Mavericks 10.9.2 and Security Update
Postby Tui » Tue Feb 25, 2014 8:56 pm
Anybody using Mavericks should install this asap. The update addresses serious security issues.
http://support.apple.com/downloads/
http://support.apple.com/kb/HT6150
Tui
Re: Mavericks 10.9.2 and Security Update
Postby desmond » Tue Feb 25, 2014 9:06 pm
This was a lovely example of a critical bug...
Yes, important to get this one fixed.
Postby chris... » Tue Feb 25, 2014 10:39 pm
Some of the media is exaggerating this abit, arguably failing to explain for folks not in the know that it can't just be exploited by any random hacker anywhere. Rather, the hacker has to already have access to your transmission path. In general, this isn't as easy as the media seems to suggest, and would generally require a determined hacker specifically deciding to target you in particular.
The fix will likely make life harder for the NSA, which is good.
But yes, definitely one to fix.
chris...
Postby desmond » Tue Feb 25, 2014 11:28 pm
chris... wrote:Some of the media is exaggerating this abit, arguably failing to explain for folks not in the know that it can't just be exploited by any random hacker anywhere.
Yep, someone *already on your network* can potentially run a man-in-the-middle attack but the attacker would already have to be on your network. The biggest risk really is when connected to public networks...
The media interest is that basically anything suggesting Apple aren't perfect gets journos and wackos salivating at the prospect of naming and shaming. "Apple has a security flaw!". Yes, and MS patch multiple Windows security flaws every tuesday but you don't make headlines about those either - even the serious ones.
But yes, a pretty nasty security bug this one, probably one of Apple's more serious ones in recent history (that I can remember anyway).
10.9.2 here now...
Test at gotofail.com
Postby xFasterMikeyH » Wed Feb 26, 2014 5:15 pm
desmond wrote:Yep, someone *already on your network* can potentially run a man-in-the-middle attack but the attacker would already have to be on your network. The biggest risk really is when connected to public networks...
Like when you check your email in a coffee shop, or at an airport.
desmond wrote:MS patch multiple Windows security flaws every tuesday but you don't make headlines about those either - even the serious ones.
Apple have a pretty woeful history on patching security flaws, for instance with their Java updates, none of which really makes the headlines. The reason this has people frothing quite so much is that it's relatively trivial to exploit and, given the ubiquity of iOS devices that are very likely to be connecting to public networks, has the potential to affect a lot of people.
chris... wrote:[exploiting this flaw would] require a determined hacker specifically deciding to target you in particular.
They don't need to target individuals, they need to target people using specific ios/osx versions using specific applications. That's trivial to do on a shared network for someone with not particularly impressive hacking skills (although they will need a dodgy cert to do it, but that's a pretty low barrier).
xFasterMikeyH
