Harbeth P3ser Spendor S3/5R² vs 'modern monitors'
Postby J_J_Breeze » Tue Jun 10, 2014 7:18 pm
There's been a lot of interest in sealed box monitors recently. I wonder how do the likes of the Harbeth P3ser / Monitor 20.1 and Spendor S3/5R² compare in performance to modern monitors such as the AE22 and (non sealed) KH 120 A ?
The original BBC versions were presumably designed for dialogue, but the P3ser seems to be marketed to a music listening crowd and the Monitor 20.1 is a very similar speaker. So are the Harbeth P3ser / Monitor 20.1 and Spendor S3/5R² suitable for the production and mix down of modern acoustic / classical music and how do they stand up to the current competition?
J_J_Breeze
Ambient / Classical
Re: Harbeth P3ser Spendor S3/5R² vs 'modern monitors'
Postby fay spook » Tue Jun 10, 2014 8:05 pm
The Spendors and Harbeths you mention ARE modern monitors as you can still buy them today. The Neumanns are derived from the Klein & Hummel range that they were know as before. The AE22s are about the same age as the Spendor S3/5R², not the earlier versions of the Spendors but the current one.
I hope this clears things up for you!!
You will find the LS3/5a type speakers do lack some of the grunt of the AE22s, low cut off frequency and overall level. The different physical sizes will have some effect over how you perceive the stereo image. However the good news is that any of the speakers you mention will allow you to make sensible mix decisions. The Spendors and Harbeths aren't cheap and you will need a good quality amplifier for them. Others can eulogise about the Neumanns.
Do go and listen to them and report back.
How about this for an alternative, make your own
Falcon acoustics
fay spook
Postby fay spook » Tue Jun 10, 2014 9:08 pm
Sorry, I meant to add that you will find the Spendors and Harbeth very neutral. This is partially due to their bass loading but mainly from years of refinement and good design. These are companies that don't just throw speakers together. I would have them down as more neutral than the AE22s but I haven't done a side by side listen.
It will be worth getting them into the studio because I have found modern versions of the LS3/5A concept need some more breathing space around them to really open up. Probably because they are designed to work in a home hifi rather than on top of a meter bridge.
fay spook
Postby John Willett » Wed Jun 11, 2014 8:51 am
The Harbeth definitely *is* a modern monitor.
The Monitor 20 was designed to be the same size as the old BBC LS3/5a and to be "what the BBC would make had they designed the LS3/5a now".
The Monitor 20.1 is the latest version.
It is neutral and amazingly detailed, telling you everything you need to know - I would have bought a pair myself had they done an active version - as it is, I did have the passive version in my room for a few weeks; an excellent monitor.
John Willett
Postby Mixedup » Wed Jun 11, 2014 9:09 am
fay spook wrote:How about this for an alternative, make your own
Falcon acoustics
Interesting, but it's priced pretty steep considering it's in kit form, and doesn't include the T27 tweeters (about £85 for a pair) or any finish to the wood.
Mixedup
Postby J_J_Breeze » Wed Jun 11, 2014 9:15 am
How would you compare the Monitor 20.1's performance to the smaller KH speakers? And why was a passive monitor a no for you?
I guess that Harbeth don't make active models as their main market is hifi and the dealer would miss a sale - fair enough, running a business is tough, so you've got to think about your distribution!
Perhaps a SoS review of the Monitor 20.1 might be interesting?
J_J_Breeze
Ambient / Classical
Postby Zukan » Wed Jun 11, 2014 11:04 am
Falcon acoustics
Not sure why they do that M. Even the MS20 is priced too steeply for a kit jobbie.
Zukan
Samplecraze   Stretch That Note Masterclasses
Postby MarkOne » Wed Jun 11, 2014 11:12 am
fay spook wrote: Probably because they are designed to work in a home hifi rather than on top of a meter bridge.
I thought the BBC LS3/5A was designed to work tucked in the back of an OB truck... It was only later that someone said 'hey, wait a minute, these are pretty good HiFi speakers!'
MarkOne
Location: Bristol, England, Earth, Peruses Gap, Milky Way
Postby fay spook » Wed Jun 11, 2014 12:32 pm
Yes you are correct, my lazy typing trying to explain that the original BBC models weren't designed for a domestic environment. I think the 3 part of the name is for OB. They have a few lumps and bumps in their frequency response but in a typical listening position it's all sort of blends and works. A good speaker is a good speaker so it should be no surprise an extensively tested and developed speaker like the LS3/5a sounds good.
As for Falcons pricing, their T27 has only recently been developed so the kits have been priced without them. £400/650 for the kit........not my choice but look at the s/h prices for original models. Price up the low production runs for the new B110 & T27 and transformers in the crossovers. Even the grilles won't be cheap. But I can't decide what is value for others.
You can always get a JR149 or 150 instead. Whatever you do just have a listen yourself.
fay spook
Postby Jeraldo » Wed Jun 11, 2014 1:22 pm
I love my LS3/5a's made by Rogers. They are well made, and attractively so with fine wood finishes and with wonderfully liveried back panels. ;)
Very clear and untiring on the ears, with a surprising and measurable amount of low end extension available past the -3dB point.
Jeraldo
Postby John Willett » Thu Jun 12, 2014 8:57 am
They are both good, but I never compared them side by side.
The Harbeth M20.1 are sealed boxes and the KH120 are bass reflex.
The M20.1 are the same size but the next step up in quality from the LS3/5a.
Harbeth did make the M30 and M40 as actives and, in fact, did do an active M20 for a while - but by the time I realised it, they had discontinued it. I think they had trouble with their amp. manufacturer at the time.
The M20/30/40 range are all designed as professional monitors, which are Harbeth's roots, though the hi-fi units do seem to be their main business nowadays.
The reason I wanted actives is that I use them as location monitors and didn't want to have to carry around heavy amplifiers and loudspeaker cables - plus I wanted the accuracy that an electronic crossover and dedicated amps give. I used the K+H O110D for several years before upgrading to the Geithain RL906 in 2012.
John Willett
Postby Mixedup » Thu Jun 12, 2014 12:45 pm
Zukan wrote:
Falcon acoustics
Yeah. You know, you can pick up a set of KEF 104AB for about £100 (it's what one of my pairs fetched, and what I paid for each pair I bought). They have T27s in. And nice woofers. In fact they sound very nice. There are some lovely bargains to be had second hand - some of the 80s sealed box KEF things sound both beautiful and revealing (for instance, I have some Cantor IIIs that cost me £40). Now, I know the NS10 and the LS3/5a have a few specific qualities to recommend them, but so do some other speakers. It defies belief the price some people seem willing to pay for this stuff.
Mixedup
Postby fay spook » Thu Jun 12, 2014 4:03 pm
+1 to looking at options for monitors. The 104s can be a little large for bedroom studios. The B200 are worth money to collectors. However unless I am mistaken the 104s are as reflex as any other because they have an ABR as a substitute for the air in a port. Also if you look at their impedance curves and you will see the classic reflex dual hump. Also older speakers can require some tlc for ageing capacitors, loosening screws and tarnished connectors. And that's before ageing glue and irreplaceable drivers. For example the KEF 105 Daleks I've heard sounded very average with knackered tweeters but the B&W penguins -I can't remember the model number- still sounded relevant to sound like a fashion journalist!!
But there are many many forgotten about speakers you could use in a home studio. How about a Visonik David?
fay spook
Postby Mixedup » Thu Jun 12, 2014 4:17 pm
fay spook wrote:unless I am mistaken the 104s are as reflex as any other because they have an ABR as a substitute for the air in a port.
Yep. That's why I also mentioned the smaller Cantor III. Near enough to an NS10ish sort of size, three-way speaker, sealed box and sound great. You can blow the money you save on a decent amp ;)
Point taken about capacitors - but you're going to have that on any old electronics, and it's easily sorted (not like the consequences of the flaming/smoking oil-filled cap in my Hammond!)
Mixedup
Postby Hugh Robjohns » Thu Jun 12, 2014 4:58 pm
fay spook wrote:However unless I am mistaken the 104s are as reflex as any other because they have an ABR as a substitute for the air in a port.
Your memory is intact! ;) The 104s uses a reflex cabinet with an ABR instead of a simple port.
Wow! That brings back memories...
Postby vinyl_junkie » Thu Jun 12, 2014 5:23 pm
I have 104aB's, I quite like them in my studio.
Worth noting though that the response is "flat" on the tweeter axis with the acoustic counter control in the "+" position otherwise there is a little dip according to some one who worked for KEF.
He added when I asked him why this was done "There was a BBC paper by Harwood which advocated a hollowed out midrange to reduce "colouration". One such BBC design became the commercially successful Spendor BC1 and it could be said that the 104 was KEF's improved "version" of the BC1. The short coil in a long gap and the ABR replacing a hole in the cabinet, were certainly worthwhile improvements in linearity.
These designs got very good ratings in the very influential Hi-Fi Choice review books of that era. The Model 103 continued the trend, though some said that it was a step too far because of the resulting low subjective sensitivity."
Also the Calinda is essentially a improved 104aB but it wasn't made a "Reference" model cos the 104aB was still selling very well.
I re-capped my 104's x-over with the new ALCAP's Falcon sell and to be honest I couldn't hear much of a difference.. The only thing I seem to notice an improvement in stereo image, when things are mono it's definitely dead centre now.
The construction on these old KEF's is very good, no rattles or air leaks after all these years. The drivers also last well if looked after.
There are a few KEF drivers though that age pretty badly like the T33 where the ferro fluid gunks up the tweeter voice coil as it hardens with age.. But not on all T33's either, the T33 SP1074 is not fluid cooled and is fine, this was fitted to the 103.2 and 105.4.
Any whom back to sealed boxes... I also have some 103.2's, these sound fantastic with music, really suck you in and I do like the low end from the sealed cab. But I feel as if they've been "voiced" and not a very honest speaker. The 104aB may have it's flaws but I feel it shows up nasties in recordings way better than the 103.2
vinyl_junkie
Postby J_J_Breeze » Sun Jun 15, 2014 9:58 pm
Mixedup wrote:Yeah. You know, you can pick up a set of KEF 104AB for about £100 (it's what one of my pairs fetched, and what I paid for each pair I bought). They have T27s in. And nice woofers. In fact they sound very nice. There are some lovely bargains to be had second hand - some of the 80s sealed box KEF things sound both beautiful and revealing (for instance, I have some Cantor IIIs that cost me £40). Now, I know the NS10 and the LS3/5a have a few specific qualities to recommend them, but so do some other speakers. It defies belief the price some people seem willing to pay for this stuff.
I'm on the look out for some small reference monitors for a tiny acoustically treated spare bedroom ( W 210cm x H 252cm x L 350 ) - listening distance of only a meter. I'm interested in BBC style monitors as the space is small and listening distance so short... I thought the early bass roll of of small non ported designs would be handy so there's not loads bass bouncing around this small space.
Any monitor speaker recommendations? I've already got some HD650 headphones in.
J_J_Breeze
Ambient / Classical
Postby fay spook » Sun Jun 15, 2014 10:53 pm
Sealed boxes might start rolling off earlier than an equivalent ported speaker but the roll off is more gentle so in some ways you get more bass.
If you could give an idea of budget then there might be some better recommendations. Don't forget the BBC don't use as many BBC style monitors already mentioned. Some say the BBC sound is a little chesty, with rolled off treble and (relatively) limited dynamics- think what they were designed to monitor, FM radio tops out at 15k etc. some earlier monitors grew a super tweeter when a domestic version was made. Also this sort of engineering doesn't come cheap. Have a look at the prices of modern versions of some BBC monitors from people like Stirling. Finally you will see a lot of ported monitors- I've seen some technical arguments for reflex loading with larger bass drivers working better than for small ones.
To start look at the speakers mentioned here. Consider some Proacs - I find they sound like Proacs whichever model I hear rather than a window on the sound but others love them. Lots of Tablettes around. PMCs, plenty of the older Dynaudio drivered ones around.
fay spook
Postby J_J_Breeze » Sun Jun 15, 2014 11:14 pm
Thanks for your reply - I had a budget of about a grand in mind initially, money's not tight - if genuine benefits can be had by spending a bit more I'm okay with it... however I've got a nagging feeling there is going to be diminishing returns in such a small space. So open to any speakers that might do a good job for less...
J_J_Breeze
Ambient / Classical
Postby John Willett » Mon Jun 16, 2014 8:05 am
When I bought my monitors. I wanted something small for location recording (active for me), about the same sort of size as the BBC LS3/5a and accurate and trustworthy.
The Harbeth Monitor 20 came out top of the passive monitors for me (same size as the LS3/5a but better).
I tried the PMC DB1 powered monitors, but they did not pass the speech test.
In the end I bought the K+H O110 (now replaced by the Neumann KH120 and are about the best at around the £1k mark) and I used these for several years.
I eventually upgraded to the Geithain RL906, but these are over £2k.
My headphones are the HD800, HD650, HD25-1 and my monitor controller is the Grace m903.
John Willett
Postby John Willett » Mon Jun 16, 2014 8:08 am
Spending more *will* get the benefits, as I found out myself and eventually spent the extra (as I detail above).
But if you want to stick around the £1k price, then the KH120 are the ones I would go for, as to get better you have to about double the price.
John Willett
Postby James Perrett » Mon Jun 16, 2014 9:01 am
To throw a spanner into the works... When I first moved into my current house I set up a temporary studio in the back bedroom. I was hoping to get away with just using my ls3/5a's in there but I ended up moving in the big Tannoy monitors as there were a few times when I just wasn't sure that I was hearing the bass I needed to hear on the ls3/5a's. Well designed bass reflex speakers like the Tannoys don't put out huge amounts of uncontrolled bass and their dual concentric design means that the stereo image, even at the 1.5m distance I was working at, remains solid and focussed. So I would say that you have nothing to fear from well designed large speakers in your space.
http://www.jrpmusic.co.uk
Postby John Willett » Mon Jun 16, 2014 2:55 pm
James Perrett wrote:To throw a spanner into the works... When I first moved into my current house I set up a temporary studio in the back bedroom. I was hoping to get away with just using my ls3/5a's in there but I ended up moving in the big Tannoy monitors as there were a few times when I just wasn't sure that I was hearing the bass I needed to hear on the ls3/5a's. Well designed bass reflex speakers like the Tannoys don't put out huge amounts of uncontrolled bass and their dual concentric design means that the stereo image, even at the 1.5m distance I was working at, remains solid and focussed. So I would say that you have nothing to fear from well designed large speakers in your space.
The important words being "well designed".
I agree with you about dual concentric (co-axial) designs, which is why I changed.
John Willett
Postby fay spook » Tue Jun 17, 2014 5:37 pm
If you have a grand for passives you need to spend a fair bit on an amplifier to do them justice.
Looking on fleabay I can see some Spendor BC1s buy now £600. But LS3/5As up to £1500. There is an amazing looking JR149 and sub set for £650. These use the same drive units as the LS3/5As but with different crossover and a very different cabinet. I prefer them. Also a pair of JR150s for much the same money. These are the big brothers to the JR149s, with two bass drivers a side each.
New, things get expensive. Stirling Broadcast LS3/5As are about a grand. The Spendors are much the same. If you go up a size to a Spendor SP3 they are about £1800.
For leftfield pair, try and see if you can find some Etude speakers with only 2 BMR drivers a side and no crossover. Don't forget the Eclipse single driver speakers either.
Again, others have said all the good things they need to about the Neumanns etc but, go on, break the mould!!!
fay spook
Postby vinyl_junkie » Tue Jun 17, 2014 7:18 pm
KEF Reference 101's are similar to LS3/5A's Same drivers, different x-over, better cabinets and substantially cheaper. How does £200-£300 sound?
Some people have said they prefer them to 3/5a's too
http://www.kef.com/html/gb/explore/about_kef/museum/1970s/Re...
I don't care how good the 3/5a is I couldn't spend what people are paying on ebay for them now days especially considering what they used to sell for.. Must be just Asians buying them for the BBC heritage lol I could think of much better ways of spending £1-2000
vinyl_junkie
