Hang on silences!
Hang on silences!
Postby Hexo » Thu Mar 22, 2012 9:03 am
Hello every body.
I'm using Ableton Suite 8 on my hp probook 4530s, corei5 sandy bridge,4gigs of ram and win7 sp1.
Ableton runs really good but my cpu meter rises up to 500~800% at clip ends, reverb tails, sudden silences, soloing a track and so on. It's really strange to me that the system can handle lots of tracks and plugins as well but it dies when the load is off.
Can you justify this?
Any solutions?
Thanks.
Hexo
There are a million keys to perfection and they are buried in different graves.
Re: Hang on silences!
Postby Dynamic Mike » Fri Mar 23, 2012 12:35 am
I don't know whether this applies to you but I had similar problems in Cubase a while back when using some of the Antress Modern plug-ins. I felt as though the less signal they had to work with the more they struggled & CPU usage rocketed even after I'd stopped playback. I had limited success with gating the signals when soloed but eventually admitted defeat. Funny cos I could use multiple instances of iZotope Ozone & Nebula (notorious CPU hogs) without a glitch.
Dynamic Mike
Internet Bullying? Kids: Log out & tell a grown-up. Grown-Ups: Log out & go figure.
Postby James Perrett » Fri Mar 23, 2012 10:13 am
Sounds a bit like the de-normalising bug that was a problem a few years ago.
http://phonophunk.com/articles/pentium4-denormalization.php?pg=3
has a few links to articles about it. I think there may also be some threads about it in the forum - hopfully Martin might know how to find them.
James.
http://www.jrpmusic.co.uk
Postby Martin Walker » Fri Mar 23, 2012 4:27 pm
James Perrett wrote:Sounds a bit like the de-normalising bug that was a problem a few years ago.
James.
Actually I discussed this problem way back in my October 2002 PC Notes column:
www.soundonsound.com/sos/oct02/articles/pcnotes1002.asp
If you want to test out elderly plug-ins for this problem there are several plug-ins that can add a tiny (inaudible) amount of background noise ahead of an offending plug-in design to make sure the denormal problem never arises.
A good example that’s still available is TObybear’s P-Bugger, downloadable in his donationware UtilBag collection here:
www.tobybear.de/p_utilbag.html
Postby Hexo » Sun Mar 25, 2012 6:19 pm
Thank you martin and friends. I'm reading them. :)
Hexo
Postby Hexo » Sun Mar 25, 2012 7:22 pm
Problem solved
Problem solved
Problem solved.
That very useful article linked above helped me and let me tell you that Lexicon Native plugins were the cause.
Thank you.
Hexo
