Connect PC VST to MAC VST
Postby alexfree » Thu Oct 27, 2011 12:15 pm
Hi,
I have tried to find a solution, but without luck. My problem!
My setup mainly is Cubase 6 on Mac Pro!
Now I want to use the Poetic Acoustic Guitar VST (best service), but it is only on Windows OS!
Is it possible to interconnect a PC VST (windows) and a MAC VST and use the MAC as the host?
//Alex
alexfree
Re: Connect PC VST to MAC VST
Postby desmond » Thu Oct 27, 2011 12:23 pm
Yes, but it won't have good performance or be particularly reliable.
You'll need to run your PC code under an emulated PC in Fusion/Parallels/VirtualBox, and send MIDI via network MIDI (there are a variety of software solutions for this) and bring audio back over the network too.
Personally, I wouldn't bother, and I wouldn't be buying Windows software if my primary platform was the Mac either, but if you want to spend a while faffing around, give it a try.
Postby G-Doubleyou » Thu Oct 27, 2011 1:32 pm
You can use your PC like a midi module, and have your mac as the master, controlling the PC with midi messages.
Providing you have sequencers on both, and by routing the PC audio.
Or you could use VSL, on both machines, it's a host allows you to use your plugs, and communicate via ethernet.
Here are some videos http://www.vsl.co.at/en/211/1343/1348/1594/1245.vsl
8-)
G-Doubleyou
G-Dub Studio G-fx 15inch quad-core i7 Macbook Pro Logic9.1.8, LPX 10.0.3
Postby alexfree » Thu Oct 27, 2011 2:17 pm
Thanks guys!
Does VSL support 3rd party plugins?
I was first thinking of using Cubase VST link system, but then I probably need 2 licenses for Cubase!
alexfree
Postby desmond » Thu Oct 27, 2011 2:20 pm
Oh, sorry I thought you meant you wanted to use it on your Mac, didn't realise you also had a PC - in which case, as stated above, just use the PC as a sound module using a regular audio/MIDI interface to connect it - you can pipe that stuff over the network, but it's not a particularly satisfactory solution imo.
Postby Richie Royale » Thu Oct 27, 2011 2:59 pm
You could install Reaper to run the other software on the PC, nice and cheap.
Richie Royale
Postby alexfree » Thu Nov 03, 2011 9:34 pm
Vienna Ensemble Pro is the way to go!!
Tested it over Ethernet and it is working perfect, both in 64-bit and/or 32-bit at the same time!
//Alex
alexfree
