Parallel compression: A thought for a new plugin
Postby DC-Choppah » Tue Feb 05, 2013 3:15 am
Thanks to SoS for the latest article on parallel compression. While I've been doing this for a while now, I really feel I understand it after reading the article. I've always thought of it as bringing up the low level stuff while keeping the top end unchanged.
But my question is, is it possible for someone to create a plugin that just lets you draw the gain curve you want (dB in vs dB out), and then applies that gain to your signal?
Why use 5-7 compressors when you can get the same thing out of one plugin? I understand for hardware compressors that you can't get the same thing, but for software plugins, can't we just draw the curve we want and let the plugin apply the gain? Can someone make that for us please?
DC-Choppah
Re: Parallel compression: A thought for a new plugin
Postby Skerrick » Tue Feb 05, 2013 3:27 am
thats an awesome idea!!
i use parallel compression/ny compression to fatten drums (obv) and i reckon if there was a plugin that could make a better chain than i can in my mixer id be super keen.
im not as technical as you lot are, i learned via youtube tutorials which is mostly visual based cues and amateur instruction, but imho im actually surprised no ones thought of this/i havent thought of it myself!
Skerrick
Postby Skerrick » Tue Feb 05, 2013 5:22 am
just did a bit of a google search and theres a plugin called "Softube FET compressor" which seems to run sounds through some sort of parallel processing type FX chain..
havent had much of a chance to explore it further cos im at work but i think this might be what youre looking for.. :)
http://www.youtube.com/watch?v=sDMBdR1OW38
Skerrick
Postby Mike Senior » Tue Feb 05, 2013 7:20 am
DC-Choppah wrote:But my question is, is it possible for someone to create a plugin that just lets you draw the gain curve you want (dB in vs dB out), and then applies that gain to your signal?
I think the Melda stuff might allow you to work like that, from memory.
Mike Senior
Postby Skerrick » Wed Feb 06, 2013 12:53 am
ahh whoops, must have overlooked that hah :)
Skerrick
Postby Will Bailey » Wed Feb 06, 2013 2:13 am
Waves' H compressor is a parallel compressor. It uses the standard controls though.
Will Bailey
Postby DC-Choppah » Wed Feb 06, 2013 2:37 am
I downloaded the Mcompressor from Melda. But it looks like it has the same set of normal controls. I just grabbed the free version though. It does draw a graph of the compression, but you can't make it look like the swoopy curves from the article with 5 parallel compressors to boost up the low level stuff.
Maybe I need to fork over the $27 US for the full version?
DC-Choppah
Postby Mike Senior » Wed Feb 06, 2013 8:17 am
DC-Choppah wrote:I downloaded the Mcompressor from Melda. But it looks like it has the same set of normal controls. I just grabbed the free version though. It does draw a graph of the compression, but you can't make it look like the swoopy curves from the article with 5 parallel compressors to boost up the low level stuff.
Maybe I need to fork over the I downloaded the Mcompressor from Melda. But it looks like it has the same set of normal controls. I just grabbed the free version though. It does draw a graph of the compression, but you can't make it look like the swoopy curves from the article with 5 parallel compressors to boost up the low level stuff.
Maybe I need to fork over the 7 US for the full version? 7 US for the full version?
It's MDynamics you need. That gives you a freely editable transfer function. It's $180 on its own, but if you've got the cash, then I'd suggest getting the MMixingBundle, as it's only another $20 and includes a bunch of other stuff including various multi-band things and a dynamic EQ.
Mike Senior
Postby Zukan » Wed Feb 06, 2013 9:00 am
Going off at a tangent here but still relevant: I would suggest a good look at Cytomic's Glue compressor as that has a nifty little mix function which throw the comp into parallel mode but handles any clipping quite well.
Zukan
Samplecraze   Stretch That Note Masterclasses
Postby James Perrett » Wed Feb 06, 2013 9:48 am
That's exactly how the dynamics processing in Adobe Audition (and Cool Edit before that) has always worked. While it is often tedious to set up for normal compression, sometimes it is exactly what is needed and I wish this was available more widely.
James.
http://www.jrpmusic.co.uk
Postby DC-Choppah » Fri Feb 08, 2013 12:18 am
Mike Senior wrote:
It's MDynamics you need. That gives you a freely editable transfer function. It's Mike Senior80 on its own, but if you've got the cash, then I'd suggest getting the MMixingBundle, as it's only another
It's MDynamics you need. That gives you a freely editable transfer function. It's 80 on its own, but if you've got the cash, then I'd suggest getting the MMixingBundle, as it's only another 0 and includes a bunch of other stuff including various multi-band things and a dynamic EQ. 0 and includes a bunch of other stuff including various multi-band things and a dynamic EQ.
Thanks Mike
DC-Choppah
Users browsing this forum: Arco, John Egan, Music Wolf, panurge and 2 guests
