Things you wish your DAW could do better
Postby Michael Dow » Fri Jul 30, 2010 12:47 pm
HI guys
I'm intersted to know what features you wish your DAW could do better. Or what it doesnt seem to do at all.
Just be interesting to know the gripes people have with their DAW's. Im not at college by the way so this isn't for coursework!
Michael Dow
Re: Things you wish your DAW could do better
Postby ken long » Fri Jul 30, 2010 12:50 pm
Michael Dow wrote:HI guys
Spot mode in Logic.
ken long
I'm All Ears.
Postby steve355 » Fri Jul 30, 2010 1:02 pm
Here's one - I'd like Cubase to have a way of managing production of an album, from initial sketches to mastering. I'd like mixes to be able to be promoted to some kind of final mixes area, and then a specific mastering window (akin to the arrange window but optimised for mastering).
An album management window could provide immediate access to any mix, and automate some key tasks, provide a "make" facility (cf IT programming), an automatically generated to do list, and version control.
I'd also like a feature to make my songs good.
steve355
Postby ken long » Fri Jul 30, 2010 1:03 pm
ken long
I'm All Ears.
Postby SecretSam » Fri Jul 30, 2010 1:06 pm
Ableton Live 8. A notepad would be handy like the one in Cubase. And maybe a slightly smoother Gate plugin. Nothing else whatsoever. I cite it to our developers as the most perfect user interface I have ever seen.
SecretSam
Postby The Elf » Fri Jul 30, 2010 2:05 pm
Cubase:
Tab to transient.
Ability to feed back an FX track send to itself.
Quantise to scale in VariAudio.
Multi-pass mix rendering – to render both offline and real-time effects without seeing the dreaded ‘processor overload’ message at 98% complete.
Ability to apply stretch processes across multiple time-aligned tracks. Currently, doing any stretching of multiple phase-aligned drum tracks is disastrous.
Re-instatement of the Studio Module, so that Cubase gets smarter about MIDI ports and channels.
Drum trigger detection, with crosstalk elimination.
Postby BenLD » Fri Jul 30, 2010 3:01 pm
Logic 9 -
Import a tempo list from another project
(if anyone knows a way of doing this - please tell me!)
Ben
BenLD
Postby Studio Support Gnome » Fri Jul 30, 2010 3:46 pm
easy ben... copy and paste
(i just tested it with both projects open at the same time....)
edit menu, (in temp list editor) select all.
copy
open tempo list editor in 2nd oproject
paste.
job done
No Longer the slightest bit interested in your audio problems .
Postby Studio Support Gnome » Fri Jul 30, 2010 3:48 pm
also tested having closed first project, still pastes happily in to new project.
Postby stinkfinger » Fri Jul 30, 2010 4:00 pm
LOGIC:
1. Pitch shift.
2. Snap.
That is all.
ps. it can already do both these things, but both are truly awful.
stinkfinger
Postby mhaigh » Fri Jul 30, 2010 4:09 pm
Sonar -
-improve notation
-audiosnap is almost impossible to use - simplify and improve
-make track envelopes easier to work with
mhaigh
Postby Paul Nagle » Fri Jul 30, 2010 5:20 pm
Logic:
Transpose to scale
Quantize on record
Record on MIDI note
Transpose of audio parts
Enough banks in environment to allow all my JV2080 cards to be addressed (current limit is around 15 IIRC)
Ability to step-time replace existing note attributes (used this a lot on Cubase)
A drum editor would be nice to have
Would also be nice if it were more configurable in terms of appearance (e.g. screensets aren't remembered across two monitors when you're using the on-board dual monitor outputs).
That's enough for today. :)
Paul Nagle
http://www.bogusfocus.com/
Postby chris... » Fri Jul 30, 2010 10:02 pm
Paul Nagle wrote:Logic:
Oh. Was thinking about a 2-monitor setup. Don't quite follow this - can anyone elaborate on what doesn't work ?
I use Logic screensets alot, and assumed windows in one screenset could be placed on either screen, and recalled correctly.
chris...
Postby desmond » Sat Jul 31, 2010 5:56 am
I've used screensets on dual monitors since Logic 4. Works fine.
"Quantize on record" - what do you mean here?
Logic:
- Bouncing using multiple cores would be nice
Postby Ruaridh » Sat Jul 31, 2010 8:15 am
steve355 wrote:Here's one - I'd like Cubase ...
You need to tick the option "Make songs good", it's hidden it the "Brain to MIDI" menu. ;)
R.
Ruaridh
Ruaridh (Pronounced "Rory").
Cubase 5.5 Guitars & Beer.
Postby BenLD » Sat Jul 31, 2010 9:08 am
Max! wrote:easy ben... copy and paste
copy
paste.
job done
Excellent, thanks Max!
Sometimes the most obvious solution is the last one you think of...
Ben
BenLD
Postby BenLD » Sat Jul 31, 2010 9:13 am
stinkfinger wrote:LOGIC:
1. Pitch shift.
2. Snap.
That is all.
Agreed - and why can't you get the grid and the snap to reflect the quantize value when you're working with triplets? (or can you? he says cautiously awaiting an obvious solution) I'm sure Cubase could do this aeons ago...
B
BenLD
Postby desmond » Sat Jul 31, 2010 9:14 am
BenLD wrote:Agreed - and why can't you get the grid and the snap to reflect the quantize value when you're working with triplets? (or can you? he says cautiously awaiting an obvious solution)
Change the Division value to /12 or /24, rather than /16. It's in the transport.
Postby MarcusH » Sat Jul 31, 2010 10:59 am
Fewer bugs in Logic (though things are improving)
Marcus
MarcusH
You live. You learn.
Postby chris... » Sat Jul 31, 2010 11:47 am
desmond wrote:I've used screensets on dual monitors since Logic 4. Works fine.
Ta.
chris...
Postby BenLD » Sat Jul 31, 2010 12:19 pm
Ah right - cool! I think Cubase used to do it automatically when you changed the quantize value
Perhaps we need more threads like this one - or maybe we should all read the manual
Speaking of which - another gripe - bring back a paper manual please!!!!
Ben
BenLD
Postby desmond » Sat Jul 31, 2010 12:57 pm
BenLD wrote:Speaking of which - another gripe - bring back a paper manual please!!!!
Eek: no - PDF's are searchable* (main reason), you can always have it with you (laptop/iPhone etc), and you can copy/paste out of, and save trees and shelf space.
With large applications, it's getting to the point where maintaining real paper documentation is almost unmanageable (shipping/printing/updating etc). The last major Logic versions (LP6pro/7/8 etc) boxes were something ridiculous like 6kilos. Imagine shipping thousands of those, versus the LP9 boxes...
* This is important because almost no-one *reads* manuals, they are mostly designed to be references - ie you find the appropriate bit containing the info you need at the time. This makes searching a key feature - especially if you don't quite know the exact name or the info you want. Indexing can't really do this for you. Plus you usually get separate update manuals or notes that contain new information or changes to older ones.
I vastly prefer electronic docs these days, and probably an iPad as a reading device (as I type, I'm dragging a laptop around the house reading a book, and it's not comfortable or convenient at all... but that's another topic we've covered to death ;) )
There's no doubt that electronic docs are the future - and as the last generation to be raised on paper books disappears we will be left with a generation more familiar with electronic docs than paper ones - ones that won't say things like "Reading just feels better with "books" rather than on a screen..."
Postby poplab studios » Sat Jul 31, 2010 3:19 pm
Logic>make it stable! :D
poplab studios
Postby Folderol » Sat Jul 31, 2010 4:38 pm
I want mine to improve its intelligence and only record the bits I play correctly.
One of the guitar plugins has a control marked 'Brilliance' but it doesn't seem to help :crazy:
Postby Paul Nagle » Sat Jul 31, 2010 8:16 pm
Do you have a graphics card in your Mac with dual output? If so I believe this works fine. I however use the two standard outputs on my Mac Pro (had to buy a weird little adapter for the second one) and it definitely doesn't remember a screenset that is stretched across the two monitors. I've asked on the Mac Pro forum too. It's weird because other programs I use (Ableton, Wavelab) can remember they're stretched across two monitors no problem, only Logic fails to do so (or did last time I tried).
Quantize on record means auto quantize incoming data so if you're looping a drum part you can build it up by hitting a single key to get ultra-tight kicks etc. hit the key again and keep playing, adding stuff in more loosely, hit the key again and overdub some robotic high hats etc. Very fast to do (and also there's no need to go and bloody well glue all the regions together afterwards). Sorry, just don't like the way Logic maintains all those separate overlaid regions for MIDI. You can tell I'm an old Cubase fan from Atari days eh?
Otherwise, it's ace. :)
Paul Nagle
Users browsing this forum: Stefan Silver and 7 guests
