Beyerdynamic 990 vs 880
Postby Hexo » Mon Feb 11, 2013 8:27 am
Dear all
I have tested the Beyerdynamic DT 990pro and I'm totally satisfied with it's sound and frequency response. But environment noise disturbs me. Do you think if a semi-open headphone like DT 880pro can give me the same frequency response with some noise attenuation?
Thanks.
Hexo
There are a million keys to perfection and they are buried in different graves.
Re: Beyerdynamic 990 vs 880
Postby Hugh Robjohns » Mon Feb 11, 2013 9:42 am
Semi-open headphones give almost no ambient noise attenuation.
If external noise is a problem, I would suggest the Sennheiser HD-25-1 II (Handbook Here)
hugh
Postby Hexo » Mon Feb 11, 2013 9:52 am
Oh really? Very good point. Thank you Hugh.
Hexo
Postby 2M » Mon Feb 11, 2013 10:01 am
I use the BD DT990Pro and DT770Pro. The latter one I use for tracking/recording and in situations where I want the minimum of noise from outside. The 990's I use mainly when mixing or just listening.
As far as sound and response I am totally sold on the 990's, which is why I opted for the 770 as well for tracking. The sound is nearly the same. The difference is most noticable in the lower frequencies. To my ears the bass is a bit tighter and thicker in the 770 (which makes sense seeing the design). Obviously the 990's also sound a bit more open and wider to my ears. But the general sound and response is very very similar to me.
So, if you like the 990's sound, and look for something similar with environmental noise attenuation, my suggestion would be to check out a pair of 770's.
Regards,
Martijn
2M
Postby Hexo » Mon Feb 11, 2013 12:11 pm
Thank you 2M. But I've actually tested the 770pro too and it's not enough for me because I really need that wide bass and even sub in 990pro while designing say a kick or a bass. I'm just eager to know if there's a choice that has 990's lows and 770's isolation.
Hexo
Postby Smellthevalve » Mon Feb 11, 2013 10:58 pm
Which impedance of DT770 did You try?
the 80ohm version does not sound the same in bass freqs as the 250 and 600 ones.
Smellthevalve
-<{DH}>-
Postby Hexo » Wed Feb 13, 2013 11:57 am
I didn't know they have different impedances. I'll check and update.
Hexo
Postby 2M » Wed Feb 13, 2013 1:41 pm
Good point, the impedance makes a lot of difference. In anycase, for sub and bass response I grab my 770's before I go to the 990's, so your experience with them surprises me a bit! To me bass in 770 is tighter and stronger than the 990's.
Curious to know what you tested.
Regards,
Martijn
2M
Postby Hexo » Fri Feb 15, 2013 8:33 pm
Hexo
Postby Smellthevalve » Mon Feb 18, 2013 1:45 pm
It would appear from the website that the DT770M has a different frequency response to the DT770.
That was certainly my experience with the DT770M 80 ohm version - an increased level in the upper bass freqs changing the tonal balance coupled with not much deep bass compared to the 600 ohm DT770 which I have used a lot in PA sound work.
I can't comment on how the DT880 sound in comparison as I have not heard them, but the DT990 phones are quite good sounding in the bass even though they are open.
Smellthevalve
-<{DH}>-
Postby Hexo » Mon Feb 18, 2013 10:45 pm
Thanks for your comment, but...
Smellthevalve wrote:but the DT990 phones are quite good sounding in the bass even though they are open.
"Though" they're open? I thought we should say "because" they're open. Most audiophiles and the most expensive and headphones specially designed for monitoring are open. It really sounds weird to me that you are on closed headphones side for monitoring. My thought is openback headphones sound better but they lack in isolation. And I'm looking to find an alternative with fixed isolation but the same quality.
Hexo
Postby Skerrick » Tue Feb 19, 2013 12:50 am
when i bought my akgs my mates all said closed back was the best for mixing and recording/producing cos youre hearing the "full sound" with nothing getting away from you through the cups and less interferance from outside noise... im no pro, but i got the AKG K171 MKII's and theyre pretty superb to say the least. :)
Skerrick
Postby Hexo » Tue Feb 19, 2013 11:28 am
I think I should proof you wrong:
Hugh Robjohns said:...most closed-backed headphones sounded pretty grim — boxy, dull, and lacking in air and openness. This is not really a problem when overdubbing or playing along with others, because it only has to provide a cue, after all, but making critical mixing decisions is almost impossible if the sound quality is poor ...........
The alternative open-backed headphone design has traditionally provided the best sound quality in headphone monitoring .........
ref: http://www.soundonsound.com/sos/dec03/a ... phones.htm
and your saying:
...cos youre hearing the "full sound" with nothing getting away from you through the cups...
let me say that this is not true! Because the most natural condition is to here the sound from one side of the headphone driver like any other physical oscillator. Closed headphones might reflect the sound and you hear it twice! There might be also phase problems. Of course most modern headphones tend to absorb the driver reflection than reflecting it back to avoid all artifacts above. So the "full sound" you said, believe me,is a myth.
Hexo
