Neumann KH-120A or Adam A77x for Dance Music Production at Home ?
Postby iasomph » Sat Mar 30, 2013 9:13 pm
I actually own a pair of Adam A5x for my small bedroom-studio (my first monitor ever, but I like them a lot for their size/price ratio. I'm working on them since almost 1.5 years and I am forced to use them only 15 cm from the wall, but I find them still pretty workable). I will probably move into another space at end of summer, so I'm already dreaming :) :) about a new pair of monitors for my dance productions works (house / deep house / progressive house).
I can spend up to maximum 1.500£ for a pair of new monitors (but of course I don't have to, if something cheaper can help me in the same way).
I am seriously thinking about:
- Pair of Adam A77X: 1.270£
- Pair of Neumann KH-120A: 1.050£
- Pair of Adam A7X: 800£ (can consider them if the A77x are too big for my space, or if they don't worth 450£ more than the A7x)
Please consider that:
- I mainly do dance/house/progressive house/deep house genre. So the low end is really important for me. But also consider that the space will not be acoustically treated....so I cannot say that it would be a perfect sounding room.
- Since I will have neighbour, I could not run the monitors at extremely high volume levels all the time, otherwise my neighboor will kick me out of the place in few weeks. I need to use the monitors mainly with a moderate volume (let's sayaround 80-95 decibel range, just to say some numbers).
- As I said , the place will probably not be acoutic-treated. I can think about some small work...maybe some small panels or bass-trap, but since the apartment is the apartment of my parents, I cannot do lot of work inside it! So I would say that it would be probably untreated.
I need to find a solution that permits me to increase the quality of the sounding room, but at the same time that doesn't damage the walls (or maybe white panels - if exists - could be a nice solution, since walls are white and so my parents will probably accept them). Let's say that if I can find someone that can help me to understand what treatment I have to do, and some product that doesn't damage the walls, I can consider other 500-700£ for "non-invasive" room treatment.
- the place is a small loft, around 45 square meters: it's an open space, but with different zones divided by the various furnishing (mainly 2 zones divided by a column and a wardrobe: it's possible of course to walk from a zone to the other without any door). So it's something different from a "classic closed room". The place will be quite small but still be "open" for the sound to flow in the other zones of the house in some way. The place is the highest floor of the building (a small attic), so the cieling is not really high everywhere, and goes down on one side.
Reviews of the Neumann KH-120 are amazing, but I think they are maybe small for dance heavy bass projects and after working with Adam A5x now I'd wish for something bigger than my Adams (I have some difficulties judging the really low end, and sometimes kick/bass balance).
Adding a Sub to monitors (from what I heard around) it seems not a good solution in an untreated space. It seems that separated subs are better to use in a really well-trated space, otherwise they can cause more problems than benefits.
Since I like Adam sound....the A77X seems a dream to look at, and review are nice too; but on the other end, will the A77X (or the cheaper but still good rated A7X) bigger woofer work well in an untreated (or semi-treated) space?
What to do? Which is the best solution for my situation considering all above?
Thanks everyone for their kind suggestions!
iasomph
Re: Neumann KH-120A or Adam A77x for Dance Music Production at Home ?
Postby whis4ey » Sat Mar 30, 2013 10:38 pm
Try the Focal CMS 50's, or if you want a larger speaker, the CMS 65's (the former are equivalent in size to the Neumann's and cheaper, the latter similar in price. and are very similar on quality :) (well there are those here who would disagree, but I use the Focals and they are an absolutely fabulous monitor for the money :) :)
whis4ey
Postby Hugh Robjohns » Sun Mar 31, 2013 10:48 am
whis4ey wrote:...the former are equivalent in size to the Neumann's and cheaper, the latter similar in price. and are very similar on quality :)
...and yet:
whis4ey wrote:Of corse, I have never heard the Neumanns
...which kinda renders the opinion dubious at best! ;)
I'm not going to recommend specific speakers here, but I will offer this advice:
1. It's easy to improve mid and high frequency room acoustics, but much more difficult to sort out the LF standing waves (room modes) from which every room suffers.
2. The more bass energy you put into a room, the more obvious those standing waves will become and the harder it will be to balance the bass end of your mixes accurately, because some notes will boom and others will go missing.
3. I know with dance music that a thumping bottom end is an important element of the music, but there is no way you'll ever recreate the 'club sound' in your project studio anyway and if you're working in a small room you'll never get an even bottom end whatever you do. So why push excessive amounts of bass into a space that can't handle it. All you'll do is struggle to compensate for the LF peaks and troughs.
It is better, in my view, to use more modest speakers that don't excite the room modes so badly, and learn how the sound they produce translates to a typical club system. Use headphones to help you assess the bottom end without the room modes.
4. The best monitor manufacturers maintain a very consistent sound across all of their models. Moving from the smallest speaker to the largest in their range sounds like you're winding out a high-pass filter, while the mid and HF character and balance stays essentially identical. This implies that the manufacturer has a firm idea of what the 'right' sound balance is supposed to be.
However, with some manufacturers you'll find that every model sounds noticeably different and I find rather disconcerting. How do you know what the 'accurate' sound is? How does the manufacturer know?
If you're spending that kind of money on monitors it's worth making the effort to find a retailer that will let you hear them for your self -- and ideally in your own studio. Remember that a monitor is supposed to have the resolution to reveal flaws in the mix, but not in a way that causes listening fatigue after an hour or two. Monitors aren't supposed to flatter the mix -- that's what hifi speakers are for ;) -- so don't be lulled into buying a speaker that sounds 'nice' or exciting, or that over-eggs the bottom end.
Just a few thoughts...
Postby whis4ey » Sun Mar 31, 2013 10:55 am
LOL Hugh ... you are finding it difficult to let me off the hook :)
whis4ey
Postby Hugh Robjohns » Sun Mar 31, 2013 11:02 am
Sorry W, I know you love your Focals and they have opened your ears to the wonders of high-end sound... but it would be remiss of me to allow anyone to pass off unfounded opinions as fact.
By all means recommend the CMS speakers on the basis of your experience of them, but lets stick with the facts, eh?
Postby iasomph » Sun Mar 31, 2013 1:21 pm
thanks for the advices! I know that low frequencies are the worst to deal with, and that's why I think it's not even worth considerin woofer size bigger than 7" in my situation. That's why I exluded Adam A8x from the choices and thinked about A7x or A77x (even if they have 2 woofer drives, they should have more accuracy and precision, but not more accentuated low end than A7x).
On the other hand the marvellous reviews of the Neumann KH-120 are tempting me as well. Everybody says that they are excellent monitors, extremely precise and accurate...and more and more I work on new tracks, the more I'd like to work with monitors that help me in taking the right mixing decision (eq, compression...) and make me save time!
Listening to many monitors at once it's not easy here in Italy. We don't have such big stores like big U.S. / UK stores with dozens of monitors ready to be listened. I've been lucky enough to listen to Dynaudio Bm Mkii series, Adam Ax series and Krk Rokit series before purchasing my Adams. I found the Krk Rokit to be less precise than Adams (more boomy bass / dark sound....less neutral), and I didn't like for personal taste the Dynaudio timbre, because I found them too middish. I didn't had any fun listening to them. I know monitors are for working, but I need to appreciate a timber from a monitor..... because audio is fun too for me. So Adam was the best for my overall neeeds. And I'm happy I've choosen the A5x model because my bedroom is not big, they need to sit on the desktop just 15cm from the back wall and listening distance from speaker to ears is just 70-80 cm, so A5x was the perfect choice for my needs. I have to say that they have a good bass extension for their size :)
But the new place will be bigger than my bedroom, and I will not be forced to keep monitors so close to the walls. I can finally use proper stands if I want, so I can imagine that the bass will probably become lighter than now. Just to know...how is the bass extension of the Neumann KH-120A (5,25" woofer) compared to the Adam A5x (5,5" woofer)? I've read of people that says that bass extension for their size is really good, but even someone that says that are not suitable for dance music (someone says the same with A5x, but I like them in my specific environmental situation). Sooo difficult to choose. But I cannot think about having less bass than now with my A5x model.
Of course I can consider other brands as well...but not Dynaudio because I didn't like the timbre. Everybody says that Focals are nice speakers, but I've read of different opinion on them as well (I've read about port noise, and that they are really good speakers in general but maybe not so great for dance as well). The Neumann seem the ones on which most people agree on the quality. My only concern is the Bass extension :)
The new apartment is in Paris: any nice shops there that can give me advices / let me try at home different monitors before choosing the final one?
It would be great finding an audio engineer that can help me about monitor positioning / discrete and basic room treatment. I'm not an expert in room treatment and I tink that doing something without the right know-how is probably worst than doing nothing. I'll prefer having an expert to pay that really know what he is doing with room treatment as well :)
Thanks again!
iasomph
Postby whis4ey » Sun Mar 31, 2013 9:01 pm
You really have to read my other comments and keep to the facts. I have NEVER criticised the Neumanns, merely given my personal opinion of the Focals
You seem to be taking all of this very personally, and I wonder why you are so determined to dismiss an honest opinion as 'unfounded' or 'suspect' simply because it is based on the experience of one particular monitor?
whis4ey
Postby Hugh Robjohns » Mon Apr 01, 2013 10:15 am
whis4ey wrote:I wonder why you are so determined to dismiss an honest opinion as 'unfounded' or 'suspect' simply because it is based on the experience of one particular monitor?
If you stuck to your honest opinion of the one speaker you have personal experience of, there'd be no issues at all. But sadly, and increasingly frustratingly, you have continually mentioned and taken thinly veiled side-swipes at another monitor of which you have no experience whatsoever, and that's just not acceptable.
Moving on...
Postby chris... » Mon Apr 01, 2013 11:10 am
jasno84 wrote:I mainly do dance/house/progressive house/deep house genre. So the low end is really important for me.
I note Narcoman was recommending AE22 over KH120, for this sort of genre.
Forum post link.
chris...
Postby fay spook » Mon Apr 01, 2013 12:32 pm
What a nice situation to be in, Paris and buying some new monitors. Good to see you have listened to some speakers and you are happy with your opinions, too many people just passively take advice but not the best advice of going out there to listen.
As people have said, if you like ADAMs bigger ADAMs should add bass etc. Have a listen to the AE22s, you can get active versions. How about some Quested S6Rs? In your price range and a sealed box like the AE22s. And yes the Focals and Genelecs are options in the cast cabinet world!!
fay spook
Postby fay spook » Mon Apr 01, 2013 12:45 pm
I forgot to add.....how about some SE Munro Eggs? It is Easter after all...... :bouncy:
I've heard them and they are great, nice bit of grunt and a precise stereo image.
fay spook
Postby iasomph » Mon Apr 01, 2013 2:39 pm
thanks to all for the advices:
- Se Egg seem a nice system too ( but 500£ more than the Neumann!)
- AE 22 seems nice, but heard less people speaking about them compared with Neumann.
- But Neumann KH-120A still appealing a lot (so many great opinions about them)!!
If it can be useful, I can give measure of the new space:
- length: around 6 metres (probably little less, because there is a sofa at the end of the length, and a small furniture at the beginning..)
- width: around 3 metres
- height: since it's an attic, it starts at 3.20 metres on the highest part, but goes down to 1.10 metres on the edge of the wall. (So the width, which length I said it's about 3m, starts with a highest heigth of 3.20 metres and lowest heigth of 1.10 metres).
So it will be around 18 square metres, with a high of the cieling from 3.20 to 1.10 metres (it's an attic, so the cieling is inclined and it becomes pretty short in height on one side of the place!). The important thing is that the space is not "closed", like a normal room: at the end of the 6 metres of length there is space on the left for walking into another small part of the house, end on the right for entering in the kitchen. And the walls that divide the various zones oh the house don't go up to the cieling, leaving some space for sound to go in other spaces.
I'm starting to think to avoid such big speakers like Adam A77X, I think that Hugh is probably right because the space is not so big, and the cieling goes down to 1.40 metres, and I don't know how much easy it will be to treat the room since it's asymmetry and inclined cieling (I can treat the room with white panels or not-invasive treatment, otherwise my parents will screw me!!). So, if the Neumann can produce an acceptable low end that is as deep as the Adam A5x (I hope it will be easier to work with Neumann than on the A5x on bass actually, otherwise why switching?), they could probably be a good choice for a particular space like that.
So new questions are:
1) Anyone can tell me how is the low end of the Neumann KH-120A compared to the Adam A5x (deeper, more precise...etc)? Would I obtain an obvious help in mixing if I pass from the Adam's A5x to the Neumann KH-120A?
2) If I find some pictures and the planimetry of the house I can publish here: could it be helpful for obtaining advices in choosing the monitor of the right size / verifying that the positioning I'm thinking of is the best one I can achieve?
3) Hugh, you seem a great fan of the Neumann's, but I see that you actually reviewed the Egg system as well with great results...which system you recomend me?
Thanks!
iasomph
Postby sambrox » Mon Apr 01, 2013 8:19 pm
You won't go wrong with the Neumanns. Best monitor I have heard for the price. I just bought AE22s and am pleasantly surprised by how low they go bass-wise, but am under no illusions - the KH120A is easily the more accurate when talking frequency response and distortion. Resolution and imaging are also excellent. I had other reasons for purchasing the AE22s, but I repeat, you won't get a better speaker for the price!
Cheers,
Sam
sambrox
Postby John Willett » Tue Apr 02, 2013 8:48 am
The Neumann KH120A do have positioning filters as standard - IE: switches to modify the response if the monitors are next to a wall, in a corner, on a console meter-bridge, etc., so you get the correct response wherever you put them.
John Willett
Postby sambrox » Tue Apr 02, 2013 9:39 am
Ps I compared the sE Eggs directly with the Neumann not so long ago. In the shop, they were both very revealing and comparable with regards to imaging and soundstage, but the Neumann had a much more pronounced low end. Incredible for the size, I would say.
sambrox
Postby Hugh Robjohns » Tue Apr 02, 2013 9:55 am
jasno84 wrote:Se Egg seem a nice system too ( but 500£ more than the Neumann!)
The Egg is a novel but impressive system, and sE have a policy of allowing the user to try at home before buying -- something that I wish a lot more manufacturers would support.
They were discussed non-stop when they were first launched, but they're kind of 'old hat' now and people have moved on to the things they see advertised more often! Speaker discussions tend to vary like fashion, and the Focal brand is very fashionable at the moment. ;) The AE22s are sealed cabinet speakers and that makes them both unusual and useful specifically because of what the sealed cabinet brings to the party in terms of the minimal bottom end resonances and time smearing. They also have a surprising bass extension, again because of the cabinet design, which isn't particularly powerful but does go down a very long way very smoothly! Something which ported cabinets generally dont't do.
Anyone who has heard and used them gives great reviews... And it is hugely popular in the pro markets, but it's not a model that many people seem to have bought into in the home studio market. One reason might be that it is such a good and accurate monitor that it doesn't sound very 'impressive' when first auditioned, and this is a common problem for the inexperienced. Monitors that are shouty or have hyped top ends appear to be more revealing and detailed when auditioned in crude comparisons, and thus tend to sell better. Sad but true.
6 x 3 x 3.2 is tricky because the dimensions are very close to simple integer multiples, which means that the standing waves will tend to pile up at similar frequencies. Bass trapping will be important and necessary to smooth out the room response.
The published specs for the two are very similar in terms of LF extension. As for whether the low end is acceptable is a probably an issue of personal expectations. It won't make your trousers flap, but equally I found the balance very acceptable and had no trouble at all mixing the bottom end with confidence.
I haven't compared them side by side, so these are largely subjective opinions based on recollections, but the bass extension will be very similar. I'm inclined the think the KH120 is better controlled at the bottom end -- the Adams seemed to me to be tuned to make them a little more punchy.
Probably... but given your descriptions so far I think you're on the right lines in terms of speaker size.
I'm a great fan of all good monitors. There are way too many monitors in the world, but a lot of them don't really warrant the term 'monitor' in my opinion. The Egg system is genuinely impressive from a sound quality point of view, but it is quite expensive and the unusual configuration is not going to suit everyone's requirements. Well worth auditioning if you can... and there are other very capable monitors around -- you'll have already seen the strong praise for the Focal CMS models which is entirely valid too. But if I was spending my own money I'd buy the KH120s without hesitation.
Postby MGBR65 » Tue Apr 02, 2013 11:21 am
John Willett wrote:The Neumann KH120A do have positioning filters as standard - IE: switches to modify the response if the monitors are next to a wall, in a corner, on a console meter-bridge, etc., so you get the correct response wherever you put them.
I've always wondered about this.
Why is it that if people want to use eq to compensate for roommodes, standing waves, corner placement etc. they get strongly advised not to (wich I totally agree on by the way). But on the other hand it's totally accepted that monitors have eq switches onboard to compensate for the very same things?
MGBR65
Postby Hugh Robjohns » Tue Apr 02, 2013 12:18 pm
MGBR wrote: Why is it that if people want to use eq to compensate for roommodes, standing waves, corner placement etc. they get strongly advised not to (wich I totally agree on by the way). But on the other hand it's totally accepted that monitors have eq switches onboard to compensate for the very same things?
The LF boost that occurs through boundary loading is a broad-band effect which is both progressive and predictable, and thus easily corrected with first-order attenuating EQ.
Room modes and standing waves are narrow band effects which are not predictable (to the speaker designer) and can result in both huge peaks and massive notches. The notches can not be filled in by electronic EQ unless the speaker has a massive headroom margin (which would make it uneconomic to produce in most cases), and the narrow band filtering required is very difficult to do in the analogue domain and has serious phase shift problems. It can be done more easily and with linear-phase filters in the digital domain (at the expense of some latency), but the problem of deep notches doesn't go away.
And at the end of the day, standing waves or room modes are the result of a physical acoustic problem that is best address in the acoustics domain.
Postby MGBR65 » Tue Apr 02, 2013 12:47 pm
Thank you very much for explaining.
I don't want to hijack this thread but I do have a follow up question, so I will start a new one in the studio design and acoustics section.
I would appreciate it very much if you could find the time to go over there and help me out?
MGBR
MGBR65
Postby Pete Kaine » Tue Apr 02, 2013 12:57 pm
Personally after running an A/B/C setup to compare them I'd take the Neumann 120 over the Adam A77X but then as I consider the Neumanns a little bass light in the first place I'd take the A8X over both of the previous options when it comes to working with dance music.
Yeah, probably not what you wanted to hear going off all that is printed above but the are another few notes extension (half an octave if I remember rightly over the A5X) on the A8X below what can be handled by the other two, althrough with the additional cone inches you'd expect that to be the case anyhow.
The Neumanns are pretty much the same size as the A5X's so I'm not expecting much more extension figures (I've not checked before posting, so feel free to smack me around with some printed specs) althrough the Neumanns are certainly a far more percise set of speakers I can't help but feel this is partially due to the tighter and less expanded lower region making that the case. I have to wonder through without some resonable room treatment is any upgrade here just going to be a bit of waste?... expecially going from 5" to 5.25" speakers.
The A77X's are not what you expect coming from any of the A*X range so get a listen to them. If your expecting A5X but with more bass then go for the A7X or above as the A77X to me at least has a slightly more pop/rock mixdown feel to it in being that they sometimes come across a little too clean and clinical. Perhaps that's exactly what you want (and with good reason) but do try and compare them first.
Pete Kaine
ScanProAudio - Studio Kit
Scan 3XS Audio Workstations
Postby iasomph » Tue Apr 02, 2013 8:45 pm
Hi Pete,
thanks for your point of view, but I think (from my current poor knowledge) that an 8 inch woofer would probably be quite hard to control in a room where I cannot do a proper and complete acoustic treatment: from what I'm understanding bigger the woofer ----> bigger the bass, but at the same time bigger problems with low frequencies control in a poor treated room.
Room will be around 18 square metres, so not very big, with a cieling that goes from 3.20 metres to 1.10 metre (really low) on the edge of one wall, so pretty asimmetric in height. Maybe the Neumann could be a good size considering all those factors.
I have to say that I personally think that the Adam's have a good amount of bass for their size, even if I'm starting to think that it's not easy to take very good decisions on them with regards to low end - low mid's. But still have to understand if the problem is related to inexistent room treatment. I think they are good for their price and happy to have bought them as my first monitor system ever, but I'd like to start to desire something more revealing in the mixing phase...something that I can trust more and more and that can translate my project better on other systems (at the end is the most important thing with a monitor!!)
What I'm hoping is that the Neumann could help me with mixing decision, compared to the Adam's. They cost more than twice at the moment, and many people says that they probably worth more than their price. So I would expect a substantial change - of course in positive terms, if I decide to switch to them :)
I think I will have soon pics of the room, and maybe planimetry too...maybe this could help with the choice.
iasomph
Postby iasomph » Wed Apr 03, 2013 2:25 pm
Hugh,
I've read all your suggestions, thanks for taking all that time to reply to all my doubts! I have to say that you are really active and helpful here, and replied to all my treads I've opened since I joined the forum! So really thank you for all the time you spend on my treads!! :)
Now I contacted Gikacoustics for discussing better a non-invasive room treatment, so I hope to be able to find a good treatment solution for my needs. Probably after I will have more information in order to choose the right monitor for my needs.
I still have few questions:
1) you said that AE22 have sealed design. Neumann are ported. In the end which technology you think work better for (dance and general) music, considering a non treated / soft-treated room? Will the fronted ports help more, compared to the sealed design?
2) What about the Neumann KH-310A ? Of course they are way lot expensive than the KH-120A, and have bigger 8" inche woofers.... so I may think about them only if they will be the definitive monitor I will ever buy in the next 10 years. And only if they can effectively work in a place like the one I described. I'm just a little fought about this: better investing less money for a still great monitor like the KH-120A (but maybe still desire upgrading in few years) and check for very low frequencies with my AKG K240 MKii headphones, or maybe worth considering a "definitive" monitor like KH-310A? If you think that the KH-310A would still be too big for my place and introduce anyway too much bass problems and that the KH-120A still seem the best overall choice considering a modest-treated living room..... maybe I can start buying them while I'm here in Italy, so can start enjoing them in my actual bedroom, and then bring them with me if I move to Paris....or you think it's worth waiting and choosing the new monitors while in Paris?
3) You said that the Neumann are great monitors, but since they don't sound "impressive" when first auditioned, they sometimes get (wrongly, from a working point of view) underestimated. So my question is: how effectively useful is demoing the sound of different monitors? Maybe the only way to understand how good a monitor is to read trustable reviews and use them effectively for some days and see how your work translates to other systems?
4) Is still fun enjoying them to listening to music, or they suit only for mixing? I ask that because at the moment I both work and listen to the music with my Adam A5x and I think in the end they have a pleasant sound to hear even while listening to music, and not only to work with. How is the timber of the Neumann? Still possible enjoying music from them? I hope to find them to audition first, just to understand if the timber is more similar to the Adam's or to the Dynaudio (that I don't like so much).
Thanks again!!
iasomph
Postby Pete Kaine » Wed Apr 03, 2013 2:27 pm
jasno84 wrote:Hi Pete,
Yeah, I got that, sorry I should have been clearer in my conclusion yesterday!
In absence of the ability to fit the A8X's in the studio but if you still want the A5x sound then the A7X might be worth considering alongside the A77X. The A77X comes acoss as the more clinical solution due to the improved seperation and if you want the slightly more vibey sound of the A8X/A5X you might acturly prefer the A7X instead which is what I was trying to get across(and failing!).
I'm quite suprised that you can't find somewhere to audition them in Paris, have you spoken to the French distro to see if they can set you up a demo session?
Pete Kaine
Postby iasomph » Wed Apr 03, 2013 2:57 pm
Hi Pete,
at the moment I'm still living in Italy...I'm thinking about moving to Paris after summer :)
I'm looking for a place where to audition the KH-120, really curious about them. The Adam A7x seem nice too...but from what I've read around, maybe it's better something little smaller but more detailed and revealing.
The truth is that we probably have too much choice...and at the end this is not always a good thing, because it makes purchase decision even more complicated :)
iasomph
Postby ken long » Wed Apr 03, 2013 3:10 pm
Hi,
Last time I was in Paris, I went here and they had a separate room to the showroom just for listening.
http://www.stars-music.fr/magasin-paris.html
They also have the Adams
http://www.stars-music.fr/home-studio/m ... acturer=16
ken long
I'm All Ears.
Users browsing this forum: Tim Gillett, zenguitar and 3 guests
