A couple of sounds
A couple of sounds
Postby Biscuits » Tue Oct 14, 2008 5:58 pm
Hi,
In a few months time I am required, as A-level coursework, to produce a multi-track recording of an existing song. For this I've chosen 'Crooked Teeth' by 'Death Cab For Cutie', you may have heard it, maybe not. Basically I have successfully demoed most of the track at home, but there are two sort of swooshing sounds after the first chorus that I can't work out how to get.
The song is here- http://uk.youtube.com/watch?v=UBkQuoIjnJg
They occur at 1:08 and 1:13 ish.
Any help regarding how I'd achieve these sounds would be greatly appreciated!
Danny
(I do realise this is school work, but for some reason I couldn't post in that thred, so sorry and please move it if you can!)
Biscuits
Re: A couple of sounds
Postby coojuice » Tue Oct 14, 2008 6:43 pm
It sounds like a reverse crash with a flanger effect on it to me. Should be fairly easy to replicate.
What DAW are you using?
Get a sample of (or record) a crash, reverse it and add a flanger effect to it.
Hope this helps ;)
coojuice
Postby Biscuits » Tue Oct 14, 2008 7:40 pm
We're using Cubase 4, so that'd be do-able. We have a proper studio at school too so I'll record it in.
I had an inkling it might be that, but wasn't sure, any idea on the second one? It sounds more synthesized...
Thanks for the help!
Biscuits
Postby coojuice » Tue Oct 14, 2008 9:32 pm
There is only that sound that occurs around those times you mentioned. It starts at 1:09 and finished at 1:11.
Are you thinking of the swooshy noise that goes along with the reverse crash? That is the Flanger ;)
coojuice
Postby Jonnypopisical » Tue Oct 14, 2008 10:20 pm
Hi - yea the sound just after the reverse cymbal is a synth resonant sweep in 'self oscillation'. You may be able to find something similar from a sample CD of synth noises or you could program your own using a analogue style synth (real or virtual). Crank up the filter resonance till it 'sings' and then assign the filter cutoff to an envelope generator - the rest I will leave for you to figure out!
BTW - will done for spotting this second more subtle effect - most peps would have not.
JP
Jonnypopisical
Mac Pro, Logic Pro, lots of software and 17 hard drives!
Postby Richie Royale » Wed Oct 15, 2008 9:20 am
I can't hear the track, but you can achieve a "swoosh" using a synth set to white noise. Hold a key and sweep a low pass filter from low frequency to high and you can achieve a swoosh that way. Put a flanger on it for extra flavour.
Richie Royale
Postby Biscuits » Wed Oct 15, 2008 9:08 pm
Thank alot guys, you've been great help ;)
Biscuits
Users browsing this forum: annadrew, Dave B, Dr Huge Longjohns, The Elf
