Using SchOPE Schwa with Logic 9
Postby JRobPiano » Tue Jun 18, 2013 3:44 pm
Dear Friends,
I recently downloaded Schwa for use with Logic 9 and, as I am sure you know, it is an amazing tool that has been extremely helpful when mixing! I am having some issues, however, and wanted to ask for any thoughts.
The plugin will not work on a mono track, period. The only way I am able to look at multiple inputs on the same graph is by creating a stereo bus with Schwa on it, then sending two channels, one panned hard left and the other panned hard right. Even with this arrangement, however, I am only able to look at two channels at once; in the Schwa plugin, the "left" channel shows up in inputs 1 and 3 and the "right" shows up in inputs 2 and 4.
Does anyone know of a way to route four separate channels to Schwa, or just an easier way to use this tool with Logic altogether? Any thoughts are much appreciated. Thanks!
JRobPiano
Users browsing this forum: Andyh 56 and 7 guests
