mp3 compression - how to test
Postby thedisillusioned » Mon Apr 01, 2013 6:19 pm
Hi all
As part of my final year university degree i have to create a track of test signals to test mp3 compression. I understand how mp3 compression works but am not sure on what sort of test signals i should be putting in
Can anyone suggest to me what sort of test signals are good for testing mp3 compression at different bit rates and why or if you have any links to articles that are useful then that would be great
thanks in advance
thedisillusioned
Re: mp3 compression - how to test
Postby Kwackman » Mon Apr 01, 2013 6:35 pm
Suzanne Vega "Tom's Diner".
I'm pretty certain this is what the original MPEG developers used, and why Suzanne Vega is known as the mother of MP3.
Kwackman
Postby sambrox » Mon Apr 01, 2013 8:06 pm
Read this
Cheers,
Sam
sambrox
Postby BJG145 » Mon Apr 01, 2013 9:46 pm
Incidentally Sonnox produce an interesting plugin for auditioning MP3 compression in real time. (15-day demo available.)
http://www.sonnoxplugins.com/ws/pub/plugins/support/demos.htm
http://dload.sonnoxplugins.com/pub/plugins/Reviews/Pro-Codec-SOS.pdf
Postby Hugh Robjohns » Tue Apr 02, 2013 10:05 am
MP3 throws stuff away. So you can evaluate the frequency domain perforamnce by uising a test signal that has everything, and then see what's missing after encoding -- white noise for example -- although you'll need a very accurate spectral analysis averaged over many passes t achieve sufficient definition.
The other thing you can do is a null test with the original and processed signals -- but take care over accurate time alignment (a one sample pulse at the start is a handy way of ensuring accurate time-alignment).
More complex signals will obviously challenge the algorithm a lot harder than simple signals, and voices are more revealing of artefacts than other signals simply because we are so familiar with the sounds that real voices make and can spot artefacts more easily.
Postby A. AuCr » Tue Apr 02, 2013 10:42 pm
Null testing the mid and side components separately can be particularly revealing. The stereo image suffers greatly at lower bitrates.
A. AuCr
Postby mjfe2 » Wed Apr 03, 2013 12:35 pm
This is a great essay if you want some cultural studies to back up your project: Jonathan Sterne, "The mp3 as cultural artifact"
mjfe2
Postby thedisillusioned » Sat Apr 06, 2013 6:14 pm
How would i go about setting up a Null test on pro tools?
thedisillusioned
Postby Martin Walker » Mon Apr 08, 2013 8:01 pm
thedisillusioned wrote:How would i go about setting up a Null test on pro tools?
You just set up two tracks - one containing the original audio, and the other containing the MP3 version, tweaked so that both are as close to the same level as you can get them, then invert the polarity of one of them and see what's left after the common parts cancel out ;)
Postby Goddard » Tue Apr 09, 2013 11:10 pm
If you just want to hear what is being removed from the input signal by the encoding, the Sonnox Fraunhofer codec plug-in as already mentioned above provides that function ("difference" auditioning) in PT.
Assume you've already consulted Fraunhofer's resources (and perhaps even contacted them for guidance?) but if not that might be helpful.
Goddard
Users browsing this forum: No registered users and 8 guests
