Cheap Laptop Audio Output
Postby Mowens800 » Fri May 06, 2011 8:29 pm
In the near future I'm going to need to do some portable critical listening via a laptop which is not high spec. It is purely playback (.wav files via media player). I don't want to carry my larger soundcard with me or spend a large amount of money on this short project.
So... would something like this give me a good improvement in the audio output from a basic laptop rather than using the default out.
http://www.dv247.com/computer-hardware/behringer-ufo202-high-quality-usb-audio-interface-with-built-in-phono-preamp--61722
USB powered, no drivers is a bonus. But I'd still need an adapter 1/8 to 1/4. What I'd ideally like is just a little USB adapter that takes care of the audio driver and splits it out down a 1/4 jack with volume control for a compact portable playback improvement option... anything out there?
Cheers
Mowens800
Re: Cheap Laptop Audio Output
Postby Martin Walker » Sat May 07, 2011 11:51 am
If your budget would stretch to it this CEntrance DACport would be perfect - excellent audio quality, rugged, yet tiny. I reviewed it in SOS June 2010, and plenty of professionals use it!
www.soundonsound.com/sos/jun10/articles ... acport.htm
If on the other hand you’re on a strict budget, take a look at M Audio’s Transit, which offers bit-transparent USB-powered audio recording/playback in a very small package with a 3.5mm headphone output. EDIT: ON further investigation the Transit has been discontinued :headbang:
You might look at the Digidesign M Box 2 Micro if that’s till available :beamup:
Just found another one that would certainly be worth looking into - ESI’s Dr. DAC nano:
www.esi-audio.com/products/drdacnano
At around £60 I think this has to be your best bet! 8-)
Postby Mowens800 » Sat May 07, 2011 12:06 pm
ouch, that's quite a big stretch. Especially since this is for about 3-5 days tops as I won't need to be portable after that. At that price I'd be more inclined to have the hassle of putting my Pro40 under my arm and carrying that along with me... which is ofcourse an option, but one I'd prefer to avoid this time.
Is there nothing in the £30 or so price range then which is simply an improved headphone output for laptop users. I'd have thought it would have a broad appeal to those listening to music on the go but care a bit more about quality and don't want a USB soundcard along with them.
or a small headphone out from the laptop socket, but I guess the laptop socket may pre-compromise the quality?
ETA: Just seen your edit. I'll check that out now
Mowens800
Postby Martin Walker » Sat May 07, 2011 12:08 pm
Just edited my original post Mowens800 - you mind find my new recommendation more palatable ;)
Postby Mowens800 » Sat May 07, 2011 12:12 pm
That looks spot on. Now if only they could half the price we'd be on to a winner :D
I won't be ordering until June if anyone else reading this has something similar or wants to review it before hand...
Thanks again, bookmarked and put on the shopping list.
Mowens800
Postby Exalted Wombat » Sat May 07, 2011 12:25 pm
Mowens800 wrote:In the near future I'm going to need to do some portable critical listening via a laptop which is not high spec. It is purely playback (.wav files via media player). I don't want to carry my larger soundcard with me or spend a large amount of money on this short project.
Cheers
What's actually wrong with the headphone output on the laptop? What will you be feeding it to, powered speakers or headphones?
If you're unlucky enough to have a laptop with a really crap, noisy audio output, fair enough. But today's computers are often a lot better than that. You may find yourself spending money on an interface that does no better than the internal audio.
Exalted Wombat
Postby Mowens800 » Sat May 07, 2011 12:28 pm
Yes that's my worry, or that it doesn't have enough power to drive the headphones properly. It's only for headphones.
I'll be able to check it in a few weeks but until then, I thought better to have a safety net thought out incase it is terrible. We are talking a sub £400 from a few years ago ACER laptop here, so the headphone output quality won't be high up on the agenda.
Mowens800
Postby Exalted Wombat » Sat May 07, 2011 4:00 pm
Mowens800 wrote:Yes that's my worry, or that it doesn't have enough power to drive the headphones properly. It's only for headphones.
Well, it's probably got the same chip running audio as every other Acer ov that vintage. And quite likely of any one bought today :-)
One thing to check. If you're worried about level, anything that is going to drive a given pair of cans louder than the laptop directly is going to need an external power supply. And that can open a whole new can of worms with noisy ground-loops. Better to look for a more efficient set of headphones.
Exalted Wombat
Postby Mowens800 » Sat May 07, 2011 4:13 pm
The devices above are pitched as bus-powered so hopefully that won't be an issue. If that was the case, the usb device wouldn't be fit for purpose and I'd have to return it.
I'll be able to get my hands on the laptop with my headphones and do a 'suck it and see' test at the end of the month. Fingers crossed I'm just being overly cautious and the normal output alone does just fine.
Mowens800
Postby twotoedsloth » Sat May 07, 2011 7:17 pm
The original mbox is bus powered and sounds (relatively) great. You can get one used for $50. The only thing is that it won't work with Pro Tools 8.x but I think it will work in PT9 with the ASIO driver.
twotoedsloth
Postby James Perrett » Mon May 09, 2011 3:26 pm
The audio output from my old Acer isn't brilliant. Good enough for the occasional DJ gig perhaps but I'd want something better for critical listening. I used to have access to an old M-Audio Mobile Pre which had a much better headphone output than the built-in one.
I've tried the headphone outputs on one or two newer laptops and they were even worse than the Acer.
James.
http://www.jrpmusic.co.uk
Postby Exalted Wombat » Tue May 10, 2011 2:07 pm
Well.. your laptop headphone output is "fit for purpose", but may not be very loud with some headphones. Ditto a USB-powered external device. Volume takes power. A bus-powered device has a certain amount available. This doesn't make it "unfit".
Exalted Wombat
Postby Martin Walker » Wed May 11, 2011 3:44 pm
Looking forward to your findings at the end of this month Mowens800 8-)
Postby Mowens800 » Fri Jun 03, 2011 6:59 pm
Currently listening to music straight from headphone out via HD650s. No major problems on commercial music. Loudness is sufficient. As the music I will be auditioning won't be at the same average level as commercial stuff, I am tempted to purchase the device as recommended above to assist further and give me that extra clean output and volume. I will listen further.
But again, using VLC player it does seem relatively clean at suitable volume. Not sure how much noticeable improvement the ESI would offer especially considering this is only really for a week or two then I'm off the laptop.
Mowens800
