Reverse Gear
Reverse Gear
Postby Situation » Sat May 26, 2012 7:11 am
I know an expander is a compressor in reverse but when you reverse a vocal and apply compression it yields different results and am wondering would that be regarded as expansion
Situation
Re: Reverse Gear
Postby Hugh Robjohns » Sat May 26, 2012 6:11 pm
No! It's a compressed reversed vocal!
An expander is not 'a compressor in reverse' in the timeline sense.
It is a dynamics processor with a 'reversed ratio', since where a compressor might have a ratio of 2:1, an expander might have a ratio of 1:2.
Hugh
Re: Reverse Gear
Postby Situation » Sun May 27, 2012 8:29 am
What the difference between upward and downward expansion
Situation
Re: Reverse Gear
Postby Hugh Robjohns » Sun May 27, 2012 2:01 pm
The direction!
Upward expansion expands the dynamic changes above the threshold. Downward expansion expands the dynamic range below the threshold.
Hugh
Re: Reverse Gear
Postby Situation » Sun May 27, 2012 2:30 pm
Hugh Robjohns wrote:The direction!
Hugh
Meaning for downward expansion softer sounds below the threshold a made even quieter and for upward expansion sounds above the threshold a elevated 'ight
Situation
Re: Reverse Gear
Postby Hugh Robjohns » Sun May 27, 2012 4:12 pm
Correct
hugh
Users browsing this forum: matthias4950 and 1 guest
