Using Markers in Adobe Audition
Postby Elephone » Tue Jan 29, 2013 5:57 pm
Hi. I've divided a long string of sounds using markers, expecting to be able to chop them into separate audio files.
It seems this can only be done with ranges, but I only know how to convert a marker to a range individually.
I simply want to turn all distances between all markers into ranges. Most other programs I've used have a 'markers to regions' option.
I spent 2 hours placing these markers, so if there's any other way around it I'd be glad of the advice. If audition can't do this, can the markers be exported for use in other programs (like Soundforge or Wavelab)?
Also, is there a way to fade the audio slightly at each side of the markers?
Cheers
Elephone
Re: Using Markers in Adobe Audition
Postby Elephone » Tue Jan 29, 2013 6:29 pm
I was in two minds about using AA for this, but I thought it inconceiveable that it wouldn't be possible. Sometimes it's just better to stick with what you know.
There is something to purchase here:
http://www.audiomastersforum.net/amforu ... 9.255.html
Elephone
Users browsing this forum: Jack Ruston and 6 guests
