Focusrite Liquid 56 - S/PDIF issue
Postby ZIBIT » Wed Aug 17, 2011 11:49 am
Hey,
If there is a topic about this already, then i'm sorry but I couldn't find any so here goes:
With my Liquid 56 I am able to use every input/output - including my two Behringer ADATS - as external effect in Cubase... EXCEPT S/PDIF !?
In Cubase the input/output is available, my M-ONE gets the lock-signal and I'm able to route (in the Saffire Mixing-Control panel) any DAW to the S/PDIF output and any input from S/PDIF to the outputs of the Liquid or one of it's ADATS. So they are able to talk to each other.
So.... Where's the problem?
Why can't I use my S/PDIF connected effects processor as "external plugin" in Cubase (and Ableton) ??? :headbang:
When I configure it, no signal is received in the M-ONE....
kind regards,
ZiBiT
ZIBIT
Re: Focusrite Liquid 56 - S/PDIF issue
Postby Mixedup » Wed Aug 17, 2011 7:09 pm
I suspect, as you have the issue with Ableton as well as Cubase that it's something you've missed in the Saffire Mix Control setup. I don't get these issues with my RME FF800 - using analogue, ADAT and S/PDIF there with Cubase and PT without problem. I don't recall having problems when I had a Liquid Saffire for a while either.
Mixedup
Postby ZIBIT » Thu Aug 18, 2011 9:03 am
hmm ok, I'll see if I can play around with the Mixing Control a wee bit more.
Strange though that I didn't have to do all this effort with my ADATS.
Thanks for confirming the Liquid Saffire thingy too....
greets
U
ZIBIT
Postby . . . Delete This User . . . » Thu Aug 18, 2011 10:58 am
i've done it in Logic no problem.... so i suspect it's something not quite right in the set up in cubase.....
Users browsing this forum: No registered users and 11 guests
