External HDD help!?!?!
Postby vorbis » Sat Jun 11, 2011 7:57 pm
Hey guys, I'm posting this 'cos I'm desperate for help!
My WD 500GB External HDD (USB), failed mid backup and now doesn't appear in Devices. I can see it in System Profiler & Disk Utility but can't do anything with it, only get information. It won't eject through Disk Utility either. It's sitting here making noise and everything. A restart doesn't help, neither does a different USB port.
Any suggestions?! I have a lot of samples & work saved on this drive!
Simon
PS
'08 Macbook White
OSX 10.5.8
2.4Ghz Intel Core 2 Duo
4GB RAM
vorbis
Re: External HDD help!?!?!
Postby desmond » Sat Jun 11, 2011 8:04 pm
Pull the power to the drive (or hold down the power button if that works), shut down everything, and try a restart.
If the drive doesn't power up, the case electronics might be fried - the drive itself is probably fine. Just get another enclosure and put the drive into that.
If the drive does work and mount, then run a disk check and/or DiskWarrior on it to see whether there's any corruption etc.
Postby vorbis » Sat Jun 11, 2011 8:24 pm
Thanks! After several restarts and unplugging then replugging in everything, a cuppa and some head scratching it now randomly works...weird! I think I'll be shopping for a backup to backup my backups!
vorbis
Postby DAGGILARR » Sat Jun 11, 2011 9:06 pm
When that happened to me it was the enclosure got a can opener out removed the drive stuck it in a new enclosure and it was fine, still use it at times
One of these is a handy thing to have about
http://www.maplin.co.uk/sata-and-ide-hdd-docking-station-with-hub-and-cardreader-388318
DAGGILARR
iMac 27" i7 2.9gh 2010 12GB ram, Focusrite Pro24DSP.
Postby chris... » Sat Jun 11, 2011 9:37 pm
Probably handier, and MUCH cheaper - widget to connect a hard drive into a USB port:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=320383801768&ssPageName=STRK:MEWNX:IT
chris...
Postby DAGGILARR » Sun Jun 12, 2011 11:16 am
chris... wrote:Probably handier, and MUCH cheaper - widget to connect a hard drive into a USB port:
Yes this is what I use just could not find one, well done although it is a bit of a faf. Remember to remove the jumper if its a IDE. Fired one up the other day did not check the jumper, it did not show up in "my computer" misread the info that was there and proceeded to reformat a 650GB partition containing 450GB of files ..OUCH..
DAGGILARR
Postby desmond » Sun Jun 12, 2011 11:29 am
DAGGILARR wrote:misread the info that was there and proceeded to reformat a 650GB partition containing 450GB of files ..OUCH..
I'm *very* careful of this, as it's so easy to do. I normally go to the lengths of unmounting and disconnecting all of my drives except my system drive and the desired target drive before starting a format.
That way I can't do something I'll regret later... :headbang:
Postby vorbis » Tue Jun 14, 2011 8:52 am
Thanks for the replies! I'll experiment with this drive once all the data is transferred.
Funny you should say that because the very reason I got this drive was because I did something very similar on a PC a couple of years ago when I was just starting out, a lot poorer and didn't bother with backing up!
vorbis
Postby DAGGILARR » Tue Jun 14, 2011 2:18 pm
It happened when I was tired tired and angry just wanted to get the dam thing up an running and in the process lost a lot of stuff. I now need a new time machine drive for my imac. there is a Hitachi one that has automatic power control which is a nice idea, but the Samsung one is reported as being the quietest, any suggestions? has to be 2tb no need for FW or speed really just back up.
DAGGILARR
