Does anyone know how to install Quicktime Alternative in FF
Postby OneWorld » Wed Oct 12, 2011 1:09 pm
I am using Firefox 7.0.1 and go to some webpages where it says there is a missing plugin, to play .mov files, so I need Quicktime, but I don't want he bloat that Apple foists on me so I chose Quicktime Alternative, which I know works as I have used it before.
I read some instructions on the internet and it said during the installation of Quicktime Alternative, point the installation to the plugins folder of Firefox, but that option doesn't appear when I am installing QTA, it goes straight into c:\program files\QTA, there is no option to browse to another folder.
So I tried Firefox again and this time clicked on the "Install Missing Plugins" and the next screen says "Apple Quicktime" but then says it isn't found, which of course FF won't find it. There is a button in FF which then says "Manual Install" but clicking that takes me to the Apple website and not the install of QTA I have just done.
I know QTA can work in FF as I managed to install it in the past, but can't remember how
OneWorld
Re: Does anyone know how to install Quicktime Alternative in FF
Postby Pete Kaine » Wed Oct 12, 2011 1:35 pm
I've not installed it in a while, but best guess is when you install it and it asks you what sort of install you wish to carry out "Basic/Normal/Custom" (just a guess at the possible options) and you'd want to click on "Custom" and see where it takes you. I imagine if the option is there to custom install then at some point in a custom install it would ask you what optional extras you may wish to install and somewhere in that lot would be the extensions for the browsers.
Pete Kaine
ScanProAudio - Studio Kit
Scan 3XS Audio Workstations
Postby OneWorld » Wed Oct 12, 2011 2:20 pm
No it gives none of those options. It does give some options, eg whether to install optional components - Media Player Classic et al, but nothing relating to file paths
OneWorld
Postby Pete Kaine » Thu Oct 13, 2011 12:33 pm
OneWorld wrote:No it gives none of those options. It does give some options, eg whether to install optional components - Media Player Classic et al, but nothing relating to file paths
Has a full version of quicktime been installed on this machine install before? It's possible that it's still pointing at the wrong codec or hasn't been fully uninstalled and is causing the hassle.
Firefox itself should also log an internal pointer (viewable via Tools>options>applications) which itself will tell the browser how to decode and view media formats inside of the browser should the support be there. You might be able to repoint firefox by hitting the help button on the applications page and following the instructions on what to do.
It could also be a Firefox 7 bug. They seem to be releasing version upgrades currently faster than most plug in makers can do revision fixes so whilst I know you've already looked around for version fixes it might be worth asking the QTA team if they can validate on the latest FF release just in case the's a problem.
Pete Kaine
Postby OneWorld » Thu Oct 13, 2011 2:41 pm
No, I have studiously avoided Quicktime having it blight my very existence when I first installed it eons ago and the very mention of it brings me out in a rash. Then I came across QTA and what a little gem of a plugin, took seconds to install and worked first time out of the box so to speak.
I moved from FF to Opera when FF took a stroll down Bloatware Boulevard, but Opera didn't work with eBay, tried Chrome, found it slow, but overtime FF kept popping up and I tried it again and was pleased that they seemed to take on the comments that was was becoming bloated and slow, and it was working fine. It has gone through several updates and now Quicktime (MOV) files won't play - why don't developers just leave things alone or at least give you the opportunity to wind things back to when things just worked.
I know things have to develop, but I see no appreciable difference between FF 2 and the one I am using now (FF 7.01), there's a few bits and bobs that have changed, but what's the use when it is only partly functional, if that's progress then they can keep it!
I tried your suggestion (thanks) of looking at tools/applications but there is no mention of quicktime or mov.
Surely if a dunderhead like myself can come up with the simple suggestion that, in the browser menu offer an option - add a plugin, and browse to where the plugin lives? Surely that's not going boil anyone's brain to add that functionality?
OneWorld
Postby Pete Kaine » Thu Oct 13, 2011 3:53 pm
OneWorld wrote:It has gone through several updates and now Quicktime (MOV) files won't play - why don't developers just leave things alone or at least give you the opportunity to wind things back to when things just worked.
The bloat continued to rev. 4 where they re-worked a lot of the engine and it got quite nice to use again, and that trend continued to rev 5.... after which they started released 6 & 7 a few months apart and seem to have undone a lot of the previous good work. :headbang:
Trust me, your not the only one getting annoyed with the almost weekly updates at this point!
Yeah, it was a stab in the dark that one. I looked at the populated list when I last posted and realised it would only list those applications which were/had been installed and thought perhaps if a previous revision had made it on there.... but then if QT hasn't been allowed near there, that isn't likely to help.
Your right, but then Mozzilla prefer you to install directly from the web using some sort of cab installer system which leaves 3rd party installation routines a bit out on a limb.
I'm thinking (and this is the long way round the mountain) that if you installed VLC media player with the firefox extension and then installed QTA onto the system then VLC should run QTA fine and you can then use the VLC extension to run your QTA in the browser... which of course if you don't like/use VLC would mean that you've just bloated your machine worse than installed QT itself.
Meh.
Pete Kaine
