Survey of Recommended PC Laptop Models
Postby Martin Walker » Wed Jan 31, 2007 10:48 am
Hi Everyone!
So many people post here asking for recommendations of PC laptop models that will work well with audio hardware/software that a sticky thread seems like a very good idea.
However, please remember that a personal recommendation, however honest and heartfelt, doesn't guarantee that someone else will have the same positive experience, or that a different audio interface may have problems, so take care out there.
Please use this thread as far as possible to post details of a model that you have that you would like to recommend to others, and why, rather than posting loads of queries. It will help greatly if you include:
1. Make and model.
2. Processor type & speed.
3. Amount of RAM.
4. Drive(s) capacity.
5. Make and model of audio interface
6. Interface connection type (USB 1.1, USB 2.0, Firewire, PCMCIA, PCI Express)
7. Main software used.
Let the recommendations commence!
Re: Survey of Recommended PC Laptop Models
Postby Martin Walker » Fri Feb 02, 2007 2:48 pm
There don't seem to be many people prepared to recommend their laptop models do there ;)
Surely someone's pleased with what they bought?
Postby auxpin » Sat Feb 03, 2007 12:08 am
great idea... had my Asus laptop for 18 months, runs like a dream and is my main machine now
1. Make and model.
ASUS A4K
AMD Athlon 3400+ (runs at aprox. 2.16Ghz)
3. Amount of RAM.
1GB
80GB Hitachi Travelstar 7200rpm internal drive
320GB Seagate 7200rpm USB external drive
160GB Seagate 7200rpm USB external drive
MOTU 828 Mark II
EgoSys WaMi box
Firewire
PCMCIA
Nuendo
Guitar Rig
Logic Platinum
AudioMulch
Wavelab
auxpin
Postby Martin Walker » Tue Feb 06, 2007 8:40 pm
Thanks auxpin for being the first to post, and welcome to the SOS Forums!
Postby mattatec » Wed Feb 07, 2007 10:53 pm
This has done many many live sets in all weathers/temperatures in environments such as beaches, deserts and sweaty clubs. it has never let me down.
1. Make and model.
IBM T42
Pentium M 1.7
3. Amount of RAM.
1 gig
60 gig
Echo Indigo I/O and DJ
PCMCIA
Ableton 5 and SX3
mattatec
Postby Colin Finnie » Wed Feb 21, 2007 1:16 am
I'm using a Compaq Presario V5155EA laptop, with a Core Duo 1.6GHZ dual processor, 1024MB RAM, 100GB 5400rpm hard drive.
This is working via firewire through the integral port (TI chipset) with a pair of MOTU 828Mk2 interfaces in a custom rack box. I'm running Nuendo.
This has handled flawlessly everything from a single voice-over (overkill perhaps, but it was what came to hand :)) to a 12-track rock band live gig recording. I'm still looking for the opportunity to try it with all 20 inputs running (16 line-in plus the 4 mic pre's built-in to the 828s).
Colin Finnie
Postby adrian_k » Thu Feb 22, 2007 1:47 pm
Hi all,
I'm extremely happy so far with my Millenium Music CX55, bought late last year. I think it is based on an Asus motherboard/chassis. The spec is:
1. CPU: Intel Core Duo T7200 @ 2GHz
2. RAM: 2GB 533 memory (could have had 667 but was too cheapskate)
3. DISK: 80GB 7200 SATA internal, 250GB Iomega 7200 USB2 external.
4. AUDIO INTERFACE: RME Fireface 800, via a SIIG Firewire 400 Expresscard. (Laptop does have onboard FW but it's 4 pin and like all 4 pin, a bit flimsy)
I'm using Sonar 5.2 with the above and (fingers crossed) have had absolutely no problems. Just been mixing a 35 track project off of the external drive with convolution reverbs, compressors etc etc no problem at all. Disk usage was showing about 75%, CPU about 35%. I could probably reduce disk usage by dumping all of the unused audio takes.
It's pretty quiet and you'd have no problem recording in the same room.
Not as good as my PaQ though ;)
cheers
Adrian
adrian_k
getting better all the time..
Postby waxwobbler » Mon Mar 26, 2007 7:27 pm
I recently bought a Toshiba Satellite pro A120
£750 inc vat from laptop direct with £100 cash back IF YOU REGISTER IN 7 DAYS.
http://uk.computers.toshiba-europe.com/cgi-bin/ToshibaCSG/jsp/productPage.do?service=UK&PRODUCT_ID=121987&toshibaShop=false
2Ghz C2 duo
Windows XP® Professional with “free” (£18) vista upgrade voucher.
- 100 GB Hard Disk Drive
- 1,024 MB DDR2 RAM (533 MHz)
- 15.4" WXGA TFT display
- DVD Super Multi (Double Layer) drive
1 year on sight warranty upon registration return to base if not.
I was drawn to this due to the price/power ratio, plus it is supposed to be very sturdy. Tosh will give a full refund & fix if any parts fail during the guarantee period. Speaking to numerous IT pro’s Tosh have a very good name.
It has a limited amount of I/O but s fine with me, no fire wire, I will use USB so no problem.
Someone on here said they suffered audio glitches under processor load at the time of the fan kicking in. This turns out to be a different model when using Firewire. I have extensively tested with Emu 0202 & M audio fast track pro. I am primarily concerned with soft synths & the Emu gave fantastic result even with a very heavy load in Reason.
The power of the laptop is really seen when using Reason, my instrument count is double that of my old P4 3 Ghz. Logic 5.5 strangely does not benefit as much & there is probably only a 25% increase in performance. Even though task manager shows 2 cpu’s being used.
Few things I have noticed.
Fan noise is not at all bad but does kick in a fair bit under load. Its definitely way louder than my P4 (silent PC) Antec case Zalman cooler etc.
Screen is really nice compared with the glossy type, matt may be a bit duller but there are very little reflections.
The keyboard feels good & the whole laptop seems to have a very strong & sturdy construction. Its is a little chunkier than other sexy Size 0 laptops.
Tosh supply all the individual drivers in a folder on the laptop along with the recovery CD so should you want to do a fresh install things should be straight forward.
Minor Gripes
3 pinned power supply leads to ground problems /digital noise in some situations. This is solved with a £15 Behringer hum eliminator or a USB soundcard. The problem is described in MW’s sticky as are details of the fix. It actually only hums in 1 of the 2 studio set ups I have used it in so there may be other ground problems in that situation
All the USB ports are round the back which is a bit of a pain but no biggie.
The wireless range seems to be slightly worse than other laptops, maybe 1 bar down. No biggie unless you are right at the edge of the wireless network.
Overall I am very happy with it & wouldn’t want to change it, good bang for the buck with the promise of refund if fails. Has enough power to use lots of soft synths & audio tracks & really is a portable studio for me.
waxwobbler
Postby MartMc » Tue Mar 27, 2007 2:08 pm
Hi guys,
I hope I'm not out of place here, but I have been offered a Lenovo 3000 N100 Core Duo T2300E and was wondering if anyone had any experience with them? The spec looks good enough and it also has an extra 1Gb of memory (1.5Gb in total)but I'm a little concerned about compatability etc. I don't have an interface as yet, but will be looking to pair up my ADA8000 with any ADAT interface.
Again, if i'm too off topic feel free to delete.
Thanks in advance,
Mart.
MartMc
Re: Survey of Recommended PC Laptop Models *DELETED*
Postby tea for two » Thu Mar 29, 2007 12:29 pm
Post deleted by Martin Walker at tft's request
tea for two
Our purpose is unique to us, just as meaning of our life is unique to us. There is no universal purpose. There is no universal meaning of life.
Postby Guss » Tue Apr 03, 2007 11:14 pm
HP Pavilion !!!!!!!!!!!
They are brilliant laptops but they have the worst customer service in the world. they are pretty similar to the Compaq Presarios (since Compaq and HP have merged)
I have had three Pavilions
First with Pentium 4 3.2 800MHZ buspeed - monster you could run millions of plugins and it wouldnt even notice ! (got nicked)
AMD 2ghz bit - great.
at the mo INTEL 4 centrino 1.73 (bit slow compared to the first one but does the job !)
512 - 1000 RAM on all
40 - 100 gb hard drives
They all do a great job and have nice speakers for a laptop which although arent "reference quality" ,hehe, can be useful for jotting down ideas.
I have also had Toshibas, sun microsystems and various unbranded nightmares.
If you ever have hastle with the customer services get the trading standards onto them and they will sort you out .
I run :
Max MSP
Cubase/Nuendo
Fruity Loops
Reason
Waves
Protools
GRM Tools
Wavelab
Audition
etc etc
Interfaces :
M-audio Firewire 410 ( I have an online petition to get them to write some proper drivers !°)
Digidesign Mbox USB2
U2A USB2
Guss
Postby Tus Tep » Wed Apr 04, 2007 11:02 pm
Hi! Sorry for interrupting with a question but I think this might help the conversation on the issue. And as I'm considering buying a notebook and HP's seems to be one of the best options I wanted to ask a couple of things about them which I don't have it so clear:
1. Which is the best line, Pavillion or Compaq? I'm not really focusing on budget nor on nice looks (I know the Pavillions ares so nice!) but I read somewhere that "business" notebook are generally better built. Though it seems that specifications for high end notebooks seem to be better on the Pavillions, is this alright? Can you enlighten me about this issue?
2. I'm looking for a really high end notebook, though not going for a 17 inch. I'd like to stay within the 15 inch range. What would be the best option on HP, the Pavillion 6000t? (Core 2 Duo) or some other Compaq?
3. What can you say about the silentness of these HP models. This is something I really care for as I plan to record on the room and also perform electroacoustic music in very subtle environmentes in which disturbing fan noise could be a problem
THANKS!!
Tus Tep
Postby Guss » Thu Apr 05, 2007 1:37 am
Tus Tep wrote:Hi! Sorry for interrupting with a question but I think this might help the conversation on the issue. And as I'm considering buying a notebook and HP's seems to be one of the best options I wanted to ask a couple of things about them which I don't have it so clear:
THANKS!!
they are as quiet as any laptop. I do not recommend a business laptop - no way get a multi media one - after all thats closer to what you want it for. There are Compaq Presarios that are multimedia though i dont know what they are like - probably pretty good too.
The HP Pavilion dv6000 looks goooodd. However you want a laptop that works not just looks nice so.... The best thing to do is go to read the reviews here (look at the user reviews not the editor review, the users will let you know what the score is after months of use, the editor looks it over for a couple of hours) :
http://reviews.cnet.com/4566-3121_7-0.html?tag=dffl2_3&filter=1000036_2792031_
DV6000T :
http://reviews.cnet.com/HP_Pavilion_dv6000t_Core_2_Duo/4505-3121_7-32036702.html?tag=prod.txt.2
I heard they had some heating problems, its always like this with laptops, they get the bugs out on the newer models. Maybe consider a MACbook to run windows on if need be, but although there is a legit version of Windows for Mac there is no support.
I make electroacoustic music too BTW . If you want to look past the looks and blablabla then look at stuff like the FSB speed, cache size and hardrive speed . Get a 2 core duo.
Guss
Postby Tus Tep » Sat Apr 07, 2007 2:26 am
Hi!
Thanks for all the info
I still don't get why is it better to get a Pavillion DV6000t rather than an HP COmpaq NC 8430 or NW8440 if these are supposed to be more reliable and better constructed machines (if one is looking for something to be professionaly used)
Any more info would be very useful.
Tus Tep
Postby StudioEner » Tue Apr 17, 2007 9:20 pm
Lenovo T60
Intel Core2Duo T5600 1.83Ghz
2 GB ram
100 GB Hitachi Travelstar HD
RME Fireface 800
Mainly Cubase SX3
Does not have integrated Firewire, but have worked like a dream for 5 months now using a PCMCIA firewire-card (VIA chip).
There is also an ExpressCard slot and 3 USB2-ports.
The 14' screen makes it pretty portable, the machine is relatively quiet.After trying out different laptops for almost 6 months I finally settled for this machine and it has not let me down!
StudioEner
Postby hegiian » Fri Apr 20, 2007 5:53 pm
1. Make and model.
redsub 15.4" pro audio laptop
pentium M (2ghz)
3. Amount of RAM.
1GB
100 gig internal drive partitioned 15/85 - program/audio
focusrite saffire pro x2 + octopre le
Firewire
Nuendo
Wavelab
This set up has been absolutely brilliant over the past year, and I would have no problem recommending redsub to ANYONE. I have used it to record 20 track live shows, to mix and remix, and occasionaly even to do some "away from home" mastering. Okay, my laptop may seem slow now ON PAPER, but it has been that well set up by the guys at redsubmarine, it seems just as fast as my duocore desktop model. The level of help, expertise, and pure build quality is of such a high standard that I will now only use redsub for all my audio purchases.
hegiian
Postby markinbfa » Tue May 22, 2007 8:22 am
1. Make and model.
TOSHIBA Satellite 30M
Intel Pentium M Processor 1.7GHz
3. Amount of RAM.
1G
Internal 60G
External One: 120G
External Two: 320G
M-Audio 410
Firewire
Nuendo 3
Cubase SX3
markinbfa
Postby PlaguesBand » Tue Jun 05, 2007 6:39 pm
Call me crazy but I bought a Dell !!!!AAAAARGGGHHH!!!! Actually it's awesome and blows my desktop (XP3200+ Barton based) out of the water. Spec is:
1. Make and model
Dell Inspiron 6400
Intel Core 2 Duo T7200 dual 2.0GHz, 667MHz FSB,FSB4MB L2 Cache
3. Amount of RAM.
1024MB 667MHz DDR2
120GB SATA
M-Audio Fasttrack Pro
USB 2.0
Mainly Sonar 6PE and Reaktor 5
This system works really well, I have pushed it plenty with some huge custom built Reaktor synths and sequencers but it seems to handle pretty much anything I throw at it. Bought a cooling plinth (Akasa) for £29.99 which keeps it nice and stable/cool.
The M-Audio interface has been great too. I use an Audiophile 24/96 PCI on my desktop and this USB has measured up pretty well. Sound is really nice and warm, great controls and nice simple layout. Only things I would improve are:
1.the routing options are slightly less flexible on the software panel interface than than the 24/96
2. Got a few pops monitoring through Sonar on the lowest soundcard latency setting but whacked it up to next slowest and the pops went away. Latency is still great, getting reported latency of 2.9 ms in Sonar which is fine, even for playing my guitar through amplitube with software monitoring.
All in all, this was a great buy - the laptop and soundcard came in at under £900.
PlaguesBand
Postby Wilco » Tue Jun 19, 2007 2:18 pm
I'm using an HP NX8220 laptop, which has good specs and a nice 15.4" screen (1640x1050). It isn't too noisy (unless it runs Vista that is).
The disadvantage I find with laptops is that they are very rapidly superceded with newer models, which mostly are not better, if only more powerful. And therefore probably much noiser also, which I personally don't like.
1. Make and model.
HP NX8220
Intel Pentium M 1,86 Mhz
3. Amount of RAM.
1024 Mb
60Gb 5400rpm, split in 3 partitions, all NTFS:
- Windows Vista
- Windows XP
- Data
Made it dualboot as my music software doesn't always agree with Vista (yet).
MOTU 828mkII
3x USB 2.0
1x Firewire 400
1x PCMCIA
1x 1Gb ethernet
1x 56kbps modem
- Brainspawn Forte for live use
- Cubase SX3
Wilco
Postby Wilco » Wed Jun 20, 2007 7:31 am
As I stated before, the laptop market is a rapidly changing one and a certain type of laptop may be superceded by another one in 3-6 months. Or (this also happens quit a lot) the internal components are changed without notice. For instance because they are cheaper to get or have slightly better specs.
As I am not only a musician but also an IT professional I see this happening an awful lot.
I therefore think that it might be better to put a list together of good components rather than complete laptops. Certain motherboards or graphic interfaces or FW/USB devices are not very good, others are very good. Some chipsets may not be working so well. Of course you could try to keep an up-to-date list of good working laptops, but that list is bound to change on a regular basis.
This, however, should be a part of the SOS website itself and not just the forum. The forum could be used to get input from everyone. The results can than be published as part of the SOS website and as such provide a very good starting point for people searching for a laptop. They can then compare the specs and that, at least, should save them from buying not-so-compatible laptops.
Ofcourse this scenario could also apply to PC's and PC components involed. These also change rapidly. Also, the 'ongoing guide to putting together a decent laptop/PC' could be published in the magazine as part of the PC Notes. A spinoff could be a list of second-hand laptops/pc's which may be a bit older but nonetheless have good quality.
Also I think that the way a forum works is not that good for this kind of thing. It is just not very handy to have to read al posts and compare specs/components everyone talks about, certainly not as the list grows and grows.
Just an idea....
Wilco
Postby John Willett » Thu Jun 21, 2007 10:11 pm
1. Make and model.
Samsung X50
Intel Pentium Centrino 2GB
3. Amount of RAM.
1GB (note to self: must upgrade this to 2GB)
80Gb - Windows XP-Pro SP2
RME Fireface 400
6. Interface connection type (USB 2.0, Firewire, PCMCIA.)
Sequoia 9.1.1
John Willett
Postby Scope » Sat Jul 14, 2007 9:38 am
Any Sony Vaio - Brilliant.
( with a proper video chip, not the crappy Intel one included in the cheaper models ! )
Or, - dare I say it -
APPLE -
Yep, an Intel Mac ! - runs XP faster than it runs Mac OS- seriously !!!!!
Good kit, not cheap, well made, runs XP / Vista ( not that I could recommend Vista right now ) and you get OS-X if you want to try it.
Now there's a thought...........
Scope
Postby Cowboy Unit 5 » Sun Jul 15, 2007 2:11 am
1. Make and model.
Dell Latitude D820
Core Duo 2Ghz
3. Amount of RAM.
2Gig
80 Gig 7200rpm
Echo IndigoIO
PCMCIA
Ableton Live
Windows XP service pack 2, kept up to date with "Windows Update"
An olde copy of Cool Edit Pro is my audio editor
I have Ubuntu Studio running (as dual boot) but haven't used it for real work since I like Live so much.
This laptop has been real stable and snappy fast. I take it with me everywhere. I record at home at night and can do mixing and editing at the cafe with headphones the next day. The widescreen is nice.
Cowboy Unit 5
Postby XLII » Tue Jul 24, 2007 11:54 am
Definitely DELL. I got 2.
first 1 from Jan 2005:
1. DELL Inspiron 1150
2. Pentium 4 2.8Ghz
3. 1GB RAM
4. 60GB 5400RPM Internal; 160GB 7200 external
5 & 6. USB: M-audio Quattro (for live shows); Firewire: M-audio 410 (for studio)
7. Cubase SX3 with NI Komplete, Reason & plug-ins for studio; Ableton Live for gigs.
I've used this PC for 2 years for live shows, it's been to more than a dozen countries, at least 200 nights out in clubs, splashed with beer, dropped, covered in sand at beach parties, covered in snow at snowboarding events and still runs smooth as the first day I got it. i'm typing on it now.:)
Second PC:
1. DELL Latitude D830
2. Intel Centrino Duo 2.4Ghz
3. 2GB RAM
4. 120GB 5400 RPM Internal; 120GB 7200 Portable external
5 & 6. E-mu 1616m (for Portable) on PCMCIA; Digidesign Digirack 002 (studio) on Firewire
7. Cubase SX3, Reason, NI stuff (I love MASSIVE!!!), Pro Tools LE 7 (for mixing only), OutSym Synth Maker, Ableton Live (for live shows)
XLII
Postby tea for two » Wed Jul 25, 2007 2:41 pm
In trying to find a low cost "ideal" laptop for music,
I have been through various laptops over the last months, including
single core Pentium M's (on the Centrinos), Celeron M, AMD Athlon Mobile, Turion,
Core Duo and Core 2 Duo on the Napa platform (945 chipset), AMD Turion X2.
As part for my "research" :roll: I was looking for a laptop that had
1. Specs
Texas Instruments Firewire chip.
Minimum 3x USB2.0.
Express card slot with no issues (for future proofing), and a normal pc card slot.
SATA hard disk.
Gigabit LAN.
2. Design
Bright screen.
Brilliant touchpad (sweaty finger & wet finger poof) ! and or excellent trackpoint.
Quiet mouse buttons ie. non clickety ... important when recording audio.
Quiet enough decent keyboard with low click noise on space bar ...
necessary for low noise play & stop operation.
Full size return, space & backspace keys.
Other keys in their normal position, eg. delete & shift keys not in the wrong place.
All USB & Firewire ports, other important ports & slots on the side, not on the back.
Non obtrusive LED's, useful quick access buttons.
All ports labelled clearly and easy to read when just looking down on the keyboard.
BIOS allows some onboard devices to be turned on & off.
3. Construction & build quality
Magnesium alloy frame, steel hinges.
Thin & lightweight.
Easy to get to parts and easy to remove and replace them.
Easy enough to disassemble and reassemble the laptop.
4. In operation
Quiet even when fans come on. Can record 3 ft away and pick up nothing.
Idle around 27-33c.
Palm rest remains cool on both sides even after prolonged use.
Turning off onboard audio in Device Manager is just fine to then use external audiocards.
The laptop that had all these were the
HP Compaq NC6320 (Core 2 Duo) and the
HP Compaq NX6325 (Turion X2) business notebooks.
No Acer, Asus, Dell, HP Pavillion, IBM, Fujitsu, Sony, Toshiba had all these considerations.
Thus IMO, once could save upto £500 by going for one of these two HP Compaq NC6320 (Core 2 Duo) and the HP Compaq NX6325 (Turion X2)
instead of a "dedicated" music laptop.
Incidently both took Vista just fine and drivers are available on HP's site.
How would I improve the NC 6230 & NX6325 :
by having a 6pin Firewire port, e-sata port (both rare on windows laptops), widescreen, as soft a keyboard as on the Fujitsu pi1536,
possibly a trackpoint in addition to the touchpad, 2 prong power supply.
If wanting to go Santa Rosa platform PM965 chipset (budget permiting)
this page lists the releavnt model numbers :
HP Compaq 8510p, 8510w, 8710p, 8710w, 6510b, 6710b, 6910p.
I know now that if I was to buy a laptop,
I would save myself a lot of time, hassle and money and go straight to the
HP Compaq business notebooks.
Though I would also google the specific model number to ensure there are no fan issues.
tea for two
Users browsing this forum: No registered users and 0 guests
