creating best quality click tracks
Postby Alibi Productions » Mon Aug 05, 2013 1:25 pm
Hi all, i'm hoping someone can help clarify some things for me here - i've been creating click tracks for a little while for a band i play in and the way i have been working to do this is as follows:
Create the backing tracks/stem tracks etc as needed - mix them and and raise volume plus limit them to around -0.5db. Then import the bounced file into a new logic project and use the direction mixer to pan that mix to the right and create a click panned to the left. I'll usually mix the levels on this so that the click is around -15db and the main track is around -1-2db.
Are there technically any errors i'm making by working this way?
Does anyone else use a similar method or an entirely different method that works brilliantly or something?
Thanks in advance for your time!
Dave
Alibi Productions
follow me on SoundCloud: AlibiProductions
Users browsing this forum: Ben Asaro and 1 guest
