Fluttering DT770
Fluttering DT770
Postby oggyb » Tue Dec 04, 2012 1:07 am
Disaster. The left driver in my beloved Beyer DT770 has started fluttering on low frequencies.
I know this isn't like the DT100/150 where everything is serviceable. Anyone had a similar situation? Is it repairable or do I need to start saving up?
oggyb
Re: Fluttering DT770
Postby Goddard » Tue Dec 04, 2012 6:49 am
The DT770s are "field serviceable" iirc. At least I hope so.
I'd get on to the local supplier/distributor or e-mail Beyer directly, they'd know.
Goddard
Postby oggyb » Tue Dec 04, 2012 6:56 pm
Looks like the UK distributor is Polar. I'll give them a call tomorrow. Thanks.
oggyb
Postby Olly » Tue Dec 04, 2012 7:15 pm
I've replaced a couple of drivers in the 770s before. It's a little fiddlier than the DT100s etc. but possible. Enjoy!
Olly
Postby oggyb » Tue Dec 04, 2012 10:19 pm
Did you have to replace both to minimise inconsistent tone between the two drivers, or did you just run the replaced driver in for a while each time?
oggyb
Postby Smellthevalve » Wed Dec 05, 2012 4:47 pm
I have had this problem with DT770 and DT990 and it is probably something loose like a internal cable causing it, You could try carefully opening up and removing the driver unit to check.
Smellthevalve
-<{DH}>-
Postby Goddard » Thu Dec 06, 2012 2:34 am
Smellthevalve wrote:I have had this problem with DT770 and DT990 and it is probably something loose like a internal cable causing it, You could try carefully opening up and removing the driver unit to check.
Seems feasible. More likely for a dodgy cable/connection to reveal itself when reproducing bass, I'd think.
oggyb, please let us know what you find out.
Goddard
Postby oggyb » Thu Dec 06, 2012 2:45 pm
Will do. :)
oggyb
Users browsing this forum: matthias4950
