Pads
Pads
Postby MattDrummerUK » Fri Jul 06, 2012 6:34 pm
So I have the option to use a pad at the mic or at the desk, one is a 10db pad at the mic the other is a 26db pad at the desk. Is there a preferred method or does it not really matter which one I use. Obvious they will pad out a different amount of sound but if they were the same would it make any difference or would there be any advantages in one over the other?
Matt
MattDrummerUK
Re: Pads
Postby MattDrummerUK » Sat Jul 07, 2012 12:43 am
Sorry it's a 20db pad on the desk.
MattDrummerUK
Re: Pads
Postby Bossman » Sat Jul 07, 2012 11:08 am
It is usually better to apply pads (and filters) as early in the chain as possible... Which means if the mic has a pad then use that first.
But I would probably just use whichever is most convenient at the time and for the situation.
Also, it depends on what is being overloaded. If the mic is being overloaded, then there is no point in applying a pad at the desk.
Bossman
Re: Pads
Postby Hugh Robjohns » Sat Jul 07, 2012 9:26 pm
+1
Hugh
