Cheap mic suits my voice better
Postby Shambolic Charm » Tue Mar 19, 2013 3:25 pm
I have been coming to terms that after more than 30 years of recording my voice sounds best to me on a cheap Sennheiser E835! I did some quick vocals with it to get some ideas down, then went on to record with some of my better mics. A modded Oktava mk319 ; an SE 2200; An SDK s51 an MXL 2003 and a Shure SM7b. Using the SDK S51 I recorded most of the first verse but not the last line, when I played it back and the last line kicked in my voice sounded so much better! I am a very gruff Baritone with quite a bit of mid range too. The E835 brought out that gruffness nicely and tails off the depth of my voice so it sits well amongst other instruments. I add a gentle rise at around 6k with a wide Q. And it just does it. So I listened back to the old recordings done with the E835 and it sounds better than I have been getting, the only thing near was the Oktava, which I applied a similar boost to and it has more sense of air but still doesn't sound quite as good. It's an uncomfortable feeling admitting that a stage mic works best but I can't deny it. Am i missing something here? Is there something I'm not getting, something I will miss out on not using a more expensive mic?
Shambolic Charm
Re: Cheap mic suits my voice better
Postby Jonny Duddle » Tue Mar 19, 2013 3:48 pm
I'll get in here before anyone else does and say if it sounds right, it is right!
If you think you might be slightly biased, bounce each one out and listen without looking at which is which while you do, then decide.
Or maybe you just got a better performance out of the first!
Jonny Duddle
Postby James Perrett » Wed Mar 20, 2013 9:53 am
With the exception of the SM7, all the mics you list are budget Chinese/Russian large diaphragm condenser mics which don't sound anything like the mics they look like. They tend to have a 'zingy' top end which sounds superficially impressive but which becomes tiring after a while.
I'm not surprised that a mic from a proper mic manufacturer sounds better - after all, they've gone through a proper design process rather than try to emulate someone else's design. There are plenty of famous records where the vocals were recorded with stage vocal mics - often in the control room too.
I'm surprised that the SM7 didn't work though.
http://www.jrpmusic.co.uk
Postby Shambolic Charm » Wed Mar 20, 2013 10:09 am
Actually I looked into this 'zingy' Top end issue before I bought and if you look into it you'll find that both the MXL and the ADK I mention have a circuit that compensates the top end in much the same manner as the Neumann they copied do. The general problem with many chinese mics is they copied the Neumann capsule but not the circuit, which takes the top end peak out. The Oktava MK319 is a Russian Mic and is well know n for being quite 'Dark'. So 'zingy is not an issue.
Shambolic Charm
Postby damoore » Wed Mar 20, 2013 12:00 pm
I am a bass, and I like a similar Sennheiser on my voice. Not sure its the exact same one but at least a relative.
However, I found the Audix OM2 to be even better - the OM5 is better still but its getting out of the "cheap mic" category, though still not expensive.
damoore
Postby Shambolic Charm » Wed Mar 20, 2013 2:44 pm
I've been looking around the net and it's interesting to find that Sinatra recorded a number of records with a Shure 546 which is very closely related to the SM57. I have a 57 but it doesn't compliment my voice still neat to find some of the great vocal recordings were done on a cheapish dynamic.
Shambolic Charm
Postby Hugh Robjohns » Wed Mar 20, 2013 3:07 pm
Shambolic Charm wrote:Am i missing something here? Is there something I'm not getting, something I will miss out on not using a more expensive mic?
The most obvious difference between most general purpose studio mics and most stage vocal mics is that the former have a broadly flat response, while the latter always have heavily boosted presence ranges. That is the certainly the case for all the mics you listed -- and the same applies to the Audix OM2 /OM5 mentioned elsewhere in this thread.
You're probably trying to make your voice sound like something it really isn't... and you need some technological help to achieve that. I would suggest that your voice lacks energy in the presence range, and that's why you prefer the sound of mics that emphasise that area heavily (about +6dB in the case of the Sennheiser and Audix mics) -- and you then push it even further with some additional boost in the same area.
There's nothing wrong in choosing a mic that complements your voice, but there aren't many 'studio' mics that have such strong presence peaks as a typical stage vocal mic.
Postby Matt Houghton » Wed Mar 20, 2013 3:12 pm
There is no 'coming to terms' for you. The same thing happened when we did a vocal mic feature a few years ago and one of the vocalists, having tested a Coles 4038, a C12, a tube 47 and various other expensive and desirable mics found that the Audio Technica AT2020 was particularly wel suited to her voice.
Like her, you can just consider yourself one of the lucky ones. It's the rest of us who have to come to terms with it, while you blow your U47 budget on axes, amps, booze and holidays (or whatever else it is that floats your boat)!
Matt Houghton
SOS Reviews Editor
Postby Hugh Robjohns » Wed Mar 20, 2013 3:20 pm
Matt Houghton wrote:...(or whatever else it is that floats your boat)!
Water works best, I think. I tried mercury once. Floats really heavy boats well, but it gave me a headache and some slightly strange ideas... ;)
Postby Tamika Caleigh » Sun Mar 24, 2013 2:08 am
I have been using the e835's and have been pleased with their performance which is slightly higher than the industry standard Shure SM58.
spam signature removed
Tamika Caleigh
