How can I find the maximum SPL of my headphones?
Postby ElGreco » Fri Dec 02, 2011 8:35 am
Hello! :)
Is there any mathematical formula to find out what is the maximum SPL that a pair of headphones can produce when connected to a headphone output?
- My soundcard's headphone output (RME Babyface) has an impedance of 30 Ohm and its output level at 0 dBFS is +7 dBu.
- My headphones (Shure SE535) are 36 Ohm (at 1KHz) and have a sensitivity of 119 dB SPL/mW (at 1KHz).
If I play a 1KHz sine wave file at 0dBFS and Totalmix is set to unity gain (0dBFS) as well, then how many SPL am I going to get out of the headphones?
Thank you in advance for your help and I apologize for my ignorance of physics/electronics! :blush:
ElGreco
Re: How can I find the maximum SPL of my headphones?
Postby ef37a » Fri Dec 02, 2011 9:20 am
Well I get that +7dBu is 21mW into 36 Ohms and thus an SPL of 132dB, a seriously loud and damaging level (in fact the phones might crack before that is acheived).
But I bow to my betters if I am wrong.
Postby James Perrett » Fri Dec 02, 2011 10:33 am
Don't forget the 30 ohm output impedance of the headphone amp Dave. With these headphones the +7dBu is into 76 ohms.
James.
http://www.jrpmusic.co.uk
Postby ef37a » Fri Dec 02, 2011 11:01 am
James Perrett wrote:Don't forget the 30 ohm output impedance of the headphone amp Dave. With these headphones the +7dBu is into 76 ohms.
James.
Didn't do that James! I was bit lazy tho' and took the attenuation to be ~6dB giving 0.867V across 36 R.
Waddayouget then?
Postby ElGreco » Fri Dec 02, 2011 11:16 am
Thank you both for your replies! :)
So, the total resistance is 36 or 76 Ohm? Or 66? (30+36)
And what is the formula to calculate it?
Thanks! :)
ElGreco
Postby ef37a » Fri Dec 02, 2011 11:35 am
ElGreco wrote:Thank you both for your replies! :)
Thanks! :)
There are several: First you need to get a voltage from +7dBu (daft archaic nonsense!) and I got 1.74volts. The total resistance is 66R and as I say I took V load to be 1/2 that= 0.867 so from vsqrd/r we get ~21mW.
SPL = 10x log W+S where W is power(21mW) and S is sensitivity( 119dB/mW)=132dB?
Nobody has shouted WRONG yet!
Postby ElGreco » Fri Dec 02, 2011 12:11 pm
If I use your formula and calculate with R=66 instead of R=36 (in your calculation) then the resulting SPL is 129.56dB. Is this calculation correct? The resistance was almost doubled but the result is only 2.5dB lower?
ElGreco
Postby ef37a » Fri Dec 02, 2011 12:33 pm
No because the voltage across the whole system is 1.74V but you only "hear" that votage across the 36R of the phones so,,, ****n you, you have made me work out the ACTUAL voltage! It is 0.936 giving 24mW but that is still just a smidge higher at 132.8dBSPL.
But why do you want to know? Tis just fekkin' loud!
Postby ElGreco » Fri Dec 02, 2011 1:02 pm
Thank you for your time and effort to help me man! :) I wanted to know in order to set my output fader in Total Mix correctly and avoid hearing damage!! Knowing that the maximum SPL is 133 then I could set my fader to -53dB and get 80dB SPL. Please correct me if my rationale is wrong!!
ElGreco
Postby ef37a » Fri Dec 02, 2011 1:22 pm
I see your reasoning (I get 86dB?) but I doubt the fader is anything like accurate enough!
The only way to tell is one of these..
http://www.maplin.co.uk/mini-sound-level-meter-226470 But I would use noise not a sine tone for testing.
Postby ElGreco » Fri Dec 02, 2011 1:56 pm
ef37a wrote:I see your reasoning (I get 86dB?) but I doubt the fader is anything like accurate enough!
The output volume is controlled by a software fader. Shouldn't be accurate enough?
Thanks for the link, but I guess that it would be difficult to measure the SPL of an in-ear phone! (Shure SE535 are in-ear phones)
ElGreco
Postby ef37a » Fri Dec 02, 2011 2:09 pm
"but I guess that it would be difficult to measure the SPL of an in-ear phone"
Don't see why? A bit of rubber tube and gaffer tape? After all you just want a "safety level check" you are not submiting data to the NPL! (or even SoS!)
Bit OT: Can anyone tell me why these in ear phones are so confoundedly expensive? I mean 350 quid buys you more than two pairs of very acceptable "studio" quality phones. (and ones moreover at a very much more sensible impedance!)
Postby ElGreco » Sat Dec 03, 2011 8:12 pm
Well, I bought them for live gigs. I think they are so expensive because they are so small and good sounding!
ElGreco
Users browsing this forum: Hugh Robjohns and 2 guests
