New ProMac System - problematic crashes
Postby Jonnypopisical » Tue May 22, 2012 9:06 am
Hi All,
Had a new System for a few month now and although it's very fast I get more crashes with Logic than I use to on my old G5! I've posted a crash log here to see if someone can make sense it it (I can't!) Seems to be when accessing audio files that have been muted for a while (like a day) - I've got 16GB of RAM, running 10.7.4 and it's a 3.2GHz Quadcore intel Xeon..I've got a Scarlett 2i2 audio interface.
Many thanks,
JP
Date/Time: 2012-05-22 10:01:07 +0100
OS Version: 10.7.4 (Build 11E53)
Architecture: x86_64
Report Version: 9
Command: Logic Pro
Path: /Applications/Logic Pro.app/Contents/MacOS/Logic Pro
Version: 9.1.7 (1700.57)
Build Version: 1
Project Name: Logic
Source Version: 17005700
Parent: launchd [141]
PID: 1991
Event: hang
Duration: 0.95s
Steps: 10 (100ms sampling interval)
Pageins: 0
Pageouts: 0
Process: Logic Pro [1991]
UID: 501
Thread 0x14a7e5 DispatchQueue 1
User stack:
10 DummyConnection::DummyConnection() + 86 (in Logic Pro) [0x10002a638]
10 NSProApplicationMain + 387 (in ProKit) [0x10120dc9f]
10 -[NSApplication run] + 555 (in AppKit) [0x7fff935230c6]
10 std::_Rb_tree<std::string, std::pair<std::string const, TOSCMessageData>, std::_Select1st<std::pair<std::string const, TOSCMessageData> >, std::less<std::string>, std::allocator<std::pair<std::string const, TOSCMessageData> > >::insert_unique(std::_Rb_tree_iterator<std::pair<std::string const, TOSCMessageData> >, std::pair<std::string const, TOSCMessageData> const&) + 292032 (in Logic Pro) [0x1005bdca0]
10 std::_Rb_tree<std::string, std::pair<std::string const, TOSCMessageData>, std::_Select1st<std::pair<std::string const, TOSCMessageData> >, std::less<std::string>, std::allocator<std::pair<std::string const, TOSCMessageData> > >::insert_unique(std::_Rb_tree_iterator<std::pair<std::string const, TOSCMessageData> >, std::pair<std::string const, TOSCMessageData> const&) + 311940 (in Logic Pro) [0x1005c2a64]
10 std::_Rb_tree<std::string, std::pair<std::string const, TOSCMessageData>, std::_Select1st<std::pair<std::string const, TOSCMessageData> >, std::less<std::string>, std::allocator<std::pair<std::string const, TOSCMessageData> > >::insert_unique(std::_Rb_tree_iterator<std::pair<std::string const, TOSCMessageData> >, std::pair<std::string const, TOSCMessageData> const&) + 291981 (in Logic Pro) [0x1005bdc6d]
10 -[NSProApplication sendEvent:] + 1829 (in ProKit) [0x10120ba6c]
10 -[NSApplication sendEvent:] + 5593 (in AppKit) [0x7fff9358ca55]
10 std::vector<SurvivingEvent, std::allocator<SurvivingEvent> >::_M_insert_aux(__gnu_cxx::__normal_iterator<SurvivingEvent*, std::vector<SurvivingEvent, std::allocator<SurvivingEvent> > >, SurvivingEvent const&) + 38147 (in Logic Pro) [0x1007784a3]
10 -[NSProWindow sendEvent:] + 242 (in ProKit) [0x10122facc]
10 -[NSWindow sendEvent:] + 6306 (in AppKit) [0x7fff935f3348]
10 std::_Rb_tree<std::string, std::pair<std::string const, TOSCMessageData>, std::_Select1st<std::pair<std::string const, TOSCMessageData> >, std::less<std::string>, std::allocator<std::pair<std::string const, TOSCMessageData> > >::insert_unique(std::_Rb_tree_iterator<std::pair<std::string const, TOSCMessageData> >, std::pair<std::string const, TOSCMessageData> const&) + 374310 (in Logic Pro) [0x1005d1e06]
10 std::vector<unsigned int, std::allocator<unsigned int> >::reserve(unsigned long) + 250856 (in Logic Pro) [0x100520da8]
10 std::vector<TTempoWarpMerge, std::allocator<TTempoWarpMerge> >::reserve(unsigned long) + 178014 (in Logic Pro) [0x1001b1cde]
10 std::vector<unsigned int, std::allocator<unsigned int> >::reserve(unsigned long) + 216181 (in Logic Pro) [0x100518635]
10 std::vector<unsigned int, std::allocator<unsigned int> >::reserve(unsigned long) + 286690 (in Logic Pro) [0x1005299a2]
10 std::vector<POINT, std::allocator<POINT> >::_M_insert_aux(__gnu_cxx::__normal_iterator<POINT*, std::vector<POINT, std::allocator<POINT> > >, POINT const&) + 237441 (in Logic Pro) [0x1002f38f1]
10 std::vector<POINT, std::allocator<POINT> >::_M_insert_aux(__gnu_cxx::__normal_iterator<POINT*, std::vector<POINT, std::allocator<POINT> > >, POINT const&) + 218630 (in Logic Pro) [0x1002eef76]
10 std::vector<MidiRegion, std::allocator<MidiRegion> >::_M_insert_aux(__gnu_cxx::__normal_iterator<MidiRegion*, std::vector<MidiRegion, std::allocator<MidiRegion> > >, MidiRegion const&) + 269565 (in Logic Pro) [0x10080d93d]
10 GetChannelIDForIndex(TAudioBusFormat, int) + 143893 (in Logic Pro) [0x10007bdd5]
10 std::vector<TTempoWarpMerge, std::allocator<TTempoWarpMerge> >::reserve(unsigned long) + 205344 (in Logic Pro) [0x1001b87a0]
10 std::vector<TTempoWarpMerge, std::allocator<TTempoWarpMerge> >::reserve(unsigned long) + 198613 (in Logic Pro) [0x1001b6d55]
10 -[NSObject performSelector:withObject:] + 61 (in CoreFoundation) [0x7fff8f89370d]
10 std::_Rb_tree<std::string, std::pair<std::string const, TOSCMessageData>, std::_Select1st<std::pair<std::string const, TOSCMessageData> >, std::less<std::string>, std::allocator<std::pair<std::string const, TOSCMessageData> > >::insert_unique(std::_Rb_tree_iterator<std::pair<std::string const, TOSCMessageData> >, std::pair<std::string const, TOSCMessageData> const&) + 128959 (in Logic Pro) [0x100595f9f]
10 std::_Rb_tree<std::string, std::pair<std::string const, TOSCMessageData>, std::_Select1st<std::pair<std::string const, TOSCMessageData> >, std::less<std::string>, std::allocator<std::pair<std::string const, TOSCMessageData> > >::insert_unique(std::_Rb_tree_iterator<std::pair<std::string const, TOSCMessageData> >, std::pair<std::string const, TOSCMessageData> const&) + 222383 (in Logic Pro) [0x1005acc8f]
10 std::_Rb_tree<std::string, std::pair<std::string const, TOSCMessageData>, std::_Select1st<std::pair<std::string const, TOSCMessageData> >, std::less<std::string>, std::allocator<std::pair<std::string const, TOSCMessageData> > >::insert_unique(std::_Rb_tree_iterator<std::pair<std::string const, TOSCMessageData> >, std::pair<std::string const, TOSCMessageData> const&) + 259606 (in Logic Pro) [0x1005b5df6]
10 std::_Rb_tree<std::string, std::pair<std::string const, TOSCMessageData>, std::_Select1st<std::pair<std::string const, TOSCMessageData> >, std::less<std::string>, std::allocator<std::pair<std::string const, TOSCMessageData> > >::insert_unique(std::_Rb_tree_iterator<std::pair<std::string const, TOSCMessageData> >, std::pair<std::string const, TOSCMessageData> const&) + 259534 (in Logic Pro) [0x1005b5dae]
10 std::_Rb_tree<std::string, std::pair<std::string const, TOSCMessageData>, std::_Select1st<std::pair<std::string const, TOSCMessageData> >, std::less<std::string>, std::allocator<std::pair<std::string const, TOSCMessageData> > >::insert_unique(std::_Rb_tree_iterator<std::pair<std::string const, TOSCMessageData> >, std::pair<std::string const, TOSCMessageData> const&) + 255088 (in Logic Pro) [0x1005b4c50]
10 std::_Rb_tree<std::string, std::pair<std::string const, TOSCMessageData>, std::_Select1st<std::pair<std::string const, TOSCMessageData> >, std::less<std::string>, std::allocator<std::pair<std::string const, TOSCMessageData> > >::insert_unique(std::_Rb_tree_iterator<std::pair<std::string const, TOSCMessageData> >, std::pair<std::string const, TOSCMessageData> const&) + 254571 (in Logic Pro) [0x1005b4a4b]
10 std::vector<SurvivingEvent, std::allocator<SurvivingEvent> >::_M_insert_aux(__gnu_cxx::__normal_iterator<SurvivingEvent*, std::vector<SurvivingEvent, std::allocator<SurvivingEvent> > >, SurvivingEvent const&) + 23572 (in Logic Pro) [0x100774bb4]
10 std::_Rb_tree<TPureClock, std::pair<TPureClock const, EuControlSwitch*>, std::_Select1st<std::pair<TPureClock const, EuControlSwitch*> >, std::less<TPureClock>, std::allocator<std::pair<TPureClock const, EuControlSwitch*> > >::insert_unique(std::pair<TPureClock const, EuControlSwitch*> const&) + 264986 (in Logic Pro) [0x1006c756a]
10 std::_Rb_tree<TPureClock, std::pair<TPureClock const, EuControlSwitch*>, std::_Select1st<std::pair<TPureClock const, EuControlSwitch*> >, std::less<TPureClock>, std::allocator<std::pair<TPureClock const, EuControlSwitch*> > >::insert_unique(std::pair<TPureClock const, EuControlSwitch*> const&) + 263968 (in Logic Pro) [0x1006c7170]
10 std::_Rb_tree<TPureClock, std::pair<TPureClock const, EuControlSwitch*>, std::_Select1st<std::pair<TPureClock const, EuControlSwitch*> >, std::less<TPureClock>, std::allocator<std::pair<TPureClock const, EuControlSwitch*> > >::insert_unique(std::pair<TPureClock const, EuControlSwitch*> const&) + 263710 (in Logic Pro) [0x1006c706e]
10 std::_Rb_tree<std::string, std::pair<std::string const, TOSCMessageData>, std::_Select1st<std::pair<std::string const, TOSCMessageData> >, std::less<std::string>, std::allocator<std::pair<std::string const, TOSCMessageData> > >::insert_unique(std::_Rb_tree_iterator<std::pair<std::string const, TOSCMessageData> >, std::pair<std::string const, TOSCMessageData> const&) + 287735 (in Logic Pro) [0x1005bcbd7]
10 std::_Rb_tree<std::string, std::pair<std::string const, TOSCMessageData>, std::_Select1st<std::pair<std::string const, TOSCMessageData> >, std::less<std::string>, std::allocator<std::pair<std::string const, TOSCMessageData> > >::insert_unique(std::_Rb_tree_iterator<std::pair<std::string const, TOSCMessageData> >, std::pair<std::string const, TOSCMessageData> const&) + 430276 (in Logic Pro) [0x1005df8a4]
10 std::_Rb_tree<TPureClock, std::pair<TPureClock const, EuControlSwitch*>, std::_Select1st<std::pair<TPureClock const, EuControlSwitch*> >, std::less<TPureClock>, std::allocator<std::pair<TPureClock const, EuControlSwitch*> > >::insert_unique(std::pair<TPureClock const, EuControlSwitch*> const&) + 272347 (in Logic Pro) [0x1006c922b]
10 std::vector<unsigned int, std::allocator<unsigned int> >::reserve(unsigned long) + 184356 (in Logic Pro) [0x1005109e4]
10 std::vector<unsigned int, std::allocator<unsigned int> >::reserve(unsigned long) + 183471 (in Logic Pro) [0x10051066f]
10 std::vector<unsigned int, std::allocator<unsigned int> >::reserve(unsigned long) + 183025 (in Logic Pro) [0x1005104b1]
10 std::vector<unsigned int, std::allocator<unsigned int> >::reserve(unsigned long) + 243868 (in Logic Pro) [0x10051f25c]
10 std::vector<unsigned int, std::allocator<unsigned int> >::reserve(unsigned long) + 255294 (in Logic Pro) [0x100521efe]
10 std::vector<unsigned int, std::allocator<unsigned int> >::reserve(unsigned long) + 170232 (in Logic Pro) [0x10050d2b8]
10 std::vector<CVirtualTrack, std::allocator<CVirtualTrack> >::operator=(std::vector<CVirtualTrack, std::allocator<CVirtualTrack> > const&) + 316037 (in Logic Pro) [0x100155535]
10 std::vector<POINT, std::allocator<POINT> >::_M_insert_aux(__gnu_cxx::__normal_iterator<POINT*, std::vector<POINT, std::allocator<POINT> > >, POINT const&) + 4188 (in Logic Pro) [0x1002ba9cc]
10 std::vector<unsigned int, std::allocator<unsigned int> >::reserve(unsigned long) + 181282 (in Logic Pro) [0x10050fde2]
10 std::vector<unsigned int, std::allocator<unsigned int> >::reserve(unsigned long) + 185396 (in Logic Pro) [0x100510df4]
10 std::vector<unsigned int, std::allocator<unsigned int> >::reserve(unsigned long) + 147955 (in Logic Pro) [0x100507bb3]
10 std::vector<unsigned int, std::allocator<unsigned int> >::reserve(unsigned long) + 185514 (in Logic Pro) [0x100510e6a]
10 std::vector<unsigned int, std::allocator<unsigned int> >::reserve(unsigned long) + 185070 (in Logic Pro) [0x100510cae]
10 std::vector<unsigned int, std::allocator<unsigned int> >::reserve(unsigned long) + 187048 (in Logic Pro) [0x100511468]
10 std::vector<unsigned int, std::allocator<unsigned int> >::reserve(unsigned long) + 184795 (in Logic Pro) [0x100510b9b]
10 std::vector<CVirtualTrack, std::allocator<CVirtualTrack> >::operator=(std::vector<CVirtualTrack, std::allocator<CVirtualTrack> > const&) + 360714 (in Logic Pro) [0x1001603ba]
10 std::vector<CVirtualTrack, std::allocator<CVirtualTrack> >::operator=(std::vector<CVirtualTrack, std::allocator<CVirtualTrack> > const&) + 342755 (in Logic Pro) [0x10015bd93]
10 std::vector<unsigned int, std::allocator<unsigned int> >::reserve(unsigned long) + 30260 (in Logic Pro) [0x1004eaff4]
10 std::vector<unsigned int, std::allocator<unsigned int> >::reserve(unsigned long) + 199913 (in Logic Pro) [0x1005146a9]
10 -[NSBundle localizedStringForKey:value:table:] + 72 (in Foundation) [0x7fff96ba0632]
10 CFBundleCopyLocalizedString + 1357 (in CoreFoundation) [0x7fff8f84268d]
10 CFDictionaryGetValue + 143 (in CoreFoundation) [0x7fff8f8018ef]
10 ??? (in Logic Pro) [0x87]
10 _sigtramp + 26 (in libsystem_c.dylib) [0x7fff91509cfa]
10 std::_Rb_tree<short, std::pair<short const, CGRect>, std::_Select1st<std::pair<short const, CGRect> >, std::less<short>, std::allocator<std::pair<short const, CGRect> > >::_M_erase(std::_Rb_tree_node<std::pair<short const, CGRect> >*) + 98331 (in Logic Pro) [0x1003b1d9b]
10 -[NSDocument(NSDeprecated) saveToURL:ofType:forSaveOperation:error:] + 310 (in AppKit) [0x7fff938e0ccd]
10 -[NSDocument _coordinateReadingContentsAndWritingItemAtURL:error:byAccessor:] + 284 (in AppKit) [0x7fff938c6a07]
10 -[NSFileCoordinator coordinateReadingItemAtURL:options:writingItemAtURL:options:error:byAccessor:] + 96 (in Foundation) [0x7fff96d4865f]
10 -[NSFileCoordinator(NSPrivate) _coordinateReadingItemAtURL:options:writingItemAtURL:options:error:byAccessor:] + 829 (in Foundation) [0x7fff96d4be35]
10 -[NSFileCoordinator(NSPrivate) _invokeAccessor:orDont:thenRelinquishAccessClaimForID:] + 207 (in Foundation) [0x7fff96d48a5d]
10 __-[NSFileCoordinator coordinateReadingItemAtURL:options:writingItemAtURL:options:error:byAccessor:]_block_invoke_1 + 121 (in Foundation) [0x7fff96d486de]
10 __-[NSDocument(NSDeprecated) saveToURL:ofType:forSaveOperation:error:]_block_invoke_1 + 188 (in AppKit) [0x7fff938de970]
10 __-[NSDocument(NSDeprecated) saveToURL:ofType:forSaveOperation:error:]_block_invoke_2 + 272 (in AppKit) [0x7fff938deab0]
10 std::_Rb_tree<std::string, std::pair<std::string const, TOSCMessageData>, std::_Select1st<std::pair<std::string const, TOSCMessageData> >, std::less<std::string>, std::allocator<std::pair<std::string const, TOSCMessageData> > >::insert_unique(std::_Rb_tree_iterator<std::pair<std::string const, TOSCMessageData> >, std::pair<std::string const, TOSCMessageData> const&) + 172068 (in Logic Pro) [0x1005a0804]
10 std::_Rb_tree<std::string, std::pair<std::string const, TOSCMessageData>, std::_Select1st<std::pair<std::string const, TOSCMessageData> >, std::less<std::string>, std::allocator<std::pair<std::string const, TOSCMessageData> > >::insert_unique(std::_Rb_tree_iterator<std::pair<std::string const, TOSCMessageData> >, std::pair<std::string const, TOSCMessageData> const&) + 326469 (in Logic Pro) [0x1005c6325]
10 std::vector<CONTEXTMENUITEM, std::allocator<CONTEXTMENUITEM> >::_M_insert_aux(__gnu_cxx::__normal_iterator<CONTEXTMENUITEM*, std::vector<CONTEXTMENUITEM, std::allocator<CONTEXTMENUITEM> > >, CONTEXTMENUITEM const&) + 13386 (in Logic Pro) [0x10026ebea]
10 GetChannelIDForIndex(TAudioBusFormat, int) + 81409 (in Logic Pro) [0x10006c9c1]
10 std::vector<MidiRegion, std::allocator<MidiRegion> >::_M_insert_aux(__gnu_cxx::__normal_iterator<MidiRegion*, std::vector<MidiRegion, std::allocator<MidiRegion> > >, MidiRegion const&) + 378119 (in Logic Pro) [0x100828147]
10 ??? (in MAToolKit) [0x1031eba27]
10 std::vector<MidiRegion, std::allocator<MidiRegion> >::_M_insert_aux(__gnu_cxx::__normal_iterator<MidiRegion*, std::vector<MidiRegion, std::allocator<MidiRegion> > >, MidiRegion const&) + 373627 (in Logic Pro) [0x100826fbb]
10 -[NSObject(NSThreadPerformAdditions) performSelectorOnMainThread:withObject:waitUntilDone:] + 135 (in Foundation) [0x7fff96bab407]
10 -[NSObject(NSThreadPerformAdditions) performSelector:onThread:withObject:waitUntilDone:modes:] + 235 (in Foundation) [0x7fff96bab570]
10 -[NSProPanel orderWindow:relativeTo:] + 43 (in ProKit) [0x10122e3fb]
10 -[NSWindow orderWindow:relativeTo:] + 154 (in AppKit) [0x7fff9362002c]
10 -[NSWindow _doOrderWindow:relativeTo:findKey:forCounter:force:isModal:] + 807 (in AppKit) [0x7fff936203a8]
10 -[NSProPanel(_ProSplash) _reallyDoOrderWindow:relativeTo:findKey:forCounter:force:isModal:] + 133 (in ProKit) [0x10120e089]
10 -[NSWindow _reallyDoOrderWindow:relativeTo:findKey:forCounter:force:isModal:] + 3152 (in AppKit) [0x7fff936210e1]
10 -[NSWindow _orderOutAndCalcKeyWithCounter:stillVisible:docWindow:] + 874 (in AppKit) [0x7fff936a7968]
10 -[NSWindow _changeKeyAndMainLimitedOK:] + 690 (in AppKit) [0x7fff9361fd86]
10 std::vector<SurvivingEvent, std::allocator<SurvivingEvent> >::_M_insert_aux(__gnu_cxx::__normal_iterator<SurvivingEvent*, std::vector<SurvivingEvent, std::allocator<SurvivingEvent> > >, SurvivingEvent const&) + 23164 (in Logic Pro) [0x100774a1c]
10 objc_msgSend + 16 (in libobjc.A.dylib) [0x7fff8ae5ce90]
Kernel stack:
10 hndl_alltraps + 225 (in mach_kernel) [0xffffff80002d9ff1]
10 user_trap + 711 (in mach_kernel) [0xffffff80002c4017]
9 exception_triage + 193 (in mach_kernel) [0xffffff8000220e41]
9 exception_deliver + 511 (in mach_kernel) [0xffffff8000220b1f]
9 mach_exception_raise + 183 (in mach_kernel) [0xffffff800024e8e7]
9 mach_msg_rpc_from_kernel_body + 277 (in mach_kernel) [0xffffff80002239d5]
9 ipc_mqueue_receive + 70 (in mach_kernel) [0xffffff8000215886]
7 thread_block_reason + 275 (in mach_kernel) [0xffffff800022f413]
7 thread_go + 608 (in mach_kernel) [0xffffff800022e060]
7 processor_idle + 149 (in mach_kernel) [0xffffff800022d375]
7 machine_idle + 289 (in mach_kernel) [0xffffff80002c63f1]
1 thread_block_reason + 357 (in mach_kernel) [0xffffff800022f465]
1 ml_set_interrupts_enabled + 23 (in mach_kernel) [0xffffff80002be337]
1 thread_block_reason + 299 (in mach_kernel) [0xffffff800022f42b]
1 thread_continue + 1661 (in mach_kernel) [0xffffff800022f1ad]
1 machine_switch_context + 361 (in mach_kernel) [0xffffff80002c2939]
1 exception_triage + 149 (in mach_kernel) [0xffffff8000220e15]
1 exception_deliver + 97 (in mach_kernel) [0xffffff8000220981]
1 lck_mtx_unlock + 192 (in mach_kernel) [0xffffff80002b5710]
Thread 0x14a7f0 DispatchQueue 2
User stack:
10 _dispatch_mgr_thread + 54 (in libdispatch.dylib) [0x7fff8f7f331a]
10 kevent + 10 (in libsystem_kernel.dylib) [0x7fff8adcb7e6]
Kernel stack:
10 kqueue_scan + 416 (in mach_kernel) [0xffffff800053a660]
Thread 0x14a7f7
User stack:
10 thread_start + 13 (in libsystem_c.dylib) [0x7fff914b8b75]
10 _pthread_start + 335 (in libsystem_c.dylib) [0x7fff914b58bf]
10 __NSThread__main__ + 1575 (in Foundation) [0x7fff96bb66a2]
10 -[NSThread main] + 68 (in Foundation) [0x7fff96bb672a]
10 +[NSURLConnection(NSURLConnectionReallyInternal) _resourceLoadLoop:] + 335 (in Foundation) [0x7fff96bc1fd7]
10 CFRunLoopRunSpecific + 230 (in CoreFoundation) [0x7fff8f838486]
10 __CFRunLoopRun + 1204 (in CoreFoundation) [0x7fff8f838c74]
10 __CFRunLoopServiceMachPort + 188 (in CoreFoundation) [0x7fff8f83050c]
10 mach_msg_trap + 10 (in libsystem_kernel.dylib) [0x7fff8adc967a]
Kernel stack:
10 ipc_mqueue_receive_continue + 0 (in mach_kernel) [0xffffff8000215930]
Thread 0x14a804
User stack:
10 __select + 10 (in libsystem_kernel.dylib) [0x7fff8adcadf2]
Kernel stack:
10 wakeup + 992 (in mach_kernel) [0xffffff8000555010]
Thread 0x14ab1d
User stack:
10 CAudioFileBlockManager::GetBlock(MDFile const*, long, int) + 2064 (in MAAudioEngine) [0x103125140]
10 __psynch_cvwait + 10 (in libsystem_kernel.dylib) [0x7fff8adcabca]
Kernel stack:
10 psynch_cvcontinue + 0 (in mach_kernel) [0xffffff800059daa0]
Thread 0x14ab46
User stack:
10 CAPThread::Entry(CAPThread*) + 98 (in CoreMIDI) [0x1016dd396]
10 XThread::RunHelper(void*) + 10 (in CoreMIDI) [0x1016dd96a]
10 MIDIProcess::RunMIDIInThread() + 207 (in CoreMIDI) [0x1016fd653]
10 XServerMachPort::ReceiveMessage(int&, void*, int&) + 96 (in CoreMIDI) [0x1016dc5be]
Kernel stack:
Thread 0x14ab47
User stack:
10 TimerThread + 332 (in CarbonCore) [0x7fff954a36dc]
10 TSWaitOnSemaphoreCommon + 358 (in CarbonCore) [0x7fff9544dc9b]
10 TSWaitOnConditionTimedRelative + 157 (in CarbonCore) [0x7fff9544dec4]
Kernel stack:
Thread 0x151ccc
User stack:
10 std::vector<MidiRegion, std::allocator<MidiRegion> >::_M_insert_aux(__gnu_cxx::__normal_iterator<MidiRegion*, std::vector<MidiRegion, std::allocator<MidiRegion> > >, MidiRegion const&) + 381742 (in Logic Pro) [0x100828f6e]
10 ??? (in MAToolKit) [0x1031eae2f]
10 -[NSObject(NSThreadPerformAdditions) performSelector:onThread:withObject:waitUntilDone:modes:] + 975 (in Foundation) [0x7fff96bab854]
10 -[NSCondition wait] + 261 (in Foundation) [0x7fff96bb84c0]
Kernel stack:
Thread 0x151cdd
User stack:
10 -[NSUIHeartBeat _heartBeatThread:] + 1727 (in AppKit) [0x7fff9375b4d3]
10 usleep + 53 (in libsystem_c.dylib) [0x7fff9146bbb5]
10 __semwait_signal + 10 (in libsystem_kernel.dylib) [0x7fff8adcae42]
Kernel stack:
10 semaphore_wait_continue + 0 (in mach_kernel) [0xffffff8000234650]
Binary Images:
0x100000000 - 0x100c15ff7 com.apple.logic.pro 9.1.7 (1700.57) <0FDF8E7F-0CCD-ECA3-2441-D4A0B3824CF9> /Applications/Logic Pro.app/Contents/MacOS/Logic Pro
0x1011ef000 - 0x10146afe7 com.apple.prokit 7.2.2 (1817) <D06E4F46-2424-3689-810E-2E4B8CACA3CC> /System/Library/PrivateFrameworks/ProKit.framework/Versions/A/ProKit
0x1016cd000 - 0x10171eff7 com.apple.audio.midi.CoreMIDI 1.8 (42) <10BAC42F-ACFE-3EBC-869A-2847A0770CE8> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x1030f5000 - 0x103171fe7 com.apple.music.apps.MAAudioEngine 9.1.7 (158.32) <D1DF9B37-D550-B036-C469-659F71C6D12B> /Applications/Logic Pro.app/Contents/Frameworks/MAAudioEngine.framework/Versions/A/MAAudioEngine
0x1031e5000 - 0x1031f0fff com.apple.music.apps.MAToolKit 9.1.7 (357.98) <7481B55A-8BC6-441F-7977-684B512FFBB9> /Applications/Logic Pro.app/Contents/Frameworks/MAToolKit.framework/Versions/A/MAToolKit
0x7fff8adb4000 - 0x7fff8add4fff libsystem_kernel.dylib ??? (???) <1DDC0B0F-DB2A-34D6-895D-E5B2B5618946> /usr/lib/system/libsystem_kernel.dylib
0x7fff8ae53000 - 0x7fff8af37e5f libobjc.A.dylib ??? (???) <871E688B-CF57-3BC7-80D6-F6476DFF109B> /usr/lib/libobjc.A.dylib
0x7fff8f7f1000 - 0x7fff8f7fffff libdispatch.dylib ??? (???) <1D5BE322-A9B9-3BCE-8FAC-076FB07CF54A> /usr/lib/system/libdispatch.dylib
0x7fff8f800000 - 0x7fff8f9d4ff7 com.apple.CoreFoundation 6.7.2 (635.21) <62A3402E-A4E7-391F-AD20-1EF20236CE1B> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff91467000 - 0x7fff91544fef libsystem_c.dylib ??? (???) <41B43515-2806-3FBC-ACF1-A16F35B7E290> /usr/lib/system/libsystem_c.dylib
0x7fff9351e000 - 0x7fff94124ff7 com.apple.AppKit 6.7.3 (1138.47) <CAF5783F-F80B-30E7-929F-BBA6D96C5C44> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff9540a000 - 0x7fff95726fff com.apple.CoreServices.CarbonCore 960.24 (960.24) <6F99A26B-788F-37B9-860F-508906EC06D7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff96b5c000 - 0x7fff96e75fff com.apple.Foundation 6.7.2 (833.25) <22AAC369-B63C-3C55-8AC6-C3ECBA44DA7B> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
Process: AirPort Base Station Agent [195]
Path: /System/Library/CoreServices/AirPort Base Station Agent.app/Contents/MacOS/AirPort Base Station Agent
UID: 501
Thread 0x5a9 DispatchQueue 1
User stack:
10 ??? (in AirPort Base Station Agent) [0x10ef89654]
10 ??? (in AirPort Base Station Agent) [0x10ef9a353]
10 CFRunLoopRun + 95 (in CoreFoundation) [0x7fff8f84819f]
Kernel stack:
Thread 0x5b2 DispatchQueue 2
User stack:
Kernel stack:
Thread 0x5b8
User stack:
Kernel stack:
Binary Images:
0x10ef88000 - 0x10ef9ffff com.apple.AirPortBaseStationAgent 1.5.5 (155.7) <0D37CC05-D1C6-3C6C-BACD-A88D4BD4C3CD> /System/Library/CoreServices/AirPort Base Station Agent.app/Contents/MacOS/AirPort Base Station Agent
Process: aosnotifyd [1945]
Path: /usr/sbin/aosnotifyd
UID: 0
Thread 0x13307b DispatchQueue 1
User stack:
10 start + 52 (in aosnotifyd) [0x1063c60b4]
10 main + 74 (in aosnotifyd) [0x1063cd9ec]
10 -[AOSNotificationDaemon startup] + 1294 (in aosnotifyd) [0x1063cd7b3]
10 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 267 (in Foundation) [0x7fff96b67f7b]
Kernel stack:
Thread 0x13308d DispatchQueue 2
User stack:
Kernel stack:
Binary Images:
0x1063c4000 - 0x106405fff aosnotifyd ??? (???) <5287944C-EDF3-3175-81A3-CC1BEF4E43F7> /usr/sbin/aosnotifyd
Process: applepushserviced [52]
Path: /System/Library/PrivateFrameworks/ApplePushService.framework/applepushserviced
UID: 0
Thread 0x214 DispatchQueue 1
User stack:
10 ??? (in applepushserviced) [0x107aa18d4]
10 ??? (in applepushserviced) [0x107aa19b8]
10 -[NSRunLoop(NSRunLoop) run] + 62 (in Foundation) [0x7fff96b67e67]
Kernel stack:
Thread 0x24c DispatchQueue 2
User stack:
Kernel stack:
Thread 0x614
User stack:
Kernel stack:
Binary Images:
0x107aa0000 - 0x107b0eff7 applepushserviced ??? (???) <95759366-ACD2-358F-B4C3-A276E2B287C1> /System/Library/PrivateFrameworks/ApplePushService.framework/applepushserviced
Process: AppleSpell [249]
Path: /System/Library/Services/AppleSpell.service/Contents/MacOS/AppleSpell
UID: 501
Thread 0xb8e DispatchQueue 1
User stack:
10 ??? (in AppleSpell) [0x10a135a7c]
10 ??? (in AppleSpell) [0x10a135d2e]
10 -[NSSpellServer run] + 74 (in Foundation) [0x7fff96cb8c76]
Kernel stack:
Thread 0xbb7 DispatchQueue 2
User stack:
Kernel stack:
Binary Images:
0x10a134000 - 0x10a1f0ff7 com.apple.AppleSpell 1.7.1 (131.1) <A994D9F1-C4D8-3361-B0F4-112A7BAED8BD> /System/Library/Services/AppleSpell.service/Contents/MacOS/AppleSpell
Process: autofsd [50]
Path: /usr/libexec/autofsd
UID: 0
Thread 0x22b DispatchQueue 2
User stack:
Kernel stack:
Thread 0x22c DispatchQueue 6
User stack:
10 _dispatch_sig_thread + 45 (in libdispatch.dylib) [0x7fff8f7f5b20]
10 __sigsuspend_nocancel + 10 (in libsystem_kernel.dylib) [0x7fff8adcb022]
Kernel stack:
Thread 0x151efc
User stack:
10 start_wqthread + 13 (in libsystem_c.dylib) [0x7fff914b8b85]
10 __workq_kernreturn + 10 (in libsystem_kernel.dylib) [0x7fff8adcb192]
Kernel stack:
10 workqueue_exit + 1616 (in mach_kernel) [0xffffff80005a4200]
Binary Images:
0x10a38b000 - 0x10a38cfff autofsd ??? (???) <A02D5E70-1BB1-30ED-A699-375CB0CCE901> /usr/libexec/autofsd
Process: blued [49]
Path: /usr/sbin/blued
UID: 0
Thread 0x211 DispatchQueue 1
User stack:
10 ??? (in blued) [0x10c690890]
10 ??? (in blued) [0x10c6c6e4f]
Kernel stack:
Thread 0x236 DispatchQueue 2
User stack:
Kernel stack:
Thread 0x376
User stack:
Kernel stack:
Binary Images:
0x10c68f000 - 0x10c747ff7 blued ??? (???) <E58F9453-9716-3A2F-97FB-0B544B7A1EB1> /usr/sbin/blued
Process: com.apple.dock.extra [207]
Path: /System/Library/CoreServices/Dock.app/Contents/XPCServices/com.apple.dock.extra.xpc/Contents/MacOS/com.apple.dock.extra
UID: 501
Thread 0x616 DispatchQueue 1
User stack:
10 ??? (in com.apple.dock.extra) [0x10b72d474]
10 xpc_service_main + 448 (in XPCService) [0x7fff9639b5ed]
10 NSApplicationMain + 867 (in AppKit) [0x7fff9379f244]
10 -[NSApplication run] + 470 (in AppKit) [0x7fff93523071]
10 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 135 (in AppKit) [0x7fff93526735]
10 _DPSNextEvent + 659 (in AppKit) [0x7fff93526e31]
10 BlockUntilNextEventMatchingListInMode + 62 (in HIToolbox) [0x7fff90e7360e]
10 ReceiveNextEventCommon + 355 (in HIToolbox) [0x7fff90e73781]
10 RunCurrentEventLoopInMode + 277 (in HIToolbox) [0x7fff90e6c4d3]
Kernel stack:
Thread 0x61c DispatchQueue 2
User stack:
Kernel stack:
Binary Images:
0x10b72c000 - 0x10b730ff7 com.apple.dock.extra 1.0 (1) <A463D32E-8F7C-32B4-8DE2-3CD131ECE6F9> /System/Library/CoreServices/Dock.app/Contents/XPCServices/com.apple.dock.extra.xpc/Contents/MacOS/com.apple.dock.extra
0x7fff90e6a000 - 0x7fff91196ff7 com.apple.HIToolbox 1.9 (???) <B7D2A06B-7BE5-3355-BF7D-8139100B9B97> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff96399000 - 0x7fff963a0ff7 com.apple.XPCService 1.3 (1) <4C0AE300-9325-3950-A132-1562C03B05CE> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
Process: configd [15]
Path: /usr/libexec/configd
UID: 0
Thread 0x1d1 DispatchQueue 1
User stack:
10 ??? (in configd) [0x102eb6d64]
10 ??? (in configd) [0x102eb751b]
10 ??? (in configd) [0x102eb7e20]
Kernel stack:
Thread 0x1d4 DispatchQueue 2
User stack:
10 __select_nocancel + 10 (in libsystem_kernel.dylib) [0x7fff8adcae06]
Kernel stack:
Thread 0x1d6
User stack:
10 ??? (in configd) [0x102eb87fe]
Kernel stack:
Thread 0x251
User stack:
10 ??? (in configd) [0x102ec3165]
Kernel stack:
Thread 0x341
User stack:
Kernel stack:
Thread 0x342
User stack:
10 pppcntl_run_thread + 2194 (in PPPController) [0x1032f4142]
Kernel stack:
Thread 0x151f1e
User stack:
Kernel stack:
Binary Images:
0x102eb6000 - 0x102edffff configd ??? (???) <68DC2451-9DFB-389B-B728-C6A200559980> /usr/libexec/configd
0x1032e6000 - 0x103325fff com.apple.SystemConfiguration.PPPController 1.7 (1.7) <B7E747DA-0A96-3020-9C48-BAF6870700F3> /System/Library/SystemConfiguration/PPPController.bundle/Contents/MacOS/PPPController
Process: ConversionHelperService [2045]
Path: /Applications/Logic Pro.app/Contents/Frameworks/MAFiles.framework/Resources/ConversionHelperService
Architecture: unknown
UID: 501
Process: cookied [1938]
Path: /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/Support/cookied
UID: 501
Thread 0x1324bc DispatchQueue 1
User stack:
10 ??? (in cookied) [0x10026beec]
10 _cookied_main + 852 (in CFNetwork) [0x7fff90dc5d7d]
Kernel stack:
Thread 0x1324bd DispatchQueue 2
User stack:
Kernel stack:
Binary Images:
0x10026b000 - 0x10026bfff cookied ??? (???) <59191DC7-027D-3E6F-B391-594651AA3423> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/Support/cookied
0x7fff90cd6000 - 0x7fff90e3dfff com.apple.CFNetwork 520.4.3 (520.4.3) <31D7A595-375E-341A-8E97-21E73CC62E4A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
Process: coreaudiod [138]
Path: /usr/sbin/coreaudiod
UID: 202
Thread 0x49d DispatchQueue 1
User stack:
10 ??? (in coreaudiod) [0x1015634a4]
10 ??? (in coreaudiod) [0x1015cbc3c]
Kernel stack:
Thread 0x49f DispatchQueue 2
User stack:
Kernel stack:
Thread 0x4a9
User stack:
10 CAPThread::Entry(CAPThread*) + 98 (in CoreAudio) [0x7fff8b04f4c2]
10 HALRunLoop::OwnThread(void*) + 159 (in CoreAudio) [0x7fff8b04c2df]
Kernel stack:
Thread 0x4ad
User stack:
10 ??? (in coreaudiod) [0x1015d5dc2]
10 ??? (in coreaudiod) [0x1015cf8ce]
10 ??? (in coreaudiod) [0x1015cf95e]
10 ??? (in coreaudiod) [0x1015cf7a2]
Kernel stack:
Thread 0x151f21
User stack:
Kernel stack:
Binary Images:
0x101562000 - 0x101622ff7 coreaudiod ??? (???) <462B66C8-EE88-3F9A-A64B-98C399EE116D> /usr/sbin/coreaudiod
0x7fff8b008000 - 0x7fff8b070ff7 com.apple.audio.CoreAudio 4.0.2 (4.0.2) <DFD8F4DE-3B45-3A2E-9CBE-FD8D5DD30923> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
Process: coreservicesd [56]
Path: /System/Library/CoreServices/coreservicesd
UID: 0
Thread 0x228 DispatchQueue 1
User stack:
10 ??? (in coreservicesd) [0x10c418e98]
10 _CoreServicesServerMain + 747 (in CarbonCore) [0x7fff954a6999]
Kernel stack:
Thread 0x239 DispatchQueue 2
User stack:
Kernel stack:
Thread 0x350
User stack:
10 fmodWatchConsumer + 332 (in CarbonCore) [0x7fff95417870]
Kernel stack:
Thread 0x351
User stack:
10 read + 10 (in libsystem_kernel.dylib) [0x7fff8adcbaf2]
Kernel stack:
10 hndl_unix_scall64 + 19 (in mach_kernel) [0xffffff80002daa13]
10 unix_syscall64 + 507 (in mach_kernel) [0xffffff80005cd61b]
10 read_nocancel + 120 (in mach_kernel) [0xffffff8000564758]
10 write + 209 (in mach_kernel) [0xffffff8000564051]
10 get_pathbuff + 3895 (in mach_kernel) [0xffffff8000326397]
10 tsleep + 91 (in mach_kernel) [0xffffff800055528b]
10 wakeup + 632 (in mach_kernel) [0xffffff8000554ea8]
10 thread_block_reason + 299 (in mach_kernel) [0xffffff800022f42b]
10 thread_continue + 1661 (in mach_kernel) [0xffffff800022f1ad]
10 machine_switch_context + 361 (in mach_kernel) [0xffffff80002c2939]
Thread 0x151f18
User stack:
Kernel stack:
Binary Images:
0x10c418000 - 0x10c418fff coreservicesd ??? (???) <91E520FB-2E13-33C6-ABBC-473AD59A2286> /System/Library/CoreServices/coreservicesd
Process: cupsd [2056]
Path: /usr/sbin/cupsd
UID: 0
Thread 0x1501f0 DispatchQueue 1
User stack:
10 ??? (in cupsd) [0x10750cc30]
10 ??? (in cupsd) [0x107526648]
Kernel stack:
Thread 0x1501f2 DispatchQueue 2
User stack:
Kernel stack:
Thread 0x1501f6
User stack:
10 ??? (in cupsd) [0x1075518f9]
Kernel stack:
Binary Images:
0x10750b000 - 0x10756bff7 cupsd ??? (???) <EA5F96D1-2110-390A-8B3B-23EF01AF50F2> /usr/sbin/cupsd
Process: CVMServer [124]
Path: /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/CVMServer
UID: 0
Thread 0x465 DispatchQueue 1
User stack:
10 ??? (in CVMServer) [0x1011af508]
10 ??? (in CVMServer) [0x1011b4aec]
10 mach_msg_server + 413 (in libsystem_kernel.dylib) [0x7fff8adc9238]
10 mach_msg_overwrite_trap + 10 (in libsystem_kernel.dylib) [0x7fff8adc9686]
Kernel stack:
Binary Images:
0x1011ae000 - 0x1011b7fff CVMServer ??? (???) <16B526F8-94EC-368B-BA31-3D9CBA77D75F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/CVMServer
Process: DashboardClient [913]
Path: /System/Library/CoreServices/Dock.app/Contents/Resources/DashboardClient.app/Contents/MacOS/DashboardClient
UID: 501
Thread 0x90dda DispatchQueue 1
User stack:
10 ??? (in DashboardClient) [0x10c7c6e88]
10 ??? (in DashboardClient) [0x10c7cae56]
Kernel stack:
Thread 0x90de1 DispatchQueue 2
User stack:
Kernel stack:
Thread 0x90dfa
User stack:
Kernel stack:
Thread 0x90dfb
User stack:
Kernel stack:
Thread 0x90e0b
User stack:
10 ??? [0x10da764f0]
10 JSC::SlotVisitor::drainFromShared(JSC::SlotVisitor::SharedDrainMode) + 493 (in JavaScriptCore) [0x7fff969e97ed]
Kernel stack:
Thread 0x90e0c
User stack:
Kernel stack:
Thread 0x90e0d
User stack:
Kernel stack:
Thread 0x90e0e
User stack:
Kernel stack:
Thread 0x90e43
User stack:
Kernel stack:
Binary Images:
0x10c7c6000 - 0x10c7ccfff com.apple.dashboard.client 1.8 (1.8) <40BD55E6-3144-34C7-9195-025B59FDEA0E> /System/Library/CoreServices/Dock.app/Contents/Resources/DashboardClient.app/Contents/MacOS/DashboardClient
0x7fff96768000 - 0x7fff96a8afe7 com.apple.JavaScriptCore 7534.56 (7534.56.6) <675725F8-37C4-3B80-ADB0-7B6AE908A908> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
Process: dbfseventsd [231]
Path: /Library/DropboxHelperTools/*/dbfseventsd
Architecture: i386
UID: 501
Process: dbfseventsd [229]
Architecture: i386
UID: 0
Process: dbfseventsd [230]
Architecture: i386
UID: 0
Process: diskarbitrationd [14]
Path: /usr/sbin/diskarbitrationd
UID: 0
Thread 0x1d0 DispatchQueue 1
User stack:
10 ??? (in diskarbitrationd) [0x102f1c39c]
10 ??? (in diskarbitrationd) [0x102f22e15]
Kernel stack:
Thread 0x1d8 DispatchQueue 2
User stack:
Kernel stack:
Binary Images:
0x102f1b000 - 0x102f36ff7 diskarbitrationd ??? (???) <F033F3D5-FF18-37D9-B9BF-59E6D4E30C10> /usr/sbin/diskarbitrationd
Process: distnoted [1968]
Path: /usr/sbin/distnoted
UID: 89
Thread 0x13bde4 DispatchQueue 1
User stack:
10 ??? (in distnoted) [0x104455904]
10 ??? (in distnoted) [0x104455c07]
Kernel stack:
Thread 0x13bde6 DispatchQueue 2
User stack:
Kernel stack:
Binary Images:
0x104454000 - 0x104458ff7 distnoted ??? (???) <93233E75-26C5-337E-B191-4F151AF5CF87> /usr/sbin/distnoted
Process: distnoted [19]
UID: 0
Thread 0x1e9 DispatchQueue 1
User stack:
10 ??? (in distnoted) [0x10c7a5904]
10 ??? (in distnoted) [0x10c7a5c07]
Kernel stack:
Thread 0x1ea DispatchQueue 2
User stack:
Kernel stack:
Thread 0x151cf8
User stack:
Kernel stack:
Thread 0x151f2d
User stack:
Kernel stack:
Binary Images:
0x10c7a4000 - 0x10c7a8ff7 distnoted ??? (???) <93233E75-26C5-337E-B191-4F151AF5CF87> /usr/sbin/distnoted
Process: distnoted [146]
UID: 501
Thread 0x4de DispatchQueue 1
User stack:
10 ??? (in distnoted) [0x109735904]
10 ??? (in distnoted) [0x109735c07]
Kernel stack:
Thread 0x4df DispatchQueue 2
User stack:
Kernel stack:
Thread 0x151d0b
User stack:
Kernel stack:
Thread 0x151d0c
User stack:
Kernel stack:
Thread 0x151f38
User stack:
Kernel stack:
Binary Images:
0x109734000 - 0x109738ff7 distnoted ??? (???) <93233E75-26C5-337E-B191-4F151AF5CF87> /usr/sbin/distnoted
Process: Dock [155]
Path: /System/Library/CoreServices/Dock.app/Contents/MacOS/Dock
UID: 501
Thread 0x50d DispatchQueue 1
User stack:
10 ??? (in Dock) [0x101284914]
10 ??? (in Dock) [0x1012ca990]
Kernel stack:
Thread 0x517 DispatchQueue 2
User stack:
Kernel stack:
Thread 0x611
User stack:
10 ??? (in Dock) [0x1011f4ca1]
Kernel stack:
Binary Images:
0x1011d9000 - 0x10141cff7 com.apple.dock 1.8 (1040.36) <10E1205F-FB2F-305B-964C-4CCEA03F5767> /System/Library/CoreServices/Dock.app/Contents/MacOS/Dock
Process: Dropbox [200]
Path: /Applications/Dropbox.app/Contents/MacOS/Dropbox
Architecture: i386
UID: 501
Process: dynamic_pager [44]
Path: /sbin/dynamic_pager
UID: 0
Thread 0x20c DispatchQueue 1
User stack:
10 ??? [0x10ed74310]
10 ??? [0x10ed7525c]
10 ??? [0x10ed74b55]
10 ??? [0x10ed74957]
10 ??? [0x10ed748be]
10 ??? [0x7fff8adc967a]
Kernel stack:
Binary Images:
Process: filecoordinationd [244]
Path: /usr/sbin/filecoordinationd
UID: 0
Thread 0x8e9 DispatchQueue 6
User stack:
Kernel stack:
Thread 0x8ea DispatchQueue 2
User stack:
Kernel stack:
Binary Images:
0x1061ea000 - 0x1061eaff7 filecoordinationd ??? (???) <46EC5502-54D4-3481-BA99-F274B34E84E0> /usr/sbin/filecoordinationd
Process: Finder [157]
Path: /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder
UID: 501
Thread 0x50f DispatchQueue 1
User stack:
10 ??? (in Finder) [0x104d07474]
10 ??? (in Finder) [0x104d074af]
Kernel stack:
Thread 0x526 DispatchQueue 2
User stack:
Kernel stack:
Thread 0x587
User stack:
Kernel stack:
Thread 0x151f24
User stack:
Kernel stack:
Thread 0x151f25
User stack:
Kernel stack:
Thread 0x151f6f
User stack:
4 start_wqthread + 13 (in libsystem_c.dylib) [0x7fff914b8b85]
4 __workq_kernreturn + 10 (in libsystem_kernel.dylib) [0x7fff8adcb192]
Kernel stack:
4 workqueue_exit + 1616 (in mach_kernel) [0xffffff80005a4200]
Binary Images:
0x104d01000 - 0x10520cfff com.apple.finder 10.7.3 (10.7.3) <3D95DBC7-C447-3597-94CD-D6DEAF15E9C2> /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder
Process: fontd [176]
Path: /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Support/fontd
UID: 501
Thread 0x565 DispatchQueue 1
User stack:
10 ??? (in fontd) [0x104193f24]
10 main_handler + 4306 (in libATSServer.dylib) [0x7fff90ad7df1]
Kernel stack:
Thread 0x566 DispatchQueue 2
User stack:
Kernel stack:
Binary Images:
0x104190000 - 0x104193fff fontd ??? (???) <4E0CAEC1-0422-315C-8976-28E9CAB97D5D> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Support/fontd
0x7fff90a53000 - 0x7fff90b04fff libATSServer.dylib ??? (???) <A522F4E8-D6C8-363D-A734-49112E0867F1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libATSServer.dylib
Process: fseventsd [12]
Path: /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/Support/fseventsd
UID: 0
Thread 0x1c7 DispatchQueue 1
User stack:
10 ??? (in fseventsd) [0x10bac541c]
10 ??? (in fseventsd) [0x10bac5fd7]
Kernel stack:
Thread 0x28f DispatchQueue 2
User stack:
Kernel stack:
9 kqueue_scan + 416 (in mach_kernel) [0xffffff800053a660]
1 hndl_unix_scall64 + 19 (in mach_kernel) [0xffffff80002daa13]
1 unix_syscall64 + 507 (in mach_kernel) [0xffffff80005cd61b]
1 kevent + 54 (in mach_kernel) [0xffffff800053bd76]
1 kevent_description + 1528 (in mach_kernel) [0xffffff800053bc58]
1 kqueue_scan + 208 (in mach_kernel) [0xffffff800053a590]
1 thread_block_reason + 275 (in mach_kernel) [0xffffff800022f413]
1 thread_go + 608 (in mach_kernel) [0xffffff800022e060]
1 processor_idle + 149 (in mach_kernel) [0xffffff800022d375]
1 machine_idle + 289 (in mach_kernel) [0xffffff80002c63f1]
Thread 0x1cc
User stack:
10 ??? (in fseventsd) [0x10bad0545]
10 ??? (in fseventsd) [0x10bad0231]
Kernel stack:
Thread 0x1cd
User stack:
10 ??? (in fseventsd) [0x10bacedd1]
Kernel stack:
Thread 0x1ce
User stack:
Kernel stack:
Thread 0x1cf
User stack:
10 ??? (in fseventsd) [0x10bacca6b]
Kernel stack:
Thread 0x1d7
User stack:
Kernel stack:
Thread 0x3ea
User stack:
Kernel stack:
Thread 0x3eb
User stack:
Kernel stack:
Thread 0x529
User stack:
Kernel stack:
Thread 0x52a
User stack:
Kernel stack:
Thread 0x52c
User stack:
Kernel stack:
Thread 0x56c
User stack:
Kernel stack:
Thread 0x56e
User stack:
Kernel stack:
Thread 0x571
User stack:
Kernel stack:
Thread 0x580
User stack:
Kernel stack:
Thread 0x598
User stack:
Kernel stack:
Thread 0x5d0
User stack:
Kernel stack:
Thread 0x65a
User stack:
Kernel stack:
Thread 0x669
User stack:
Kernel stack:
Thread 0x66a
User stack:
Kernel stack:
Thread 0x67b
User stack:
Kernel stack:
Thread 0x904
User stack:
Kernel stack:
Thread 0xc2a
User stack:
Kernel stack:
Thread 0x61567
User stack:
Kernel stack:
Thread 0xf5278
User stack:
Kernel stack:
Thread 0x133016
User stack:
Kernel stack:
Thread 0x139064
User stack:
Kernel stack:
Thread 0x149e79
User stack:
Kernel stack:
Thread 0x14a80b
User stack:
Kernel stack:
Thread 0x14a80c
User stack:
Kernel stack:
Thread 0x14a815
User stack:
Kernel stack:
Thread 0x14d1a4
User stack:
Kernel stack:
Thread 0x151f31
User stack:
Kernel stack:
Thread 0x151f85
User stack:
3 start_wqthread + 13 (in libsystem_c.dylib) [0x7fff914b8b85]
3 __workq_kernreturn + 10 (in libsystem_kernel.dylib) [0x7fff8adcb192]
Kernel stack:
2 workqueue_exit + 1616 (in mach_kernel) [0xffffff80005a4200]
1 workq_kernreturn + 695 (in mach_kernel) [0xffffff80005a5347]
1 workqueue_exit + 5332 (in mach_kernel) [0xffffff80005a5084]
Binary Images:
0x10bac4000 - 0x10bad9fff fseventsd ??? (???) <DE9D6EF7-EF49-3929-B195-8C6ABA952181> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/Support/fseventsd
Process: hidd [42]
Path: /usr/libexec/hidd
UID: 0
Thread 0x20a DispatchQueue 1
User stack:
10 ??? (in hidd) [0x109252eb0]
10 ??? (in hidd) [0x109252ef2]
Kernel stack:
Thread 0x21d DispatchQueue 2
User stack:
Kernel stack:
Thread 0x221
User stack:
10 __IOHIDSessionStartOnThread + 257 (in IOKit) [0x7fff92ff9e33]
Kernel stack:
Thread 0x151efa
User stack:
Kernel stack:
Binary Images:
0x109252000 - 0x109252fff hidd ??? (???) <76D5B34D-1345-3A26-94DC-0520BD883910> /usr/libexec/hidd
0x7fff92fcd000 - 0x7fff93038ff7 com.apple.framework.IOKit 2.0 (???) <6C604894-7F61-3130-8499-20791D14577F> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
Process: iCal [1941]
Path: /Applications/iCal.app/Contents/MacOS/iCal
UID: 501
Thread 0x132fc6 DispatchQueue 1
User stack:
10 ??? (in iCal) [0x108c7bb50]
10 ??? (in iCal) [0x108ba9917]
Kernel stack:
Thread 0x132fdc DispatchQueue 2
User stack:
Kernel stack:
Thread 0x133022
User stack:
Kernel stack:
Thread 0x13302d
User stack:
Kernel stack:
Thread 0x151f64
User stack:
5 start_wqthread + 13 (in libsystem_c.dylib) [0x7fff914b8b85]
5 __workq_kernreturn + 10 (in libsystem_kernel.dylib) [0x7fff8adcb192]
Kernel stack:
5 workqueue_exit + 1616 (in mach_kernel) [0xffffff80005a4200]
Binary Images:
0x108ba7000 - 0x108ec3fff com.apple.iCal 5.0.3 (1605.3) <8358EEE7-68EE-3F06-AA57-B8C349BB6C35> /Applications/iCal.app/Contents/MacOS/iCal
Process: Image Capture Extension [785]
Path: /System/Library/Image Capture/Support/Image Capture Extension.app/Contents/MacOS/Image Capture Extension
UID: 501
Thread 0x61560 DispatchQueue 1
User stack:
10 start + 52 (in Image Capture Extension) [0x108ca7ef8]
Kernel stack:
Thread 0x61562 DispatchQueue 2
User stack:
Kernel stack:
Thread 0x6156a
User stack:
Kernel stack:
Binary Images:
0x108ca6000 - 0x108d08ff7 com.apple.ImageCaptureExtension2 7.0.2 (7.0.2) <1D87F0C4-3103-304F-86F9-320FEF5889C9> /System/Library/Image Capture/Support/Image Capture Extension.app/Contents/MacOS/Image Capture Extension
Process: imagent [190]
Path: /System/Library/PrivateFrameworks/IMCore.framework/imagent.app/Contents/MacOS/imagent
UID: 501
Thread 0x5a4 DispatchQueue 1
User stack:
10 start + 52 (in imagent) [0x10edc0d24]
10 ??? (in imagent) [0x10edcd903]
Kernel stack:
Thread 0x5c9 DispatchQueue 2
User stack:
Kernel stack:
Binary Images:
0x10edbf000 - 0x10edd6ff7 com.apple.imagent 6.0 (800) <EAE1B88E-E22E-3E44-9780-A6B85C9E382C> /System/Library/PrivateFrameworks/IMCore.framework/imagent.app/Contents/MacOS/imagent
Process: iTunes [1346]
Path: /Applications/iTunes.app/Contents/MacOS/iTunes
UID: 501
Thread 0xf5122 DispatchQueue 1
User stack:
10 ??? (in iTunes) [0x10c3f6a78]
10 ??? (in iTunes) [0x10c3f6c38]
Kernel stack:
Thread 0xf5148 DispatchQueue 2
User stack:
Kernel stack:
Thread 0xf5161
User stack:
10 ??? (in iTunes) [0x10cc8571a]
10 ??? (in iTunes) [0x10c3fcac7]
Kernel stack:
Thread 0xf51a1
User stack:
10 ??? (in iTunes) [0x10c40d34f]
10 ??? (in iTunes) [0x10c3fcc74]
Kernel stack:
Thread 0xf51cc
User stack:
10 ??? (in iTunes) [0x10c415674]
Kernel stack:
Thread 0xf5279
User stack:
10 ??? (in iTunes) [0x10cdab8d1]
10 ??? (in iTunes) [0x10cdab8ac]
10 ??? (in iTunes) [0x10c3fcbb0]
Kernel stack:
Thread 0xf527a
User stack:
10 ??? (in iTunes) [0x10c4e5acb]
Kernel stack:
Thread 0xf527b
User stack:
Kernel stack:
Thread 0xf527c
User stack:
Kernel stack:
Thread 0xf527f
User stack:
Kernel stack:
Thread 0xf5289
User stack:
Kernel stack:
Thread 0xf53b2
User stack:
Kernel stack:
Thread 0xf6375
User stack:
Kernel stack:
Binary Images:
0x10c3f3000 - 0x10d592fef com.apple.iTunes 10.6.1 (10.6.1) <DEC5D8BF-1816-C165-F0C9-F9B6F4B36D03> /Applications/iTunes.app/Contents/MacOS/iTunes
Process: iTunesHelper [198]
Path: /Applications/iTunes.app/Contents/MacOS/iTunesHelper.app/Contents/MacOS/iTunesHelper
UID: 501
Thread 0x5ce DispatchQueue 1
User stack:
10 ??? (in iTunesHelper) [0x100000e44]
10 ??? (in iTunesHelper) [0x1000020e9]
Kernel stack:
Thread 0x5d3 DispatchQueue 2
User stack:
Kernel stack:
Thread 0x5db
User stack:
Kernel stack:
Binary Images:
0x100000000 - 0x100024fff com.apple.iTunesHelper 10.6.1 (10.6.1) <87F14F95-B1DE-755F-84F5-DDE8E7671915> /Applications/iTunes.app/Contents/MacOS/iTunesHelper.app/Contents/MacOS/iTunesHelper
Process: KernelEventAgent [40]
Path: /usr/sbin/KernelEventAgent
UID: 0
Thread 0x208 DispatchQueue 1
User stack:
10 start + 52 (in KernelEventAgent) [0x10a948bc0]
10 main + 959 (in KernelEventAgent) [0x10a94aec1]
Kernel stack:
Thread 0x225 DispatchQueue 2
User stack:
Kernel stack:
Thread 0x222
User stack:
Kernel stack:
Binary Images:
0x10a948000 - 0x10a94efff KernelEventAgent ??? (???) <14E5DD9C-0663-3709-8106-4B12B26B3171> /usr/sbin/KernelEventAgent
Process: kextd [10]
Path: /usr/libexec/kextd
UID: 0
Thread 0x1c3 DispatchQueue 1
User stack:
10 ??? (in kextd) [0x10fc5c41c]
10 ??? (in kextd) [0x10fc5d131]
Kernel stack:
Thread 0x1d2 DispatchQueue 2
User stack:
Kernel stack:
Binary Images:
0x10fc5b000 - 0x10fc78fff kextd ??? (???) <71044F2F-5090-3A8A-9F2A-3B5221F4E52D> /usr/libexec/kextd
Process: launchd [1]
Path: /sbin/launchd
UID: 0
Thread 0x1b1 DispatchQueue 1
User stack:
10 ??? (in launchd) [0x1000b8fd8]
10 ??? (in launchd) [0x1000bea26]
10 ??? (in launchd) [0x1000c10b7]
Kernel stack:
Thread 0x1b6
User stack:
Kernel stack:
Thread 0x1b7
User stack:
10 ??? (in launchd) [0x1000beae6]
10 sleep + 61 (in libsystem_c.dylib) [0x7fff9146bc2c]
Kernel stack:
Binary Images:
0x1000b8000 - 0x1000e3fff launchd ??? (???) <B63A6D4C-8D70-303B-B5E2-ECE75246F278> /sbin/launchd
Process: launchd [1965]
Path: /sbin/launchd
UID: 89
Thread 0x13bdda DispatchQueue 1
User stack:
10 ??? (in launchd) [0x106d01fd8]
10 ??? (in launchd) [0x106d07a26]
10 ??? (in launchd) [0x106d0a0b7]
Kernel stack:
Thread 0x13bdde
User stack:
Kernel stack:
Binary Images:
0x106d01000 - 0x106d2cfff launchd ??? (???) <B63A6D4C-8D70-303B-B5E2-ECE75246F278> /sbin/launchd
Process: launchd [141]
Path: /sbin/launchd
UID: 501
Thread 0x4d0 DispatchQueue 1
User stack:
10 ??? (in launchd) [0x10f818fd8]
10 ??? (in launchd) [0x10f81ea26]
10 ??? (in launchd) [0x10f8210b7]
Kernel stack:
Thread 0x4d1
User stack:
Kernel stack:
Binary Images:
0x10f818000 - 0x10f843fff launchd ??? (???) <B63A6D4C-8D70-303B-B5E2-ECE75246F278> /sbin/launchd
Process: launchdadd [2062]
Path: /usr/libexec/launchdadd
UID: 0
Thread 0x151f3a DispatchQueue 1
User stack:
9 start + 52 (in launchdadd) [0x10df3b234]
9 main + 286 (in launchdadd) [0x10df42049]
9 CFRunLoopRun + 95 (in CoreFoundation) [0x7fff8f84819f]
9 CFRunLoopRunSpecific + 230 (in CoreFoundation) [0x7fff8f838486]
9 __CFRunLoopRun + 1204 (in CoreFoundation) [0x7fff8f838c74]
9 __CFRunLoopServiceMachPort + 188 (in CoreFoundation) [0x7fff8f83050c]
9 mach_msg_trap + 10 (in libsystem_kernel.dylib) [0x7fff8adc967a]
Kernel stack:
9 ipc_mqueue_receive_continue + 0 (in mach_kernel) [0xffffff8000215930]
Thread 0x151f3b DispatchQueue 2
User stack:
9 _dispatch_mgr_thread + 54 (in libdispatch.dylib) [0x7fff8f7f331a]
9 kevent + 10 (in libsystem_kernel.dylib) [0x7fff8adcb7e6]
Kernel stack:
Thread 0x151f3c
User stack:
9 start_wqthread + 13 (in libsystem_c.dylib) [0x7fff914b8b85]
9 __workq_kernreturn + 10 (in libsystem_kernel.dylib) [0x7fff8adcb192]
Kernel stack:
9 workqueue_exit + 1616 (in mach_kernel) [0xffffff80005a4200]
Binary Images:
0x10df3a000 - 0x10df47fff launchdadd ??? (???) <F946CA77-019F-3D2E-BEEF-9BFE7B781AAF> /usr/libexec/launchdadd
Process: licenseDaemon [54]
Path: /Library/PrivilegedHelperTools/licenseDaemon.app/Contents/MacOS/licenseDaemon
UID: 0
Process: logind [136]
Path: /System/Library/CoreServices/logind
UID: 0
Thread 0x494 DispatchQueue 1
User stack:
10 ??? (in logind) [0x109d2329c]
10 ??? (in logind) [0x109d2331b]
Kernel stack:
Thread 0x495 DispatchQueue 2
User stack:
Kernel stack:
Binary Images:
0x109d22000 - 0x109d24fff logind ??? (???) <BC28D86F-DE3F-34B5-91E4-7071220FA877> /System/Library/CoreServices/logind
Process: loginwindow [38]
Path: /System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow
UID: 501
Thread 0x206 DispatchQueue 1
User stack:
10 ??? (in loginwindow) [0x1091cacd4]
10 ??? (in loginwindow) [0x1091cb226]
Kernel stack:
Thread 0x3e1 DispatchQueue 2
User stack:
Kernel stack:
Thread 0x151d09
User stack:
Kernel stack:
Thread 0x151d0a
User stack:
Kernel stack:
Thread 0x151d0d
User stack:
Kernel stack:
Thread 0x151dd6
User stack:
Kernel stack:
Binary Images:
0x1091c6000 - 0x109250ff7 com.apple.loginwindow 7.2 (7.2) <7FABFF0C-9256-390A-9841-126F5CB14BFA> /System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow
Process: Mail [239]
Path: /Applications/Mail.app/Contents/MacOS/Mail
UID: 501
Thread 0x8a7 DispatchQueue 1
User stack:
10 ??? (in Mail) [0x10d64c52c]
Kernel stack:
Thread 0x8c3 DispatchQueue 2
User stack:
Kernel stack:
Thread 0x8f4
User stack:
10 -[RSSInterchange _runManager] + 1345 (in Message) [0x7fff8b1d52dd]
Kernel stack:
Thread 0x98d
User stack:
10 +[_NSSocket _runIOThread] + 80 (in Message) [0x7fff8b1f4aa9]
Kernel stack:
Thread 0x996
User stack:
Kernel stack:
Thread 0x9fd
User stack:
Kernel stack:
Thread 0xa02
User stack:
Kernel stack:
Thread 0xc12
User stack:
Kernel stack:
Thread 0xc13
User stack:
Kernel stack:
Thread 0xc14
User stack:
Kernel stack:
Thread 0xc15
User stack:
Kernel stack:
Thread 0x151f68
User stack:
Kernel stack:
Thread 0x151f6a
User stack:
Kernel stack:
Thread 0x151f6c
User stack:
Kernel stack:
Thread 0x151f69
User stack:
Kernel stack:
Thread 0x151f76
User stack:
Kernel stack:
Thread 0x151f77
User stack:
Kernel stack:
Thread 0x151f69 DispatchQueue 7
User stack:
1 start_wqthread + 13 (in libsystem_c.dylib) [0x7fff914b8b85]
1 _pthread_wqthread + 316 (in libsystem_c.dylib) [0x7fff914b73da]
1 _dispatch_worker_thread2 + 255 (in libdispatch.dylib) [0x7fff8f7f3965]
1 _dispatch_call_block_and_release + 18 (in libdispatch.dylib) [0x7fff8f7f2a86]
1 ____NSOQSchedule_block_invoke_2 + 124 (in Foundation) [0x7fff96bb7912]
1 -[__NSOperationInternal start] + 705 (in Foundation) [0x7fff96ba46b4]
1 -[IMAPClientOperation main] + 85 (in Message) [0x7fff8b1fe4c8]
1 -[IMAPGateway allowClientOperationThrough:] + 350 (in Message) [0x7fff8b1fe652]
1 -[IMAPGateway _allowClientOperationThrough:] + 855 (in Message) [0x7fff8b1fec36]
1 -[IMAPConnection prepareAndExecuteOperation:outWrongState:] + 1510 (in Message) [0x7fff8b1ff75d]
1 -[IMAPClientNoopOperation executeOnConnection:] + 25 (in Message) [0x7fff8b2393eb]
1 -[IMAPConnection executeNoop:] + 137 (in Message) [0x7fff8b239479]
1 -[IMAPConnection _responseFromSendingOperation:] + 937 (in Message) [0x7fff8b210433]
1 -[IMAPConnection _copyNextTaggedOrContinuationResponseForCommand:exists:] + 519 (in Message) [0x7fff8b201b98]
1 -[IMAPConnection _copyNextServerResponse:] + 56 (in Message) [0x7fff8b1f740a]
1 -[IMAPResponse initWithConnection:error:] + 150 (in Message) [0x7fff8b1f74da]
1 -[IMAPConnection(MFPrivate) _readDataOfLength:intoData:error:] + 113 (in Message) [0x7fff8b1f7999]
1 -[IMAPConnection _readLineIntoData:error:] + 53 (in Message) [0x7fff8b1f7af9]
1 -[Connection _readLineIntoData:error:] + 74 (in Message) [0x7fff8b1f7b87]
1 -[Connection _fillBuffer:] + 673 (in Message) [0x7fff8b1f7f34]
1 -[Connection _readBytesFromSocketIntoBuffer:amount:requireAllBytes:error:] + 86 (in Message) [0x7fff8b1f80a2]
1 -[_NSSocket readBytes:length:error:] + 164 (in Message) [0x7fff8b1f8489]
1 _handleRequestWithTimeout + 1484 (in Message) [0x7fff8b1f5e60]
1 CFRunLoopRunSpecific + 230 (in CoreFoundation) [0x7fff8f838486]
1 __CFRunLoopRun + 1204 (in CoreFoundation) [0x7fff8f838c74]
1 __CFRunLoopServiceMachPort + 188 (in CoreFoundation) [0x7fff8f83050c]
1 mach_msg_trap + 10 (in libsystem_kernel.dylib) [0x7fff8adc967a]
Kernel stack:
1 ipc_mqueue_receive_continue + 0 (in mach_kernel) [0xffffff8000215930]
Binary Images:
0x10d574000 - 0x10d927fff com.apple.mail 5.2 (1278) <D5ABE1D8-66AA-336A-9886-3D2D6189E115> /Applications/Mail.app/Contents/MacOS/Mail
0x7fff8b1b2000 - 0x7fff8b50cff7 com.apple.MessageFramework 5.2 (1278) <36138A1B-7760-3E6D-A496-06DCF535F562> /System/Library/Frameworks/Message.framework/Versions/B/Message
Process: mDNSResponder [36]
Path: /usr/sbin/mDNSResponder
UID: 65
Thread 0x204 DispatchQueue 1
User stack:
10 start + 52 (in mDNSResponder) [0x109050d74]
10 main + 3556 (in mDNSResponder) [0x10901e028]
Kernel stack:
Thread 0x26f DispatchQueue 2
User stack:
Kernel stack:
Thread 0x3dd
User stack:
Kernel stack:
Thread 0x151f79
User stack:
Kernel stack:
Binary Images:
0x10901c000 - 0x10909bfff mDNSResponder ??? (???) <A304F98D-1DCA-328D-9176-2CC2E76D9B75> /usr/sbin/mDNSResponder
Process: mds [35]
Path: /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Support/mds
UID: 0
Thread 0x203 DispatchQueue 1
User stack:
10 ??? (in mds) [0x10911f498]
10 ??? (in mds) [0x109128c4d]
Kernel stack:
Thread 0x339 DispatchQueue 2
User stack:
Kernel stack:
Thread 0x3b7
User stack:
Kernel stack:
Thread 0x151e01
User stack:
Kernel stack:
Thread 0x151e02
User stack:
Kernel stack:
Thread 0x151f5f
User stack:
Kernel stack:
Thread 0x151f60
User stack:
Kernel stack:
Binary Images:
0x10911b000 - 0x109227ff7 mds ??? (???) <7B467B37-91C5-3A22-A3DE-76C58C113ECC> /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Support/mds
Process: mdworker [1975]
Path: /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker
UID: 89
Note: Self-throttled
Thread 0x14993f DispatchQueue 1
User stack:
10 ??? (in mdworker) [0x10c79fd60]
10 ??? (in mdworker) [0x10c7a8d1b]
Kernel stack:
Thread 0x149948 DispatchQueue 2
User stack:
Kernel stack:
Thread 0x14994f
User stack:
10 ??? (in mdworker) [0x10c7acc52]
10 ??? (in mdworker) [0x10c7ad45a]
Kernel stack:
Binary Images:
0x10c79e000 - 0x10c7f1fff mdworker ??? (???) <79547446-7F7C-36D4-8341-EE5E9B7ECB3E> /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker
Process: mdworker [2058]
UID: 89
Thread 0x151cce DispatchQueue 1
User stack:
10 ??? (in mdworker) [0x10f1a8d60]
10 ??? (in mdworker) [0x10f1b1d1b]
Kernel stack:
Thread 0x151cd3 DispatchQueue 2
User stack:
Kernel stack:
Thread 0x151cd7
User stack:
10 ??? (in mdworker) [0x10f1b5c52]
10 ??? (in mdworker) [0x10f1b645a]
Kernel stack:
Binary Images:
0x10f1a7000 - 0x10f1fafff mdworker ??? (???) <79547446-7F7C-36D4-8341-EE5E9B7ECB3E> /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker
Process: mdworker [1976]
UID: 501
Thread 0x149953 DispatchQueue 1
User stack:
10 ??? (in mdworker) [0x10a739d60]
10 ??? (in mdworker) [0x10a742d1b]
Kernel stack:
Thread 0x149954 DispatchQueue 2
User stack:
Kernel stack:
Thread 0x149958
User stack:
10 ??? (in mdworker) [0x10a746c52]
10 ??? (in mdworker) [0x10a74745a]
Kernel stack:
Thread 0x14a285
User stack:
10 ??? (in mdworker) [0x10a75c516]
Kernel stack:
Binary Images:
0x10a738000 - 0x10a78bfff mdworker ??? (???) <79547446-7F7C-36D4-8341-EE5E9B7ECB3E> /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker
Process: Microsoft AU Daemon [897]
Path: /Library/Application Support/Microsoft/*/Microsoft AutoUpdate.app/Contents/MacOS/Microsoft AU Daemon.app/Contents/MacOS/Microsoft AU Daemon
Architecture: i386
UID: 501
Process: Microsoft Database Daemon [894]
Path: /Applications/Microsoft Office 2008/*/Microsoft Database Daemon.app/Contents/MacOS/Microsoft Database Daemon
Architecture: i386
UID: 501
Process: Microsoft Excel [891]
Path: /Applications/Microsoft Office 2008/Microsoft Excel.app/Contents/MacOS/Microsoft Excel
Architecture: i386
UID: 501
Process: MIDIServer [206]
Path: /System/Library/Frameworks/CoreMIDI.framework/MIDIServer
UID: 501
Thread 0x610 DispatchQueue 1
User stack:
10 ??? (in MIDIServer) [0x104c70dc0]
10 ??? (in MIDIServer) [0x104c70e8e]
10 MIDIServerRun + 978 (in CoreMIDI) [0x104c9300d]
Kernel stack:
Thread 0x612 DispatchQueue 2
User stack:
Kernel stack:
Thread 0x638
User stack:
10 CAPThread::Entry(CAPThread*) + 98 (in CoreMIDI) [0x104c8b396]
10 XThread::RunHelper(void*) + 10 (in CoreMIDI) [0x104c8b96a]
10 TimerTaskMgr::Run() + 436 (in CoreMIDI) [0x104ca472e]
10 CAGuard::Wait() + 93 (in CoreMIDI) [0x104c8ab59]
Kernel stack:
Thread 0x639
User stack:
10 DriverIOThread::Run() + 52 (in CoreMIDI) [0x104c9d7ee]
Kernel stack:
Thread 0x684
User stack:
10 MIDIIOThread::Run() + 124 (in CoreMIDI) [0x104c93ff8]
10 XServerMachPort::ReceiveMessage(int&, void*, int&) + 96 (in CoreMIDI) [0x104c8a5be]
Kernel stack:
Thread 0x14d1d9
User stack:
Kernel stack:
Thread 0x151e39
User stack:
Kernel stack:
Binary Images:
0x104c70000 - 0x104c70fff MIDIServer ??? (???) <46A466D4-9A9B-301C-9459-F9B0978A24AC> /System/Library/Frameworks/CoreMIDI.framework/MIDIServer
0x104c7b000 - 0x104cccff7 com.apple.audio.midi.CoreMIDI 1.8 (42) <10BAC42F-ACFE-3EBC-869A-2847A0770CE8> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
Process: netbiosd [121]
Path: /usr/sbin/netbiosd
UID: 222
Thread 0x44d DispatchQueue 2
User stack:
Kernel stack:
Thread 0x44f DispatchQueue 6
User stack:
Kernel stack:
Thread 0xcacf
User stack:
Kernel stack:
Binary Images:
0x103ebe000 - 0x103f14ff7 netbiosd ??? (???) <8A0E31A0-8B26-33B8-9FB5-24BF62368D55> /usr/sbin/netbiosd
Process: NIHardwareAgent [199]
Path: /Library/Application Support/Native Instruments/*/NIHardwareAgent.app/Contents/MacOS/NIHardwareAgent
UID: 501
Process: notifyd [13]
Path: /usr/sbin/notifyd
UID: 0
Thread 0x1c9 DispatchQueue 2
User stack:
10 ??? [0x7fff8f7f331a]
10 ??? [0x7fff8adcb7e6]
Kernel stack:
Thread 0x1ca DispatchQueue 6
User stack:
10 ??? [0x7fff8f7f5b20]
10 ??? [0x7fff8adcb022]
Kernel stack:
Thread 0x151f1d
User stack:
10 ??? [0x7fff914b8b85]
10 ??? [0x7fff8adcb192]
Kernel stack:
Binary Images:
Process: ntpd [21]
Path: /usr/sbin/ntpd
UID: 0
Thread 0x1f5 DispatchQueue 1
User stack:
10 ??? (in ntpd) [0x106bd7bbc]
10 ??? (in ntpd) [0x106c00d01]
10 __sigsuspend + 10 (in libsystem_kernel.dylib) [0x7fff8adcb00e]
Kernel stack:
Binary Images:
0x106bd7000 - 0x106c37ff7 ntpd ??? (???) <DC2B5EC4-D7E1-3E8A-9A66-E82354F44115> /usr/sbin/ntpd
Process: opendirectoryd [17]
Path: /usr/libexec/opendirectoryd
UID: 0
Thread 0x1dc DispatchQueue 6
User stack:
10 _pthread_wqthread + 316 (in libsystem_c.dylib) [0x7fff914b73da]
10 _dispatch_worker_thread2 + 255 (in libdispatch.dylib) [0x7fff8f7f3965]
10 _dispatch_call_block_and_release + 18 (in libdispatch.dylib) [0x7fff8f7f2a86]
10 __odm_register_requesttypes_block_invoke_1 + 49 (in SystemCache) [0x10c626cbc]
10 mach_msg_server + 473 (in libsystem_kernel.dylib) [0x7fff8adc9274]
Kernel stack:
Thread <multiple> DispatchQueue 6
User stack:
20 start_wqthread + 13 (in libsystem_c.dylib) [0x7fff914b8b85]
20 _pthread_wqthread + 316 (in libsystem_c.dylib) [0x7fff914b73da]
20 _dispatch_worker_thread2 + 255 (in libdispatch.dylib) [0x7fff8f7f3965]
20 _dispatch_call_block_and_release + 18 (in libdispatch.dylib) [0x7fff8f7f2a86]
10 __odm_register_requesttypes_block_invoke_2 + 49 (in SystemCache) [0x10c626d03]
10 ??? (in opendirectoryd) [0x10bef12de]
Kernel stack:
Thread <multiple> DispatchQueue 8
User stack:
10 ___kernel_kauth_listener_block_invoke_2 + 343 (in SystemCache) [0x10c6266c0]
10 semaphore_wait_trap + 10 (in libsystem_kernel.dylib) [0x7fff8adc96b6]
10 __syscall + 10 (in libsystem_kernel.dylib) [0x7fff8adcb09a]
Kernel stack:
Thread 0x1dd DispatchQueue 2
User stack:
Kernel stack:
Thread 0x151b2e
User stack:
Kernel stack:
Thread 0x151cfc
User stack:
Kernel stack:
Thread 0x151f23
User stack:
Kernel stack:
Thread 0x151f2e
User stack:
Kernel stack:
Binary Images:
0x10bed7000 - 0x10bf31ff7 opendirectoryd ??? (???) <B9B86780-3681-35A9-B391-F779DE7EBB28> /usr/libexec/opendirectoryd
0x10c61e000 - 0x10c649ff7 com.apple.opendirectoryd.module.SystemCache 10.7 (172.13) <FAFB00E4-6599-3454-932E-40CCCCA12E1A> /System/Library/OpenDirectory/Modules/SystemCache.bundle/Contents/MacOS/SystemCache
Process: pboard [180]
Path: /usr/sbin/pboard
Architecture: x86_64
UID: 501
Thread 0x579 DispatchQueue 1
User stack:
10 ??? (in pboard) [0x10005b684]
10 ??? (in pboard) [0x10005b746]
10 mach_msg_server + 641 (in libsystem_kernel.dylib) [0x7fff8adc931c]
Kernel stack:
Binary Images:
0x10005a000 - 0x10005bff7 pboard ??? (???) <3656507E-F257-3E7A-8960-0BDAEF31D0F5> /usr/sbin/pboard
Process: powerd [18]
Path: /System/Library/CoreServices/powerd.bundle/powerd
UID: 0
Thread 0x1e3 DispatchQueue 1
User stack:
10 start + 52 (in powerd) [0x103f73c68]
10 main + 2119 (in powerd) [0x103f79c49]
Kernel stack:
Thread 0x1e6 DispatchQueue 2
User stack:
Kernel stack:
Thread 0x151d78
User stack:
1 __workq_kernreturn + 10 (in libsystem_kernel.dylib) [0x7fff8adcb192]
Kernel stack:
1 workqueue_exit + 1616 (in mach_kernel) [0xffffff80005a4200]
Binary Images:
0x103f73000 - 0x103f8dfff powerd ??? (???) <7F6EDABB-9C76-3FEF-A9CE-8BF180A19766> /System/Library/CoreServices/powerd.bundle/powerd
Process: PrinterProxy [797]
Path: /Users/USER/Library/Printers/Canon iP4800 series.app/Contents/MacOS/PrinterProxy
UID: 501
Thread 0x61678 DispatchQueue 1
User stack:
10 ??? (in PrinterProxy) [0x10031cb48]
Kernel stack:
Thread 0x61684 DispatchQueue 2
User stack:
Kernel stack:
Thread 0x151de0
User stack:
Kernel stack:
Binary Images:
0x10031b000 - 0x10031cff7 com.apple.print.PrinterProxy 7.3 (373.5) <C9004463-7A4B-3C4C-BEF6-F91A84074859> /Users/USER/Library/Printers/Canon iP4800 series.app/Contents/MacOS/PrinterProxy
Process: qmasterd [55]
Path: /usr/sbin/qmasterd
Architecture: i386
UID: 0
Thread 0x217
User stack:
10 ??? (in qmasterd) [0x2c0a]
10 ??? (in qmasterd) [0x8be9]
10 ??? (in qmasterd) [0x89b6]
10 -[NSRunLoop(NSRunLoop) run] + 76 (in Foundation) [0x952bd392]
10 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 273 (in Foundation) [0x952bd4af]
10 CFRunLoopRunInMode + 120 (in CoreFoundation) [0x96136088]
10 CFRunLoopRunSpecific + 332 (in CoreFoundation) [0x961361dc]
10 __CFRunLoopRun + 1428 (in CoreFoundation) [0x96136b04]
10 __CFRunLoopServiceMachPort + 170 (in CoreFoundation) [0x9612d9da]
10 mach_msg_trap + 10 (in libsystem_kernel.dylib) [0x993dec22]
Kernel stack:
Thread 0x695 DispatchQueue 1701273966
User stack:
10 _dispatch_mgr_thread + 53 (in libdispatch.dylib) [0x9390485f]
10 kevent + 10 (in libsystem_kernel.dylib) [0x993e190a]
Kernel stack:
Binary Images:
0x1000 - 0x1afff qmasterd ??? (???) <FCE41B92-9D71-3B70-6E56-98BA94239F74> /usr/sbin/qmasterd
0x93903000 - 0x93911fff libdispatch.dylib ??? (???) <2F918480-12C8-3F22-9B1A-9B2D76F6F4F5> /usr/lib/system/libdispatch.dylib
0x952b1000 - 0x955bbff3 com.apple.Foundation 6.7.2 (833.25) <4C52ED74-A1FD-3087-A2E1-035AB3CF9610> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x960fb000 - 0x962d2fe7 com.apple.CoreFoundation 6.7.2 (635.21) <4D1D2BAF-1332-32DF-A81B-7E79D4F0A6CB> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x993c8000 - 0x993e6ff7 libsystem_kernel.dylib ??? (???) <3705DE40-E00F-3E37-ADB0-D4AE5F9950F5> /usr/lib/system/libsystem_kernel.dylib
Process: revisiond [31]
Path: /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/Support/revisiond
UID: 0
Thread 0x230 DispatchQueue 2
User stack:
Kernel stack:
Thread 0x296 DispatchQueue 6
User stack:
Kernel stack:
Thread 0x297
User stack:
Kernel stack:
10 utf8_encodelen + 3723 (in mach_kernel) [0xffffff8000312d6b]
10 VNOP_READ + 77 (in mach_kernel) [0xffffff800031b54d]
10 spec_read + 174 (in mach_kernel) [0xffffff800032b77e]
10 cdev_read + 101 (in AppleFSCompressionTypeDataless) [0xffffff7f81e1c52a]
10 msleep + 119 (in mach_kernel) [0xffffff8000555397]
10 wakeup + 267 (in mach_kernel) [0xffffff8000554d3b]
10 lck_mtx_sleep + 74 (in mach_kernel) [0xffffff8000227efa]
Thread 0x298
User stack:
10 fsctl + 10 (in libsystem_kernel.dylib) [0x7fff8adcb516]
Kernel stack:
10 fsctl + 336 (in mach_kernel) [0xffffff80003055e0]
10 nspace_proc_exit + 4489 (in mach_kernel) [0xffffff8000304d79]
10 nspace_proc_exit + 2368 (in mach_kernel) [0xffffff8000304530]
Thread 0x151f88
User stack:
Kernel stack:
Binary Images:
0x107775000 - 0x1077c8fff revisiond ??? (???) <83042487-F8A5-346F-9E72-B731E40C5B26> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/Support/revisiond
Process: Safari [234]
Path: /Applications/Safari.app/Contents/MacOS/Safari
UID: 501
Thread 0x85b DispatchQueue 1
User stack:
10 ??? (in Safari) [0x105492f24]
10 SafariMain + 197 (in Safari) [0x7fff8e9c91d3]
10 -[BrowserApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 171 (in Safari) [0x7fff8e814939]
Kernel stack:
Thread 0x8d6 DispatchQueue 2
User stack:
Kernel stack:
Thread 0x8e1
User stack:
10 WebCore::IconDatabase::iconDatabaseSyncThreadStart(void*) + 9 (in WebCore) [0x105db113f]
10 WebCore::IconDatabase::iconDatabaseSyncThread() + 491 (in WebCore) [0x105db132f]
10 WebCore::IconDatabase::syncThreadMainLoop() + 375 (in WebCore) [0x105db3885]
Kernel stack:
Thread 0x8e2
User stack:
10 thread_fun + 24 (in QuartzCore) [0x7fff8e61e219]
10 CA::Render::Server::server_thread(void*) + 184 (in QuartzCore) [0x7fff8e61e2d9]
Kernel stack:
Thread 0x902
User stack:
10 Safari::MessageRunLoop::threadCallback(void*) + 9 (in Safari) [0x7fff8e9837fb]
10 Safari::MessageRunLoop::threadBody() + 163 (in Safari) [0x7fff8e9838a3]
Kernel stack:
Thread 0x903
User stack:
Kernel stack:
Thread 0xbd2
User stack:
Kernel stack:
Thread 0xbda
User stack:
Kernel stack:
Thread 0xbe6
User stack:
10 JSC::SlotVisitor::drainFromShared(JSC::SlotVisitor::SharedDrainMode) + 493 (in JavaScriptCore) [0x10571978d]
Kernel stack:
Thread 0xbe7
User stack:
Kernel stack:
Thread 0xbe8
User stack:
Kernel stack:
Thread 0xbe9
User stack:
10 WTF::ThreadCondition::timedWait(WTF::Mutex&, double) + 151 (in JavaScriptCore) [0x1054a2aa7]
Kernel stack:
Thread 0xddaec
User stack:
10 _ZL13startIOThreadPv + 148 (in CoreVideo) [0x7fff95d263e9]
10 CVDisplayLink::runIOThread() + 710 (in CoreVideo) [0x7fff95d266c8]
Kernel stack:
Binary Images:
0x105492000 - 0x105492fff com.apple.Safari 5.1.7 (7534.57.2) <962C15B1-EAC2-397C-83C2-A6A2D1B67EE7> /Applications/Safari.app/Contents/MacOS/Safari
0x105498000 - 0x1057bafff com.apple.JavaScriptCore 7534.57 (7534.57.3) <519848A3-D6C0-3CF8-B2E4-D4B41FD91E76> /System/Library/StagedFrameworks/Safari/JavaScriptCore.framework/JavaScriptCore
0x105dad000 - 0x106ae4fef com.apple.WebCore 7534.57 (7534.57.2) <0DDABF2E-FF0F-3E94-8EC5-A48F613211AE> /System/Library/StagedFrameworks/Safari/WebCore.framework/WebCore
0x7fff8e61c000 - 0x7fff8e7bbff7 com.apple.QuartzCore 1.7 (270.4) <97E20A5F-652B-3E85-8C46-DCB777248ECD> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff8e7bc000 - 0x7fff8ec4cff7 com.apple.Safari.framework 7534 (7534.57.2) <D61DA7E6-8153-31E2-B277-CEE5090F54B3> /System/Library/PrivateFrameworks/Safari.framework/Versions/A/Safari
0x7fff95d24000 - 0x7fff95d4dfff com.apple.CoreVideo 1.7 (70.3) <9A9D4058-9935-3B0A-B1A6-27EB78D02249> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
Process: securityd [29]
Path: /usr/sbin/securityd
UID: 0
Thread 0x1fd DispatchQueue 1
User stack:
10 start + 52 (in securityd) [0x10b4b230c]
10 main + 2179 (in securityd) [0x10b4c8878]
10 Security::MachPlusPlus::MachServer::run(unsigned long, int) + 103 (in securityd) [0x10b505589]
10 Security::MachPlusPlus::MachServer::runServerThread(bool) + 676 (in securityd) [0x10b49dd4a]
Kernel stack:
Thread 0x35d DispatchQueue 2
User stack:
Kernel stack:
Thread 0x3a3
User stack:
10 Security::Thread::runner(void*) + 104 (in securityd) [0x10b49d842]
10 AuditMonitor::action() + 97 (in securityd) [0x10b4e8bc1]
10 au_sdev_read_aia + 79 (in libbsm.0.dylib) [0x7fff9061b091]
10 fgetc + 50 (in libsystem_c.dylib) [0x7fff9149ddee]
10 __srget + 20 (in libsystem_c.dylib) [0x7fff914fd5e8]
10 __srefill1 + 30 (in libsystem_c.dylib) [0x7fff914b2166]
10 __read_nocancel + 10 (in libsystem_kernel.dylib) [0x7fff8adcad52]
Kernel stack:
10 audit_session_setaia + 2482 (in mach_kernel) [0xffffff8000524322]
Binary Images:
0x10b48e000 - 0x10b579fff securityd ??? (???) <A5610E11-6503-3CF2-9D46-585AB4A6D24F> /usr/sbin/securityd
0x7fff9060e000 - 0x7fff90620ff7 libbsm.0.dylib ??? (???) <349BB16F-75FA-363F-8D98-7A9C3FA90A0D> /usr/lib/libbsm.0.dylib
Process: spindump [2059]
Path: /usr/sbin/spindump
UID: 0
Thread 0x151f19 DispatchQueue 1
User stack:
10 ??? (in spindump) [0x106aad7b4]
10 ??? (in spindump) [0x106aade03]
Kernel stack:
Thread 0x151f1a DispatchQueue 2
User stack:
Kernel stack:
6 kqueue_scan + 416 (in mach_kernel) [0xffffff800053a660]
4 hndl_unix_scall64 + 19 (in mach_kernel) [0xffffff80002daa13]
4 unix_syscall64 + 507 (in mach_kernel) [0xffffff80005cd61b]
4 kevent + 54 (in mach_kernel) [0xffffff800053bd76]
4 kevent_description + 1528 (in mach_kernel) [0xffffff800053bc58]
4 kqueue_scan + 208 (in mach_kernel) [0xffffff800053a590]
4 thread_block_reason + 275 (in mach_kernel) [0xffffff800022f413]
4 thread_go + 608 (in mach_kernel) [0xffffff800022e060]
4 processor_idle + 149 (in mach_kernel) [0xffffff800022d375]
4 machine_idle + 289 (in mach_kernel) [0xffffff80002c63f1]
Thread 0x151f1b DispatchQueue 18
User stack:
10 _dispatch_worker_thread2 + 198 (in libdispatch.dylib) [0x7fff8f7f392c]
10 _dispatch_queue_invoke + 54 (in libdispatch.dylib) [0x7fff8f7f4132]
10 _dispatch_queue_drain + 210 (in libdispatch.dylib) [0x7fff8f7f42a0]
10 _dispatch_queue_invoke + 71 (in libdispatch.dylib) [0x7fff8f7f4143]
10 _dispatch_source_invoke + 649 (in libdispatch.dylib) [0x7fff8f7f7497]
Kernel stack:
10 stack_snapshot2 + 160 (in mach_kernel) [0xffffff80005272c0]
Thread 0x151f1f
User stack:
Kernel stack:
Thread 0x151f1c
User stack:
Kernel stack:
Thread 0x151f1c DispatchQueue 29
User stack:
1 _dispatch_worker_thread2 + 198 (in libdispatch.dylib) [0x7fff8f7f392c]
1 _dispatch_queue_invoke + 54 (in libdispatch.dylib) [0x7fff8f7f4132]
1 _dispatch_queue_drain + 264 (in libdispatch.dylib) [0x7fff8f7f42d6]
1 ??? (in spindump) [0x106ab0a32]
1 ??? (in spindump) [0x106ab0d58]
1 ??? (in spindump) [0x106ab1b53]
1 _dispatch_barrier_sync_f_invoke + 33 (in libdispatch.dylib) [0x7fff8f7f4c79]
1 ??? (in spindump) [0x106ab252e]
1 ??? (in spindump) [0x106ab2ce9]
1 _CFBundleCreateWithExecutableURLIfLooksLikeBundle + 96 (in CoreFoundation) [0x7fff8f8af1e0]
1 _CFBundleCreate + 774 (in CoreFoundation) [0x7fff8f840996]
1 _CFBundleCopyInfoDictionaryInDirectoryWithVersion + 1358 (in CoreFoundation) [0x7fff8f82119e]
1 CFURLCreateWithString + 220 (in CoreFoundation) [0x7fff8f82177c]
1 _parseComponents + 137 (in CoreFoundation) [0x7fff8f821cb9]
1 constructBuffers + 176 (in CoreFoundation) [0x7fff8f8226c0]
1 __CFStringEncodeByteStream + 2404 (in CoreFoundation) [0x7fff8f80a034]
1 CFStringEncodingIsValidEncoding + 9 (in CoreFoundation) [0x7fff8f80aa79]
1 DYLD-STUB$$OSSpinLockUnlock + 0 (in CoreFoundation) [0x7fff8f960210]
Kernel stack:
1 hndl_allintrs + 290 (in mach_kernel) [0xffffff80002da282]
1 interrupt + 192 (in mach_kernel) [0xffffff80002c4860]
1 lapic_interrupt + 121 (in mach_kernel) [0xffffff80002c99c9]
1 cpu_signal_handler + 172 (in mach_kernel) [0xffffff80002cb8bc]
1 sync_iss_to_iks + 118 (in mach_kernel) [0xffffff80002c3c76]
Binary Images:
0x106aac000 - 0x106ac2ff7 spindump ??? (???) <7E2BD993-9467-38E4-9CB0-5A22B642A219> /usr/sbin/spindump
Process: spindump_agent [2060]
Path: /usr/libexec/spindump_agent
UID: 501
Thread 0x151f20
User stack:
10 ??? (in spindump_agent) [0x1012b3334]
10 ??? (in spindump_agent) [0x1012b3498]
10 dispatch_main + 43 (in libdispatch.dylib) [0x7fff8f7f3dec]
10 pthread_exit + 30 (in libsystem_c.dylib) [0x7fff914b727d]
10 _pthread_exit + 142 (in libsystem_c.dylib) [0x7fff914b6f7c]
10 _pthread_tsd_cleanup + 230 (in libsystem_c.dylib) [0x7fff914fb942]
10 _dispatch_queue_cleanup2 + 88 (in libdispatch.dylib) [0x7fff8f7f5a39]
10 sleep$NOCANCEL + 61 (in libsystem_c.dylib) [0x7fff91508ae5]
10 __semwait_signal_nocancel + 10 (in libsystem_kernel.dylib) [0x7fff8adcae56]
Kernel stack:
Thread 0x151f29 DispatchQueue 2
User stack:
Kernel stack:
Thread 0x151f28 DispatchQueue 6
User stack:
Kernel stack:
Thread 0x151f27
User stack:
Kernel stack:
Thread 0x151f2a
User stack:
Kernel stack:
Thread 0x151f37
User stack:
Kernel stack:
Binary Images:
0x1012b2000 - 0x1012b4fff spindump_agent ??? (???) <9712265B-6142-3285-B6BD-3125216A6069> /usr/libexec/spindump_agent
Process: spindump_symbolicator [2063]
Path: /usr/libexec/spindump_symbolicator
UID: 0
Thread 0x151f3d
User stack:
9 ??? (in spindump_symbolicator) [0x10cac6068]
9 ??? (in spindump_symbolicator) [0x10cac61c2]
9 dispatch_main + 43 (in libdispatch.dylib) [0x7fff8f7f3dec]
9 pthread_exit + 30 (in libsystem_c.dylib) [0x7fff914b727d]
9 _pthread_exit + 142 (in libsystem_c.dylib) [0x7fff914b6f7c]
9 _pthread_tsd_cleanup + 230 (in libsystem_c.dylib) [0x7fff914fb942]
9 _dispatch_queue_cleanup2 + 88 (in libdispatch.dylib) [0x7fff8f7f5a39]
9 sleep$NOCANCEL + 61 (in libsystem_c.dylib) [0x7fff91508ae5]
9 __semwait_signal_nocancel + 10 (in libsystem_kernel.dylib) [0x7fff8adcae56]
Kernel stack:
9 semaphore_wait_continue + 0 (in mach_kernel) [0xffffff8000234650]
Thread 0x151f3f DispatchQueue 2
User stack:
Kernel stack:
Thread 0x151f41 DispatchQueue 6
User stack:
9 _dispatch_sig_thread + 45 (in libdispatch.dylib) [0x7fff8f7f5b20]
9 __sigsuspend_nocancel + 10 (in libsystem_kernel.dylib) [0x7fff8adcb022]
Kernel stack:
9 wakeup + 992 (in mach_kernel) [0xffffff8000555010]
Thread 0x151f40
User stack:
Kernel stack:
Thread 0x151f43
User stack:
3 thread_start + 13 (in libsystem_c.dylib) [0x7fff914b8b75]
3 _pthread_start + 335 (in libsystem_c.dylib) [0x7fff914b58bf]
3 cleaner_thread_main(void*) + 42 (in CoreSymbolication) [0x7fff8b52e3bb]
3 __semwait_signal + 10 (in libsystem_kernel.dylib) [0x7fff8adcae42]
Kernel stack:
3 semaphore_wait_continue + 0 (in mach_kernel) [0xffffff8000234650]
Binary Images:
0x10cac5000 - 0x10cac6ff7 spindump_symbolicator ??? (???) <1B3E47B5-67AB-3499-8B5A-C8452877BA9C> /usr/libexec/spindump_symbolicator
0x7fff8b511000 - 0x7fff8b587fff com.apple.CoreSymbolication 2.2 (73.2) <126415E3-3A35-315B-B4B7-507CDBED0D58> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
Process: stackshot [28]
Path: /usr/libexec/stackshot
UID: 0
Thread 0x1fc DispatchQueue 1
User stack:
10 ??? (in stackshot) [0x10be74c94]
10 ??? (in stackshot) [0x10be769b2]
Kernel stack:
Thread 0x27d DispatchQueue 2
User stack:
Kernel stack:
Thread 0x295
User stack:
10 ??? (in stackshot) [0x10be75174]
10 __sigwait + 10 (in libsystem_kernel.dylib) [0x7fff8adcb036]
Kernel stack:
10 __sigwait_nocancel + 333 (in mach_kernel) [0xffffff8000552fad]
Binary Images:
0x10be74000 - 0x10be77fff stackshot ??? (???) <14417EDE-A9B4-39AB-9FFD-4BDCEEDB813E> /usr/libexec/stackshot
Process: Synsopos [2038]
Path: /Library/Application Support/eLicenser/*/Synsopos.app/Contents/MacOS/Synsopos
UID: 501
Process: syslogd [16]
Path: /usr/sbin/syslogd
UID: 0
Thread 0x1da DispatchQueue 1
User stack:
10 ??? (in syslogd) [0x10bf6cbe8]
Kernel stack:
Thread 0x1ef
User stack:
10 ??? (in syslogd) [0x10bf73a82]
Kernel stack:
Thread 0x1f0
User stack:
10 ??? (in syslogd) [0x10bf74218]
10 ??? (in syslogd) [0x10bf71123]
Kernel stack:
Thread 0x1f2
User stack:
10 ??? (in syslogd) [0x10bf70b3b]
10 _vprocmgr_log_drain + 69 (in liblaunch.dylib) [0x7fff92f78dda]
10 ??? (in liblaunch.dylib) [0x7fff92f7b355]
Kernel stack:
Binary Images:
0x10bf6c000 - 0x10bf80fff syslogd ??? (???) <43F6586B-1A9E-33C0-8FA2-71880E747BC7> /usr/sbin/syslogd
0x7fff92f75000 - 0x7fff92f7fff7 liblaunch.dylib ??? (???) <6ECB7F19-B384-32C1-8652-2463C1CF4815> /usr/lib/system/liblaunch.dylib
Process: SystemStarter [26]
Path: /sbin/SystemStarter
UID: 0
Thread 0x1fa DispatchQueue 1
User stack:
10 ??? (in SystemStarter) [0x1010a6f6c]
Kernel stack:
Thread 0x502 DispatchQueue 2
User stack:
Kernel stack:
Binary Images:
0x1010a6000 - 0x1010aafff SystemStarter ??? (???) <C62C4BF2-6BF3-3318-BB6A-ED508A278C2D> /sbin/SystemStarter
Process: SystemUIServer [156]
Path: /System/Library/CoreServices/SystemUIServer.app/Contents/MacOS/SystemUIServer
UID: 501
Thread 0x50e DispatchQueue 1
User stack:
10 ??? (in SystemUIServer) [0x10d2b1898]
10 ??? (in SystemUIServer) [0x10d2b1b63]
Kernel stack:
Thread 0x514 DispatchQueue 2
User stack:
Kernel stack:
Binary Images:
0x10d29d000 - 0x10d2fffff com.apple.systemuiserver 1.7 (352.1) <BA3A14B8-DF67-324B-A768-0D6630FE258A> /System/Library/CoreServices/SystemUIServer.app/Contents/MacOS/SystemUIServer
Process: talagent [154]
Path: /System/Library/CoreServices/talagent
UID: 501
Thread 0x50c DispatchQueue 1
User stack:
10 ??? (in talagent) [0x1059054e4]
10 ??? (in talagent) [0x1059065d2]
10 ??? (in talagent) [0x10590b8e2]
Kernel stack:
Thread 0x51a DispatchQueue 2
User stack:
10 _dispatch_mgr_thread + 54 (in libdispatch.dylib) [0x7fff8f7f331a]
10 kevent + 10 (in libsystem_kernel.dylib) [0x7fff8adcb7e6]
Kernel stack:
10 kqueue_scan + 416 (in mach_kernel) [0xffffff800053a660]
Binary Images:
0x105904000 - 0x105926ff7 talagent ??? (???) <6F3A8AC5-81C1-37C5-950A-ADA223071F87> /System/Library/CoreServices/talagent
Process: usbmuxd [24]
Path: /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/Resources/usbmuxd
UID: 213
Thread 0x1f8 DispatchQueue 1
User stack:
10 ??? (in usbmuxd) [0x100000fc4]
10 ??? (in usbmuxd) [0x100002441]
10 CFRunLoopRunSpecific + 230 (in CoreFoundation) [0x7fff8f838486]
10 __CFRunLoopRun + 1204 (in CoreFoundation) [0x7fff8f838c74]
10 __CFRunLoopServiceMachPort + 188 (in CoreFoundation) [0x7fff8f83050c]
10 mach_msg_trap + 10 (in libsystem_kernel.dylib) [0x7fff8adc967a]
Kernel stack:
10 ipc_mqueue_receive_continue + 0 (in mach_kernel) [0xffffff8000215930]
Thread 0x276 DispatchQueue 2
User stack:
Kernel stack:
Thread 0x279
User stack:
10 thread_start + 13 (in libsystem_c.dylib) [0x7fff914b8b75]
10 _pthread_start + 335 (in libsystem_c.dylib) [0x7fff914b58bf]
10 __select + 10 (in libsystem_kernel.dylib) [0x7fff8adcadf2]
Kernel stack:
10 wakeup + 992 (in mach_kernel) [0xffffff8000555010]
Thread 0x151f7d
User stack:
Kernel stack:
3 workqueue_exit + 1616 (in mach_kernel) [0xffffff80005a4200]
Binary Images:
0x100000000 - 0x100015ff7 usbmuxd ??? (???) <2201917F-97E6-A744-8CEE-FB8F3B855E44> /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/Resources/usbmuxd
Process: UserEventAgent [11]
Path: /usr/libexec/UserEventAgent
UID: 0
Thread 0x1c4 DispatchQueue 1
User stack:
10 start + 52 (in UserEventAgent) [0x10e4db9bc]
10 ??? (in UserEventAgent) [0x10e4dc30e]
Kernel stack:
Thread 0x1c5 DispatchQueue 2
User stack:
Kernel stack:
Thread 0x11ca38 DispatchQueue 20
User stack:
10 ??? (in CertsKeychainMonitor) [0x10e5e1469]
10 _dispatch_barrier_sync_f_slow + 137 (in libdispatch.dylib) [0x7fff8f7f4f7e]
Kernel stack:
Thread 0x1f1
User stack:
10 captived_thread + 1370 (in CaptiveSystemAgent) [0x10e7cf2a5]
Kernel stack:
Thread 0x5c6
User stack:
Kernel stack:
Binary Images:
0x10e4da000 - 0x10e4ddfff UserEventAgent ??? (???) <8347C77E-D2D7-31BD-AE7A-56171D897B7A> /usr/libexec/UserEventAgent
0x10e5de000 - 0x10e5e3fff com.apple.servermgrd.CertsKeychainMonitor 1.1 (1.1) <BE59657F-B7A7-3F50-BB7E-48F452111361> /System/Library/UserEventPlugins/CertsKeychainMonitor.plugin/Contents/MacOS/CertsKeychainMonitor
0x10e7cd000 - 0x10e7ebff7 com.apple.CaptiveSystemAgent 1.11 (1.11) <17F148F0-4C80-3F5B-9D5E-A15DA2967447> /System/Library/UserEventPlugins/CaptiveSystemAgent.plugin/Contents/MacOS/CaptiveSystemAgent
Process: UserEventAgent [144]
UID: 501
Thread 0x4d9 DispatchQueue 1
User stack:
10 start + 52 (in UserEventAgent) [0x105af29bc]
10 ??? (in UserEventAgent) [0x105af330e]
Kernel stack:
Thread 0x4e7 DispatchQueue 2
User stack:
Kernel stack:
Thread 0x4ea
User stack:
10 __NSThread__main__ + 1575 (in Foundation) [0x7fff96bb66a2]
10 -[NSThread main] + 68 (in Foundation) [0x7fff96bb672a]
10 ??? (in ACRRDaemon) [0x105b96a64]
Kernel stack:
Binary Images:
0x105af1000 - 0x105af4fff UserEventAgent ??? (???) <8347C77E-D2D7-31BD-AE7A-56171D897B7A> /usr/libexec/UserEventAgent
0x105b94000 - 0x105b9bfff com.apple.CrashReporter.ACRRDaemonPlugin 10.7.4 (352) <BE6DF00C-52AD-3328-B383-A59EBAE9591E> /System/Library/UserEventPlugins/ACRRDaemon.plugin/Contents/MacOS/ACRRDaemon
0x7fff8adb4000 - 0x7fff8add4fff libsystem_kernel.dylib ??? (???) <1DDC0B0F-DB2A-34D6-895D-E5B2B5618946> /usr/lib/system/libsystem_kernel.dylib
0x7fff8f7f1000 - 0x7fff8f7fffff libdispatch.dylib ??? (???) <1D5BE322-A9B9-3BCE-8FAC-076FB07CF54A> /usr/lib/system/libdispatch.dylib
0x7fff8f800000 - 0x7fff8f9d4ff7 com.apple.CoreFoundation 6.7.2 (635.21) <62A3402E-A4E7-391F-AD20-1EF20236CE1B> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff91467000 - 0x7fff91544fef libsystem_c.dylib ??? (???) <41B43515-2806-3FBC-ACF1-A16F35B7E290> /usr/lib/system/libsystem_c.dylib
Process: warmd [23]
Path: /usr/libexec/warmd
UID: -2
Thread 0x29c DispatchQueue 2
User stack:
Kernel stack:
Thread 0x2bb DispatchQueue 6
User stack:
Kernel stack:
Thread 0x2b9
User stack:
Kernel stack:
Thread 0x151f89
User stack:
Kernel stack:
Binary Images:
0x101369000 - 0x10137ffff warmd ??? (???) <C58F8EA6-0031-3E08-B773-32E8671800B1> /usr/libexec/warmd
Process: warmd_agent [185]
Path: /usr/libexec/warmd_agent
UID: 501
Thread 0x5ca DispatchQueue 2
User stack:
Kernel stack:
Thread 0x5cd DispatchQueue 6
User stack:
Kernel stack:
Binary Images:
0x10a8f9000 - 0x10a8fefff warmd_agent ??? (???) <B50D7239-0CB0-3BC2-B2B5-3CE083F66F4A> /usr/libexec/warmd_agent
Process: WindowServer [114]
Path: /System/Library/Frameworks/ApplicationServices.framework/Frameworks/CoreGraphics.framework/Resources/WindowServer
UID: 88
Thread 0x3e4 DispatchQueue 1
User stack:
10 start + 52 (in WindowServer) [0x10d029f20]
10 main + 9 (in WindowServer) [0x10d029f31]
10 CGXServer + 1069 (in CoreGraphics) [0x7fff8cbf4142]
10 CGXServerLoop + 165 (in CoreGraphics) [0x7fff8c6a827f]
9 CGXRunOneServicesPass + 423 (in CoreGraphics) [0x7fff8c69e9ef]
7 CGXRunOneServerPass + 237 (in CoreGraphics) [0x7fff8c6a0e71]
7 mach_msg_trap + 10 (in libsystem_kernel.dylib) [0x7fff8adc967a]
2 CGXRunOneServerPass + 199 (in CoreGraphics) [0x7fff8c6a0e4b]
2 mach_msg_overwrite_trap + 10 (in libsystem_kernel.dylib) [0x7fff8adc9686]
1 CGXRunOneServicesPass + 161 (in CoreGraphics) [0x7fff8c69e8e9]
1 _CGXRunTimerPass + 439 (in CoreGraphics) [0x7fff8c68beed]
1 CGXUpdateDisplay + 7594 (in CoreGraphics) [0x7fff8c694c7e]
1 CGXReleaseDisplayDeviceSurface + 352 (in CoreGraphics) [0x7fff8c6d633f]
1 MPFinishSurfaceForDisplayDevice + 244 (in CoreGraphics) [0x7fff8c6d7580]
1 IOAccelFlushSurfaceOnFramebuffers + 80 (in IOKit) [0x7fff92fdb707]
1 IOConnectCallMethod + 172 (in IOKit) [0x7fff92fd1f3f]
1 io_connect_method + 431 (in IOKit) [0x7fff93017199]
Kernel stack:
1 hndl_mach_scall64 + 19 (in mach_kernel) [0xffffff80002daa33]
1 thread_set_child + 336 (in mach_kernel) [0xffffff80002aef20]
1 mach_msg_overwrite_trap + 184 (in mach_kernel) [0xffffff800021bbd8]
1 ipc_kmsg_send + 105 (in mach_kernel) [0xffffff80002148a9]
1 ipc_kobject_server + 342 (in mach_kernel) [0xffffff8000223096]
1 iokit_server_routine + 31048 (in mach_kernel) [0xffffff80002a3f08]
1 is_io_connect_method + 395 (in mach_kernel) [0xffffff800065609b]
1 IOUserClient::externalMethod(unsigned int, IOExternalMethodArguments*, IOExternalMethodDispatch*, OSObject*, void*) + 708 (in mach_kernel) [0xffffff80006558dc]
1 shim_io_connect_method_scalarI_scalarO + 461 (in mach_kernel) [0xffffff800065553d]
1 IOATIR800Surface::surface_flush(unsigned int, unsigned int) + 139 (in ATIRadeonX3000) [0xffffff7f81689bfd]
1 IOATIR800Surface::flush_surface(unsigned int, unsigned int) + 138 (in ATIRadeonX3000) [0xffffff7f81684628]
1 IOATIR800Surface::submit_swap(unsigned int, eDoSwap, unsigned int, IOATIR800GLContext*) + 679 (in ATIRadeonX3000) [0xffffff7f81685a81]
1 ATIR800Surface::generateSwapFlush(unsigned int, unsigned int, unsigned int) + 1144 (in ATIRadeonX3000) [0xffffff7f816a200e]
1 ATIRadeonX3000BltMgr::Stretch(_UBM_STRETCHINFO*, _UBM_E_RETURNCODE*) + 34 (in ATIRadeonX3000) [0xffffff7f8168fe34]
1 BltMgr::Stretch(BltDevice*, _UBM_STRETCHINFO*) + 2040 (in ATIRadeonX3000) [0xffffff7f8170b61a]
1 R800BltMgr::ExecuteBlt(BltInfo*) + 137 (in ATIRadeonX3000) [0xffffff7f8172f92b]
1 memset + 46 (in mach_kernel) [0xffffff80002af80e]
Thread 0x3e5 DispatchQueue 2
User stack:
Kernel stack:
Thread 0x464
User stack:
10 eventThread + 410 (in CoreGraphics) [0x7fff8c68822d]
10 CFRunLoopRun + 95 (in CoreFoundation) [0x7fff8f84819f]
Kernel stack:
Thread 0x58b
User stack:
Kernel stack:
Thread 0x590
User stack:
10 layer_blit_work_queue_server + 72 (in CoreGraphics) [0x7fff8c766968]
10 layer_blit_work_queue_thread + 1008 (in CoreGraphics) [0x7fff8c75c8c0]
10 __psynch_cvwait + 10 (in libsystem_kernel.dylib) [0x7fff8adcabca]
Kernel stack:
10 psynch_cvcontinue + 0 (in mach_kernel) [0xffffff800059daa0]
Thread 0x591
User stack:
Kernel stack:
Thread 0x592
User stack:
Kernel stack:
Thread 0x593
User stack:
Kernel stack:
Thread 0x594
User stack:
Kernel stack:
Thread 0x595
User stack:
Kernel stack:
Thread 0x596
User stack:
Kernel stack:
Binary Images:
0x10d029000 - 0x10d029fff WindowServer ??? (???) <632806B7-BBA7-3891-80CD-C88D8D90BF52> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/CoreGraphics.framework/Resources/WindowServer
0x7fff8c66e000 - 0x7fff8d00bc9f com.apple.CoreGraphics 1.600.0 (???) <1DB9C92C-DFA8-36ED-B513-998134462148> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
Process: xpchelper [2061]
Path: /usr/libexec/xpchelper
UID: 501
Thread 0x151f2b
User stack:
10 ??? (in xpchelper) [0x102046244]
10 ??? (in xpchelper) [0x102046f1f]
10 ??? (in xpchelper) [0x10204662c]
Kernel stack:
10 semaphore_wait_continue + 0 (in mach_kernel) [0xffffff8000234650]
Thread 0x151f30 DispatchQueue 2
User stack:
Kernel stack:
Thread 0x151f34 DispatchQueue 6
User stack:
10 _dispatch_sig_thread + 45 (in libdispatch.dylib) [0x7fff8f7f5b20]
10 __sigsuspend_nocancel + 10 (in libsystem_kernel.dylib) [0x7fff8adcb022]
Kernel stack:
Thread 0x151f33
User stack:
10 start_wqthread + 13 (in libsystem_c.dylib) [0x7fff914b8b85]
10 __workq_kernreturn + 10 (in libsystem_kernel.dylib) [0x7fff8adcb192]
Kernel stack:
10 workqueue_exit + 1616 (in mach_kernel) [0xffffff80005a4200]
Thread 0x151f35
User stack:
Kernel stack:
Thread 0x151f36
User stack:
Kernel stack:
Binary Images:
0x102045000 - 0x102055ff7 xpchelper ??? (???) <2196FD45-3FB6-3663-8E9D-255945DEBB4F> /usr/libexec/xpchelper
Process: kernel_task [0]
Path: kernel_task
UID: 0
Version: Darwin Kernel Version 11.4.0: Mon Apr 9 19:32:15 PDT 2012; root:xnu-1699.26.8~1/RELEASE_X86_64
Thread 0x1
Kernel stack:
10 vm_pageout_continue + 0 (in mach_kernel) [0xffffff800028ece0]
Thread 0x2
Kernel stack:
10 idle_thread + 0 (in mach_kernel) [0xffffff800022ccc0]
Thread 0x3
Kernel stack:
9 assert_wait_deadline + 480 (in mach_kernel) [0xffffff800022fb20]
1 call_continuation + 23 (in mach_kernel) [0xffffff8000820057]
Thread 0x4
Kernel stack:
10 thread_daemon_init + 272 (in mach_kernel) [0xffffff800023b6d0]
Thread 0x5
Kernel stack:
10 thread_create + 16 (in mach_kernel) [0xffffff800023b260]
Thread 0x6
Kernel stack:
10 thread_call_func_delayed + 304 (in mach_kernel) [0xffffff800023d9b0]
Thread 0x7
Kernel stack:
10 call_continuation + 23 (in mach_kernel) [0xffffff8000820057]
10 mapping_replenish + 393 (in mach_kernel) [0xffffff80002ade69]
Thread 0x8
Kernel stack:
10 zone_prio_refill_configure + 178 (in mach_kernel) [0xffffff8000243f22]
Thread 0x9
Kernel stack:
10 IOWorkLoop::threadMain() + 0 (in mach_kernel) [0xffffff800063b152]
Thread 0xb
Kernel stack:
Thread 0xd
Kernel stack:
Thread 0x2c
Kernel stack:
Thread 0x2e
Kernel stack:
10 AppleIntelCPUPowerManagement::~AppleIntelCPUPowerManagement() + 20592 (in AppleIntelCPUPowerManagement) [0xffffff7f81c22ec6]
Thread 0x31
Kernel stack:
Thread 0x34
Kernel stack:
Thread 0x37
Kernel stack:
Thread 0x3a
Kernel stack:
9 call_continuation + 23 (in mach_kernel) [0xffffff8000820057]
9 idle_thread + 27 (in mach_kernel) [0xffffff800022ccdb]
9 processor_idle + 149 (in mach_kernel) [0xffffff800022d375]
9 machine_idle + 289 (in mach_kernel) [0xffffff80002c63f1]
1 idle_thread + 0 (in mach_kernel) [0xffffff800022ccc0]
Thread 0x3d
Kernel stack:
10 idle_thread + 27 (in mach_kernel) [0xffffff800022ccdb]
10 processor_idle + 149 (in mach_kernel) [0xffffff800022d375]
10 machine_idle + 289 (in mach_kernel) [0xffffff80002c63f1]
Thread 0x40
Kernel stack:
Thread 0x43
Kernel stack:
Thread 0x48
Kernel stack:
Thread 0xa0
Kernel stack:
Thread 0xac
Kernel stack:
Thread 0xaf
Kernel stack:
Thread 0xb4
Kernel stack:
Thread 0xb9
Kernel stack:
Thread 0xba
Kernel stack:
Thread 0xbb
Kernel stack:
9 IOWorkLoop::threadMain() + 0 (in mach_kernel) [0xffffff800063b152]
1 IOWorkLoop::threadMain() + 118 (in mach_kernel) [0xffffff800063b1c8]
Thread 0xbc
Kernel stack:
Thread 0xbd
Kernel stack:
Thread 0xbe
Kernel stack:
Thread 0xc0
Kernel stack:
Thread 0xc3
Kernel stack:
Thread 0xc4
Kernel stack:
Thread 0xc9
Kernel stack:
10 m_prepend_2 + 24272 (in mach_kernel) [0xffffff800057d090]
Thread 0xca
Kernel stack:
10 audit_worker_init + 80 (in mach_kernel) [0xffffff80005260a0]
Thread 0xcb
Kernel stack:
10 get_aiotask + 160 (in mach_kernel) [0xffffff800052aa70]
Thread 0xcc
Kernel stack:
Thread 0xcd
Kernel stack:
Thread 0xce
Kernel stack:
Thread 0xd2
Kernel stack:
10 dlil_if_ref + 3469 (in mach_kernel) [0xffffff800034383d]
Thread 0xd3
Kernel stack:
10 dlil_init + 1179 (in mach_kernel) [0xffffff800034431b]
Thread 0xd6
Kernel stack:
10 utun_register_control + 60033 (in mach_kernel) [0xffffff8000373bd1]
Thread 0xd9
Kernel stack:
10 bpf_validate + 24886 (in mach_kernel) [0xffffff800033b616]
Thread 0xda
Kernel stack:
10 sockwall_gc_thread + 0 (in ALF) [0xffffff7f81ed1355]
Thread 0xdc
Kernel stack:
Thread 0xde
Kernel stack:
Thread 0xdf
Kernel stack:
Thread 0xe0
Kernel stack:
Thread 0x13a
Kernel stack:
Thread 0x13d
Kernel stack:
Thread 0x140
Kernel stack:
Thread 0x143
Kernel stack:
Thread 0x179
Kernel stack:
Thread 0x1b2
Kernel stack:
9 catch_exception_raise + 481 (in mach_kernel) [0xffffff80005acfe1]
9 mach_msg_receive + 163 (in mach_kernel) [0xffffff800021be03]
9 ipc_mqueue_receive + 70 (in mach_kernel) [0xffffff8000215886]
5 thread_block_reason + 275 (in mach_kernel) [0xffffff800022f413]
5 thread_go + 608 (in mach_kernel) [0xffffff800022e060]
5 processor_idle + 149 (in mach_kernel) [0xffffff800022d375]
5 machine_idle + 289 (in mach_kernel) [0xffffff80002c63f1]
3 thread_block_reason + 357 (in mach_kernel) [0xffffff800022f465]
3 ml_set_interrupts_enabled + 23 (in mach_kernel) [0xffffff80002be337]
1 thread_block_reason + 299 (in mach_kernel) [0xffffff800022f42b]
1 thread_continue + 1661 (in mach_kernel) [0xffffff800022f1ad]
1 machine_switch_context + 361 (in mach_kernel) [0xffffff80002c2939]
1 catch_exception_raise + 381 (in mach_kernel) [0xffffff80005acf7d]
1 mach_msg_send + 348 (in mach_kernel) [0xffffff800021bf8c]
1 ipc_kmsg_copyin + 36 (in mach_kernel) [0xffffff8000214534]
1 ipc_kmsg_copyin_header + 694 (in mach_kernel) [0xffffff8000213de6]
1 ipc_right_copyin + 857 (in mach_kernel) [0xffffff8000218e09]
Thread 0x1b3
Kernel stack:
10 vm_pageout_internal_start + 112 (in mach_kernel) [0xffffff800028c7d0]
Thread 0x1b4
Kernel stack:
10 vm_pageout_internal_start + 1296 (in mach_kernel) [0xffffff800028cc70]
Thread 0x1b5
Kernel stack:
10 vm_object_page_grab + 4800 (in mach_kernel) [0xffffff8000283020]
Thread 0x1be
Kernel stack:
10 sock_inject_data_in + 638 (in mach_kernel) [0xffffff8000598f9e]
10 thread_block_reason + 299 (in mach_kernel) [0xffffff800022f42b]
10 thread_continue + 1661 (in mach_kernel) [0xffffff800022f1ad]
10 machine_switch_context + 361 (in mach_kernel) [0xffffff80002c2939]
Thread 0x247
Kernel stack:
Thread 0x254
Kernel stack:
Thread 0x257
Kernel stack:
Thread 0x25a
Kernel stack:
Thread 0x2e9
Kernel stack:
Thread 0x2ed
Kernel stack:
Thread 0x2ee
Kernel stack:
Thread 0x2ef
Kernel stack:
Thread 0x2f0
Kernel stack:
Thread 0x2f1
Kernel stack:
Thread 0x2f9
Kernel stack:
Thread 0x304
Kernel stack:
Thread 0x308
Kernel stack:
Thread 0x30c
Kernel stack:
Thread 0x30d
Kernel stack:
Thread 0x317
Kernel stack:
Thread 0x31b
Kernel stack:
Thread 0x31c
Kernel stack:
Thread 0x330
Kernel stack:
Thread 0x38c
Kernel stack:
Thread 0x390
Kernel stack:
Thread 0x3f2
Kernel stack:
Thread 0x42c
Kernel stack:
Thread 0x45e
Kernel stack:
10 thread_call_func_delayed + 544 (in mach_kernel) [0xffffff800023daa0]
Thread 0x461
Kernel stack:
Thread 0x462
Kernel stack:
Thread 0x11af15
Kernel stack:
Thread 0x14f550
Kernel stack:
Thread 0x151f86
Kernel stack:
1 IOWorkQueue::ThreadCallMain(void*, int) + 26 (in IOBluetoothFamily) [0xffffff7f80da0f1a]
1 IOWorkQueue::processWorkCallFromSeparateThread(IOWorkQueueCall*) + 30 (in IOBluetoothFamily) [0xffffff7f80da1128]
1 IOWorkQueue::checkForWork() + 45 (in IOBluetoothFamily) [0xffffff7f80da117f]
1 IOWorkQueue::executeWorkCall(IOWorkQueueCall*) + 51 (in IOBluetoothFamily) [0xffffff7f80da0e41]
1 IOBluetoothHCIController::DesyncIncomingDataAction(IOBluetoothHCIController*, int (*)(IOBluetoothHCIController*, unsigned char*, unsigned int, unsigned int), void*, unsigned int, unsigned int) + 105 (in IOBluetoothFamily) [0xffffff7f80d7bd1f]
1 IOBluetoothHCIController::ProcessACLDataAction(IOBluetoothHCIController*, unsigned char*, unsigned int, unsigned int) + 18 (in IOBluetoothFamily) [0xffffff7f80d6cd08]
1 IOBluetoothHCIController::ProcessACLDataWL(unsigned char*, unsigned int, unsigned int) + 100 (in IOBluetoothFamily) [0xffffff7f80d6cd78]
1 IOBluetoothHCIController::DispatchIncomingACLData(unsigned char*, unsigned int) + 189 (in IOBluetoothFamily) [0xffffff7f80d78ef5]
1 IOBluetoothDevice::moreIncomingData(void*, unsigned int) + 353 (in IOBluetoothFamily) [0xffffff7f80d8eaa3]
1 IOBluetoothDevice::dispatchPacketToChannel(unsigned short, unsigned short, void*) + 119 (in IOBluetoothFamily) [0xffffff7f80d8d817]
1 IOBluetoothL2CAPChannel::newL2CapPacket(void*, unsigned short) + 54 (in IOBluetoothFamily) [0xffffff7f80d92c26]
1 IOBluetoothL2CAPChannel::newDataIn(unsigned short, void*) + 172 (in IOBluetoothFamily) [0xffffff7f80d92692]
1 BNBMouseDevice::processInterruptData(unsigned char*, unsigned short) + 541 (in AppleBluetoothMultitouch) [0xffffff7f81e33add]
1 IOBluetoothHIDDriver::processInterruptData(unsigned char*, unsigned short) + 408 (in IOBluetoothHIDDriver) [0xffffff7f80de870a]
1 IOHIDDevice::handleReport(IOMemoryDescriptor*, IOHIDReportType, unsigned int) + 61 (in IOHIDFamily) [0xffffff7f80a15541]
1 IOHIDDevice::handleReportWithTime(unsigned long long, IOMemoryDescriptor*, IOHIDReportType, unsigned int) + 173 (in IOHIDFamily) [0xffffff7f80a13e8d]
1 IOGeneralMemoryDescriptor::getPhysicalSegment(unsigned long long, unsigned long long*, unsigned int) + 0 (in mach_kernel) [0xffffff80006472ee]
Binary Images:
0xffffff7f80a10000 - 0xffffff7f80a47ff3 com.apple.iokit.IOHIDFamily 1.7.1 (1.7.1) <D78939C1-7812-3ABF-93E5-1281B95E9129> /System/Library/Extensions/IOHIDFamily.kext/Contents/MacOS/IOHIDFamily
0xffffff7f80d6b000 - 0xffffff7f80daefff com.apple.iokit.IOBluetoothFamily 4.0.5 (4.0.5f11) <49E0FFC8-BBE6-3C2C-9452-1518CB2FC2CE> /System/Library/Extensions/IOBluetoothFamily.kext/Contents/MacOS/IOBluetoothFamily
0xffffff7f80de2000 - 0xffffff7f80decfff com.apple.driver.IOBluetoothHIDDriver 4.0.5 (4.0.5f11) <E0B4C9D7-BCBB-390A-8764-849CEF0EA41B> /System/Library/Extensions/IOBluetoothHIDDriver.kext/Contents/MacOS/IOBluetoothHIDDriver
0xffffff7f81670000 - 0xffffff7f81798ff1 com.apple.ATIRadeonX3000 7.18.18 (7.1.8) <BB62D2AF-725C-3D33-8009-C51F397EBB72> /System/Library/Extensions/ATIRadeonX3000.kext/Contents/MacOS/ATIRadeonX3000
0xffffff7f81c1d000 - 0xffffff7f81c39fff com.apple.driver.AppleIntelCPUPowerManagement 193.0.0 (193.0.0) <654D2ABC-8783-3A8C-ADAC-5B56A63ECDF4> /System/Library/Extensions/AppleIntelCPUPowerManagement.kext/Contents/MacOS/AppleIntelCPUPowerManagement
0xffffff7f81e19000 - 0xffffff7f81e1cff9 com.apple.AppleFSCompression.AppleFSCompressionTypeDataless 37 (1.0.0d1) <038E60E5-3805-313A-A66A-B24EC84013DA> /System/Library/Extensions/AppleFSCompressionTypeDataless.kext/Contents/MacOS/AppleFSCompressionTypeDataless
0xffffff7f81e30000 - 0xffffff7f81e38fff com.apple.driver.AppleBluetoothMultitouch 70.12 (70.12) <FDCED3EF-FA31-3B5B-9DC4-2300E4839F56> /System/Library/Extensions/AppleBluetoothMultitouch.kext/Contents/MacOS/AppleBluetoothMultitouch
0xffffff7f81ecc000 - 0xffffff7f81ed2fff com.apple.nke.applicationfirewall 3.2.30 (3.2.30) <646061A5-10A6-3928-9399-EC1F428F3593> /System/Library/Extensions/ALF.kext/Contents/MacOS/ALF
0xffffff8000200000 - 0xffffff8000731f19 mach_kernel ??? (???) <A8ED611D-FB0F-3729-8392-E7A32C5E7D74> /mach_kernel
Kextstat:
Index Refs Address Size Wired Name (Version)
1 77 0xffffff7f80732000 0x683c 0x683c com.apple.kpi.bsd (11.4.0)
2 6 0xffffff7f80852000 0x3d0 0x3d0 com.apple.kpi.dsep (11.4.0)
3 101 0xffffff7f8073a000 0x1b9d8 0x1b9d8 com.apple.kpi.iokit (11.4.0)
4 105 0xffffff7f80756000 0x9b54 0x9b54 com.apple.kpi.libkern (11.4.0)
5 93 0xffffff7f80739000 0x88c 0x88c com.apple.kpi.mach (11.4.0)
6 32 0xffffff7f807d5000 0x4990 0x4990 com.apple.kpi.private (11.4.0)
7 53 0xffffff7f807da000 0x229c 0x229c com.apple.kpi.unsupported (11.4.0)
8 19 0xffffff7f80c0e000 0x7000 0x7000 com.apple.iokit.IOACPIFamily (1.4) <7 6 4 3>
9 27 0xffffff7f807dd000 0x1e000 0x1e000 com.apple.iokit.IOPCIFamily (2.6.8) <7 6 5 4 3>
10 2 0xffffff7f81e65000 0x58000 0x58000 com.apple.driver.AppleACPIPlatform (1.5) <9 8 7 6 5 4 3 1>
11 1 0xffffff7f80a04000 0xc000 0xc000 com.apple.driver.AppleKeyStore (28.18) <7 6 5 4 3 1>
12 9 0xffffff7f80856000 0x25000 0x25000 com.apple.iokit.IOStorageFamily (1.7.1) <7 6 5 4 3 1>
13 0 0xffffff7f80cce000 0x19000 0x19000 com.apple.driver.DiskImages (331.6) <12 7 6 5 4 3 1>
14 0 0xffffff7f81c1d000 0x28000 0x28000 com.apple.driver.AppleIntelCPUPowerManagement (193.0.0) <7 6 5 4 3 1>
15 0 0xffffff7f80853000 0x3000 0x3000 com.apple.security.TMSafetyNet (7) <7 6 5 4 2 1>
16 2 0xffffff7f808ba000 0x4000 0x4000 com.apple.kext.AppleMatch (1.0.0d1) <4 1>
17 1 0xffffff7f808be000 0x11000 0x11000 com.apple.security.sandbox (177.5) <16 7 6 5 4 3 2 1>
18 0 0xffffff7f808cf000 0x5000 0x5000 com.apple.security.quarantine (1.3) <17 16 7 6 5 4 2 1>
19 0 0xffffff7f81ecc000 0x8000 0x8000 com.apple.nke.applicationfirewall (3.2.30) <7 6 5 4 3 1>
20 0 0xffffff7f81c19000 0x3000 0x3000 com.apple.driver.AppleIntelCPUPowerManagementClient (193.0.0) <7 6 5 4 3 1>
21 0 0xffffff7f81e42000 0x3000 0x3000 com.apple.driver.AppleAPIC (1.5) <4 3>
22 2 0xffffff7f80bb3000 0x4000 0x4000 com.apple.iokit.IOSMBusFamily (1.1) <5 4 3>
23 0 0xffffff7f81ebd000 0x7000 0x7000 com.apple.driver.AppleACPIEC (1.5) <22 10 8 5 4 3>
24 0 0xffffff7f81b4e000 0x4000 0x4000 com.apple.driver.AppleSMBIOS (1.8) <7 4 3>
25 8 0xffffff7f80a10000 0x6b000 0x6b000 com.apple.iokit.IOHIDFamily (1.7.1) <11 7 6 5 4 3 2 1>
26 0 0xffffff7f81ec6000 0x4000 0x4000 com.apple.driver.AppleACPIButtons (1.5) <25 10 8 7 6 5 4 3 1>
27 0 0xffffff7f81c4d000 0x3000 0x3000 com.apple.driver.AppleHPET (1.6) <8 7 5 4 3>
28 0 0xffffff7f81b73000 0x8000 0x8000 com.apple.driver.AppleRTC (1.5) <8 5 4 3 1>
29 1 0xffffff7f81e23000 0x4000 0x4000 com.apple.driver.AppleEFIRuntime (1.5.0) <7 6 5 4 3>
30 0 0xffffff7f81e27000 0x7000 0x7000 com.apple.driver.AppleEFINVRAM (1.5.0) <29 7 5 4 3>
31 11 0xffffff7f809a1000 0x4f000 0x4f000 com.apple.iokit.IOUSBFamily (4.5.8) <9 7 5 4 3 1>
32 0 0xffffff7f80a8f000 0x10000 0x10000 com.apple.driver.AppleUSBUHCI (4.4.5) <31 9 7 5 4 3 1>
33 0 0xffffff7f80ad2000 0x17000 0x17000 com.apple.driver.AppleUSBEHCI (4.5.8) <31 9 7 5 4 3 1>
34 3 0xffffff7f80e67000 0xc000 0xc000 com.apple.iokit.IOAHCIFamily (2.0.8) <5 4 3 1>
35 0 0xffffff7f81e46000 0x18000 0x18000 com.apple.driver.AppleAHCIPort (2.3.0) <34 9 5 4 3 1>
36 5 0xffffff7f8096f000 0x29000 0x29000 com.apple.iokit.IONetworkingFamily (2.1) <7 6 5 4 3 1>
37 0 0xffffff7f80c4f000 0x10000 0x10000 com.apple.driver.Intel82574L (2.2.0b2) <36 9 5 4 3 1>
39 1 0xffffff7f80e9c000 0x33000 0x33000 com.apple.iokit.IO80211Family (420.3) <36 7 6 5 4 3 1>
40 0 0xffffff7f80ecf000 0x1ee000 0x1ee000 com.apple.driver.AirPort.Brcm4331 (530.4.20) <39 36 9 7 5 4 3 1>
41 0 0xffffff7f80a01000 0x3000 0x3000 com.apple.iokit.IOUSBUserClient (4.5.8) <31 7 5 4 3 1>
42 0 0xffffff7f80abd000 0x11000 0x11000 com.apple.driver.AppleUSBHub (4.5.0) <31 5 4 3 1>
43 6 0xffffff7f808d5000 0x2b000 0x2b000 com.apple.iokit.IOSCSIArchitectureModelFamily (3.2.0) <5 4 3 1>
44 0 0xffffff7f80e73000 0x9000 0x9000 com.apple.iokit.IOAHCISerialATAPI (2.0.3) <43 34 5 4 3 1>
45 6 0xffffff7f80760000 0x75000 0x75000 com.apple.iokit.IOFireWireFamily (4.4.5) <5 4 3 1>
46 0 0xffffff7f80d17000 0x28000 0x28000 com.apple.driver.AppleFWOHCI (4.8.9) <45 9 7 6 5 4 3 1>
47 0 0xffffff7f812a6000 0x9000 0x9000 com.apple.BootCache (33) <7 6 5 4 3 1>
48 0 0xffffff7f81e12000 0x5000 0x5000 com.apple.AppleFSCompression.AppleFSCompressionTypeZlib (1.0.0d1) <6 4 3 2 1>
49 0 0xffffff7f81e19000 0x5000 0x5000 com.apple.AppleFSCompression.AppleFSCompressionTypeDataless (1.0.0d1) <7 6 4 3 2 1>
50 0 0xffffff7f80bc9000 0x7000 0x7000 com.apple.iokit.SCSITaskUserClient (3.2.0) <43 12 5 4 3 1>
51 3 0xffffff7f80bd2000 0xd000 0xd000 com.apple.iokit.IOCDStorageFamily (1.7) <12 5 4 3 1>
52 2 0xffffff7f80bdf000 0xb000 0xb000 com.apple.iokit.IODVDStorageFamily (1.7) <51 12 5 4 3 1>
53 1 0xffffff7f80bea000 0xa000 0xa000 com.apple.iokit.IOBDStorageFamily (1.6) <52 51 12 5 4 3 1>
54 0 0xffffff7f80bf4000 0x1a000 0x1a000 com.apple.iokit.IOSCSIMultimediaCommandsDevice (3.2.0) <53 52 51 43 12 5 4 3 1>
55 2 0xffffff7f80946000 0x1d000 0x1d000 com.apple.iokit.IOFireWireSBP2 (4.2.0) <45 5 4 3 1>
56 1 0xffffff7f80963000 0x6000 0x6000 com.apple.iokit.IOFireWireSerialBusProtocolTransport (2.1.0) <55 45 43 5 4 3 1>
58 0 0xffffff7f81b09000 0x3000 0x3000 com.apple.driver.Oxford_Semi (3.0.1) <56 55 45 43 5 4 3 1>
63 1 0xffffff7f80a83000 0x6000 0x6000 com.apple.driver.AppleUSBComposite (4.5.8) <31 4 3 1>
64 0 0xffffff7f80ab7000 0x6000 0x6000 com.apple.driver.AppleUSBMergeNub (4.5.3) <63 31 4 3 1>
65 0 0xffffff7f80921000 0x15000 0x15000 com.apple.iokit.IOSCSIBlockCommandsDevice (3.2.0) <43 12 5 4 3 1>
66 0 0xffffff7f80e7f000 0x15000 0x15000 com.apple.iokit.IOAHCIBlockStorage (2.0.3) <34 12 5 4 3 1>
67 0 0xffffff7f81a03000 0x3000 0x3000 com.apple.driver.XsanFilter (404) <12 5 4 3 1>
68 1 0xffffff7f80a7b000 0x8000 0x8000 com.apple.iokit.IOUSBHIDDriver (4.4.5) <31 25 5 4 3 1>
69 1 0xffffff7f81c5d000 0x3000 0x3000 com.apple.driver.AppleHIDKeyboard (160.7) <25 4 3>
70 0 0xffffff7f81c60000 0x3000 0x3000 com.apple.driver.AppleUSBHIDKeyboard (160.7) <69 68 25 4 3>
71 4 0xffffff7f80d6b000 0x77000 0x77000 com.apple.iokit.IOBluetoothFamily (4.0.5f11) <7 5 4 3 1>
72 1 0xffffff7f80e02000 0xb000 0xb000 com.apple.driver.AppleUSBBluetoothHCIController (4.0.5f11) <71 31 7 5 4 3>
73 0 0xffffff7f80e15000 0xb000 0xb000 com.apple.driver.BroadcomUSBBluetoothHCIController (4.0.5f11) <72 71 31 5 4 3>
75 1 0xffffff7f812b0000 0x5000 0x5000 com.apple.kext.triggers (1.0) <7 6 5 4 3 1>
76 0 0xffffff7f812b5000 0x9000 0x9000 com.apple.filesystems.autofs (3.0) <75 7 6 5 4 3 1>
77 0 0xffffff7f8091d000 0x3000 0x3000 com.paceap.kext.pacesupport.snowleopard (5.8) <7 5 4 3 1>
78 2 0xffffff7f811b5000 0x6000 0x6000 com.apple.kext.OSvKernDSPLib (1.3) <5 4>
79 6 0xffffff7f811bb000 0x2d000 0x2d000 com.apple.iokit.IOAudioFamily (1.8.6fc17) <78 5 4 3 1>
80 0 0xffffff7f811e8000 0x12000 0x12000 com.focusrite.driver.usb2audio (1.3) <79 31 5 4 3 1>
81 0 0xffffff7f81a4b000 0x30000 0x30000 com.apple.driver.AppleUSBAudio (2.8.5f4) <79 31 5 4 3>
82 4 0xffffff7f80c15000 0x7000 0x7000 com.apple.driver.IOPlatformPluginFamily (5.1.0d17) <8 7 6 5 4 3>
83 0 0xffffff7f81c0c000 0x3000 0x3000 com.apple.driver.AppleLPC (1.5.8) <82 9 5 4 3>
84 0 0xffffff7f81b3d000 0x3000 0x3000 com.apple.driver.AppleSMBusPCI (1.0.10d0) <9 5 4 3>
85 1 0xffffff7f80c1c000 0x12000 0x12000 com.apple.driver.IOPlatformPluginLegacy (5.0.0d0) <82 8 7 6 5 4 3>
86 2 0xffffff7f80c2e000 0xd000 0xd000 com.apple.driver.AppleSMC (3.1.3d8) <8 7 5 4 3>
87 0 0xffffff7f80c3b000 0xf000 0xf000 com.apple.driver.ACPI_SMC_PlatformPlugin (5.0.0d0) <86 85 82 9 8 7 6 5 4 3>
88 13 0xffffff7f80c84000 0x38000 0x38000 com.apple.iokit.IOGraphicsFamily (2.3.2) <9 7 5 4 3>
89 5 0xffffff7f80cbc000 0x12000 0x12000 com.apple.iokit.IONDRVSupport (2.3.2) <88 9 7 5 4 3>
90 1 0xffffff7f81e00000 0x3000 0x3000 com.apple.driver.AppleGraphicsControl (3.0.16) <89 88 9 8 7 5 4 3 1>
91 0 0xffffff7f81e03000 0xf000 0xf000 com.apple.driver.ApplePolicyControl (3.0.16) <90 89 88 9 8 7 5 4 3 1>
92 2 0xffffff7f81c68000 0xc000 0xc000 com.apple.iokit.IOHDAFamily (2.2.0f3) <5 4 3 1>
93 1 0xffffff7f81c96000 0x14000 0x14000 com.apple.driver.AppleHDAController (2.2.0f3) <92 88 9 6 5 4 3 1>
94 0 0xffffff7f812c0000 0x4000 0x4000 com.apple.driver.AudioIPCDriver (1.2.2) <79 5 4 3 1>
95 0 0xffffff7f8120a000 0x5000 0x5000 com.apple.Dont_Steal_Mac_OS_X (7.0.0) <86 7 4 3 1>
96 1 0xffffff7f80bbb000 0xe000 0xe000 com.apple.iokit.IOSerialFamily (10.0.5) <7 6 5 4 3 1>
97 0 0xffffff7f80df4000 0xa000 0xa000 com.apple.iokit.IOBluetoothSerialManager (4.0.5f11) <96 7 5 4 3 1>
98 0 0xffffff7f80ba1000 0x12000 0x12000 com.apple.iokit.IOSurface (80.0.2) <7 5 4 3 1>
99 0 0xffffff7f80998000 0x6000 0x6000 com.apple.iokit.IOUserEthernet (1.0.0d1) <36 6 5 4 3 1>
100 0 0xffffff7f807fb000 0x28000 0x28000 com.uaudio.driver.UAD2System (6.1.0) <45 9 5 4 3 1>
101 0 0xffffff7f80d0a000 0xd000 0xd000 com.apple.iokit.IOFireWireIP (2.2.4) <45 36 5 4 3 1>
102 2 0xffffff7f814e6000 0x18a000 0x18a000 com.apple.kext.ATISupport (7.1.8) <88 9 8 7 5 4 3 1>
103 0 0xffffff7f819c5000 0x3e000 0x3e000 com.apple.kext.ATI5000Controller (7.1.8) <102 88 9 8 5 4 3 1>
104 0 0xffffff7f81670000 0x29b000 0x29b000 com.apple.ATIRadeonX3000 (7.1.8) <89 88 9 7 6 5 4 3 1>
105 1 0xffffff7f81b40000 0xe000 0xe000 com.apple.driver.AppleSMBusController (1.0.10d0) <22 9 8 5 4 3>
106 0 0xffffff7f81df1000 0xb000 0xb000 com.apple.driver.AGPM (100.12.42) <89 88 9 5 4 3>
107 0 0xffffff7f81a90000 0x9000 0x9000 com.apple.driver.AppleTyMCEDriver (1.0.2d2) <82 9 8 7 6 5 4 3 1>
108 0 0xffffff7f819ae000 0x12000 0x12000 com.apple.kext.ATIFramebuffer (7.1.8) <102 88 9 8 7 5 4 3 1>
109 0 0xffffff7f81c74000 0x15000 0x15000 com.apple.driver.AppleMikeyDriver (2.2.0f3) <105 8 5 4 3 1>
110 1 0xffffff7f81caa000 0xaa000 0xaa000 com.apple.driver.DspFuncLib (2.2.0f3) <79 78 5 4 3 1>
111 0 0xffffff7f81d54000 0x7a000 0x7a000 com.apple.driver.AppleHDA (2.2.0f3) <110 93 92 89 88 79 6 5 4 3 1>
112 0 0xffffff7f812c6000 0x5000 0x5000 com.apple.driver.AudioAUUC (1.59) <88 79 9 8 7 5 4 3 1>
114 0 0xffffff7f81bdd000 0xa000 0xa000 com.apple.driver.AppleMCCSControl (1.0.26) <88 9 7 5 4 3 1>
115 0 0xffffff7f81a89000 0x5000 0x5000 com.apple.driver.AppleUpstreamUserClient (3.5.9) <88 9 8 7 5 4 3 1>
116 0 0xffffff7f81bd2000 0x3000 0x3000 com.apple.driver.AppleMikeyHIDDriver (122) <25 7 4 3 1>
117 1 0xffffff7f80de2000 0x12000 0x12000 com.apple.driver.IOBluetoothHIDDriver (4.0.5f11) <71 25 5 4 3>
118 1 0xffffff7f81bc0000 0x12000 0x12000 com.apple.driver.AppleMultitouchDriver (231.4) <25 5 4 3 1>
119 0 0xffffff7f81e30000 0xe000 0xe000 com.apple.driver.AppleBluetoothMultitouch (70.12) <118 117 71 25 5 4 3>
120 0 0xffffff7f81c46000 0x5000 0x5000 com.apple.driver.AppleHWSensor (1.9.5d0) <5 4 3>
Model: MacPro5,1, BootROM MP51.007F.B03, 4 processors, Quad-Core Intel Xeon, 3.2 GHz, 16 GB, SMC 1.39f11
Graphics: ATI Radeon HD 5870, ATI Radeon HD 5870, PCIe, 1024 MB
Memory Module: DIMM 1, 4 GB, DDR3 ECC, 1066 MHz, 0x0198, 0x393936353532352D3031392E4130304C4620
Memory Module: DIMM 2, 4 GB, DDR3 ECC, 1066 MHz, 0x0198, 0x393936353532352D3031392E4130304C4620
Memory Module: DIMM 3, 4 GB, DDR3 ECC, 1066 MHz, 0x0198, 0x393936353532352D3031392E4130304C4620
Memory Module: DIMM 4, 4 GB, DDR3 ECC, 1066 MHz, 0x0198, 0x393936353532352D3031392E4130304C4620
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8E), Broadcom BCM43xx 1.0 (5.106.198.4.20)
Bluetooth: Version 4.0.5f11, 2 service, 18 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en2
Network Service: Ethernet 2, Ethernet, en1
PCI Card: ATI Radeon HD 5870, sppci_displaycontroller, Slot-1
PCI Card: Universal Audio UAD-2 Solo, sppci_othermultimedia, Slot-2
Serial ATA Device: HL-DT-ST DVD-RW GH61N
Serial ATA Device: WDC WD1001FALS-41Y6A1, 1 TB
Serial ATA Device: WDC WD1003FBYX-01Y7B1, 1 TB
Serial ATA Device: ST3320620AS, 320.07 GB
Serial ATA Device: WDC WD10EADS-00P8B0, 1 TB
USB Device: Scarlett 2i2 USB, 0x1235, 0x8006, 0xfa400000 / 2
USB Device: Keyboard Hub, apple_vendor_id, 0x1006, 0xfd500000 / 2
USB Device: ProtectExecuter, 0x0819, 0x0101, 0xfd510000 / 4
USB Device: Apple Keyboard, apple_vendor_id, 0x0250, 0xfd520000 / 3
USB Device: General Purpose USB Hub, 0x0451 (Texas Instruments), 0x2077, 0x1a200000 / 2
USB Device: iP4800 series, 0x04a9 (Canon Inc.), 0x10d5, 0x1a240000 / 3
USB Device: vendor_device, 0x086a (Emagic Soft-und Hardware Gmbh), 0x0001, 0x1a270000 / 5
USB Device: iLok, 0x088e, 0x5036, 0x1a210000 / 4
USB Device: BRCM2046 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0x5a100000 / 2
USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x8215, 0x5a110000 / 3
USB Device: USB Axiom 61, 0x0763 (M-Audio), 0x019a, 0x1d100000 / 2
FireWire Device: built-in_hub, 800mbit_speed
FireWire Device: Oxford ATA Device 00, G-TECH, 800mbit_speed
FireWire Device: My Book 1112, WD, 800mbit_speed
Jonnypopisical
Mac Pro, Logic Pro, lots of software and 17 hard drives!
Re: New ProMac System - problematic crashes
Postby chris... » Tue May 22, 2012 9:27 am
Wonder if it's memory related ?
You might try carefully taking out each memory module one at a time, to see if that cures things.
Also, did all the RAM come from Apple, or did you add 3rd party memory ?
chris...
Postby desmond » Tue May 22, 2012 9:41 am
That's not a crash, that's a hang.
Try removing third-party stuff like audio drivers, eucontrol etc - does it still happen?
Under what circumstances is this hang happening?
And unless you really are running Lion on a G5 somehow, then your sig's out of date.. ( ! )
Postby Jonnypopisical » Tue May 22, 2012 11:35 am
Sig's out of date!
Seems to only happen in 64-bit mode - is this an issue with 64-bit? Gone back to 32-bit and it seems better - will keep you posted....
I'll change my sig now! JP
Jonnypopisical
Postby Jonnypopisical » Tue May 22, 2012 11:38 am
BTW - What exactly is a hang - what's it waiting for?
JP
Jonnypopisical
Postby desmond » Tue May 22, 2012 12:09 pm
Also, make sure you are using fresh new Logic songs, rather than working off old LP7 or LP8 project templates.
Does it still happen then?
You're non-specific as to when this hang happens - is it on Logic startup? Randomly with seemingly no connection to events? Does it only happen in Logic? Have you downloaded and run Memtest to check your ram is ok?
Hangs are just that - something which should respond isn't responding for some reason. Did you migrate your old G5 system over to the new Mac, or did you start with a fresh clean OS install? If the former, you might have some old crud, drivers and PPC stuff which needs to be removed or updated.
Postby Jonnypopisical » Tue May 22, 2012 12:16 pm
Hi - Thanks for the replies.
It was a clean install from new and all software was installed on the machine as if new (most of it was).
It happens when I'm just working on a track (a new song started on this system) - seems to happen more in 64-bit mode but still happens in 32 bit. It's a real pain! It usually happens when I try to edit some audio - but not always...sometimes when I do something 'new' like unmute a track rather than just playing the song etc.
JP
Jonnypopisical
Postby Jonnypopisical » Tue May 22, 2012 2:00 pm
I'm now running it from the Line O/P of the Mac just to see if it's the 2i2 causing problems...
JP
Jonnypopisical
Postby Jonnypopisical » Wed May 23, 2012 9:53 pm
Seems 'better' but I'd still like to understand what is 'hanging' the machine - I need to live with it as is and see how frequently is crashes/hangs....
Jonnypopisical
Postby jrbcm » Wed May 23, 2012 10:09 pm
My Mac Pro has had stability issues lately too and I'm suspecting Firefox 12 is crashing and causing other progs to also crash at the same time. I'm on Snow Leopard. I also installed some extra RAM recently so that could be a cause I guess.... :?
jrbcm
Postby TBTS » Wed May 23, 2012 11:39 pm
That's alot of hard drives, it could be related to drive sleep states, disconnect all non essential drives and see if it improves.
TBTS
Apple Certified Technician + songwriter ** Shiny New Website with new music, videos etc... **
http://www.turnbacktospring.com
Postby Jonnypopisical » Thu May 24, 2012 10:37 pm
I've 'only' got 4 drives in the machine and 3 external ones - the others are all off line or in other machines...don't think that's the problem...
What I have found is that without the 2i2 as audio device my system no longer stalls over night - before the audio would just stop working - that's an improvement!
Jonnypopisical
Postby desmond » Fri May 25, 2012 12:05 am
Jonnypopisical wrote:What I have found is that without the 2i2 as audio device my system no longer stalls over night - before the audio would just stop working - that's an improvement!
So it could be crappy drivers. I this situation, check you have the most up-to-date driver and that it's officially compatible with your system. If it proves to be unstable, then you can try downloading older driver versions - sometimes an earlier version is more stable on your system.
Also, you could try running the kernel in 32-bit mode and seeing whether that has any affect on driver stability...
