Protools Question
Protools Question
Postby RemoHead » Wed May 15, 2013 9:18 am
Hi Guys, I'm running Protools 9 Native on my mac pro.
Can anyone tell me if there is a way of having tools automatically enter warp markers WITHOUT it automatically quantising?
I have a song I've been given to mix that wasn't recorded to a click, the drummers timing is good, as is the rest of the band, all except the bass player. I want to use elastic audio on the bass part to tighten up the bass with the kick and snare hits.
I was just wondering if tools could put the markers in automatically so that then I only have to line them up, rather than having to manually put them all in myself.
Many thanks, Remo
RemoHead
Re: Protools Question
Postby DC-Choppah » Sat May 18, 2013 4:21 am
Sounds like you are in the GRID edit mode. Switch the edit mode to SLIP.
DC-Choppah
Postby DC-Choppah » Sat May 18, 2013 4:28 am
That's a classic job for Beat Detective.
DC-Choppah
Postby Dodger » Sun May 19, 2013 11:45 pm
Ide always take the beat detective root. I found elastic audio to do weird things to the audio. Might be me doing it wrong but always done what I wanted to do with beat detective or manually moving things around and cross fading
Dodger
Postby DC-Choppah » Wed May 29, 2013 1:52 am
Beat detective doesn't alter the audio. It splits the whole track up into lots (perhaps thousands) of regions and then moves them around and crossfades between them to put the transients on a click or a tempo track that you derived from an audio track.
Elastic audio modifies the audio waveform itself, stretching the duration of a note perhaps while trying to fill in the time with the correct sound. It only works for small changes without adding artifacts to the sound. So if you had to move things far to line back up with a tempo track, it won't work.
DC-Choppah
