Mixing Drum n Bass advice needed!
Postby OverDrawn » Mon Apr 01, 2013 6:53 pm
I have produce a Liquid Drum and Bass track recently. I have got all synthesised in it, except a piano and violin, which are recorded in a studio. Can someone give me an advice to get the violin sound right. I've mixed in a piano pretty well, but struggling with the violin.
There is the track:
https://soundcloud.com/denissberezins/m ... umnbass-by
OverDrawn
Re: Mixing Drum n Bass advice needed!
Postby oggyb » Mon Apr 01, 2013 8:22 pm
Violin, being a "natural" acoustic sound, is less tolerant to tonal modification than other "electronic" sounds. You've written an arrangement that is pretty full-on frequency-wise for the whole piece, and trying to squeeze a violin in there is going to be tough.
Case in point, right now it sounds more like an oboe.
Try use the 1KHz region less, and increase the 5-12KHz region. You will probably need to reduce the level or the HF content of some of your other synths to leave room.
oggyb
Postby OverDrawn » Mon Apr 01, 2013 9:42 pm
I lowered a couple db down in area from 1kHz - 5-7kHz of my mix (without violin).
I pushed violin a bit further with delay, cuz it has got a bit close in a mix, pushed a notch up in 1-5 kHz for violin.
Is that better? Still sounds like oboe to me.
https://soundcloud.com/denissberezins/mpp-liquid-drumnbass-by-1
Maybe I should leave a track without violin at all?
The person who played it really wants it in, i suppose.
OverDrawn
