2008 MacBook Pro freezes up
Postby danielhuw » Tue Jun 18, 2013 11:16 am
I've got a MacBook Pro 17" (Model A1261), 2.6 GHz, Early 2008.
After a few minutes use, the system freezes and the screen displays "digital noise". screen photo
I can restart the system by resetting the PRAM on power up. However the fault re-occurs a few minutes later. Any Ideas what the fault is? If I need a repair centre, can anyone recommend somewhere I could send it to?
Many thanks
Dan
danielhuw
Re: 2008 MacBook Pro freezes up
Postby Wimek » Tue Jun 18, 2013 1:59 pm
It sounds like a hardware problem. The first step I would take is to run the Apple Hardware diagnostics. I'm not completely sure, but as far as I remember it works like: insert the original MacOS install disk, restart while holding down the "D" key on the keyboard. If that works you should get a relatively simple menu where you can choose different hardware tests...
If there are no hardware problems, I would do a clean reinstall of MacOS... lots of work...
Hope this works for you.
Wimek
Postby danielhuw » Tue Jun 18, 2013 7:32 pm
Hi Wimek. Thanks for replying. That seems like a reasonable plan. I'll give it a try.
Dan
danielhuw
Postby Scope » Tue Jun 18, 2013 9:56 pm
Depending on the age of your mac, you can simply hold "D" on boot for be diagnostic mode
( unibody macs).
It sounds like logicboard / graphics / VRAM issue to me.
I'd expect it to fail a hardware test and need a new board if its displaying weirdness and freezing.
(Sorry !)
Scope
Postby Jumpeyspyder » Wed Jun 19, 2013 7:38 am
Agree with all above
It could also be the display mulfunctioning this could be tested by connecting to an external display (if you have one available).
Jumpeyspyder
Postby MonkeySpank » Wed Jun 19, 2013 11:10 am
This looks very familiar. I had a 15" of the same vintage and something very similar to this happened.
It turned out to be a known fault with the NVidia graphics chip on the logic board. Apple replaced it for free under warranty even though the machine was 3 years old. That warranty repair programme is now closed but it would be worth taking it to an Apple store for diagnosis.
MonkeySpank
Spanky
Postby danielhuw » Wed Jun 19, 2013 1:51 pm
Thanks for all those responses. I took it to a local repair centre for a diagnosis this afternoon. They ran a very quick diagnosis routine to test the graphics system, but it passed them all. I've let them keep it to run some more tests.
Dan
danielhuw
