KRK VXT disaster... Put me off now...
Postby Persuazion » Sun Mar 04, 2012 11:08 pm
So... I just replaced my Mackie 824s with a pair of VXT 8s. It was a rather rushed choice as one of our 824s packed in during a session and we needed to replace them for the following day. I'd used VXTs in another studio and was pleased with how they translated, so I've always had my eye on them and went ahead and ordered from DV.
That was on the 8th of Feb so 26 days ago. Today, I thought someone's amp was rattling like mad somewhere but low and behold, it turns out to be the right monitor! :headbang:... Seems to be the tweeter (or tweeter amp?) A very fizzy distortion that even sounds digital. Desk outputs have been swapped round but the same monitor has the same problem.
So now I'm back where I was 26 days ago!
I'm guessing (hoping) I'll be covered for returns at DV (although it could prove a headache like it has in the past!) and it was purchase on a credit card. But now, I'm wondering if i even like the VXTs at all! Particularly after this. And having to return them asap and get replacements asap (in the same price range) is stressing me out somewhat!
The main, perhaps only thing I don't really like about the VXTs is they do seem a tad fatiguing to work on after a while -something people I've heard mentioned in the past. I do like the richness and apparent tightness of the low end on them though.
I'm completely unprepared for this but I really need to get replacements ordered by tomorrow! At least I had some previous experience with the VXTs but I have no idea what else to look at in the £900 bracket. Monitors haven't been something I've paid much attention to. Once you've got the ones you want, that's kind of it. Unlike preamps etc where you're constantly keeping up with them and know what's out there.
So... Queue horrible, cliche question.... What active, accurate monitors are out there for £900ish that i should consider? Really pushed to go beyond 900 but still keen to hear any thoughts.
Thanks guys. :x :headbang:
Persuazion
http://www.loverslanestudios.co.uk
Re: KRK VXT disaster... Put me off now...
Postby John Willett » Mon Mar 05, 2012 7:09 am
At that sort of price I would go for the Neumann KH120A - retail at £1,199 a pair (£599.50 each) including VAT (so, if you are VAT registered.......)
Not sure what the street price is - but these do seem to be the top of the tree at the moment in this price bracket.
John Willett
Postby Hugh Robjohns » Mon Mar 05, 2012 10:43 am
I'd +1 that. Although they are physically small they kick well above their size and the quality is very impressive, bery neutral, and not at all fatiguing. And if you need more volume or bottom end, a matching sub can be added later.
Hugh
Postby Persuazion » Mon Mar 05, 2012 11:10 am
Thanks guys, but this is horrible! :frown:. I'm shopping completely in the dark. And even just going over by £100 at £1,119 isn't going to be easy! We've lost out on a lot of work because of this (session cancelled today and I'm sure tomorrow may be the same)
Funnily enough the Neumanns are among the only monitors that have caught my attention lately! Intriguing that you should mention them now too.
My only worry now is - I've seen a few references to the sub... Is that really needed or are they pleasing enough on their own in the bottom end? The bottom is something I really need as I can be flicking from a Rock/Pop project to Electronic, bass heavy/subby stuff all the time.
:? :? :? :? :? :? :headbang: :headbang: :headbang: :headbang: :headbang: :headbang:
ADVICE PLEASE :) - Do you think I have enough time to sit on this for the afternoon before contacting DV? We took receipt of the KRKs 27 days ago and payment went through 29 days ago. I'd like to have a plan in my head before getting in touch.
Persuazion
Postby Richie Royale » Mon Mar 05, 2012 11:13 am
I would contact DV. 4 weeks isn't reasonable wear and tear.
Maybe consider the AE22s? Might not have enough low end for your applications, but certainly a good monitor.
Richie Royale
Postby Persuazion » Mon Mar 05, 2012 11:44 am
Richie Royale wrote:I would contact DV. 4 weeks isn't reasonable wear and tear.
Thanks Rich. Yeah its not on at all. I'll need to bite my tongue as there was a big problem with ordering the KRKs from them in the first place. Its maybe not DVs fault, I know the buck ultimately stops with KRK, but the seller has to assume some responsibility too.
So the AE22s are a bit bass light you think?
Persuazion
Postby Persuazion » Mon Mar 05, 2012 11:50 am
I should have said its a balance of say 70/30 between Rock/Pop and the Really subby, electro work that I get so I'm not a complete bass head 100% of the time ;) EDIT - oohhh.... just saw the 22s only go down to 60hz. That may be an issue. Mind you... At least they actually HAVE some numbers with the,m. What do the Neumanns go down to?
Persuazion
Postby Hugh Robjohns » Mon Mar 05, 2012 12:03 pm
It depends if you want something that flaps the trousers and reorganises the internal organs of you and your clients, of if you want something that allows you to hear whats going on and deal with it. Both the AE22 and the KH120 have a decent bass response -- I wouldn't describe either as bass light -- and both will let you hear exactly what's going on. But neither will blow dry your hair each time the kick drum is thumped -- at least not without a sub.
To my ears, KRKs tend to be a bit boom and tizz, with an emphasis on both that makes them initially impressive but ultimately fatiguing. The KH120s and the AE22s are more honest speakers, for slightly different reasons. I know plenty of people who are happy mixing rock/pop on both without issue.
Hugh
Postby Persuazion » Mon Mar 05, 2012 12:48 pm
Thanks Hugh.
I know its all numbers on paper but I'm a tad worried... The VXTs go all the way down to 37hz. Thats a pretty major drop from only 60 odd hz. I know its different on test so, do you think I'll hear a major drop in the bottom end with either the AEs or Neumanns compared to the VXTs?
It's using sub kicks, sculpting sub basses etc that I'm worried about. I've used KRK Rokits (the biggest they do. 6s?) and just couldn't use them without a sub as I couldn't tell what was going on down there.
I also need to get on to DV as soon as I can think of a suitable replacement! :?
Persuazion
Postby benniferj » Mon Mar 05, 2012 12:50 pm
Why have you not already called DV to see if they can ship out a replacement VXT on special delivery for tomorrow?
benniferj
Postby Persuazion » Mon Mar 05, 2012 12:51 pm
I should also add that i found the bottom end not too bad on my Mackie 824s.
Persuazion
Postby Persuazion » Mon Mar 05, 2012 12:56 pm
benniferj wrote:Why have you not already called DV to see if they can ship out a replacement VXT on special delivery for tomorrow?
Good point but I'd much rather get these out and new ones in asap. Also worried about the 30 day mark coming up in a couple of days. Plus its been a bit of a nightmare in the past to work with DV (Just my experience, sorry) so I'm not sure it would be as easy as - ''yeah sure, here's another one. Just send that and the other 2 back when you're done and we'll then ship out another pair altogether when you've decided what ones you want'' :roll: I could be wrong.
I've set a target to call them before 2pm though. It'd be great if I could come to some plan in my head first.
Persuazion
Postby Hugh Robjohns » Mon Mar 05, 2012 1:03 pm
Persuazion wrote:I know its all numbers on paper but I'm a tad worried... The VXTs go all the way down to 37hz.
That's 37Hz at -3dB, below which it drops like a brick because it's ported. The KH120 is quoted as 52Hz at -3dB and is also ported. The AE22 is quoted as having a -3dB LF point at 60Hz, but it's a sealed cabinet and has a very slow roll off.
The differences are roughly a musical fouth/fifth (E1 to A1 and Bb1)... but the roll offs are such that I doub't you'd notice much difference in LF extension in practice. Added to which, they're all capable of exciting your room modes which will cloud the issue nicely.
I think you'll notice the different quality of bass rather than the extension.
hugh
Postby Persuazion » Mon Mar 05, 2012 1:43 pm
Thanks Hugh that's great.
Well the AE22s come in under budget. But, thinking about it, +£100 isn't much if there's a notable quality (for want of a better word) difference between the AE22s and Neumanns.
It seems you, Hugh are more swayed by the KHs? Is there one of the two that would provide the 'lushest', fullest bass response in your opinion?
Persuazion
Postby Hugh Robjohns » Mon Mar 05, 2012 2:13 pm
The solidity and germanic engineering of the KH would sway it for me. AE22s are great, and I'm a huge fan of sealed box cabinets because of the much better quality of bass, gentler roll off, and greater extension.
The KH120 is also a remarkable speaker in that it delivers far more than you would think possible in such a compact box, and is wonderfully refined and revealing.
But I would strongly advise a personal audition as monitors are quite a personal choice, and I don't know what your expectations and requirements are.
Compared to the KRKs, I think you'll probably find both initially lacking in bass power because they don't 'thump' like the KRK does. For me, that's a good thing (for a monitor) and I think once you're familiar with them you'll actually find it easier to make descisions about the bottom end beacuse they are both more accurate -- albeit in slightly different ways.
But if you need to 'feel' the bass then you might want to look at alternatives, or think about adding a sub. But you'd be hard pressed to get better for the budget you've set.
hugh
Postby Persuazion » Mon Mar 05, 2012 2:22 pm
Right.... Well I'm now armed with some good info. Add to that that I've noticed the single KH 120s are in stock while the AEs are not.
I may well have to go for the Neumanns and see how I get on.
Do you think I'd be cheeky, considering there have been a few bumpy moments on DVs part throughout this transaction, to say I may well have to change these yet again after a trial?
Thanks for all the info guys. I'll et on the blower asap.
Persuazion
Postby Persuazion » Mon Mar 05, 2012 2:39 pm
Doh! :headbang: Just realized the KH 120s are actually £200 more! Maths was never my strong point :blush:
Persuazion
Postby mjfe2 » Sun Mar 11, 2012 5:42 pm
At that price is it worth considering Quested S6R's too?
mjfe2
Postby Persuazion » Sun Mar 11, 2012 11:13 pm
I'm all sorted folks!
Got a nice deal on a pair of AE22s and Pro Sub from a nice fellow SOS'er! Haven't had a chance to install them yet.
Persuazion
Postby John Willett » Mon Mar 12, 2012 8:43 am
Persuazion wrote:Doh! :headbang: Just realized the KH 120s are actually £200 more! Maths was never my strong point :blush:
The DV price for a pair of KH120As is only £1,078.00 - so you are saving about £120 off the normal pro-user price. :D
John Willett
Postby Nites » Tue Mar 13, 2012 3:45 pm
I bought a pair of KRK's Rokits based off a SOS review which said they were none fatiguing and had a quite flat frequency response. After reading this I'm now regretting and should have probably bought Yamaha MSP5's instead for the same price. My only reference at the time were headphones and hifi speakers.
But anyway why are KRK's so popular at trade shows? Particularly at synth demonstrations.
Nites
Postby James Perrett » Tue Mar 13, 2012 5:16 pm
Possibly because KRK lend demo models to other exhibitors?
James.
http://www.jrpmusic.co.uk
Postby Persuazion » Fri Mar 16, 2012 12:46 am
James.
And after my experiences, I'd say they do sound instantly impressive (the VXTs anyway) so that may be a factor in that decision. I'm loving how 'un impressive' these AE22s sound. Rather comforting :lol:
Persuazion
Postby MartinJG » Mon Mar 26, 2012 9:33 pm
Hugh
I have a pair of AE22's. Great monitors but I have a problem with what sounds like digital 'buzzing'. I have an M-Audio 2496 card. My old P4 was fine but I now have a 2500K Sandy Bridge and have had all sorts of noise problems (squeeks, buzzes, you name it)which I believe are the well known PCI/Sandy Bridge issues. I have disabled the EIST settings etc on the BIOS but this has made no difference to the AE22's. The odd thing is that my old Roland MA-8 media style monitors are fine. Is this down to lack of shielding on the AE22's? Driving me mad. I have pretty much exhausted most of the standard diagnostics tests with no luck. Even tried running the AE22's through the on board sound card Realtek (ASUS P8P67LE)and the noise gets worse which suggests it is not a PCI issue? I would add that the buzzing goes when I use a cheap Skytronic isolator but it also wrecks the dynamics on my monitors. Baby and the bathwater syndrome. Is the only remaining option to try a decent ground loop braid breaker box? I am worried that this could also muzzle my AE22's which are very sensitive things. Any ideas?
Many thanks
MartinJG
Postby James Perrett » Tue Mar 27, 2012 8:22 am
Martin - if the AE22's have balanced inputs then you need to make up some phono to XLR (or jack) pseudo balanced cables. Connect the tip of the phono plug to pin 2 on the XLR and the outer of the phono plug to pin 3 of the XLR using the 2 cores of a 2 core + screen cable. Connect the screen of the cable to pin 1 of the XLR but leave it disconnected at the phono end.
James.
