High Pass . . . Low Shelving ?
Postby Situation » Wed Apr 25, 2012 12:33 pm
What's the different between a high
pass filter and a low shelving EQ
Situation
Re: High Pass . . . Low Shelving ?
Postby Sam Inglis » Wed Apr 25, 2012 12:36 pm
A high-pass filter progressively eliminates more and more of the frequencies below the cutoff point, whereas a low shelving cut attenuates all frequencies below the cutoff point equally.
Sam Inglis
Postby Situation » Wed Apr 25, 2012 1:17 pm
thanx
Situation
Postby SafeandSound Mastering » Wed Apr 25, 2012 2:53 pm
Have a little look here:
How to use an EQ
Cheers
Postby Hugh Robjohns » Wed Apr 25, 2012 2:59 pm
This image shows the effect of a 3rd order (18dB/octave) high-pass filter with a turnover at 100Hz (green line), and a low shelf cut of -12dB, also set to 100Hz (blue line) on a white noise signal (red line).
As you can see, the high pass filter's slope just goes on down, providing ever-more attenuation as the frequency gets lower, where as the low shelf looks just like a shelf -- it reduces the signal to a set level below the turnover frequency, but no more.
Shelf equalisers can also boost the signal, whereas a filter can only cut.
Hugh
Postby Hugh Robjohns » Wed Apr 25, 2012 3:08 pm
SafeandSound Mastering wrote:Have a little look here:
How to use an EQ
Or you could look here:
SOS EQ Exploration
or here:
SOS Equalisers Explained
or here:
SOS Using Equalisation
or here:
SOS What's the Frequency?
or here:
SOS EQ: How and When To Use it
hugh
Postby Andi » Thu Apr 26, 2012 9:27 pm
How to use an EQ
SOS EQ Exploration
or here:
or here:
or here:
or here:
hugh
So I'm getting that this so-called "EQ" stuff is important then?
Andi
Postby Stef Andrews » Thu Apr 26, 2012 9:55 pm
I wouldn't bother with EQ - just cover up any mess with masses of reverb and delay!
However, those articles are all excellent. Well worth the time it takes to read through them!
Stef Andrews
