Need a cheap USB soundcard, cheap, like CHEAP!
Postby schuey » Fri May 18, 2012 2:06 pm
So the most important thing here is cheap. I'm looking for a very basic soundcard for my Mac, running the latest OS, basically so I can get two outputs out of the Mac, just need two outputs, no inputs and that's it.
When I say cheap I do want it to actually make some sound when plugged in but as long as it does that then I'm happy :)
Anyone have any ideas?
schuey
Re: Need a cheap USB soundcard, cheap, like CHEAP!
Postby boymarsh » Fri May 18, 2012 2:17 pm
Sorry if its a daft question but do you need two stereo outputs? Or is it just two mono outputs that you want, in which case you'll have that with the stereo out.
At least, I think so - not used a mac in ages. Last I did they were sticking to the single mouse button, so maybe they're stubborn mono fans.
Stu :D
boymarsh
Postby schuey » Fri May 18, 2012 2:19 pm
:) Actually what I'm trying to do is use some djing software on the Mac which needs to have a main output for the main mix and a headphone output for the headphone mix, if that makes sense :)
schuey
Postby RegressiveRock » Fri May 18, 2012 3:07 pm
schuey wrote::) Actually what I'm trying to do is use some djing software on the Mac which needs to have a main output for the main mix and a headphone output for the headphone mix, if that makes sense :)
And the problem with the signal from the Mac soundcard is???? ;)
Reg
RegressiveRock
Postby schuey » Fri May 18, 2012 3:09 pm
I need to listen to both sources individually. Am I being dumb, I can do that?
schuey
Postby RegressiveRock » Fri May 18, 2012 3:11 pm
schuey wrote:I need to listen to both sources individually. Am I being dumb, I can do that?
Are they sparate sources, or do you just need to split the Mac out signal?
RegressiveRock
Postby schuey » Fri May 18, 2012 3:13 pm
They are, one is the headphone mix, which for example might be a song from the right 'turntable' and the other will be the full mix which is both left and right turntable.
schuey
Postby Airfix » Fri May 18, 2012 3:47 pm
Native Instruments Traktor Audio 2 is less than €100.
It's hard to think of anything with 4 outputs for much cheaper than that.
The MixVibes U-MIX 44, a 16 bit device, is around the same price.
Airfix
Postby schuey » Fri May 18, 2012 3:49 pm
Only actually need two outputs, was thinking of something like this http://www.dv247.com/computer-hardware/behringer-uca202-2-in-2-out-usb-audio-interface--32730
schuey
Postby Richie Royale » Fri May 18, 2012 4:28 pm
You are probably better off with four outputs; Numark do one called DJiO which might be fine for you. It has RCA connections though.
Richie Royale
Postby Richie Royale » Fri May 18, 2012 4:29 pm
The one you linked to has only got two outputs = one stereo output. You need a four output interface to get two stereo outputs.
Richie Royale
Postby Jonesd90 » Sun May 20, 2012 10:53 pm
Actually the one you have posted is perfectly suitable.
You have 3!!! outputs on that sound card. There are 2 stereo outputs (so four mono outputs) on phono outputs and also a mini jack output for headphones, which will also be a stereo output.
However, having never used anything like that myself before, I have no idea whether the outputs are individually assignable.
If the design is there you will be able to get a separate mix in all three outputs, or if its a very basic design then it will just be one stereo audio signal feeding all three stereo outputs.
Dave
NO, I'M WRONG. PLEASE IGNORE MY TERRIBLE ADVICE.
Apologies here, yes it only has 1 stereo output and 1 stereo input. The headphone output will give the exact same output as the phono output.
Jonesd90
Postby Dynamic Mike » Sun May 20, 2012 11:50 pm
Reloop Play has 4 outs + headphones. Also Novation Nio 2/4 has been discontinued so there may be some end of line bargains if you shop around.
DM
Dynamic Mike
Internet Bullying? Kids: Log out & tell a grown-up. Grown-Ups: Log out & go figure.
Postby ef37a » Mon May 21, 2012 2:55 am
http://www.juno.co.uk/products/esi-maya44-usb-audio-interface/340872-01/
^ My ESP 1010e seems ok so that probably is.
I THINK you have to be a bit wary with macs and usb.AFAIK any usb AI works with PC but not always with mac....But you REALLY would do a lot better with an NI KA6!
Postby Pete Kaine » Tue May 22, 2012 2:10 pm
I'd go for the Native Instruments KA 2 (great convertors, tight drivers) but that's around £80. Cheaper than that I can only really think of the Numark DJIO or the Alesis io2 for about a tenner less and whilst they'll do the job I'd still prefer to work with the KA2 due to the previously mentioned reasons.
Pete Kaine
ScanProAudio - Studio Kit
Scan 3XS Audio Workstations
Postby schuey » Tue May 22, 2012 2:34 pm
Ok great, thanks everyone, I'll probably take a look at the NI card, seems like a lot of money to be fair, oh well :)
schuey
Postby Richie Royale » Tue May 22, 2012 2:36 pm
In the scheme of things, £80 isn't that much. If you can make money out of DJing, that is a few hours work.
Richie Royale
Postby The Red Bladder » Tue May 22, 2012 3:02 pm
schuey wrote:So the most important thing here is cheap.
Ebay listing for £1.75 USB audio output.
I bought one of these and it just works when you plug it in. £1.75 seems cheap enough and it really does work!
The Red Bladder
