Just out of intersest: What program are people here using to stretch pitch and time on vox?
Postby alexis » Mon Jun 04, 2012 9:02 pm
Thanks!
alexis
Re: Just out of intersest: What program are people here using to stretch pitch and time on vox?
Postby The Elf » Mon Jun 04, 2012 9:15 pm
Cubase's own VariAudio does 90% of what I need these days. The seamless integration is a huge winner, making adjustments and re-work very simple. Thankfully it also sounds pretty good too.
Postby desmond » Mon Jun 04, 2012 11:31 pm
Logic flex or Melodyne, depending on the needs of the task.
Postby alexis » Tue Jun 05, 2012 4:30 am
The Elf wrote:Cubase's own VariAudio does 90% of what I need these days. The seamless integration is a huge winner, making adjustments and re-work very simple. Thankfully it also sounds pretty good too.
Thanks for that, The Elf!
What kind of situations do you find challenge VariAudio consistently? Certain kinds of singing styles (raspy, or swooping into the notes), or maybe something else like how it handles multiple parts?
The not having formant correction - I'd think that'd be challenging, but maybe not?
Thanks for any further awesome insights!
alexis
Postby The Elf » Tue Jun 05, 2012 10:00 am
Formant correction is unimportant for slight changes (and if you're looking for more than slight changes then VariAudio is maybe not the tool for the job).
VariAudio can sometimes create a garbled sound on certain notes. I've not discovered a consistent pattern to the problem. It's just something you have to be aware of - editing the pitch detection bars usually cures it. The longer you spend editing the pitch detection before applying any correction, the better the results are. Often I'll reduce the corrected portion to a fraction of the overall note length and that's enough to sound corrected without sounding obviously processed. Removing detection from consonants and breaths is not always necessary, but if you spend the time doing it you're more likely to get something you like at the end.
Multiple parts are fine. If the going gets tough for your computer then you can always flatten the processing.
And yes, correct only that which needs correcting.
Postby Bossman » Tue Jun 05, 2012 10:07 am
I use Melodyne
Bossman
Postby Jonnypopisical » Wed Jun 06, 2012 10:51 pm
Serato Pitch n Time
Jonnypopisical
Mac Pro, Logic Pro, lots of software and 17 hard drives!
Postby G-Doubleyou » Thu Jun 07, 2012 1:38 pm
desmond wrote:Logic flex or Melodyne, depending on the needs of the task.
+1 The Melodyne plug with DNA( Direct Note Access ) allows you to get inside of chords, great for adapting Keyboard, and horn phrases.
8-)
G-Doubleyou
G-Dub Studio G-fx 15inch quad-core i7 Macbook Pro Logic9.1.8, LPX 10.0.3
Postby sambrox » Thu Jun 07, 2012 2:01 pm
Melodyne Editor (with DNA) for pitch duties, Logic's Flex function for timing issues (it's a little more user-friendly than Melodyne for this).
sambrox
Postby alexis » Thu Jun 07, 2012 10:49 pm
The Elf wrote:...
Thank you The Elf and everyone for some great and helpful answers!
Do people find that these programs have a harder time correcting raspy, sandpaper-cigarette-whiskey singers (like Ray Charles, early John Lennon, Mitch Ryder) than smooth voicers?
alexis
