Leopard and Lion on Separate drives on a Mac Pro
Postby forumuser663843 » Thu Jan 24, 2013 10:35 pm
Hi. is it possible to have two drives, one with Leopard and the other with Lion on Mac Pro and be able to switch between the two? The reason I need to do this is that Im upgrading cubase 4 to 7,but still need to be able to use cusebase 4 for some older projects.
forumuser663843
Re: Leopard and Lion on Separate drives on a Mac Pro
Postby chris... » Thu Jan 24, 2013 10:57 pm
Yep
chris...
Postby Mark6432 » Thu Jan 24, 2013 11:23 pm
As Chris says, yes it is.
Using disk utility you just wipe and install each OS on each HD, you then normally hold 'alt' on startup and it simply lets you choose the OS boot.
You might be better off partitioning one of the HD's, doing a similar dual boot process and using the other HD for storage etc. - things like audio files or sample libraries if you use them. This method can help improve performance although with a lot of current comps and HDs the difference may negligible.
There's loads of info via google on 'setting up dual boot systems'.
Mark6432
Postby Dave B » Fri Jan 25, 2013 8:46 am
I do this with Leopard (Cubase4) and Snow Leopard (Logic). I just have to remember to hold the Alt (*) key down when it's booting and you get to select which drive to boot from.
(*) or the apple key ... I can never remember which it is an sometimes it takes couple of goes. But I'm getting old and flaky
Dave B
Veni, Vidi, Aesculi
(I came, I saw, I conkered)
Postby forumuser663843 » Fri Jan 25, 2013 10:58 am
Thats great news. Thanks for all your help.
forumuser663843
Postby chris... » Fri Jan 25, 2013 11:41 am
Dave B wrote:I do this with Leopard (Cubase4) and Snow Leopard (Logic). I just have to remember to hold the Alt (*) key down when it's booting and you get to select which drive to boot from.
For what it's worth:
It's not the apple key aka "CMD" (which no longer has an apple on it, but does have the clover leaf thing).
It is indeed the "ALT" key, which back in the day was called "Option". So I used to remember: I want an option of what drive to boot from.
chris...
Postby Pink Fluid » Fri Jan 25, 2013 12:43 pm
Better still, I use rEFit which allows you to select which disk you want to boot from without any of that option key stuff. Find it here.... refit
Pink Fluid
Postby Will_m » Fri Jan 25, 2013 3:27 pm
Pretty sure you can open C4 projects in C7 too, just not the other way around.
Will_m
williammorrismusic.com
Postby Dave B » Sat Jan 26, 2013 3:00 pm
Chris - ta very muchly for the correction. I keep trying to remember it as "I want to boot to my ALTernative OS"
Dave B
Veni, Vidi, Aesculi
Postby chris... » Sat Jan 26, 2013 5:19 pm
Dave B wrote: "I want to boot to my ALTernative OS"
Clever!
chris...
