About doing FTP on a PPC Mac..
Postby Gone To Lunch » Thu Oct 10, 2013 6:37 pm
I want to send my master for pressing by FTP, but am unsure how it works....
I have had a look at a few sites, and as I understand it, I just open an account, load up the files.
And then what ? do I just give an address to the pressing people who download them ?
Can anyone recommend an FTP that runs on a PPC pre-intel G5 ?
Gone To Lunch
Re: About doing FTP on a PPC Mac..
Postby Phil O » Thu Oct 10, 2013 6:52 pm
These days it's not usually necessary to have a FTP server utility as there are numerous online companies that provide a similar service e.g wetransfer, sendspace etc.
It's as simple as uploading your audio and providing the recipient with the download url (supplied by the company).
If you must have a FTP utility Fetch had a version that worked on PPC though I don't know if it's still available.
Phil O
Postby Scope » Thu Oct 10, 2013 9:16 pm
TRANSIT was a useful ( & free ) app for FTP
Scope
Postby Exalted Wombat » Thu Oct 10, 2013 9:22 pm
Gone To Lunch wrote:I want to send my master for pressing by FTP, but am unsure how it works....
The people doing the pressing will doubtless have a FTP (or similar) "mailbox" for this very purpose. Have a look on their website.
Exalted Wombat
Postby ManFromGlass » Fri Oct 11, 2013 12:17 pm
I have used CyberDuck for many years. It is free.
Cheers
Eric
Postby molecular » Fri Oct 11, 2013 5:12 pm
the easiest site I've found for this is wetransfer.com which is just a matter of entering their email address, your email address and choosing a file then waiting.
For anything under 2GB it's free and you don't even need an account.
The above are all good, though, and I've also used cyberduck for years, no glitches. It just means getting log in details for their FTP site rather than just an email address.
molecular
Location: The turn off where the main road goes over the river. If you're at the post box you've gone too far.
Anto mo Ninja, Watashi mo Ninja
http://www.hectormacinnes.com
Postby mpvano » Sat Oct 12, 2013 2:28 pm
1. +1 for cyberduck - handles almost any kind of transfer - not just ftp - and it can be tried for free. The only downside is that it requires Java and some people don't like installing it these days (but it does NOT require installing the java browser plugin - which is where most of the danger lies).
2. In some cases, the finder can handle the transfer directly after logging in to the server using the "connect to server" item in the "go" menu with the correct "ftp://" url. Sadly this works with very few ftp servers - check with your intended recipient or just try it.
3. In a REAL pinch, every OSX version has included a command line ftp client called ... "ftp"! While it's clumsy for non-geek use, it's also very compatible with nearly all ftp servers as it's a standard Unix implementation. You may be able to figure out how to use it with a little step by step help from your file recipient. It usually only needs 4 or 5 typed commands to upload a file. If you know how to use it, use the "man ftp" command for more information about it, or just google "osx command line ftp".
hope these add to your options...
M
mpvano
Surprised about "wetransfer"
Postby Jeraldo » Wed Oct 16, 2013 5:05 pm
I am surprised.
Because of the two mentions here, I tried "wetransfer." Both upload and download speeds are absolutely glacial, and it is completely impractical for sending and receiving almost anything of any size-even a short PDF file.
On the site, it mentions complaints about slow downloads (they say "sooooo slow"), and says it could be 1. time of day and/or 2. the users ISP. It also seems to indicate both free and paid plans are unthrottled.
My ISP speeds are just fine, and downloads from other sources are about 20 times faster. wetransfer also has a progress bar which has a running speed indicator for downloads. So the 20 times factor I mention is really on the conservative side relative to my ISP speeds and the experience of other downloads. The uploads are even worse-again, relative to my ISP upload speeds, and uploads to other sites.
Another transfer service,"sendthisfile," *is* throttled considerably for the free plans (they state this and provide a bar which indicates level of throttling for uploads) and it still much, much faster than wetransfer. The downloads from sendthisfile seem to be at normal speeds and unthottled-"normal" being the speeds of downloads in general, and generally near my ISP speeds, depending, of course, on the server providing the download.
This is not so much a complaint as a report, and I'm hoping that I've misunderstood something in a major way as there are reasons that would otherwise make me prefer wetransfer. (File size, for one, along with restrictive data amounts per month)
Are others' experiences similar to mine, or is something really wrong on my part?
(BTW, I've written wetransfer to report my experience and see if they have an explanation. I just sent that, so I'm hoping for a reply in the next several days.)
I'm hoping something is amiss, and I'll report back to revise my relatively negative comments.
Jeraldo
Re: Surprised about "wetransfer"
Postby molecular » Thu Oct 17, 2013 8:42 am
That's interesting stuff.
I've never really done an AB comparison with sending the same file by these means, so you could be right that wetransfer is unnecessarily slow. Where I live, 500mb+ can be an overnighter anyway so I wouldn't really notice a throttle.
Maybe I should stress again the bonus of it's super-simple interface, which has been a godsend when I've occasionally had to work with people who can't tell a .zip file from a seed potato, but I'm definitely interested to see what you come back with.
The one programme I have felt is noticeably slower than anything else is when placing files for other people to download using Dreamweaver, but that probably wouldn't be normal practise for most folk here anyway.
molecular
Postby Jeraldo » Thu Oct 17, 2013 2:45 pm
molecular wrote:That's interesting stuff.
500mb+ would not be an overnighter with wetransfer, it would be days.
Seriously, a 2 page PDF document took five minutes or more to load and the same to download. Sending the same file via email took about two seconds to send and a few seconds to receive/download.
molecular wrote:Maybe I should stress again the bonus of it's super-simple interface, which has been a godsend when I've occasionally had to work with people who can't tell a .zip file from a seed potato, but I'm definitely interested to see what you come back with.
Other services, like the one I mentioned (with some qualifications) above have equally simple interfaces.
I have to give them marks for frankly acknowledging the complaints about extremely slow speeds, but the causes they list are not the operative ones. And people wouldn't be complaining if the download speeds were the same as all the other sites they download from. (Apart from the slow uploads...)
I will definitely update this thread if I hear back from them.
Jeraldo
Postby ken long » Thu Oct 17, 2013 3:50 pm
Upload/download speeds and service providers aside - this particular thread was answered by this post. They have an FTP. You uplaod to their FTP. They give you login and password details. End of.
As for sharing services, can't go wrong with Google Drive. I've given up on Wetransfer and Sendspace because the links expire.
ken long
I'm All Ears.
Postby molecular » Thu Oct 17, 2013 8:58 pm
I wonder if there is some kind of clash with your system - I sent a file that was a little over 1GB just a few days ago with wetransfer and it took about 5 or 6 hours, and I live in the middle of nowhere. Anyway - I guess we can't solve it unless you hear back :)
Good luck to the OP...
molecular
Postby Gone To Lunch » Fri Oct 18, 2013 6:23 pm
Thanks for all your comments.
I have now done it happily and successfully via wetransfer.
Yes it was a little slow, but it was free, the pressing plant accepted it, and it was a once in a blue moon requirement for us, so it ended well for us.
Gone To Lunch
