Fluid behind ear drum???
Postby geometricnothing » Thu Dec 06, 2012 11:51 am
OK, I know this is not a recording technique post, but I really need help.
I had a very bad bout of flu recently, and now I've recovered only to be left with fluid behind my ear drum! Its been nearly a week, and I havent been able to work. My left ear feels totally submerged. Im on antibiotics, and doctor says the only other thing he can do it put a hole in my ear drum to clear things up. Anyone got experience with this? anything else I can try? I really dont want someone to put a hole in my ear drum!
geometricnothing
Re: Fluid behind ear drum???
Postby Arthur Stone » Thu Dec 06, 2012 12:06 pm
I've had a bad ear for a while now...lot of it about. Obviously the docs know best - I'd just add that eating well and resting will help the body to heal itself. Take a break from loud music/long sessions and clean your headphones. Get well soon : )
Arthur Stone
Postby Scramble » Thu Dec 06, 2012 12:43 pm
Last year I got a blocked up ear from a bad cold and it lasted for a couple of months. I also knew a few other people with the same cold who had the same problem. Very unpleasant.
They normally clear themselves up eventually. Perforating the ear drum is not normally done unless the blockage really won't go away after a long time, as it's not really something you generally want to be doing.
Scramble
Postby zoosound » Thu Dec 06, 2012 1:18 pm
I've had something similar too lately. I heard this program the other day
http://www.bbc.co.uk/iplayer/episode/b01p41h6/Its_My_Story_Music_and_Silence/
which just reinforces how careful you need to be. It also makes you realise how many folks are in the same boat, or worse & coping.
zoosound
Postby geometricnothing » Thu Dec 06, 2012 1:43 pm
Well thats pretty scary! As a sound engineer, it would be career over. A musician could get away with it, depending on how bad the damage is.
The only good news Ive had is that I burped and there was a momentary clarity. Going to attack with menthol steam now. Desperation ;)
geometricnothing
Postby geometricnothing » Thu Dec 06, 2012 2:30 pm
Anyone know a private ear clinic I could visit? My GP is not very agreeable, and the whole process of being referred to a ENT clinic might take ages...
geometricnothing
Postby scw » Thu Dec 06, 2012 2:55 pm
From your description you have a bit of eustachian tube dysfunction. Very common with colds/respiratory tract infections. It WILL settle down on its own. Give it time, gentle valsalva (which is what happened when you burped), avoid decongestant use for more than a week and stop the inhalations. Avoid getting your ear drum perforated and save yourself the time and money on an ENT specialist. Not needed. Frustrating advice I know but life is like that. No quick fix. See your doc if not settling after a few more weeks or if you get any new symptoms/pain/discharge.
I should add that this is not medical advice only an opinion from a previous sufferer!
Stewart
scw
Postby geometricnothing » Thu Dec 06, 2012 2:59 pm
WHy stop the use of decongestants and menthol inhalation? The doc told me it could help....
geometricnothing
Postby scw » Thu Dec 06, 2012 3:08 pm
You should stop using decongestant after a week or so - it can cause "rebound" congestion on stopping if used long term.
scw
Postby oggyb » Thu Dec 06, 2012 5:19 pm
I had my ear accidentally perforated by an infection a couple of Christmases ago. It discharged that direction for about 2 weeks, then after about a month it was healed and (afaik) I have my hearing back completely.
It took a while longer to clear my eustachian tube, which wasn't fun, but I just used lemsip and olbas oil, etc., and not too many decongestants.
Just adding my story for extra reference. :crazy:
oggyb
Postby Jack Ruston » Thu Dec 06, 2012 6:59 pm
Doctors are generally quite useless on this. They tend to advise you to do things like try to clear it by holding your nose and 'pushing' air. Don't. You're forcing air into the tube which could cause a further problem. Don't take decongestants because you can dry fluid out in the tubes which leaves deposits you can't remove, thus leading to further blocks. You'll just have to wait.
Oh and don't let them cut a hole in your ear unless you're constantly getting infections.
J
Jack Ruston
Postby geometricnothing » Thu Dec 06, 2012 8:59 pm
Its not the first time its happened in my left (always left) ear. But its never been this bad. its bad enough that I cant work. If i have to wait 2 months, thats 2 months without work....
That would ruin me.
geometricnothing
Postby Madman_Greg » Thu Dec 06, 2012 9:12 pm
Not that I read the Daily Mail. I do have some personal interest in this thread, this is worth a quick read.
Daily Mail article
Madman_Greg
Madman_Greg
Postby Madman_Greg » Thu Dec 06, 2012 9:18 pm
Daily Mail article
The anti gas tablets mentioned in the above are not licensed for this particular treatment in this country. But they are over the counter medicine so readily available to anyone.
Madman_Greg
Madman_Greg
Postby caveman82 » Thu Dec 06, 2012 9:23 pm
I've had exactly this same thing, and it lasted for about two months.
It was a right pain in the behind.
I was referred to ENT (for another thing) which sorted out the problem (kind of) with the fluid behind my eardrum.
I was prescribed a steroid to sort out the eustachian tube so some of the fluid has drained away from the eardrum. It's been a few weeks into the medication, and it's working.
Wait til you see a ENT specialist before anything... They worked out the problem what 7 GP's over 3 years have failed to do.
caveman82
Postby turtles » Thu Dec 06, 2012 9:30 pm
To the original poster:
If you are in the UK, and you are dependent on your hearing for your livelihood, then I suggest it may be worth the £100 or so to see anent consultant at your local private hospital. You can arrange this yourself without a gp referral.
Please ignore the poster above re: 'ear popping' activities being counterproductive. They are incorrect. If you can still POP your ears, this is good as itt means your eustacian tube is still patent intermittently, and the risk of creating a retraction pocket in the tympanic membrane will be reduced.
In addition, if a tympanostomy is eventually required, the mechanical advantage of your ossicular chain will not be adversely affected; the middle ear cleft is designed to work in a fully aerated state, so a drained ear will return your higher frequencies as there is no damping of ossicular motion.
If you are in east mids, pm me.
turtles
Postby geometricnothing » Thu Dec 06, 2012 10:01 pm
turtles wrote:To the original poster:
Im in London....
Havent been able to pop my ears. Just by accident once when i burped.
geometricnothing
Postby Richard901 » Thu Dec 06, 2012 11:55 pm
Otovent
I haven't tried this myself, but it might be worth a try. It has good reviews and I've read that it is used by adults for Eustachian Tube Dysfunction.
http://www.gluear.co.uk
http://www.amazon.co.uk/Otovent-Glue-Ear-Treatment-Pack/dp/B00308F9O6
Perhaps check with your doctor first.
Richard901
Postby turtles » Fri Dec 07, 2012 12:28 am
Otovents and their like, are basically the same as holding your nose and blowing- it's a way of increasing nasopharyngeal pressure to open the eustachian canal mucosa and attempt to equalise the pressure either side of the canal. Kids struggle to do this, hence an Otovent is a balloon on the end of a nasal plug and kids can more easily visualise that- coincidentally the pressure required to part inflate the balloon is usually enough to open the canals and 'pop' the ears.
The problem with a blocked eustachian canals is that the normal air volume in the middle ear cavity is slowly resorbed, and the pressure in the now-sealed middle ear cavity goes _down_ relative to room air pressure. The eardrum retracts inward and becomes tenser as a result, fluid in the middle ear builds up, and the normal action of the ossicular chain is significantly damped. All of these things together make for an uncomfortable listening experience.
I must stress that internet fora are not great places to seek specific medical advice. If you have ongoing concerns, I suggest you see your GP and ask for a referral into ENT on the NHS, stressing the occupational element to your problem. Alternatively, you can pay and see an ENT consultant privately; a quick google search will demonstrate there is significant crossover in consultant staff between NHS and private in London (normal).
turtles
Postby geometricnothing » Fri Dec 07, 2012 1:22 am
I was just inhaling menthol steam for 10 mins, then tried holding my nose and breathing. POP. And a squeak. And a bit of crackle. Things feel a bit better, though theres still liquid there. The slight relief has given me some hope of getting some work in before xmas.
Seeing GP tomorow and private ENT asap.
Theres all kinds of horrible movement in there now. Feels good :)
geometricnothing
Postby OneWorld » Fri Dec 07, 2012 11:30 am
I got a really weird senstaion after having only a very slight cold. A noise almost exactly the dsame as a plastic bag being rustled, but only certain frequencies set it off - running water, plastic bags, cymbals, HiHats etc anythign with a 'white noise' element.
It started after I had a phase of nose bleeds, something I have never had before, that lasted about a month and stopped just as abruptly as it started. Then a few days later the crackling in my ear started. I went to see the GP and she just said "Oh it is fluid on the ear which you get after a cold and it will go after a short while"
I hadn't had a cold. I sort of learned to live with it, a knob of cotton woll in the affected ear blocked out white noise, but of course made hearing a bit one sided. And sure enough after about a month, it stopped within the space of a couple of days.
But after about a month it has returned, the GP is basically saying "Live with it" I suppose she can then tick the box "Satisfactory Outcome"
it does not seem as acute as before and does seem to be getting less frequent so maybe it is on the wane again. What a complex thing the human body is, a miracle of engineering!
OneWorld
Postby caveman82 » Fri Dec 07, 2012 4:18 pm
geometricnothing wrote:OK, I know this is not a recording technique post, but I really need help.
I missed a essential detail, of it being a week since you had the problem. That really is nothing. If it doesn't clear up within a week or two then you should bother doing something serious about it.
Fluid behind the eardrum after a cold is a very common occurence, it usually doesn't last that long.
caveman82
Postby Guest » Fri Dec 07, 2012 4:46 pm
Had the same problem. Are you sure it's behind the eardrum (the middle ear) and not blocked (Eustachian) tubes that drain the middle ear? If there's a cold breeze, can you feel the fluid going cold on the inside of your ear drum? Have you got clicky ears when you yawn? That would be your Eustachian tubes opening and closing.
Doctors struggle with these kind of mechanical problems not easily solved with pills. He might put you on prednisolone, but before you try those steriods (they can make you feel weird), I suggest some methods that helped me:
Common advice: Try yawning with your head back on your pillow (this position helps the middle ear drain). Chew gum, decongestants/nasal sprays. These open up the tubes allowing the middle ear to drain.
Less common -but harmless- methods I discovered by chance:
1. Eat something really spicy with about 3 medium hot chillies in and garlic (this gets the mucas flowing and the garlic kills bacteria in your saliva preventing infection).
2. I noticed while playing Jaw harp that the movement and position of the jaw helped the middle ear to drain (causes the tubes to open and close)
3. Get a didgeridoo (or some long pipe) and learn to play it. The changing air pressure and deep vibrations really shake things up! Might sound unscientific but it worked for me.
General advice for prevention:
1. Never stifle a sneeze (it's got to go somewhere and that could be your middle ear if there's no out.
2. If you have to stop a sneeze, hold your breath, pull your nose forward from the tip and tickle the roof of your mouth with your tongue.
3. Don't sniff. Blow your nose in tiny little bursts
Hope that wasn't patronising, I myself really found this prevented further occurences.
Some Common advice I was more more wary of:
1. Hold your nose, and swallow.
2. Hold your nose and mouth close and gently blow.
3. There's also a manouvre where you hold your nose, take a gulp of air, then push your cheeks in while swallowing so the air blows back into your mouth opening up the Eustachian tubes.
I'm not sure about potential damage with these methods, especially the last two, but they are offered by some doctors.
Guest
Postby Beat Poet » Sun Dec 09, 2012 4:23 pm
I went to a quack about the same thing and the response was just to let it clear on its own. Some people do suffer from glue ear though, which is more debilitating.
Beat Poet
Postby Dilithium » Mon Dec 10, 2012 3:59 pm
I'm currently in the same situation. Have been for about 1 month now. I haven't had any kind of cold, this year (so far) though. It's not hurting, but I can tell it's there. It's very slightly dulling the sound in my ear. central sounds seem slightly off-centre.
After a couple of weeks I went to see the doc. He said there's very little he can do. Two weeks of ibuprofen was his advice... to take the swelling down. The annoying thing about it is I'm finding it really difficult to let out a full-blown yawn. I keep stopping short. Grrrrrr!! I also get short 'pulses' in my blocked ear, a few times a day.
Good to hear the people on here say it should clear in time. After a month I was starting to get worried, but it sounds like I could be in for a bit longer. :frown:
Thanks.
Dilithium
