ASUS DRW-24B1ST OFFSET
Postby yonatan yitzhakov » Mon Jul 11, 2011 8:57 am
Can anyone confirm that the read sample offset correction value of the ASUS DRW-24B1ST
is 6 +
As it says in this link:
http://www.accuraterip.com/driveoffsets.htm
yonatan yitzhakov
Re: ASUS DRW-24B1ST OFFSET
Postby James Perrett » Wed Jul 13, 2011 4:58 pm
While the SOS forum is a great resource for most sound recording questions, I suspect that drive offsets are so specialised that few people around here even know about them - let alone actually worry about them.
If I was worried about this, I would simply set the drive offset to 0, extract a known CD as a reference, and then see how far off the audio was from the expected position. I could then set the offset accordingly. I guess I have the luxury of owning a drive with a known offset in order to create the reference though.
Normally you only need to worry about drive offsets if you are extracting a CD where the mastering engineer has really pushed the start markers right up to the start of each track. Most mastering engineers actually allow a gap of 5-10 CD frames between the start marker and the start of audio specifically to allow for players that don't position themselves accurately. So these offsets are pretty much irrelevant with most CD's.
James.
http://www.jrpmusic.co.uk
Postby yonatan yitzhakov » Sat Jul 16, 2011 2:24 pm
1."If I was worried about this, I would simply set the drive offset to 0, extract a known CD as a reference, and then see how far off the audio was from the expected position. I could then set the offset accordingly".
How do I make this test? With what tools?
2."I guess I have the luxury of owning a drive with a known offset in order to create the reference though."
From which resources you took the information about the offset of your drive?
yonatan yitzhakov
