Mono vs. Stereo Recording for Large Ensemble
Postby JRobPiano » Tue Apr 23, 2013 3:31 am
Hello all,
This is something of a follow up to my previous post on recording choir (thank you for the extremely helpful responses!). The concert is tomorrow and I have decided that I will try the ORTF miking with my matched NT5's with omni capsules as close as I can get without it being in the way.
I realize this is pretty much a complete newbie question, but I decided I would put it out there anyhow. Would it be in my best interest to record into one stereo track or put each microphone into a separate mono track?
Thank you so much for your input. I have learned so much since joining Sound On Sound and it is my sincere hope that I can pass the knowledge I have gained just the same as you all have been so helpful to me!
JRobPiano
Re: Mono vs. Stereo Recording for Large Ensemble
Postby Bob Bickerton » Tue Apr 23, 2013 4:49 am
First up some confusion. Generally speaking you'd use cardioid microphones in an ORTF array.
Read these articles:
Stereo Miking Techniques 1
Stereo Miking Techniques 2
Here's schematic of it:
So if using ORTF use the cardioid capsules on the NT5s.
If you're using the omni caps, then you'd need to use a spaced array (or a Jecklin disk).
I'd opt for the spaced array.
Oh and I'd generally record to two mono channels myself, but it's not a big issue as you could always convert your stereo file to two monos if you had to.
Bob Bickerton
http://www.bickerton.co.nz
