respond to articles via email
Postby edencane » Tue Jul 10, 2012 7:05 am
Hi.
I want to respond to an article by email.
Specfically in the July Issue, the 'up to the wire' article by Craig Anderton.
I have a specific question about the routing between reason in rewire mode and its rewire host...
My question is:
If I use the default routing in Reason 6, everything will go through the SSL mixer and I get a stereo input into the rewire host.
However if I route/patch individual reason instruments to individual outputs to get them on individual (stereo) inputs into the rewire host, I cannot use the SSL mixer...
Is there a way around this.
I have asked this question on the Pheads forums but got no answer...
Could you pass this on to Craig Anderton or anyone else on your SOS team who is Reason savvy?
Thanks very much.
Best regards.
Luke Vanderfluit (Digital Subscriber)
edencane
Re: respond to articles via email
Postby Wease » Fri Jul 13, 2012 8:08 pm
ok - for a start, it's not an SSL mixer - I'm sure SSL would be very upset if you kept calling it an SSL mixer... it's a model!
So you need to think of record/reasons mixer as an additional "plug in" before the reason sound "hit's" rewire
i don't know if you can have multiple reason mixers before you hit rewire...i don't think you can
so - you're basic answer is no...you need to wire in reasons sound sources to the audio outs in reason, separately, so they can access your DAW outputs as individual ins
you'll have to forgo the reason SSL emulated mixer I'm afraid if you want to go down this route
alternatively - mix everything in the reason mixer, then have a stereo feed to your DAW
...you "could" use the aux sends on the mixer - post eq- to send up to 6 channels to corresponding audio outs into your DAW......this might be a help?
or - buy duende native for £200 for your DAW to get "real emulated" SSL sound into your mix! :beamup:
Wease
http://soundcloud.com/seaapes
Postby molecular » Fri Jul 13, 2012 11:44 pm
From the manual... ;)
"The Mix Channel and Audio Track devices feature Direct Out connectors. By patching cables into these outputs, you break the internal signal chain from the device to the Master Section, and can route the channel output signals directly to the Reason Hardware Device’s outputs. This is a very nice feature if you want to use outboard mixing or summing - or if you’re using ReWire (see “ReWire”) to route individual channel signals to another application."
I've not actually tried this myself, I normally go straight from the instrument outputs to REWIRE, but it sounds like the direct outs (right hand side of mix channel in the rack) are post EQ/COMP etc. in the main mixer. So I reckon it's a yes.
H.
molecular
Location: The turn off where the main road goes over the river. If you're at the post box you've gone too far.
Anto mo Ninja, Watashi mo Ninja
http://www.hectormacinnes.com
Postby edencane » Sat Jul 14, 2012 1:33 am
Wease wrote:ok - for a start, it's not an SSL mixer - I'm sure SSL would be very upset if you kept calling it an SSL mixer... it's a model!
Thanks for the suggestions, sends is a good'un... I also looked at duende... good to be aware of... and re: SSL mixer, I understand it can be confusing, but within the context of a reason post Im sure Ill be forgiven (-:
I had a listen to seaapes... I love the guitar work, fantastic stuff, the voice doesnt cut it though... you need to change singers! Who's the guitarist?
edencane
Postby Wease » Sat Jul 14, 2012 11:03 am
I stand corrected by Molecule! - seems you can use the mixer as you want (I'm an old version of reason user - so I was going from the website!)
The sends idea will also work, but direct outs would be better
Yes - you can certainly be forgiven for calling the reason mixer "SSL" - but from what I've gathered, it's not quite as good as the Duende stuff....you can demo duende for free (4 weeks i think)...fully working, so you could decide for yourself what you think between the 2
As for the Sea -Apes - thanks for listening...the guitarist is Steve - he is rather good
The singer is Debs....she's infinitely more 'easy on the eye' than the rest of the band and writes the tunes (in conjunction with Steve)....we have a new EP that's due to be finished soon (next week) - with better (IMHO) recordings - maybe you can hold judgement on her singing till then??
(i quite like her voice - but then, if we all liked the same thing, the world would be a more boring place, no?)
Wease
