos/nov04/articles/pluginfolder.htm
-------------------- YewTreeMagic
Tim.
Loc: Not here
[Re: Martin Walker]
#261439 - 01/03/06 04:20 PM
Thanks guys, feedback is most appreciated.
Martin, my review originally
appeared in Greek in the March 2004 edition of ‘Sound Maker’ http://www.soundmaker.gr
The editor did slap my wrist ‘cos it ran to four pages Since then I have added to it too so it’s now even longer; fortunately
(both a blessing and a curse*) we don’t have space limitations here on the forum.
I know four pages are too much even for a two plug-in review for SOS; I had
submitted it via Ian on 30th April 2004.
Anyway, I posted it here and now
‘cos a reasonable amount of time had passed (I didn’t want to post too soon after
Vincent’s review) and I wanted to bring these excellent plug-ins to the attention of
people who haven’t perhaps come across them before. I know you will enjoy Firium Martin…
go on, treat yourself, you deserve it
*You can’t prematurely end a review destined for the web
with: ‘unfortunately lack of space doesn’t permit me to go into detail’
That isn’t in anyway meant as snipe at anyone; it’s just an
observation… and no, before anyone asks, I’m not going to do a Logic Review… that would
run to thousands of pages with hundreds of screenshots and would be a Herculean task to
both write and read
active member
[Re: Tim.]
#261454 - 01/03/06 04:39 PM
Another stonking review Tim. Well done!
Marky
posting's fun
Loc: Boston, MA
[Re: Tim.]
#263297 - 05/03/06 08:50 PM
Equim is a solid EQ ... I'm also a big fan of Neodynium; I'm still finding new ways of
using that thing - and soon I'm hoping to be able to spell it off the top of my head
too!
Great review, Tim.
-------------------- "Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful people with talent."
Tim.
Loc: Not here
[Re: Marky]
#263392 - 06/03/06 07:55 AM
Thank you kind sirs
Neodynium is great isn’t it Marky … I know what you mean about the spelling;
although it’s not as hard as Eqium
I can’t think of any other word where ‘q’ isn’t immediately
followed by ‘u’… seems most unnatural to write it the way EAS spell it.
active member
[Re: Tim.]
#263414 - 06/03/06 08:57 AM
Qantas
Tim.
Loc: Not here
[Re: -----]
#263416 - 06/03/06 09:09 AM
That’s a wonky word Wonks
Isn’t it an acronym?
Tim.
Loc: Not here
Re: Elemental Audio Systems Firium and Eqium - BAD NEWS!
[Re: Tim.]
#300037 - 20/05/06 03:55 PM
Bad news! Elemental have been taken over by Roger Nichols Digital.
As
a consequence, the names of the products have been changed, the prices have gone from $169
for the pair to, get this, $698 for the pair. I’ve heard of people taking the piss
but that is beyond words!
If that weren’t bad enough, they are now protected
by iLock too!
Oh well, it was good while it lasted…
cebenezer
[Re: James Lehmann]
#300539 - 21/05/06 08:08 PM
Hi Guys --
I don't know if you've checked out the elementalaudio site recently
It appears that they have been bought out by another company.
Here's the thing - go to the new company site, and the only plugins available are the
Neodynium, Firium and Equim (renamed as DYNAM-IZER, FREQUAL-IZER, UNIQUEL-IZER)
It seems as customers we get one more update and then nada.
And the renamed
products are now $349 each.
Loc: Cornwall, UK
[Re: Tim.]
#300798 - 22/05/06 11:08 AM
A four-fold increase in price? That's unbelievable!
I could understand it more
if the original developers created a fresh product for the new owner that started selling
at a higher price, but to take existing products and whack up the price like that is
almost bound to cause an incredible amount of ill-feeling among existing users and
potential new users.
I'll be interested to read the ensuing feedback and flak
from around the world after this takeover
0 registered and 1 anonymous users are browsing this forum.
Moderator: Forum Admin, Frank Eleveld, ForumModTeam
Forum Permissions
You cannot start new topics
You cannot reply to topics
HTML is disabled
UBBCode is enabled
Rating:
UBB.threads™ 6.4.2
| Thursday 9th September 2010
WIN Great Prizes in SOS Competitions!
September 2010
On sale now at main newsagents and bookstores (or buy direct from the SOS Web Shop)
Click image for September 2010
Buy + Download PDF Articles
Now direct from SOS — we sell downloadable Acrobat PDF versions of SOS articles (from 99p each).
