Favourite Mixing EQ?
Postby Mixedup » Sun Oct 09, 2011 2:14 pm
OK, so this is a bit of a silly question - everyone's tastes vary and all that - but I'm curious what people use as their go-to choices for EQ when mixing.
For me, the UA Harrison, Pultec Pro and 1073 get used a lot on individual tracks, and the UA Massive Passive and Brainworx bx_digital V2 get used on groups and sometimes the master buss. DDMF LP10 sometimes for surgical correction, and sometimes in MS mode on a group/buss.
They're not the only ones that get used by a long way, but they'll generally get used more than the rest.
The Abbey Road stuff gets used less than it probably deserves. Sometimes I like the Liquid Mix emulations for adding air. Really not feeling the love for Nebula, but maybe others can convince me with recommendations for impulses.
So... what are *your* favourites?
Mixedup
Re: Favourite Mixing EQ?
Postby Jack Ruston » Sun Oct 09, 2011 3:07 pm
Software...
Waves SSL 4k channel eq gets a lot of use. I use the Massenburg 3 and 5 band quite a bit. Metric Halo Channel Strip also sounds really nice and clean. I occasionally use the Waves Puigtech and other more coloured options but actually in software I often prefer the cleaner options. I also use multiband compressors like the Waves C6 as an eq. The Waves phase linear eq also sees a few outings on vocals.
Hardware...
Pultecs for vocals and bass usually. Again the SSL. GML8200 is worth a trip to the recall sheet.
Overall I'd rather use an 8200 on the mix than a plug in (if that's what I'm doing) but overall I'd rather do the more coloured outboard eq's at tracking so that I dont have to use and thus recall them for the mix. If I can use a clean plug in to nip and tuck when I'm mixing then I'd rather do that.
Jack
Jack Ruston
Postby Mixedup » Sun Oct 09, 2011 6:32 pm
Cheers Jack... I meant to specify software rather than hardware! I've been getting more and more into hardware processing again... loved the Great River Harrison EQs & the Kush Clariphonic. Still don't think the software can touch this stuff (the Harrison certainly doesn't - I ABd the Great River & UA). Hence the question... hardware's just not practical/affordable for me over a full mix.
Mixedup
Postby franciskimberley » Sun Oct 09, 2011 8:22 pm
There are three that get serious usage round these parts:
SSL Duende Channel is usually the first one I fire up for bread and butter duties. I keep it in G mode. It sounds good on just about everything you can throw at it. The way it can add air and sparkle is phenomenal.
The Abbey Road TG12412 is the number 1 colour eq. I still get impressed with the way you can push or pull the gains really hard and it still sounds sweet and musical. Especially good at shaping samples from crusty old Akais and Emus. The TG12414's Presence control is also amazing at lifting snares and vocals.
112db's Redline Equaliser is the third and final. Proper underrated and so versatile. This can shape (or fix) anything and has saved more mixes and masters than I care to think about. Absolutely mammoth. Linear or nonlinear, harmonic distortion controls, dynamic eq, 5 bands each with a selectable response curve and two lowpass and highpass sections... the options go on and on.
There a couple of others that get pulled out every now and again - Bootsy's BootEQ mkII and Stillwell's 1973 - but nowhere near as much as the above.
franciskimberley
Postby Mike Senior » Mon Oct 10, 2011 6:09 am
Cockos ReaEQ. Pricey, I know... :) Just deals with technical EQ tasks in a no-nonsense fashion.
Also URS Console Strip Pro (the Pultec emulation), Stillwell Audio Vibe EQ, DDMF LP10, and recently Sonimus SonEQ. The UAD Harrison does sound fantastic, too, although I tend to save it for high days and holidays.
Mike Senior
Postby The Elf » Mon Oct 10, 2011 7:33 am
Given that I have some lovely hardware EQ that pretty much does everything I ever need, short of replicating itself(!), I’ve frequently considered whether a good software investment would be Waves Q-Clone. Maybe that approach is worth considering for you?
Postby . . . Delete This User . . . » Mon Oct 10, 2011 7:48 am
SSL Duende & Liquid Mix are both "go to" choices.... but there's lots of others also , SPL & Abbey Road, for example, and Waves Q Clone , to make more use of my hardware EQ
depends what is in order..... for surgical CUTTING, then , frankly anything with decent control set up and minimal side effects will do..... whether PT or Logics own plugs, or someone else's .
when it comes to colour , then it gets harder to choose.... i'll often find myself , quite deliberately quickly auditioning 3 or 4 almost randomly chosen EQ's from the available list , to see if anything "happy accident" like happens.... before i will allow myself to gravitate towards my gut instinct choice for the job at hand.... .
(i say almost randomly, it's not really, i more often deliberately look to choices i've not used for a while, and that i wouldn't actively have gone for "based on perceived wisdom" )
using Q-clone is always a good way to expand the application of one's hardware...
and then of course, there's the EQ on the desk....
8-)
Postby Mixedup » Mon Oct 10, 2011 8:52 am
I'd totally forgotten about Q-Clone. :headbang: I do like it, though it's rather a faff. I tend rather to bounce audio through outboard to free it up.
Glad to see I'm not the only Liquid Mix fan, then. It seems to get such a bad press, but it works so well (half the time!).
Mixedup
Postby Guy Johnson » Mon Oct 10, 2011 11:21 am
Sadly I've never tried UAD and Liquid Mix ... Or may of the newer EQs, apart from PSPs ... But here are some of my faves:
Me also, for surgical I always go to Logic's own Channel or Linear Phase EQ (I swap and see which I prefer)
Tritone - HydraTone, ValveTone and especially ClassicTone PEV ... Nice.
Wave Arts - Tube Saturator. Costly on oomph, but RatherNice for ovearall tone shaping
Sonalksis - SV517 mk II
PSP Vintage Warmer II. I love these for broad adjustments of EQ, quite apart form the limiting functions
PSP Micro Comp ... Those sideband filters in 'listen mode' ... Oh, yes!
I have a few more, but never seem to use them.
But I'd love to have some actual EQs I've heard: Decca Passives (with fab new active buffers), A funky 6-way valve graphic, Some Neve channels, SSL channels, and some more I can't remember the names of! BUt even more, I'd like even better monitors in a better room!
Now off to work mixing some classical concerts. This means getting off the net, making a cuppa and coming back to this laptop!
G
Guy Johnson
Postby adrian_k » Mon Oct 10, 2011 4:20 pm
Mixedup wrote:Glad to see I'm not the only Liquid Mix fan, then. It seems to get such a bad press, but it works so well (half the time!).
Me too, me too. It works great for me (now - took a few goes and updated drivers etc) :)
adrian_k
getting better all the time..
Postby marsnic » Mon Oct 10, 2011 4:47 pm
I like the PSP sQuad eqs.
marsnic
Postby twotoedsloth » Tue Oct 11, 2011 12:22 am
Is anyone else using the Oxford EQ? To my ears, it is far better than any of the built in EQs I have (Sound Forge, Vegas, Pro Tools and Cubase) and is subjectively superior to the Izotope mastering bundle.
twotoedsloth
Postby mcguirk » Tue Oct 11, 2011 8:40 am
Recently bought the PSP NobleQ (which is sort of Pultec-like), and I'm using it more and more. It also includes NobleQex, which adds another mid band.
Other than that, my two other go-tos are Izotope Alloy and the Massive Passive model ("Huge Tube") in the Liquid Mix. Between these three, I feel I've got everything I need. Although I still use the built-in Pro Tools EQ for utility jobs.
mcguirk
Postby Zukan » Tue Oct 11, 2011 9:22 am
I'm going through a Nugen and Softube vibe at the moment. Software and affordable.
On the hardware front there are many and I have always been a fan of the MP. The HI Def used to be nice but the legending ruined my early teens. The IBIS is quite nice too but there are so many boutique bits of gear that sound nice that it is almost impossible to pick a fav....API, Millenia, AD2055, GML, Masselac blah blah....and let us not forget the loin vibrating Chandler TC. Jack is about to buy me one for Xmas.
Zukan
Samplecraze   Stretch That Note Masterclasses
Postby Martin Walker » Tue Oct 11, 2011 11:27 am
mcguirk wrote:Recently bought the PSP NobleQ (which is sort of Pultec-like)
I'm enjoying the NobleQ too - so quick and easy to use, and good results every time 8-)
Postby Jack Ruston » Tue Oct 11, 2011 1:39 pm
Ed, if it weren't for the incessant financial demands placed upon me by my wife, my mistress, my girlfriend, seventeen illegitimate children spread across three continents, assorted subscriptions to websites which let you see naughty pictures on your mobile phone, and my eunuch (Alan), it would certainly be yours.
Jack Ruston
Postby 4TrackMadman » Tue Oct 11, 2011 4:13 pm
Vintage Warmer which is not just eq per se...
4TrackMadman
Postby Guy Johnson » Tue Oct 11, 2011 7:17 pm
Off to try the demos, nice one chaps.
Guy Johnson
Postby Sam Inglis » Tue Oct 11, 2011 7:39 pm
I'm a total convert to Fabfilter's Pro-Q. It sounds really good and has the best interface of any EQ I've ever used.
Sam Inglis
Postby Chaconne » Tue Oct 11, 2011 8:30 pm
SSL Duende works on most things, and I also bought this thing called Tilt EQ from softube.
It just pretty much has one knob to emphasise / de-emphasise the treble or bass content- plus some filters. At first I thought it was just a bit of snake oil, but after taking the challenge, I can nearly do a whole mix with it - providing there are no serious corrections needed.
Anyway its a great lesson in the art of simple balance being the main reason for eq.
Liquid mix is lovely, and I use the knobs, looking away fron the screen. A plug-in and controller for that price is excellent value.
Chaconne
Postby Mixedup » Tue Oct 11, 2011 8:45 pm
Yeah, I ilke the Tilt EQ. I also tried the Togu Audio Line one that does the same thing. Really nice and it's free!
I actually never use the controller for the Liquid Mix. I wish there was a native version so I could lose the temperamental box. Alas, I don't have a PT HD system to use that version.
Another one I forgot to mention is the TC Powercore's Dynamic EQ, which is side-chainable. Really really useful that one.
I've not tried the Fabfilter one Sam. Must give it a whirl when I have a spare moment. I must say, though, that I've never really felt any EQ GUI was lacking. I mean... there are a few controls and I set them by ear... or am I missing something?! The only time it bothers me is if I want a waveform display on there, so I can hone in precisely on a problem resonance or over-prominent note or some such.
Mixedup
Postby Zukan » Wed Oct 12, 2011 7:52 am
I understand.
Eunuchs are hard to dress.
Zukan
Postby JamesSimpson » Wed Oct 12, 2011 3:23 pm
Zukan wrote:
I understand.
If this were facebook, this would get a like.
JamesSimpson
Squarehead Jam Jar Facebook Jam Jar
Postby Sam Inglis » Wed Oct 12, 2011 8:17 pm
Mixedup wrote: I must say, though, that I've never really felt any EQ GUI was lacking. I mean... there are a few controls and I set them by ear... or am I missing something?! The only time it bothers me is if I want a waveform display on there, so I can hone in precisely on a problem resonance or over-prominent note or some such.
What I love about the Fabfilter interface is that they've sat down and thought about the best way to interact with a piece of software. It's proper software GUI design, not a slightly adapted virtual hardware interface. You fire up the EQ and are greeted with a blank screen, rather than six bands of three or four controls each -- it only ever shows the information you actually need.
Sam Inglis
Postby Mixedup » Thu Oct 13, 2011 11:28 am
Sam Inglis wrote:You fire up the EQ and are greeted with a blank screen, rather than six bands of three or four controls each -- it only ever shows the information you actually need.
Just had a look. Kinda puts me in mind of DDMF's LP10... though with a bit more clutter. Looks good though.
Mixedup
