AKG C1000S MK IV‎
AKG C1000S MK IV‎
Postby aroldi » Fri Feb 08, 2013 12:16 pm
Hello,
is the new version of the AKG C1000S, AKG C1000S MK IV‎, should be different from the previous version in its :Sensitivity, Signal/noise ratio, Equivalent noise level..etc?
thanks
aroldi
Re: AKG C1000S MK IV‎
Postby The Elf » Fri Feb 08, 2013 1:28 pm
One can only hope they've improved it. Heaven knows it really needed it.
Postby Smellthevalve » Sat Feb 09, 2013 1:23 am
I see you posted the same question on gearslutz :)
As far as I can see there is no Mk IV. If it has a presence boost adapter, a red warning light for low battery and is silver in colour and a noise level of 21 dB(A) then it is the same as the MkIII most likely.
The part number for the current model is AKG0075, what part number does the MkIV have?
P.S. I looked on the harman-akg website as well!
Smellthevalve
-<{DH}>-
