RSI sufferers.. good mouse product discovery
Postby SafeandSound Mastering » Fri Aug 02, 2013 10:03 am
So my rather pricey Quill (Aerobic) mouse was on the way out (won't track properly anymore) £100.00
I researched some options and came across something I liked to try out and it's good.
The unlikely titled "Anker" mouse, :ooo:
Unfortunate name jokes aside, almost as funny as the SPL MasterBay S (currently awaiting a model T :crazy:) It is is 80pct as good as the Quill mouse currently retailing for 8 x the price, now that is what I personally call a bargain ! (on extra special offer of £11.99 at the mo.)
Available from our somewhat controversial friends at Amazon...
http://www.amazon.co.uk/Anker-Vertical-Ergonomic-Optical-Ver...
This mouse actually has a higher quality feel than the expensive quill mouse, nicely weighted, soft touch surface, nice button sensitivity, well packaged. I suspect for those not used to a vertical mouse this will initially be slightly less alien in feel than the Quill mouse.
Of course if you have RSI go to a physiotherapist but this is a good starting point IMO.
All the best with it if you give it a try.
Album mastering - dedicated to mastering
Re: RSI sufferers.. good mouse product discovery
Postby Red Mastering » Fri Aug 02, 2013 3:38 pm
thx for info Barry,
I bought it on amazon to see how it works.
Currently using kensington 'express mouse' track ball. It indeed is the best thing I ever used, yet after long hours of use (including short breaks for exercise) - my hand feel a bit tired.
I will try this one and get back with short review.
Ta
Red Mastering
online mastering
Postby R_A » Sun Aug 04, 2013 7:31 am
R_A
Ambient / Classical Composer
Postby ManFromGlass » Sun Aug 04, 2013 1:37 pm
I have a vertical mouse, a regular sized wired mouse, a trackball and a small wireless mouse all connected at once. I did have that wireless track pad but hated it. I switch up every few days and I find it really helps my RSI. But 12 to 14 hour sessions take their toll. I even switch between the over-hyped/priced Aeron chair and a good quality kneeling chair which helps my back endure any necessary long hours. A wrist brace does help the RSI, as does getting the hell out of the chair and stretching or taking a quick walk. It goes without saying that all this after learning the proper suggested ratios of chair height to desk height to computer monitor height etc. I liked that post about keeping a tv turned on in the corner with the sound turned off in the room. It pulls your eyes and head away from always looking forward, and we do forget to turn our heads, keep our shoulders down and sometimes even breathe during focused work.
Eric
Postby G-Doubleyou » Sun Aug 04, 2013 5:28 pm
The problem is pushing/pulling moving an object around for long periods of time.
I use Apple's Magic Trackpad, it's a glass topped bluetooth trackpad, like on a laptop.
You only move your fingers, no stress on the hand wrist joint.
There are plenty of Windows versions available.
Previously I used a Wacom pad and stylus for navigation.
8-)
G-Doubleyou
G-Dub Studio G-fx 15inch quad-core i7 Macbook Pro, LPX 10.3.1
Postby grab » Sun Aug 04, 2013 8:51 pm
Alternatively, the problem may not be the mouse, it may be bad posture. If you've not seen a physio, do.
Also check your wrists. A *lot* of desks (I'd go so far as to say most desks) have quite sharp right-angle edges on them. If you're resting your wrists on the edge of the desk, that right-angle digs into all the nerves and tendons, which is very much ungood. Official advice is not to rest your arms on the desk. So then you get shoulder strain from supporting your arms out in front of you for hours at a time. Yeah right.
The best solution I've found is a desk with a return, and sit in the corner with the monitor at 45 degrees to both sides. You push the monitor right back of the desk, and your keyboard and mouse go a long way back too - a good foot or more. Then your elbows rest on the desk and return, your wrists don't touch anything, and you're sorted.
Next best solution is a chair with adjustable armrests. Same principle, except you use the armrests for support.
Both those suggestions come without any guarantee of success, sensibleness or medical competence, of course. All I can say is that I used to have problems with my arms, and I don't any more.
grab
Postby Dynamic Mike » Mon Aug 05, 2013 12:28 am
I agree with Grab, much of this is probably triggered by bad posture & positioning. Most of the pain I get is actually in my elbow, not my wrist or hand. Unfortunately for those of us looking for a left handed solution there is far less choice available. I normally use a wireless keyboard, a separate wireless number pad (so I can place it on the left) & a bog standard MS comfort mouse also on the left. The keypad doubles up as Cubase controller which is really handy for recording/mixing duties & saves stretching. A chair with arms isn't an option if you play a lot of guitar but I do have a very deep desk which helps.
Recently things have been getting worse so I though I'd try a trackball. This is definitely helping, although being a leftie means the scroll wheel works back to front (you can change most options in the software but unfortunately not this). Finally getting to the point, whilst it's too late to start using a mouse right-handed, I'm gonna give the trackball a try on the right. For some reason I feel I might be able to adapt to this & I've noticed most right handed people who normally moan about my mouse being on the left are fine with the trackball being there. If you've never used a trackball, buy one & try using it on the left.
Dynamic Mike
Currently struggling to find something to want
Postby SafeandSound Mastering » Mon Aug 05, 2013 8:11 am
Different symptoms and probably causes for different people. I was given some nerve stretches by my physio which are very good. My condition is largely under control with usually only minimal ache by the end of the week, fortunately. I went through a freelance employment period with a post production company where I was mainly editing and that started the situation off.
The Quill mouse absolutely made a big difference to my situation, the difference between working and not, along with my physio visits.
Postby Red Mastering » Tue Aug 13, 2013 5:09 pm
got he mouse,
it's def too small for my large hands:)
been using it for a week, so maybe it's too early to say
but good and inexpensive 'second/ mouse (as main one I use kensington trackball)
the truth is you need to make breaks and exercise or you gonna have suffer...
sometimes it's tough to have a break, I try to do break every few hours,
5-10 min exercise, making a tea and stretching,
cigarette break, etc:)
you can grab a small ball and exercise by squeezing it for example
Red Mastering
online mastering
Users browsing this forum: matthias4950
