Can I use the Sibelius 7 sounds in Logic?
Postby I'd Rather Play » Sat Feb 23, 2013 6:31 pm
Hi there,
Is there any way of using the Sibelius 7 Orch library (ideally as an instrument plugin) in Logic?
I'd Rather Play
Re: Can I use the Sibelius 7 sounds in Logic?
Postby Exalted Wombat » Sat Feb 23, 2013 7:04 pm
I'd Rather Play wrote:Hi there,
I'm afraid the short answer is "no".
So's the long one, come to that.
I don't think you're looking for what Rewire does?
Exalted Wombat
Postby chris... » Sat Feb 23, 2013 7:17 pm
I've never used Sibelius, but I imagine its sounds can be triggered via midi.
In which case, presumably you can use the Mac's internal midi bus (IAC) to route midi from Logic to Sibelius.
At a guess:
- switch IAC on in Audio/Midi Setup
- set Logic to output midi to IAC
- set Sibelius to receive from it
(if Sibelius works like Logic, and simply receives from all midi ports simultaneously, then the latter step won't be needed)
chris...
Postby Exalted Wombat » Sat Feb 23, 2013 10:49 pm
chris... wrote:I've never used Sibelius, but I imagine its sounds can be triggered via midi.
No. Sibelius is a score publisher, with SOME sequencer features. MIDI input is on a single channel, for the purpose of capturing notation from a keyboard or other MIDI controller.
You COULD prepare MIDI tracks in Logic, export a MID file and open it in Sibelius. Then Rewire Sibelius' audio output back to Logic. But I think this is far from what's required here.
Exalted Wombat
Postby chris... » Sat Feb 23, 2013 11:38 pm
Ah right. It sounds like we could route one midi channel from Logic. But, for orchestral arrangements, that might be a bit limiting...
chris...
