SSL Nucleus headphone output
Postby sambrox » Thu Jan 12, 2012 4:18 pm
Hi all.
Just a quickie. Will I be getting the best from my Beyer Dynamic DT880 Pro headphones with the built-in headphone output of my SSL Nucleus? The DT880s are the 250 ohm variants. On SSL's website, the rating for the headphone output looks like this : Image
To be perfectly honest, those specs go right over my head, so if anyone who's more tech-savvy would help me out, that'd be much appreciated.
Cheers!
Sam
sambrox
Re: SSL Nucleus headphone output
Postby Jonnypopisical » Thu Jan 12, 2012 4:33 pm
Call me crazy but why don't you plug them in and try them :headbang:
Jonnypopisical
Mac Pro, Logic Pro, lots of software and 17 hard drives!
Postby Hugh Robjohns » Thu Jan 12, 2012 4:53 pm
The Nucleus headphone amp is quite respectable and it will work fine with your Beyers. However, if you are particularly demanding there are better standalone headphone amps out there, like the Benchmark DAC1, the Grace Design M903 and several others...
But I'd get used to the Nucleus first and decide whether or not it does what you require before looking for alternatives. I suspect you'll be quite happy with it.
Hugh
Postby Guest » Thu Jan 12, 2012 10:21 pm
Off topic a little but to the OP - you have a Nucleus obviously and it's something on my wish list. But I also want to get a slave PC and VE Pro to link to my master PC - the slave will be running my samples and the master my DAW etc. VE Pro handles the network side of things between the 2. It uses ethernet.
So, onto my question - am I right in thinking that the Nucleus also uses the ethernet to connect to the DAW as if so, I can't use both by the sounds of it
Thanks and sorry for off topic Q.
Guest
Postby Jabba1 » Fri Jan 13, 2012 12:13 am
skipstream wrote:Off topic a little but to the OP - you have a Nucleus obviously and it's something on my wish list.
+1. :headbang:
God yes... I could afford it but doubt I've got the talent to make such an investment justifiable! :blush:
Jabba1
Postby sambrox » Fri Jan 13, 2012 11:12 am
Yes yes, but what I wanted to know was if I would be getting the best out of them. Obviously, that's hard to know when you have nothing to judge it against... :headbang:
Ah, thanks Hugh. That was the answer I was hoping for!
It does indeed use the ethernet port for the control surface functions, whereas the audio interface functions via USB.
I'm not sure I have the talent either, but I landed a couple of lucky punches and scored a couple of ad jobs. This one earned me the equivalent of £12,500, so the missus couldn't complain too much about me spunking two-and-a-half on the SSL :D
Cheers all!
Sam
sambrox
