Transferring old tapes
Postby twotoedsloth » Wed Feb 01, 2012 6:30 pm
Hello,
I've been given a stack of 1/4 inch 3 3/4 ips tapes to transfer to CD. Is there a reason why I can't transfer these at 7.5 ips and then transpose down an octave before burning the discs?
Thanks all.
twotoedsloth
Re: Transferring old tapes
Postby Nebulae » Wed Feb 01, 2012 9:02 pm
Artifacts from the transpose?
Nebulae
Postby Exalted Wombat » Wed Feb 01, 2012 9:09 pm
twotoedsloth wrote:Hello,
The playback eq curve on the tape deck will be wrong. You'll be asking the signal path to deal with frequencies twice what it's designed for.
But then, cassette playback with Dolby switched off SHOULDN'T be an improvement, but sometimes is! Try it and see. Results may be acceptable.
Exalted Wombat
Postby ken long » Wed Feb 01, 2012 9:59 pm
apart from EQ already mentioned - there might be other considerations:
1. If this is a paid gig transferring at 7.5 will obviously mean the job is finished double quick. Good if you factored per tape. Not so good if you based your valuation on time.
2. what are the tapes holding? I'd be loathe to playback unique recordings, particularly music performances, at double the recorded speed. 3.75 was never "excellent", but why make it worse?
I'd hire out another tape machine and do a parallel ingest. Use error analysis software post transfer to point out any clicks or dropouts.
If you really must use 7.5, I would advise a high sample rate. 88.2 - 192 if you can, before you pitch it down digitally.
ken long
I'm All Ears.
Postby twotoedsloth » Thu Feb 02, 2012 12:15 am
Thanks so much for your responses. It's not really a paid job, I might get a coffee card out it if I'm friendly and lucky. They are live concert recordings of a classical pianist (former university professor where I work) made between 1982 and 1991. There are 22 tapes to be transferred.
The main problem (aside from time and lack of interest) is that my predecessor got rid of most of the old tape decks, so now the only quarter inch deck we have is a Revox that will only do 15 ips or 7.5 ips. I guess I will have to track down a machine that will do 3.75 ips.
How serious do you think the EQ curve issue is? Obviously, recording at 88.2, it is trivial to reduce it to 44.1 since there will be no altered samples.
The only bright side to this project is that they are live concert recordings, so I don't need to go through the tapes to find the splices and retape them.
twotoedsloth
Postby ken long » Thu Feb 02, 2012 1:08 am
I'd be concerned with getting correct azimuth before worrying about the EQ to be honest. But yeah, if you can get it right, it's worth doing right. Shouldn't be hard to get hold of a slower machine but without a budget, you may have to just cut some corners. Is it a PR99 Mk3 by any chance?
ken long
I'm All Ears.
Postby James Perrett » Thu Feb 02, 2012 9:56 am
Unless your deck is optimised for higher than audio frequencies (as some duplication decks are) you will find that transferring at 7.5ips will cause the high frequencies to be lost. A typical deck (say a Revox A77) may handle up to 16kHz at 3.75ips and 20kHz at 7.5ips. If you play the tape at 7.5ips and then slow the recording down digitally you'll end up with the frequency response tailing off at 10kHz.
As Ken says, azimuth adjustment is also more critical at slow speeds.
So it isn't a great idea to do what you propose although you might get away with it for non-critical tapes.
James.
http://www.jrpmusic.co.uk
Postby Folderol » Thu Feb 02, 2012 6:14 pm
I really don't think there is any alternative to running them at the correct speed for reasons as above. Also, if you have the time do do the job thoroughly adjust the azimuth individually for each tape - on a listening test a little way into the tape set for maximum treble content. If you can get a professional machine with three point head adjustment, also consider adjusting head height for minimum cross-talk.
Postby twotoedsloth » Fri Feb 03, 2012 2:12 am
It's a Revox G36. Strangely a couple of websites I've browsed say it offers a 3.75 tape speed... I'm quite sure this one doesn't.
This seems like a job more suited to an archivist rather than a recording tech.
Thanks for your suggestions.
twotoedsloth
Postby ken long » Fri Feb 03, 2012 10:03 am
yes, apparently there's a switch (No.3) for 7.5 / 3.75. Maybe not on your model?
ken long
I'm All Ears.
Postby James Perrett » Fri Feb 03, 2012 10:12 am
I've never heard of a high speed G36 although high speed A77's and B77's were fairly common. Has it been modified perhaps? Could you remove the modifications to make it work at 3.75ips?
James.
Postby Hugh Robjohns » Fri Feb 03, 2012 10:58 am
It might be that a collar or sleeve has ben added to the capstan to double its diameter, or that the motor has been replaced for one with a double-diameter shaft or spindle. It wasn't an uncommon modification...
An alternative suggestion is to borrow or acquire an old Akai DS4000 or similar -- in fact any reel-reel machine intended for domestic use. They would be more likely to have the 3-3/4 ips setting. (The Akai changed speeds by unscrewing a cap on the capstan and adding or removing a sleeve!).
Or... the Studer A807 has three speeds including 3-3/4 ips if you can find somewhere or someone with one of those...
Hugh
Postby Exalted Wombat » Fri Feb 03, 2012 11:42 am
twotoedsloth wrote:Thanks so much for your responses. It's not really a paid job, I might get a coffee card out it if I'm friendly and lucky. They are live concert recordings of a classical pianist (former university professor where I work) made between 1982 and 1991. There are 22 tapes to be transferred.
I think you have enough information now to go back to whoever commissioned the work, explain what is possible with the equipment you have and point out that results may not be perfect.
They may be assuming it's a trivial job.
Exalted Wombat
Postby twotoedsloth » Sat Feb 04, 2012 2:59 pm
Well, it was worth a try. This morning I tried to transfer a few minutes of one of the tapes at 7.5 ips 88.2khz resolution, and it sounded horrible, before and after transposing down 1 octave. Thin and scratchy, yet muted at the same time, in short, awful.
So now I get to hunt for a tape machine that will work at 3.75 ips.
Thanks everyone for your helpful suggestions, advice and observations.
twotoedsloth
Postby twotoedsloth » Mon Feb 13, 2012 10:19 pm
Does anyone know anything about Uher? I'm not familiar with them. I've been offered a 4 track stereo (I assume they mean 2 tracks one way, and two tracks with the tape reversed) quarter inch recorder/player that will do 3.75 ips for $20. Obviously, for the money I can't lose, but I need to go and get it, which will take a couple of hours.
Your advice, please, kind folks.
twotoedsloth
Postby Hugh Robjohns » Mon Feb 13, 2012 10:27 pm
Uhers were used widely as broadcast (radio) location recorders. Loads of stuff on the net about them. I think all models we restricted to 5 inch spools... But maybe there were larger machines.
Hugh
Postby twotoedsloth » Mon Feb 13, 2012 11:13 pm
Thanks for your response. Someone on this thread earlier recommended a consumer model tape deck, I believe this Uher is a professional model. Also, it may or may not only work with 5 inch reels. I understand the seller in that for $20 I shouldn't expect too much from him, and he doesn't even have the manual anymore.
Do you think it's worth the 2 hours or so commute to pick it up? And is it even possible to carry one of these recorders on public transit, or will I need to hire a cab (which will certainly cost more than the unit)?
Thanks,
Peter
twotoedsloth
Postby Mike Stranks » Tue Feb 14, 2012 8:11 am
As ever, you'll find Google is your friend...
A very quick search found this:
Uher Tape-recorder
which shows that they did make machines other than the portables. (I thought I recalled that they had done, but couldn't be sure. Very rare beasts in the UK!)
The page I've referenced gives all the info including the weight.
Suggest you need to talk to the seller to find out the model number and whether it's in full working order.
Postby James Perrett » Tue Feb 14, 2012 9:55 am
As others have said, you need to get the model number from the seller. If he's calling it a professional it is likely that it is one of the smaller portable models as I don't think any of the larger models found their way into professional use. These can be easily carried on public transport. Just be aware of the 5 inch reel limit on the smaller recorders.
Personally I would treat one of these machines as an interesting curiosity - while it may make some sound, it may well need some work to get it working properly as rubber belts and idlers could have deteriorated. Be prepared to spend a little time bringing it up to full spec.
James.
Postby Folderol » Tue Feb 14, 2012 6:30 pm
Hmmm. Mentioning Uher reminds me I probably have access to a Report 4400 which I think is in reasonable condition.
Where in the country are you? If it's not a million miles away I might be able to arrange a loan.
Postby Exalted Wombat » Tue Feb 14, 2012 8:17 pm
Folderol wrote:Hmmm. Mentioning Uher reminds me I probably have access to a Report 4400 which I think is in reasonable condition.
Yes, where are you? There's an Akai 4000D in a cupboard here (East London.Essex). Can't guarantee the rubber bits are still usable though.
Exalted Wombat
Postby James Perrett » Wed Feb 15, 2012 9:50 am
From looking at the email in his profile, I suspect that Canada is a little too far for you.
James.
Postby ken long » Wed Feb 15, 2012 4:28 pm
twotoedsloth wrote:Well, it was worth a try. This morning I tried to transfer a few minutes of one of the tapes at 7.5 ips 88.2khz resolution, and it sounded horrible, before and after transposing down 1 octave. Thin and scratchy, yet muted at the same time, in short, awful.
Leaving aside all other factors, have you checked the heads are still useable? And if so, have you given them a thorough clean? A Q-tip imbibed in Iso=propyl alcohol should do the trick.
ken long
I'm All Ears.
Postby Folderol » Wed Feb 15, 2012 4:45 pm
James.
Ah! Yes, that would be a bit of a problem :roll:
Postby twotoedsloth » Thu Feb 16, 2012 5:29 pm
Thank you for your kind offers to lend me an open reel tape deck, but as you've already noticed, I'm a bit far away here in "the colonies".
So, I went to pick up the Uher recorder... and found out it is actually a Sony "stereo center 230". Not sure how the seller thought it was a Uher. Again, for $20 I guess I can't expect much.
Anyways, it does do 3.75 ips, so I should be good to go.
If I could bother you with one more question, is there anything I should do with the tapes? A colleague suggested I play them back in reverse, and then flip them before burning the CD. He tells me it will preserve the transients. Is there anything to this? I remember being told years ago to store tapes tail out, but I don't remember why.
A final note... what you guys used to call portable is insane. This "portable" recorder must weigh at least 25 pounds.
Thanks,
Peter
twotoedsloth
