Recommendation for good HiFi headphones?
Postby Kevin Nolan » Sun Dec 30, 2012 5:51 pm
Hi -
I use some excellent headphones for mixing / monitoring but don't have any headphones for just general HiFi music listening.
Anyone got any recommendations for good, general HiFi headphones that purposely 'flatter' the sound, in and around the £50 - £100 range? I'm looking for good stolid bass but not excessive, clarity in the high end, quite balanced over all - and very comfortable - but NOT monitoring headphone. And I'm only after closed back, full sized headphone. I ask as I haven't a clue what's currently regarded as good in that regard.
I realise this is a production forum - admittedly I am looking to use these headphones for pleasure - but it is also as part of my daily obsessive listening to other people's music for all the reasons that nutty sound people like us find vital to our daily existence!!! :-)
Cheers,
Kevin.
Kevin Nolan
Kevin Nolan,KNECT.
http://www.knect.ie
Re: Recommendation for good HiFi headphones?
Postby IAA » Sun Dec 30, 2012 8:37 pm
Kevin, I use these for tracking and general HiFi (iPod etc). I like them and they're dead comfy.
http://www.production-room.com/krk-spea ... eadphones/
IAA
Postby Kevin Nolan » Mon Dec 31, 2012 11:51 am
Thanks for the pointer IAA. Looking at those, they look like monitoring headphones and I already have very good Sennheiser monitoring headphones. I'm after something less neutral and more flattering and warmer - good, comfortable headphones that add a little bass and are still clear and true.
the issue is I see lots of headphones from the likes of Sennheiser in the £60 regions but they usually say for DJ'ing or with phrases like 'Power Bass'. Most of those concern me as they look to be for dance music only. I'm after a good, all round pair of HiFi headphones but perhaps they are not available any longer?
Thanks,
Kevin.
Kevin Nolan
Kevin Nolan,KNECT.
http://www.knect.ie
Postby SafeandSound Mastering » Mon Dec 31, 2012 1:09 pm
The Beyer DT-770 are hi fi and closed back, although bottom end is a tad overblown as well. A very rich, detailed and crystal clear / wide spacious sound. A professional tool but with the traits you wish for GAK doing for £111.79 at the mo.
In fact they tick every box as your second post says you want a little extra bass. I think you might like them a lot.
Visit site
Postby Kevin Nolan » Mon Dec 31, 2012 3:04 pm
Thanks SafeandSound Mastering - appreciate the pointer. Will definitely check them out.
Cheers
Kevin.
Kevin Nolan
Kevin Nolan,KNECT.
http://www.knect.ie
Postby Kevin Nolan » Wed Jan 02, 2013 1:23 pm
In this search I'm coming round to getting either the Sennheiser HD595 (open back) or HD598's (closed back).
Might anyone have an experience with either of these? Isolation (in or out) is not an issue so I don't mind open back. Would open back / closed back affect the level of bass delivered by the headphone?
Thanks,
Kevin.
Kevin Nolan
Kevin Nolan,KNECT.
http://www.knect.ie
Postby chris... » Fri Jan 04, 2013 2:05 pm
Open back usually sounds better, so I'm not sure why you want closed back, unless you actually need the extra isolation.
chris...
Postby ezza » Fri Jan 04, 2013 4:06 pm
If you are thinking about the HD595 then have a look at this:
http://www.youtube.com/watch?v=PvQ8PzBrHXE
If you are ok with open-backs then I would definitely consider Grado SR60 or SR80. I have the SR60s and they are very nice for <100 quid.
/erol
ezza
Postby Tartaruga » Sat Jan 05, 2013 10:34 am
Hi Kevin!
Have you tried this:
http://europe.beyerdynamic.com/shop/hah/headphones-and-headsets/studio-and-stage/headphones-for-live-applications/dt-250.html
There’s a 80ohm version…
You can use them for everything,a true reference,no hype…
Cheers!
Pedro
Tartaruga
Postby Tartaruga » Sat Jan 05, 2013 10:36 am
Or this one…a classic.
http://www.production-room.com/beyerdynamic-microphones/beyer-dynamic-dt-100-16/
And you can replace broken parts…
Cheers
Tartaruga
Postby The Elf » Sat Jan 05, 2013 12:37 pm
Tartaruga wrote:Or this one…a classic.
http://www.production-room.com/beyerdynamic-microphones/beye...
Cheers
But don't choose these headphones for their 'hi-fi' audio quality - they sound like baked bean tins. :crazy:
Postby BJG145 » Sat Jan 05, 2013 12:50 pm
The Elf wrote:they sound like baked bean tins
That's very insulting to Heinz.
Postby Tartaruga » Sun Jan 06, 2013 1:59 pm
Hi The Elf
I first tried them in a few big studios.I then manage to buy a pair and used them for years.I even made some mixes that translate to any system perfectly.
Finally,I replaced them by the next generation,the DT 250 which again,suits me perfectly.
I can understand that you don’t like them,but they’re still in use in a lot places,and,in my humble opinion,in lack of something really better,they work perfectly for several tasks.
Maybe you tried some in bad shape…?Don’t know...
Cheers
Tartaruga
Postby The Elf » Sun Jan 06, 2013 2:24 pm
I've owned and used (and repaired!) loads and loads of DT100s in my time. I haven't just tried them - I know them very well! I bought them (and so did many studios) because they were cost-effective, and for that they have my eternal thanks, but nowadays there are alternatives.
They are robust, good for isolation, and simple to repair, but they don't sound good. I have several clients who simply refuse to use them on these grounds.
If they work for you that's good, but next chance you get, try them against some modern cans, such as the Sennheiser HD215 (which are gradually replacing all of my DT100s), and I think you'll begin to notice their shortcomings.
Postby chris... » Sun Jan 06, 2013 6:13 pm
Tartaruga wrote:DT 250 which again,suits me perfectly.
Being in common use for some arbitrary task (presumably providing a crude monitor mix to musicians whilst tracking, to keep them in time / tune) does not in itself make them appropriate for the task at hand (Hi-Fi listening).
chris...
Postby chris... » Sun Jan 06, 2013 6:16 pm
The Elf wrote:They are robust, good for isolation, and simple to repair, but they don't sound good.
You forgot "make the wearer look like he/she is recording the next "Band Aid" single!
( is that a plus or minus?)
chris...
Postby The Elf » Sun Jan 06, 2013 7:07 pm
Actually they do have a certain 'Nation Health'-ish-ness about them. Makes me think back to kids at school with sticking plaster on the nose of their spectacles! :D
Postby Tartaruga » Mon Jan 07, 2013 10:08 am
Hi The Elf
I totally agree with you,it’s just that,back in the 80’s/beg.90’s,you didn’t had the same choices that you have today and somehow,travelling from studio to studio,this old cans were something that I get used too and at the end,I use to bring my own.
Sure that,as soon as i could,I bought better ones.But the old ones sure helped me a lot,in a lot of situations,hence,’the classic’ remarque…
Maybe just because I get used to them…in the 80’s…
Cheers.
Tartaruga
Postby Kevin Nolan » Tue Jan 08, 2013 11:59 am
Hi -
Just to let you know I settled on the HD598's. I've bought these untested so it'll be interesting to see if they work out !! I'll let you know.
I have several sets of Sennheiser Studio reference headphones (HD600, 650's and 800s) so I'm probably biased towards Sennheiser. The HD598's are for general listening (and piano practice on a clavinova) - I want to stop using those expensive studio headphones for that sort of thing.
As an aside, in my searches I also came across the Sennheiser HD700's ! This was a surprise - I was not aware of these until now. Has anyone tried or purchased them? Do SOS intend reviewing them? They look VERY exciting.
Thanks for all the insights that pointers.
Kevin.
Kevin Nolan
Kevin Nolan,KNECT.
http://www.knect.ie
Postby Hugh Robjohns » Tue Jan 08, 2013 2:24 pm
I presume we will review them at some point, but I have no knowledge of when that might be. However, the 700s are based on the technology used in the 800s that we reviewed (in brief) here:
http://www.soundonsound.com/sos/jan10/a ... phones.htm
Postby Matt Houghton » Wed Jan 09, 2013 12:20 pm
Tartaruga wrote:Hi Kevin!
http://europe.beyerdynamic.com/shop/hah/headphones-and-heads...
Cheers!
Pedro
I have a pair of those here as I type. They're a pleasant enough sound. Rather darker sounding than most Sennheisers of the same sort of price, but smooth enough and not over-hyped in any way. But I wouldn't say they were very revealing (unlike the more expensive cans Beyer do design for critical listening, which are excellent!). I miss loads of details in them in the mid range and high end compared with the HD650s I normally use (which are nice but a tad poor on the bass side of things.
OP... The thing about asking for recommendations for listening pleasure, which 'flatter' the sound is that everyone's taste in this respect is different! It's like asking someone else to recommend what my favourite fruit should be ;)
Matt Houghton
SOS Reviews Editor
Postby Kevin Nolan » Sat Jan 19, 2013 10:04 pm
Just thought I'm report back on having purchased the Sennheiser HD598's. I have to say, they are absolutely fabulous. The are slightly more 'present' than the HD650s, ever more slightly coloured in the bass and high end - but - they are absolutely magnificent. If I didn't know the difference between the HD650s I'd use them as monitor headphones any day. The quality of the sound - definition, superb stereo etc.. is essentially that of the 650s - a variation on a theme rather than in any way inferior whatsoever.
But for the sort of listening I bought them for they are a marvel. lLstening to my iPod (AAC encoded pieces) and connected through a NECO SOUNDLAB portable V-2 headphone preamp, I am totally bold over by the sound, it's stunning. Overall, I could not recommend these headphones highly enough. Sennheiser have absolutely mastered how to manufacture headphones these days.
Kevin.
Kevin Nolan
Kevin Nolan,KNECT.
http://www.knect.ie
