Crazy MIDI to CV convertor. Any suggestions before hitting it with hammer?
Postby Kolakube » Sat Jul 21, 2012 8:28 pm
Hey guys,
My Kenton Pro 1 mk 1 convertor from way back is acting bizzarly. Wonderign if anyone can offer any advice if they have had a similar experience.
MPC midi out to Kenton Pro1 in, Kenton Midi thru to synth 2.
I can play synth 2 fine, no probs at all. Synth 2 being the one on the thru channel, if anything I thought this would have been the problematic.
However my kenton'd synth synth 1 plays fine for 5 seconds then stops for 5 more then plays for 30 seconds then stops for 5 seconds. Of course these times are note typical, more using an example of how it works fine then stops then starts again without touching it.
Midi in dot flashes even when silent so its getting a midi signal when it drops out. Im guessing its not the midi end of things and more the CV side.
Anyone know a simple fix I dont know about?
Kolakube
Re: Crazy MIDI to CV convertor. Any suggestions before hitting it with hammer?
Postby Tomás Mulcahy » Sun Jul 22, 2012 9:05 am
Sounds like the Kenton has lost its CV settings. I can't remember if it uses a backup battery for memory, or what. What's synth 1? Check that the Kenton is sending the right flavour of gate and CV.
Tomás Mulcahy
madtheory creations
Soundware Shop
Postby Kolakube » Tue Jul 24, 2012 8:09 am
Hello mate. Thanks for reply and trying to help.
I found the problem. Stupid owner syndrome. I had the envelope set to the arp and the arp slider at minimum :-/
Kolakube
Postby Martin Walker » Tue Jul 24, 2012 9:47 am
Kolakube wrote:I found the problem. Stupid owner syndrome.
So that was an SOS problem then :bouncy:
Postby Kolakube » Tue Jul 24, 2012 12:10 pm
haha, I had to read that over and over to make the link.
Yeah its a SOS problem. All your fault mate!
Kolakube
Postby Tomás Mulcahy » Tue Jul 24, 2012 5:14 pm
LOLzers! :)
Tomás Mulcahy
madtheory creations
Soundware Shop
Users browsing this forum: GRAHAM99, Hugh Robjohns and 3 guests
