Single Coil Guitar Hum
Postby Louism » Thu Sep 01, 2011 6:43 am
What is the best way to deal with hum from single coils. I tried getting the guitarist to do the usual stuff as changing pickups etc. but it did not suit his playing ability.Now it is recorded to tape(protools) is there a good method to reduce or get rid of it altogether. It is very brief between notes in some riffs. Is the only way to edit this out which I would like to avoid.
Louism
Re: Single Coil Guitar Hum
Postby Martin Walker » Thu Sep 01, 2011 9:24 am
Hi Louism, and welcome to the SOS Forums! 8-)
If it’s just hum then there are specialist notch filters that can deal with it - you just set the frequency (50Hz or 60Hz) and it will notch out 50, 100, 150, 200 or 60, 120, 180 etc.
If it’s background digital grunge then using a fingerprint filter should do the trick - find a short section containing just the background noise, click on the Learn button, then apply this to the offending bits.
Remember also that with a standard tuned guitar, the bottom E is at 82Hz, so you should be able to roll off anything lower than that.
Good luck!
Users browsing this forum: Jian and 1 guest
