Television Broadcast Weirdness
Postby soundshaper » Thu Jan 29, 2009 8:23 am
Hi all, new here, but looks like a cool place to discuss audio.
Anyhoo, recently I've been working on post audio and mixing for a couple new television shows on FuelTV. We were told by the network that peak levels should stay below -8db, although I'm used to staying even lower with advertising, like -10db. So the masters (Dbeta) were created and we signed off on them in good spirits.
Well when watching the shows via broadcast, there were very noticeable changes in the overall level of the mix, like someone was riding a fader during the show!
After hearing this is a couple of episodes, I decided to record the audio stream from the broadcast and compare it to the original mix. My ears weren't lying after all, as there are very noticeable differences when visually comparing the waveforms. However, it definitely doesn't seem to be limiting, as you would see that clearly.
You can check out what I'm talking about with these comparison images. (They are just the L channel for quick comparison sake).
Anyone have any ideas of what may be going on here?
soundshaper
Re: Television Broadcast Weirdness
Postby Hugh Robjohns » Thu Jan 29, 2009 9:19 am
There's probably one (or more) automatic multi-band dynamics controllers in the audio paths somewhere -- Optimod-style devices. They aren't ise in the UK TV broadcast chain, but they are quite common in the USA distribution chains.
hugh
Postby soundshaper » Thu Jan 29, 2009 10:38 am
Hugh Robjohns wrote:There's probably one (or more) automatic multi-band dynamics controllers in the audio paths somewhere -- Optimod-style devices. They aren't ise in the UK TV broadcast chain, but they are quite common in the USA distribution chains.
hugh
Right.. ok. I kinda figured it was something to that note. However, is there any way to change what I'm doing to get more predictable broadcast results? I mean, it's quite destructive.
soundshaper
Postby Hugh Robjohns » Thu Jan 29, 2009 11:15 am
They work by sensing the energy in different audio bands and try to level it out (which you can see they do pretty well). So the solution is to reduce the dynamics in your mix and try to keep the energy as even as you can.
Makes for a boring programme, though.
Personally, I prefer to mix to make it sound good on a proper linear system. If people complain at the end of a broadcast chain, then the complints can be directed at the poorly set up transmission chain -- not the source programme.
Frustrating, isn't it? As I said, we don't (yet) suffer this problem in TV in the UK, but it's been the bug-bear of radio for years.
hugh
Postby MajorFubar69 » Thu Jan 29, 2009 5:43 pm
soundshaper wrote:...although I'm used to staying even lower with advertising, like -10db...
That's very interesting to hear. On this side of the pond I'm certain the opposite is true, with the adverts (commercials) appearing to be very much louder than the main program. Dunno about the peak levels but they are deliberately volume-maximized/compressed to make their RMS level higher. It's so obvious even your average Joe Bloggs writes to TV watchdogs complaining about it, but nothing ever gets done. It's another take on the continuing "loudness war".
MajorFubar69
I'm a bedroom beatsmith in an 8x7 cell, writing trance dance and techno, and sometimes words as well...
Postby Hugh Robjohns » Thu Jan 29, 2009 6:39 pm
MajorFubar69 wrote:On this side of the pond I'm certain the opposite is true, with the adverts (commercials) appearing to be very much louder than the main program.
The perceived loudness is often (still) very high, but the peak level (as seen on a waveform display) is actually significantly lower. Certainly for TV ads in the UK the ASA regulations (ASA rule 6.9) restricts the peak level of ads to 6dB below the peak level for programmes (ie, PPM4.5 instead of PPM6). It's a crude attempt to balance programme and ad levels, but it's never going to work very well.
Yes, they are -- another example of the daft notion that louder means more people will hear the ad. In fact, a growing majority of people now mute their TVs to avoid the noise, so all that heavy compression has become largely self-defeating!
This is an inevitable problem when audio is metered by devices that look at the signal voltage. Thankfully, there is significant progress being made in introducing metering systems that do provide a reliable measurement of perceived volume, such as the ITU recommendations BS 1770 and 1771.
You might find this interesting:
www.ibs.org.uk/public/lineuparchive/2008/118_Nov-Dec/10_Hush_the_Ads.pdf
and this:
www.ibs.org.uk/public/lineuparchive/2008/118_Nov-Dec/11_DK-Technologies_Loudness_Metering.pdf
Hugh
Postby soundshaper » Thu Jan 29, 2009 9:20 pm
Thank you guys for discussing this with me.. very interesting stuff.
I guess a multi-band compressor or similar could definitely be the culprit, although in some instances it doesn't make sense. There's one bumper in the second example above that should be 2-3 dB louder than the following content, but instead it actually aired 3-4 dB lower than the following content. F'in crazy.
The rule of thumb I gathered from working at commercial recording studios is that advertising should not have peak levels of more than -10, so yes, sometimes engineers will squeeze the mix up into that peak pretty hard trying to get the maximum perceived loudness. Crossing above -10 dB is risking rejection by the networks. But for program(me) material, we usually mix with more dynamic range and a bit higher peak of -8dB.
But as I said, it really sounds like someone grabbed a master fader and pulled it down or even up at the strangest times. We were watching epidsode1 live at the premiere party and it sounded all over the place! Argghh! This network is also young and inexperienced, so maybe they have some multi-dynamics broadcast device set on a stupid preset or something. Very aggravating.
So is the answer to use multi-band compression myself, getting RMS equal among several bands? How would I know which frequencies are within each band, or the slope of the filters?
soundshaper
Postby TVSound » Thu Jan 29, 2009 9:57 pm
You're mastering too high.
-18 dBFS = 4 PPM
So your peak level should be -10 dBFS (=6PPM)
Anything above that will be limited.
You should aim for around -14 dBFS (5 PPM) and certainly never louder than -10.
This is industry standard.
When I'm mixing I don't hit 6PPM (-10dBFS) as I don't rely on limiters to do my job for me.
Going above that is very bad practice - you can't complain about the results, as I'm afraid you're to blame.
Never go above -10 dBFS.
There's nothing wierd happening - you're just going 2 dB higher than the industry peak level (-10 dBfs) and banging into their limiters.
TVSound
Postby soundshaper » Fri Jan 30, 2009 1:10 am
TVSound wrote:You're mastering too high.
-18 dBFS = 4 PPM
Ok, that makes sense. Thanks.
They must have some awful settings on their equipment, cause what it's doing is drastic and extremely apparent.
soundshaper
Postby Hugh Robjohns » Fri Jan 30, 2009 11:24 am
TVSound wrote:So your peak level should be -10 dBFS (=6PPM)
Maybe... but unlikely, at least in the UK.
There is a lot of confusion about acceptable peak audio levels in UK broadcasting, and part of that is the widespread lack of understanding of the differences between a standard PPM meter, and a standard digital meter.
The UK practice is to allow peaks up to PPM 6 as observed on a Type II PPM. A lot of people then simplistically extrapolate from the EBU line up of PPM4 = -18dBFS, and assume that PPM6 must equal -10dBFS. THIS IS NOT TRUE FOR DYNAMICALLY CHANGING PROGRAMME MATERIAL
The EBU alignment is performed with a steady state tone, but the acceptable peak programme level is metered with dynamically changing signal levels. This is a critical difference because the Type II PPM has a 10ms integration time -- it is not a true peak reading meter. In contrast, the vast majority of digital meters are true peak reading (they certainly have a zero integration time), and as a result will show brief signal peaks which the PPM will completely ignore (by design).
What this means in practice is that transient peaks that aren't seen on a standard PPM will be revealed clearly on a standard digital meter. As a result, a programme produced using traditional PPMs to peak no higher than PPM6 will, if checked using a digital meter, exhibit transient peaks up to -6dBFS or higher quite frequently. [/i]This is quite normal and totally expected [/i] -- and from a technical point of view, is actually completely acceptable too. Sadly, some broadcast companies currently have policy documents written by imbeciles that persist in demanding programmes do not exceed -10dBFS. :roll:
Firstly, the OP is talking about his experiences in the US, which has a variety of different broadcast production standards, none of which are the same as the UK.
Secondly, the distribution chain in the US is considerably more complicated than that employed in the UK, and frequently involves the use of multiband compressors and mult-stage format conversions.
Third, the UK industry peak level IS NOT -10dBFS, although a lot of people (including some at very senior levels) share that particular gross misunderstanding -- you are certainly not alone.
And fourth, the kind of level control seen in those waveforms could not be caused by brick-wall transmission limiters.
Hugh
Postby Hugh Robjohns » Fri Jan 30, 2009 11:25 am
soundshaper wrote:Ok, that makes sense.
Er... no it doesn't ;)
hugh
Postby soundshaper » Fri Jan 30, 2009 6:03 pm
This is why I have inquired with the network about their signal processing chain.
Although young, I've actually been mixing material for other networks for some time now, and I have never run into this issue before. I'll keep everyone posted on what we conclude, but for now I'll be observing a -10dB limit.
soundshaper
Postby Robert Eidschun » Sun Feb 22, 2009 8:35 am
What exactly are broadcasters after in specifying and limiting peak levels, energy levels in various bands over certain integration times, etc.? A sense of perceived loudness that doesn't vary all that much? But why would broadcasters want that? Surely, you end up with strange things, like the rustling of clothing that's just as loud as footsteps, no?
By the way, what about films distributed on DVD? Do they typically have audio that uses the full dynamic range of the medium?
And what about projected films in theaters? Are they allowed to have audio that uses the full the dynamic range of the medium?
Thanks.
Robert Eidschun
Robert Eidschun
Postby Hugh Robjohns » Sun Feb 22, 2009 10:09 am
Hi Robert... to asnwer your questions in reverse order:
Robert Eidschun wrote:what about projected films in theaters? Are they allowed to have audio that uses the full the dynamic range of the medium?
Yes. And many do. The thing that makes it possible is that cinemas have carefully specified, powerful and properly calibrated sound systems which are capable of delivering high sound levels when required, and reasonably well isolated theatres that allow the quiet bits still to be heard (assuming the popcorn and sweetie rustling is minimal ;) )
DVDs generally do, yes, but becaues few home theatre systems could cope, the Dolby Digital sound track incorporates metadata that allows the decoder to reduce the dynamic range in a way which the film dubbing studio thought was acceptable -- if the home user activates it.
Initially, it was to protect analogue transmitters from over-modulation and causing interference in adjaceant channels. It is also about providing consistent levels between programmes and channels so that the home viewer doesn't have to constantly adjust the listening volume.
In Europe, peak levels are set using a PPM meter with a nominal peak of +8dBu (UK) or +9dBu (most of Europe) -- but the important thing to realise is that the PPM isn't a true peak reading meter; it has a deliberately slugged response so that it ignores low-energy high-level transient peaks.
Yes, but over the long term. It's not about making the sheep farts as loud as the airplane crashes -- that would clearly be stupid. It's about trying to maintain a consistent level for average conversational speech, so that if you change channels from watching a news report to a documentary to a soap opera to a children's programme, people talking normally all sound pretty much the same level as each other. And the same at programme junctions on the same channel. When one programme ends, the speech in the voice over announcement or adverts should be roughly the same volume as each other.
Not at all.... but it is all about interpretation and common sense, and sometiems both appear to go AWOL! ;)
hugh
Postby Robert Eidschun » Sun Feb 22, 2009 7:57 pm
Hi Hugh,
Thanks for your response. My comments are below, in-line.
Robert
Hugh Robjohns wrote: ... cinemas have carefully specified, powerful and properly calibrated sound systems which are capable of delivering high sound levels when required ...
I'm not sure how particular such sound systems have to be other than loud enough. I was at Kilbourn Hall last week, where I heard the performance of a piece for Pro Tools and live voice: there were six Mackie HR824s, each fed a separate channel and arranged throughout the seating, and the sound was incredible and much better than I've ever heard in any cinema, with extremely quiet passages as well as thunderously loud sections. The composer sat in the middle of the seating, adjusting faders a wee bit now and then, but that's all he did.
Kibourn Hall, Eastman School of Music, Rochester, New York:
Hugh Robjohns wrote: ... the Dolby Digital sound track [on DVDs] incorporates metadata that allows the decoder to reduce the dynamic range in a way which the film dubbing studio thought was acceptable -- if the home user activates it ...
On my Sony Bravia TV, which has two built-in speakers, I do not listen to the Dolby track. In addition, that TV offers what is explicitly called "compression", but I keep that turned off. Consequently, I'm having to boost the quiet sounds (e.g., the rustling of clothing) of my own audiovisual project quite considerably so that they are audible, when my project is played back from DVD and shown (and heard) on that TV. But that means that if I listen to the soundtrack on my home stereo, the quiet sounds sound somewhat too loud. This is of concern because I can imagine that at certain film and video festivals, there may be hi-fi sound systems...
Robert wrote:What exactly are broadcasters after in specifying and limiting peak levels, energy levels in various bands over certain integration times, etc.?
Hugh Robjohns wrote:Initially, it was to protect analogue transmitters from over-modulation and causing interference in adjaceant channels.
Well, I assume that that is no longer an issue. It's hard to imagine that it would be in this day and age, given modern electronics.
Hugh Robjohns wrote:It is also about providing consistent levels between programmes and channels so that the home viewer doesn't have to constantly adjust the listening volume.
I'm not sure I follow here... Do you mean, "so that the home viewer no longer 'wants' to adjust the volume"? If there is some standard specified by the broadcaster that correlates sound pressure level to signal level, then there shouldn't be a problem. So, for example, something like, "normal speach by a source within a few feet of the camera should produce average levels of around -x dBFS", or something like that.
Hugh Robjohns wrote:In Europe, peak levels are set using a PPM meter with a nominal peak of +8dBu (UK) or +9dBu (most of Europe)
"+8 dBu" means that the voltage of the signal, v, is 8 db above 1 microvolt, i.e. +8 = 20 log (v/0.000001). But this specification is only meaningful in the analogue domain, where it refers to, for example, the voltage measured at the output of a playback head that is reading an analogue audio track off of tape. How then can such a specification pertain to an audio signal that is represented digitally?
Hugh Robjohns wrote: -- but the important thing to realise is that the PPM isn't a true peak reading meter; it has a deliberately slugged response so that it ignores low-energy high-level transient peaks.
That probably means that it's showing the average signal level over time, using the Mean Value Theorem. So, one might ask, what is the area under a curve, over a certain width -- say, a curve that represents signal amplitude, expressed as voltage, over time? Answer: the integral over that width. But one might also ask, what is the height of a rectangle that has the same width and the same area? Answer: the integral just mentioned, divided by its width. That height is the "average" voltage, according to the Mean Value Theorem. The latter does nothing but validate the procedure that I just mentioned. But that procedure is only one way of specifying the average of a varying signal level. For example, one might determine the average power of a varying signal, since changes in power (rather than signal amplitude) correspond more closely to changes in perceived volume.
In practice, the PPM meter is probably much "dumber", not doing any calculus at all, but simply allowing a capacitor to charge up, or something like that, where the voltage reached across the capacitor would be a function of the waveform and for how long it was monitored.
Robert wrote:Surely, you end up with strange things, like the rustling of clothing that's just as loud as footsteps, no?
Hugh Robjohns wrote:Not at all.... but it is all about interpretation and common sense, and sometiems both appear to go AWOL! ;)
I don't see how you won't end up with, as I pointed out, the rustling of clothing that's just as loud as footsteps, and in fact, that's what I've ended up with. The problem is that the scene in question is a classical music concert, and I've set things up so that the loudest part of the music is at full scale (and would thus clip if any louder). Now, when the performers whisper, it's barely audible, as it should be. But clothes rustling should be even quieter, and making them so results in their being inaudible. So, I've performed "manual compression", raising the volume of the rustling clothes. This seems OK until the music goes quiet, at which point you realize that the rustling clothes that you just heard were just as loud as the quiet music that you're now hearing, which seems a bit ridiculous. So, I raised the volume of the whispering too -- as much as I could stand before it started to seem too loud with respect to the rest of the music. This then allowed me to raise the volume of the rustling clothes, but which still ended up being too quiet. So, I raised the volume of the rustling clothes even more so, but now I'm back to having rustling clothes that are too loud with respect to the music.
I'm describing what I've done in order to accommodate the audio playback system of a standard TV. By contrast, if I were to set levels for audio playback on a good stereo, then I wouldn't need any "manual compression". There seems to be no good solution in the situation that I've described here, unless you have any ideas(?).
Robert Eidschun
Robert Eidschun
Postby Hugh Robjohns » Mon Feb 23, 2009 10:24 am
Robert Eidschun wrote:I'm not sure how particular such sound systems have to be other than loud enough.
Cinema sound systems are certified for levels, frequency response, dispersion, isolation and so on. THX certified cinemas are particularly tightly controlled. You can find the specs on the Dolby and THX websites.
A perfect example of why the dynamic range control requirements are different for different reproduction systems in different listening environments. There is no 'one-fix-suits-all' solution. The Dolby Digital metadata (Dialnorm, DRC, downmixing ) is a very clever attempt to provide near-perfect results for different listening environments and situations, but it requires the production team to use it appropriately, and the home use to employ it in the approporiate situations. Many, like you, still avoid it and then wonder why they can't hear the quiet bits, or why the loud bits wake the babies!
Peak level control will always be required, whether the broadcast chain is analogue or digital (or hybrid). As long as analogue broadcasting continues (as it will here for another few years in TV, and indefinitely in radio), there will remain the need to prevent overmodulation, and digital systems must snever be allowed to clip, obviously.
The advantage of digital systems is that the alignment of different stages and interfaces becomes far simpler, but peak lvels still need to be monitored and controlled.
No, I mean so they don't feel the need to adjust the volume between programmes or channels. In an ideal world, the home viewer/listener should be able to set the listening level they feel comfortable with and leave it at that for the duration of their viewing. They shouldn't have to turn it down when the adverts come on during the programme they are watching, or adjust it significantly when they switch to a different channel to watch a different programme.
...but this is a surprisingly difficult thing to achieve and is actually far more complicated than it appears. Some very clever peoploe in the EBU and other standards bodies have been trying to find ways of addressing it for years.
There isn't and can't be. There is in the film/cinema world, because the replay environment is known and the signal level/SPL level can be defined and fixed -- that's part of the Dolby/THX spec.
But in the home environment, there is no fixed listening level. Some people listen loudly, others quietly. Some have noisy backgrounds to content with (eg, the kitchen ) and some need to keep it quiet to avoid waking the children. So in general, the dynamnic range must be kept relatively small. The BBC's own guidelines suggest maintaining dialogue within an 8dB range, for example.
That is done, as I said above. Normal speech would typically register between PPM4 and PPM6 on a BBC-style peak meter, which is roughly -18 to -10dBFS.
No. 0dBu is a reference voltage of 0.775V (RMS). So +8dBu is a signal level of 1.95V (RMS). The 'u' in dBu is derived from 'unterminated' and refers to the fact that modern audio interfaces are no longer the matched impedance types that were used up until about 40 years ago. Before then, the standard audio signal level was 0dBm where 'm' referred to the power 1 milliwatt. The standard citcuit impedance was 600 ohms, and dissipating 1mW in 600 Ohms produces a voiltage of 0.775V. Modern interfaces are voltage-interfaces, and we kept the same reference voltage.
Many US audio systems use an elevated reference voltage of +4dBu, or 1.223V (RMS).
Obviously, because it is an analogue voltage signal measurement.
In the digital domain we use dBFS (dB below full scale), and the relationship between dBu and dBFS is set by the A-D and D-A converters employed. The EBU recommends an alignment of 0dBu = -18dBFS, while the SMPTE recommends +4dBu = -20dBFS.
Yes, pretty much all analogue meters are integrating meters. While the VU meter is intended to give some indication of 'avearage signal level' which has a vague relationship to perceived volume, the European PPMs were designed to give a much better and more reliable indication of signal peak levels.
However, a very deliberate engineering decision was made to prevent the meter from displaying fast transient peaks since even if these were allowed to overdrive transmitters, the resulting harmonic distortion products were too brief to cause annoyance, and leaving sufficient headroom to avoid transient overloads undermodulated the system very wastefully. To that end, European PPMs integrate over 5 or 10ms, and that's why they don't indicate fast transient peaks.
That was fine in the analogue domain, but is no longer entirely appropriate for the digital world where distortion caused by transient overloads in digital systems results in anharmonic distortion which is instantly audible, even when very brief. But the industry's familiarty with analogue PPMs ensures their continued use in many areas, and so the digital systems havea been engineered to maintain adequate headroom to prevent transient overload (as detailed earlier).
This is true, but reliable determination of perceived volume is quite complicated, and a lot of work has been (and is being) done on finding a consistent way of metering perceived volume. Dolby produce a bespoke system for metering perceived loudness (primarily for the film industry) and a lot of broadcasters are now adopting the ITU Recommendations BS.1770 and BS.1771 for loudness metering. Meter manufacturers such as DK-Technologies and RTW already manufacturer suitable devices, and I think this will become the way forward in maintaining consistent programme and channel signal levels.
I think you'd be surprised just how complicated the electronics of an analogue PPM is -- and there definitely is calculus in the signal processing.
Rustling clothes can certainly be as loud as footstpes, or footsteps as quiet as rustling clothes -- it all depends on the clothes, the shoes and the surfaces!
But I take your point. At the end of the day it comes down to the skill and artistry of the dubbing mixer to balance the sounds as appropriate withing the dynamic range constraints of the medium he or she is working in.
The key is to maintain a consistent dialogue level, that matches the guidelines of the format, and then balance everything else around that, within the dynamic range constraints of the medium.
I'll take your word for it. There is such a thing as a 'stage whisper' which gives the impression of whispering but remains entirely audible. There is little point in giving a performance where a proportion of the audience can't hear what is being said! And what might be barely audible in a cinema or oonn a hiigh quality dueatre monitoringg system will be completely inaudible when vieewed on a typical domestic TV. Hence the inherent need for skillful dynamic range control to suit the replay environment.
;) No one said the art of audio dubbing was an easy one! Mixing (or at least regualrly checking a mix) on a comparative monitor system is essential until you have acquired sufficient expereince to know how a mic will translate from big hifi monitors to small TV ones. And mixing at low listening levels will also help to produce more appropriate and consistent results.
It's a compromise, quite obviously. Some aspects of mixing perfection have to be compromised to produce a mix which is satisfactory when heard in a typical domestic environement on a typical TV. That's just the way it is. Skillful balancing can make that compromise less obvious, but it will always be there.
hugh
Postby Robert Eidschun » Mon Feb 23, 2009 7:53 pm
Hugh,
"Thanks for your additional, very helpful comments. My comments are below, in-line.
Robert
Robert wrote:Well, I assume that that is no longer an issue. It's hard to imagine that it would be in this day and age, given modern electronics.
Hugh wrote:Peak level control will always be required, whether the broadcast chain is analogue or digital (or hybrid). As long as analogue broadcasting continues (as it will here for another few years in TV, and indefinitely in radio), there will remain the need to prevent overmodulation, and digital systems must snever be allowed to clip, obviously.
I'm not sure what you mean by overmodulation, as the audio that accompanies an analogue TV signal is FM modulated, and one needs only keep frequency modulation of the audio carrier below a certain value. (I don't know what the maximum allowable modulation frequency is for analogue TV, but for FM radio in the USA, it's about 17 kHz.) However, modulation, as I just described it, is independent of amplitude, and yet your original comment was that one had to control amplitude to prevent overmodulation. Perhaps I'm missing something here.
Robert wrote:I'm not sure I follow here... Do you mean, "so that the home viewer no longer 'wants' to adjust the volume"?
Hugh wrote:No, I mean so they don't feel the need to adjust the volume between programmes or channels... They shouldn't have to... adjust it significantly when they switch to a different channel to watch a different programme.
Robert wrote:If there is some standard specified by the broadcaster that correlates sound pressure level to signal level, then there shouldn't be a problem.
Hugh wrote:There isn't and can't be.
Robert wrote:So, for example, something like, "normal speach by a source within a few feet of the camera should produce average levels of around -x dBFS", or something like that.
Hugh wrote:That is done, as I said above. Normal speech would typically register between PPM4 and PPM6 on a BBC-style peak meter, which is roughly -18 to -10dBFS.
Hugh, I intended my first statement ("correlates sound pressure level to signal level...") to be a generalization of the example given in my second statement ("normal speach...")
Robert wrote:+8 dBu" means that the voltage of the signal, v, is 8 db above 1 microvolt, i.e. +8 = 20 log (v/0.000001).
Hugh wrote:No. 0dBu is a reference voltage of 0.775V (RMS).
Actually, it's different here in the States, where we use "dBv" to mean your "dBu", and "dBu" here means yet something else. But my point here was only that such a figure alone does not specify the magnitude of a digital representation of a signal, despite all of the suggestions to the contrary earlier in this thread.
Robert wrote:In practice, the PPM meter is probably much "dumber", not doing any calculus at all
Hugh wrote:I think you'd be surprised just how complicated the electronics of an analogue PPM is -- and there definitely is calculus in the signal processing.
That means that it's sampling and then using a microprocessor to do maths. By the way, this isn't necessary, as you can always use an "analogue computer" to function as a meter, as was done in the past. So, for example, rather than calculating how much time is required to charge a capacitor, you simply charge a capacitor and measure how long it took.
Robert Eidschun
Robert Eidschun
Postby Hugh Robjohns » Mon Feb 23, 2009 9:41 pm
Robert Eidschun wrote: I'm not sure what you mean by overmodulation
the origina of the problem relates to early Am broadcasting, but over-deviation of FM broadcasts is equally anti-social.
Ah... two nations separated by a common language!
In the strict sense, you are right, but the accepted EBU and SMPTE conventions enable people to assume a fixed relationship between analogue signal levels and their digital representation in a usefully consistent way.
No. It's quite possible to perform quite involved maths functions with analogue electronics. I suggest you google-search for the standard PPM circuits to see how involved it is.
Hugh
Postby Robert Eidschun » Tue Feb 24, 2009 1:04 am
Hugh wrote:No. It's quite possible to perform quite involved maths functions with analogue electronics. I suggest you google-search for the standard PPM circuits to see how involved it is.
Let me clarify what I was on about... Mathematics is a human construct that involves numbers, and because of that, there is never any maths done outside of humans unless numbers are explicitly represented -- never any maths done by analogue electronics, and in general, never any maths done outside of humans if humans have not developed numerical algorithms and implemented them in machines, where inside those machines, there are explicit representations of numbers.
This might seem merely philosophical and not terribly practical, but it is what distinguishes analogue from digital electronics: in the latter, there are explicit representations of numbers in the hardware, where as in the former, there is an analogue of the physical process being analyzed.
So, for example, we can determine the frequency at which a circuit oscillates by using a digital computer to solve numerically the differential equation that describes that circuit; or, we can use an analogue computer instead, switching in the various circuit elements to create physically the circuit in question, then apply a voltage to its input, then observe at which frequency it oscillates. Since we know which differential equation corresponds to that circuit, the frequency that we observe is the same as the frequency sought in solving the equation using mathematics, even though no mathematics is performed by the analogue circuit.
As an even simpler example, imagine that you want to determine the speed reached by a ball after it has fallen from rest in a vacuum for a certain amount of time. You could simply multiply g and t, where g is the acceleration due to gravity and t is the elapsed time; or, you could actually drop a ball in a vacuum, let it fall for a certain amount of time, then measure its speed. Now, clearly, in using the latter method, neither the ball nor you have multiplied g and t, or have done any maths whatsoever. You, your watch, the ball, etc. constitute the analogue computer; your brain, engaged to multiply g and t, constitutes the digital computer.
Robert Eidschun
Robert Eidschun
Postby Hugh Robjohns » Wed Feb 25, 2009 9:48 pm
Robert Eidschun wrote:Let me clarify what I was on about...
OK. I take the point, even if it is philosphical pedantry that isn't relevant to the thread or the point I was making. But... er... thanks. ;)
hugh
hugh
Postby Robert Eidschun » Wed Feb 25, 2009 11:46 pm
I didn't really mean to sound that way -- only to illustrate the difference between two distinct ways of using electronics to determine the same quantity: through the explicit representation and manipulation of numbers to solve mathematical equations versus the observation of systems whose behavior is analogous to the behavior of those equations.
It is easier to build the latter, but more difficult to design, since you have to know the maths to some degree of rigor, such as that associated with analytical integration, e.g., the Fundamental Theorem of calculus. By contrast, integration in the digital domain requires only geometry, and more specifically, the notion of determining the area under a curve by adding up the areas of a finite number of rectangles, etc.
Then again, the multiplicity of digital circuits in any given digital machine makes for very intricate design -- but it doesn't require the abstract notions of analytical mathematics, which most folks find much more difficult than Boolean algebra.
On another note, after much "manual compression" (through manual, upward adjustment in volume of the quiet bits), the dynamic range of my soundtrack is now 45 dB. Is that small enough for a low cost TV, with built-in speakers, etc.? By the way, the dynamic range seems adequately small on a couple of such TVs that I have, as the quietest bits are just barely audible, while the loudest bits are still below the level at which I think most folks would say, "the TV is too loud -- turn it down!"
(Of course, the loudest bits are at full scale, i.e. sixteen one's, given that it's 16 bit, 48 kHz audio, designed for DVD.)
Thanks.
Robert Eidschun
Robert Eidschun
Postby turbodave » Thu Feb 26, 2009 5:01 pm
Hugh...where can I get one, what does it do and how much does it cost? :D
turbodave
My head hurts!
Postby Robert Eidschun » Mon Mar 02, 2009 10:15 pm
Hugh wrote:Normal speech would typically register between PPM4 and PPM6 on a BBC-style peak meter, which is roughly -18 to -10dBFS.
Hi Hugh,
Just as a reminder, I'm working on the audio track for something to be distributed on DVD, primarily to be entered into film competitions, and I'd like the loudest bits to be at full scale.
I have a few more questions for you then, if you would be so kind as to provide answers please, so that I can be off and on my way:
1) In reference to your remark above, do you mean that the average peak value should be between the limits that you've specified, or that all peak values should be between those limits? If the latter, then this might require not only amplification or attenuation, but compression as well, in order to keep all of the speech entirely between those limits at all times. The procedure then would be first to compress the speech to a dynamic range of 8 dB, if necessary, then amplify or attenuate to move the speech into the range that you've specified. Have I got that right?
By the way, I have a habit of speaking with widely varying volume, even within a single sentence, and in listening to a recording of myself speaking normally, I notice it even more. It seems a bit excessive, even to the extent of making it a bit difficult to understand me, I imagine. So, I can certainly imagine using compression on a recording of my voice, for the sake of intelligibility.
2) The level of everything else other than normal speech should be set with respect to normal speech, i.e. with respect to the range that you've specified for normal speech. So, for example, thunder might be set at full scale, while the rustling of clothing would probably be set at something less than -18dBFS. Do I have that right?
3) After much "manual compression" (through manual, upward adjustment in volume of the quiet bits), the dynamic range of my soundtrack is now 45 dB. Is that small enough for a low cost TV, with a built-in speaker or two? Indeed, the dynamic range now seems adequately narrow on a couple of such TVs that I have, as the quietest bits are now just barely audible, while the loudest bits are still below the level at which I think most folks would say, "the TV is too loud -- turn it down!"
Thanks.
Robert Eidschun
Robert Eidschun
Postby Hugh Robjohns » Tue Mar 03, 2009 8:40 am
Robert Eidschun wrote:the dynamic range of my soundtrack is now 45 dB. Is that small enough for a low cost TV, with built-in speakers, etc.?
I don't think you'll find anywhere a definition of an acceptable dynamic range. In a more practical sense, the BBC PPM has as working range of about 24dB, and normal practice is to keep the peaks of anything critical within that metered range. The total system dynamic range for analogue TV is around 80dB. Film soundtracks tend to have a wider dynamic range because they are intended for viewing in an entirely different environment, but you can't have it both ways (unless you take advantage of Dolby Digital's metadata.
At the end of the day, that's what matters. It is a combination of specific technical criterion, and aesthetic acceptibility. If you and your clients are happy with the mix, and it falls within the appropriate tech specs, then it's fine.
(Of course, the loudest bits are at full scale given that it's 16 bit, 48 kHz audio, designed for DVD.)
There's no 'of course' about it. It comes down to standards again. Films generally do exercise the full dynamic range available and extend to full scale on occasions. TV programmes (both broadcast and on DVD), in general, do not, as in my experience they typically maintain the broadcasting standards of restricting peaks to around -9dBFS.
You have to decide: is this primarily a programme to be viewed in a cinema, in which case it should be mixed to cinema standards, or for TV, in which case it should be mixed to TV standards.
The only saving grace is that if you mix it to filmic stanards, you could then take advantage of the metadata in the Dolby Digital soundtrack that I presume will be used ont he DVD, to establish suitable dynamic range reduction characteristics to make the mix sound more acceptable (and match the regulations) on TVs.
Hugh
Postby Hugh Robjohns » Tue Mar 03, 2009 9:01 am
Robert Eidschun wrote:Just as a reminder, I'm working on the audio track for something to be distributed on DVD, primarily to be entered into film competitions, and I'd like the loudest bits to be at full scale.
Fair enough. But don't be surprised when it sounds much louder than other TV programmes (unless you implement Dolby Digital metadata properly).
Normal dubbing does involve all that yes. The best advice is to analyse commercial films (and/or TV programmes) on DVD that you think sound good, and see how they have handled the dialogue.
In the UK, TV dialogue is normally contained between about PPM 4 and PPM 6 -- roughly -18 to -10dBFS. In film mixes, the dialogue is generally lower (to allow more headroom for the explosions), typically around -24 to -12dBFS. But these are only guides, and it is the way the mix sounds that matters.
That is certainly one way of dealing with it... but I'm not suggesting that the quietest whisper should only be 8dB quieter than the loudest scream. I'm talking about the general normal dialogue which acts as the benchmark for other level judgements. Stuff that's meant to be loud can be loud, and stuff that's meant to be quiet can be quiet. The skill and art is in achieving a mix that enables everything to be followed without being difficult to endure or for the mix to draw attention to itself.
Yes. Context has a lot to do with it too, of course. In a dramatic, tense scene, for example, you might allow everything to get quieter through the duration of the scene in order to draw the audience in as well as to provide more 'subjective headroom' to accommodate the sudden high-impact shock of a huge explosion of terrifying scream at the climax of the scene. A mix is a dynamic thing that evolves and develops along with the film.
...the dynamic range of my soundtrack is now 45 dB. Is that small enough for a low cost TV, with a built-in speaker or two?
It depends how you're defining dynamic range, but possibly. I don't know the material, but as I said vefore, the BBC PPM (as used for judging TV balances) has a dynamic range on its scale of about 24 dB and in most cases, a balance engineer wouldn't let the needle sit on the bottom end stop for too long unless there was a really good reason.
You're probably too close to the project to really make that call. I would suggest burning a disc and letting a few friends/family/colleagues have a listen and see how they respond to it. They'll tell you if it meets their expectations and acceptibility factors or not.
Hugh
